Mon Jan 20 03:30:21 HKT 2025
Derek,
Am 03.05.24 um 12:53 schrieb Derek Caudwell via OvmsDev:
> When running *firmware **3.3.004-74-gbd4e7196* on my Nissan Leaf I
> suspect (but can't be 100% sure as it's only been 24h without fault)
> the new poller caused the car to throw the attached faults from
> overloading the can bus whilst driving. The fault was sufficient to
> send the car into limp mode and could not be driven until cleared with
> LeafSpy.
Build 3.3.004-74 (released 2024-04-30) did not yet include the poller
tracing control, i.e. it did lots of logging for frames, significantly
affecting overall performance.
Poller tracing control was introduced in
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/7e4046042a99339d0212aac8f874cc8f780e634e
on May 12.
That commit was first included in build 3.3.004-103-g11fddbf6 released
2024-05-25. Do you remember testing that build or a later one?
But as I still don't understand how a software queue overflow could
cause a bus crash, I've also checked the 500 kbit timing for the MCP2515
and found that may have the same issue as the 125 kbit timing:
Our timing is:
case CAN_SPEED_500KBPS:
cnf1=0x00; cnf2=0xf0; cnf3=0x86;
= PROP=1, PS1=7, PS2=7, SJW=1, Sample 3x @56.3%
Remember, the SAE/CiA recommendation is SJW=2, Sample 1x @87.5%. That
would translate to:
PROP=5, PS1=8, PS2=2, SJW=2, Sample 1x @87.5% =
cnf1=0x40; cnf2=0xbc; cnf3=0x81;
I also checked the Arduino MCP_CAN lib, and that uses:
cnf1=0x40; cnf2=0xe5; cnf3=0x83;
= PROP=6, PS1=5, PS2=4, SJW=2, Sample 3x @75%
So our timing for 500 kbit/s on the MCP buses also isn't as recommended.
Derek, could you test the SAE/CiA recommendation and the MCP_CAN config
as shown? Or anyone else with a live can2/can3 bus at 500 kbit?
If these work, the question is which is the more general setup we should
adopt. Apparently the MCP_CAN lib also does not follow the CiA
recommendation, I wonder if the MCP_CAN config is a compromise for
compatibility.
Am 19.01.25 um 19:07 schrieb Derek Caudwell via OvmsDev:
> Hi Michael
> I just used the firmware stock with no changes to the poller settings.
> The Leaf is using high speeds on both buses:
> RegisterCanBus(1,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS);
> RegisterCanBus(2,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS);
> On Sun, 19 Jan 2025, 10:15 pm Michael Balzer via OvmsDev,
> <ovmsdev at lists.openvehicles.com> wrote:
> Michael,
> I suggest adding a standard bool member variable to reflect if any
> filter is defined, so `PollerRxCallback()` can just skip the
> filter test while that is false. A mutex has some overhead, even
> if used non-blocking, and a bool variable only read there will be
> sufficient to signal "apply filtering" to the callback. With the
> simple bool test, all vehicles that don't need filtering (i.e.
> most vehicles) will have a neglectible impact from this.
> Regarding the overhead: the GCC atomic implementation should use
> the xtensa CPU builtin atomic support (SCOMPARE1 register & S32C1I
> instruction), so should be pretty fast and not use any interrupt
> disabling, see:
> * https://gcc.gnu.org/wiki/Atomic (xtensa atomic support since
> gcc 4.4.0)
> * https://www.cadence.com/content/dam/cadence-www/global/en_US/documents/tools/silicon-solutions/compute-ip/isa-summary.pdf
> (section 4.3.13)
> So I still doubt the queue overflow is the real culprit.
> But having the filter option doesn't hurt (with my suggestion
> above), and your changes to the queue processing look promising as
> well.
> @Derek: what was your poller tracing & timing setup when you had
> the bus issue on the Leaf? I still think that was something
> related to your car or setup. There are currently 11 Leafs on my
> server running "edge" releases including the new poller, all
> without (reported) issues.
> Am 19.01.25 um 04:26 schrieb Michael Geddes:
>> P/R Created
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/1100
>> Let me know if you want me to split it up or ANY changes and I'll
>> get onto it asap.
>> Maybe somebody could grab the code and check it out in the
>> context of specifying some filters. This will prevent those
>> messages from coming to the vehicle implementation at all.. and
>> even from going through the poller queue. It is non-blocking
>> meaning that the filter is briefly inopperational while the
>> filter is being modified.
>> On Sun, 19 Jan 2025 at 11:02, Michael Geddes
>> <frog at bunyip.wheelycreek.net> wrote:
>> On Sat, 18 Jan 2025 at 17:08, Michael Balzer via OvmsDev
>>> I have commented out the line with the Atomic_Increment
>>> statement. Now I no longer receive any messages with “RX
>>> Task Queue Overflow Run”
>>> Here is the output of poller times status:
>> The main question is if you still get the CAN bus crash
>> (vehicle running into issues) with that modification in
>> active mode. Timing statistics were not expected to change.
>> I have a feeling that the atomic operations are along the
>> lines of:
>> * Set Interrupts off
>> * atomic operation
>> * Set interrupts on
>> Which means no real 'blocking' .. just not allowing
>> interrupts and therefor task switching for a couple of
>> instructions.
>> Nearly 2800 frames per second is quite a lot, and most is
>> on can1 with many frame periods at 20 ms. Yet the total
>> processing time averages at 30-40 ms, so there is no
>> actual CPU capacity issue for that amount of frames.
>> @Derek: can you please supply these statistics for the
>> Leaf in drive mode as well?
>> Am 18.01.25 um 02:42 schrieb Michael Geddes via OvmsDev:
>>> Maybe try setting CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE
>>> = 160 and see if that reduces the overflow?
>> Simons car sends at least 91 process data frame IDs on
>> can1 and 84 on can2. Worst case would be these come all
>> in within the shortest possible time span, that would
>> mean the queue needs to be able to hold 175 frames. I'd
>> add some headroom and round up to 200.
>> But keep in mind, if the Incoming processing actually
>> occasionally gets blocked for up to 60 ms -- as indicated
>> by Simons statistics --, the queue may need to be twice
>> as large.
>>> I was thinking that the frame filter would be here:
>>> void OvmsPollers::PollerRxCallback(const CAN_frame_t*
>>> frame, bool success)
>>> Queue_PollerFrame(*frame, success, false);
>>> which I guess is executed in the task handling the CAN
>>> queue. (we don't know how many frames get dropped there).
>> Actually we do know that, or at least have some
>> indication, as we count the CAN transceiver queue
>> overruns. That info is included as "Rx overflw" in the
>> can status output & as "rxovr" in the logs.
>> Adding a filter before queueing the frame would exclude
>> the filtered IDs from all vehicle processing. I meant
>> adding a filter just to exclude IDs from the timing
>> statistics, assuming those are the culprits, as Simon
>> wrote the issue only appears after enabling the timing
>> statistics and printing them. That's why I asked if
>> printing might need to lock the statistics for too long
>> in case of such a long list.
>> Completely blocking ID ranges from processing by the
>> vehicle should normally not be necessary, unless the
>> Incoming handler is written very poorly.
>> Yet, if we add that, a mutex in the CAN RX callback must
>> be avoided, or would need to be non-blocking:
>>> The only real concern is thread safety between checking
>>> and adding to the filter - so the check itself might
>>> have to be mutexed.
>>> // Check filter
>>> OvmsRecMutexLock lock(&m_filter_mutex);
>>> if (! m_filter->IsFiltered(frame))
>>> return;
>> A mutex like that could block the CAN task, which must be
>> avoided at all cost. I introduced CAN callbacks for
>> vehicles & applications that need to react to certain
>> frames as fast as possible, e.g. to maintain control
>> precedence, so cannot use the standard CAN listener
>> mechanism (frame queueing).
>> The current poller callback use is OK, if (!) the atomic
>> type really isn't the culprit, ie doesn't block.
>> So if (!) an ID filter needs to be added before queueing,
>> it needs to be done in a way that needs no mutex. But I
>> don't see an issue with the vehicle passing a fixed
>> filter when registering with the poller/buses. The filter
>> doesn't need to by mutable on the fly.
>> Am 17.01.25 um 19:42 schrieb Simon Ehlen via OvmsDev:
>>>> The poller statistics can help you track this down, but
>>>> you need to have at least 10 seconds of statistics, the
>>>> more the better. Rule of thumb: PRI average at
>>>> 0.0/second means you don't have enough data yet.
>>> There were again many messages with “RX Task Queue
>>> Overflow Run”.
>>> Here are the statistics of poller times status:
>>> OVMS# poll times status
>>> Poller timing is: on
>>> Type | count | Utlztn | Time
>>> | per s | [%] | [ms]
>>> Poll:PRI Avg| 1.00| 0.0043| 0.004
>>> Peak| | 0.0043| 0.052
>>> RxCan1[010] Avg| 34.26| 1.6741| 0.015
>>> Peak| | 1.6741| 1.182
>>> RxCan1[030] Avg| 34.06| 1.7085| 0.020
>>> Peak| | 1.7085| 1.390
>>> RxCan1[041] Avg| 49.89| 0.8109| 0.016
>>> Peak| | 0.8541| 1.098
>>> RxCan1[049] Avg| 50.00| 1.5970| 0.019
>>> Peak| | 1.7154| 32.233
>>> RxCan1[04c] Avg| 49.92| 0.8340| 0.014
>>> Peak| | 0.8933| 1.995
>>> RxCan1[04d] Avg| 34.43| 1.6211| 0.014
>>> Peak| | 1.6756| 1.318
>>> RxCan1[076] Avg| 50.00| 0.8362| 0.024
>>> Peak| | 0.8784| 2.185
>>> RxCan1[077] Avg| 50.00| 0.7837| 0.014
>>> Peak| | 0.8083| 1.156
>>> RxCan1[07a] Avg| 34.31| 2.1870| 0.017
>>> Peak| | 2.3252| 1.888
>>> RxCan1[07d] Avg| 50.00| 0.8001| 0.013
>>> Peak| | 0.8434| 1.150
>>> RxCan1[0c8] Avg| 49.96| 0.8359| 0.013
>>> Peak| | 0.8715| 1.171
>>> RxCan1[11a] Avg| 34.35| 1.6701| 0.020
>>> Peak| | 1.6981| 1.273
>>> RxCan1[130] Avg| 50.00| 0.7902| 0.018
>>> Peak| | 0.8513| 0.980
>>> RxCan1[139] Avg| 49.92| 0.7872| 0.013
>>> Peak| | 0.8219| 0.795
>>> RxCan1[156] Avg| 10.00| 0.1620| 0.014
>>> Peak| | 0.1729| 0.919
>>> RxCan1[160] Avg| 50.04| 0.7977| 0.014
>>> Peak| | 0.8232| 1.495
>>> RxCan1[165] Avg| 49.85| 0.7976| 0.014
>>> Peak| | 0.8486| 1.015
>>> RxCan1[167] Avg| 34.39| 1.6025| 0.016
>>> Peak| | 1.6888| 1.354
>>> RxCan1[171] Avg| 50.00| 0.8150| 0.017
>>> Peak| | 0.8488| 1.091
>>> RxCan1[178] Avg| 10.00| 0.1614| 0.014
>>> Peak| | 0.1702| 0.903
>>> RxCan1[179] Avg| 10.00| 0.1630| 0.017
>>> Peak| | 0.1663| 1.336
>>> RxCan1[180] Avg| 50.00| 0.8137| 0.014
>>> Peak| | 0.8605| 1.566
>>> RxCan1[185] Avg| 50.04| 0.8033| 0.013
>>> Peak| | 0.8393| 1.126
>>> RxCan1[1a0] Avg| 49.92| 0.7748| 0.013
>>> Peak| | 0.8169| 1.184
>>> RxCan1[1e0] Avg| 49.92| 0.7738| 0.014
>>> Peak| | 0.8028| 1.049
>>> RxCan1[1e4] Avg| 49.89| 0.9692| 0.018
>>> Peak| | 1.0096| 1.332
>>> RxCan1[1f0] Avg| 33.22| 0.5544| 0.014
>>> Peak| | 0.5855| 0.848
>>> RxCan1[200] Avg| 49.92| 0.7879| 0.015
>>> Peak| | 0.8345| 1.206
>>> RxCan1[202] Avg| 34.28| 1.7075| 0.016
>>> Peak| | 1.7874| 1.218
>>> RxCan1[204] Avg| 34.35| 1.5641| 0.013
>>> Peak| | 1.6427| 1.235
>>> RxCan1[213] Avg| 49.89| 0.7814| 0.015
>>> Peak| | 0.8232| 0.910
>>> RxCan1[214] Avg| 49.92| 0.7736| 0.014
>>> Peak| | 0.8216| 0.800
>>> RxCan1[217] Avg| 34.31| 1.6294| 0.014
>>> Peak| | 1.7165| 1.153
>>> RxCan1[218] Avg| 49.86| 0.7877| 0.013
>>> Peak| | 0.8290| 1.068
>>> RxCan1[230] Avg| 50.00| 0.7596| 0.014
>>> Peak| | 0.7660| 1.021
>>> RxCan1[240] Avg| 10.00| 0.1669| 0.013
>>> Peak| | 0.1835| 0.887
>>> RxCan1[242] Avg| 24.96| 0.4764| 0.020
>>> Peak| | 0.4963| 1.501
>>> RxCan1[24a] Avg| 9.89| 0.1789| 0.015
>>> Peak| | 0.2009| 0.874
>>> RxCan1[24b] Avg| 9.89| 0.1702| 0.014
>>> Peak| | 0.1870| 1.195
>>> RxCan1[24c] Avg| 9.89| 0.2146| 0.019
>>> Peak| | 0.2187| 1.242
>>> RxCan1[25a] Avg| 10.00| 0.1603| 0.013
>>> Peak| | 0.1667| 0.720
>>> RxCan1[25b] Avg| 49.94| 0.7918| 0.017
>>> Peak| | 0.8454| 1.666
>>> RxCan1[25c] Avg| 34.24| 1.5331| 0.013
>>> Peak| | 1.5997| 1.538
>>> RxCan1[260] Avg| 10.00| 0.1626| 0.014
>>> Peak| | 0.1682| 0.718
>>> RxCan1[270] Avg| 49.90| 0.8120| 0.014
>>> Peak| | 0.8460| 1.671
>>> RxCan1[280] Avg| 49.92| 0.7777| 0.019
>>> Peak| | 0.8447| 1.157
>>> RxCan1[2e4] Avg| 19.89| 0.5778| 0.032
>>> Peak| | 0.6648| 2.226
>>> RxCan1[2ec] Avg| 10.00| 0.1701| 0.014
>>> Peak| | 0.1755| 0.928
>>> RxCan1[2ed] Avg| 10.00| 0.1650| 0.013
>>> Peak| | 0.1747| 0.917
>>> RxCan1[2ee] Avg| 9.98| 0.1544| 0.013
>>> Peak| | 0.1588| 1.312
>>> RxCan1[312] Avg| 10.00| 0.1648| 0.017
>>> Peak| | 0.1690| 0.922
>>> RxCan1[326] Avg| 9.89| 0.1603| 0.015
>>> Peak| | 0.1833| 1.230
>>> RxCan1[336] Avg| 1.00| 0.0146| 0.015
>>> Peak| | 0.0150| 0.349
>>> RxCan1[352] Avg| 6.66| 0.1223| 0.022
>>> Peak| | 0.1338| 1.015
>>> RxCan1[355] Avg| 2.00| 0.0424| 0.019
>>> Peak| | 0.0431| 0.786
>>> RxCan1[35e] Avg| 9.96| 0.1570| 0.013
>>> Peak| | 0.1644| 0.579
>>> RxCan1[365] Avg| 10.00| 0.1600| 0.014
>>> Peak| | 0.1653| 0.961
>>> RxCan1[366] Avg| 10.00| 0.1716| 0.013
>>> Peak| | 0.1890| 0.987
>>> RxCan1[367] Avg| 9.93| 0.1793| 0.015
>>> Peak| | 0.1864| 0.984
>>> RxCan1[368] Avg| 10.00| 0.1645| 0.014
>>> Peak| | 0.1778| 0.768
>>> RxCan1[369] Avg| 10.00| 0.1562| 0.016
>>> Peak| | 0.1606| 0.724
>>> RxCan1[380] Avg| 10.00| 0.1619| 0.014
>>> Peak| | 0.1644| 0.605
>>> RxCan1[38b] Avg| 25.00| 0.3991| 0.016
>>> Peak| | 0.4280| 1.448
>>> RxCan1[3b3] Avg| 10.00| 0.1537| 0.013
>>> Peak| | 0.1610| 0.380
>>> RxCan1[400] Avg| 4.00| 0.0626| 0.014
>>> Peak| | 0.0626| 0.251
>>> RxCan1[405] Avg| 3.90| 0.1019| 0.028
>>> Peak| | 0.1019| 0.781
>>> RxCan1[40a] Avg| 7.90| 0.1256| 0.020
>>> Peak| | 0.1256| 0.991
>>> RxCan1[410] Avg| 10.00| 0.1643| 0.016
>>> Peak| | 0.1839| 1.634
>>> RxCan1[411] Avg| 10.00| 0.1532| 0.013
>>> Peak| | 0.1645| 0.824
>>> RxCan1[416] Avg| 10.00| 0.1516| 0.016
>>> Peak| | 0.1582| 0.807
>>> RxCan1[421] Avg| 10.00| 0.1648| 0.013
>>> Peak| | 0.1740| 0.839
>>> RxCan1[42d] Avg| 10.00| 0.1548| 0.014
>>> Peak| | 0.1658| 0.741
>>> RxCan1[42f] Avg| 10.00| 0.1527| 0.013
>>> Peak| | 0.1578| 0.667
>>> RxCan1[430] Avg| 10.00| 0.1730| 0.016
>>> Peak| | 0.1880| 1.209
>>> RxCan1[434] Avg| 10.00| 0.1620| 0.021
>>> Peak| | 0.1712| 1.140
>>> RxCan1[435] Avg| 6.66| 0.1104| 0.014
>>> Peak| | 0.1121| 1.011
>>> RxCan1[43e] Avg| 20.00| 0.3194| 0.013
>>> Peak| | 0.3434| 1.212
>>> RxCan1[440] Avg| 1.00| 0.0160| 0.014
>>> Peak| | 0.0175| 0.315
>>> RxCan1[465] Avg| 1.00| 0.0172| 0.015
>>> Peak| | 0.0194| 0.404
>>> RxCan1[466] Avg| 1.00| 0.0198| 0.015
>>> Peak| | 0.0252| 0.890
>>> RxCan1[467] Avg| 1.00| 0.0152| 0.014
>>> Peak| | 0.0160| 0.217
>>> RxCan1[472] Avg| 0.70| 0.0533| 0.075
>>> Peak| | 0.0546| 0.990
>>> RxCan1[473] Avg| 0.65| 0.0325| 0.051
>>> Peak| | 0.0361| 0.774
>>> RxCan1[474] Avg| 1.00| 0.0146| 0.014
>>> Peak| | 0.0151| 0.189
>>> RxCan1[475] Avg| 2.00| 0.0332| 0.015
>>> Peak| | 0.0362| 0.513
>>> RxCan1[476] Avg| 2.00| 0.0305| 0.014
>>> Peak| | 0.0307| 0.249
>>> RxCan1[477] Avg| 2.00| 0.0309| 0.014
>>> Peak| | 0.0311| 0.438
>>> RxCan1[595] Avg| 1.00| 0.0151| 0.014
>>> Peak| | 0.0160| 0.230
>>> RxCan1[59e] Avg| 1.00| 0.0179| 0.015
>>> Peak| | 0.0209| 0.716
>>> RxCan1[5a2] Avg| 1.00| 0.0154| 0.016
>>> Peak| | 0.0184| 0.699
>>> RxCan1[5ba] Avg| 1.00| 0.0159| 0.017
>>> Peak| | 0.0174| 0.485
>>> RxCan2[010] Avg| 0.00| 0.0000| 0.015
>>> Peak| | 0.0000| 0.146
>>> RxCan2[020] Avg| 31.10| 0.5159| 0.015
>>> Peak| | 0.5730| 0.992
>>> RxCan2[030] Avg| 20.70| 0.3506| 0.016
>>> Peak| | 0.3956| 1.055
>>> RxCan2[03a] Avg| 18.65| 0.3157| 0.014
>>> Peak| | 0.3292| 0.702
>>> RxCan2[040] Avg| 18.60| 0.3111| 0.015
>>> Peak| | 0.3474| 0.953
>>> RxCan2[060] Avg| 18.60| 0.3182| 0.014
>>> Peak| | 0.3569| 0.694
>>> RxCan2[070] Avg| 15.55| 0.4581| 0.017
>>> Peak| | 0.6859| 39.212
>>> RxCan2[080] Avg| 15.50| 0.5041| 0.029
>>> Peak| | 0.5414| 1.555
>>> RxCan2[083] Avg| 18.70| 0.3083| 0.014
>>> Peak| | 0.3325| 0.557
>>> RxCan2[090] Avg| 23.40| 0.3961| 0.014
>>> Peak| | 0.4445| 1.218
>>> RxCan2[0a0] Avg| 15.55| 0.2734| 0.014
>>> Peak| | 0.3144| 1.062
>>> RxCan2[100] Avg| 15.50| 0.2645| 0.016
>>> Peak| | 0.2875| 1.021
>>> RxCan2[108] Avg| 23.40| 0.4231| 0.016
>>> Peak| | 0.4680| 1.297
>>> RxCan2[110] Avg| 15.55| 0.2467| 0.014
>>> Peak| | 0.2684| 0.475
>>> RxCan2[130] Avg| 13.30| 0.2231| 0.014
>>> Peak| | 0.2447| 0.512
>>> RxCan2[150] Avg| 15.50| 0.2533| 0.015
>>> Peak| | 0.2836| 0.823
>>> RxCan2[160] Avg| 4.70| 0.0784| 0.014
>>> Peak| | 0.0863| 0.608
>>> RxCan2[180] Avg| 15.55| 0.2713| 0.015
>>> Peak| | 0.2841| 0.884
>>> RxCan2[190] Avg| 15.50| 0.2596| 0.014
>>> Peak| | 0.2825| 0.743
>>> RxCan2[1a0] Avg| 0.95| 0.0164| 0.015
>>> Peak| | 0.0164| 0.346
>>> RxCan2[1a4] Avg| 18.65| 0.3232| 0.015
>>> Peak| | 0.3515| 0.989
>>> RxCan2[1a8] Avg| 11.60| 0.1911| 0.016
>>> Peak| | 0.2012| 0.757
>>> RxCan2[1b0] Avg| 9.35| 0.1558| 0.016
>>> Peak| | 0.1641| 0.795
>>> RxCan2[1b4] Avg| 9.35| 0.1543| 0.015
>>> Peak| | 0.1617| 1.217
>>> RxCan2[1b8] Avg| 11.65| 0.2003| 0.014
>>> Peak| | 0.2236| 1.549
>>> RxCan2[1c0] Avg| 9.40| 0.1532| 0.016
>>> Peak| | 0.1673| 0.955
>>> RxCan2[1e0] Avg| 9.30| 0.1582| 0.015
>>> Peak| | 0.1708| 0.661
>>> RxCan2[215] Avg| 7.80| 0.1409| 0.016
>>> Peak| | 0.1531| 0.660
>>> RxCan2[217] Avg| 7.80| 0.1239| 0.014
>>> Peak| | 0.1333| 0.520
>>> RxCan2[220] Avg| 6.20| 0.1041| 0.015
>>> Peak| | 0.1094| 0.652
>>> RxCan2[225] Avg| 23.40| 0.4648| 0.015
>>> Peak| | 0.4696| 4.288
>>> RxCan2[230] Avg| 6.20| 0.3120| 0.048
>>> Peak| | 0.3377| 1.065
>>> RxCan2[240] Avg| 7.70| 0.1248| 0.014
>>> Peak| | 0.1364| 0.635
>>> RxCan2[241] Avg| 18.60| 0.3258| 0.014
>>> Peak| | 0.3343| 1.288
>>> RxCan2[250] Avg| 4.70| 0.0761| 0.014
>>> Peak| | 0.0809| 0.322
>>> RxCan2[255] Avg| 11.75| 0.2058| 0.014
>>> Peak| | 0.2283| 0.937
>>> RxCan2[265] Avg| 11.65| 0.1964| 0.014
>>> Peak| | 0.2068| 0.965
>>> RxCan2[270] Avg| 4.70| 0.0808| 0.016
>>> Peak| | 0.0949| 0.729
>>> RxCan2[290] Avg| 3.15| 0.0498| 0.015
>>> Peak| | 0.0504| 0.449
>>> RxCan2[295] Avg| 6.25| 0.1019| 0.014
>>> Peak| | 0.1094| 0.859
>>> RxCan2[2a0] Avg| 3.15| 0.0550| 0.014
>>> Peak| | 0.0551| 0.779
>>> RxCan2[2a7] Avg| 11.65| 0.1929| 0.014
>>> Peak| | 0.2080| 0.775
>>> RxCan2[2b0] Avg| 3.00| 0.0497| 0.015
>>> Peak| | 0.0562| 0.528
>>> RxCan2[2c0] Avg| 3.10| 0.0534| 0.016
>>> Peak| | 0.0592| 0.501
>>> RxCan2[2e0] Avg| 1.55| 0.0247| 0.014
>>> Peak| | 0.0289| 0.319
>>> RxCan2[2f0] Avg| 1.55| 0.0244| 0.014
>>> Peak| | 0.0273| 0.192
>>> RxCan2[2f5] Avg| 11.65| 0.2078| 0.016
>>> Peak| | 0.2333| 0.879
>>> RxCan2[300] Avg| 1.60| 0.0266| 0.018
>>> Peak| | 0.0278| 0.724
>>> RxCan2[310] Avg| 1.55| 0.0276| 0.016
>>> Peak| | 0.0285| 0.759
>>> RxCan2[320] Avg| 1.60| 0.0240| 0.014
>>> Peak| | 0.0258| 0.179
>>> RxCan2[326] Avg| 9.30| 0.1550| 0.014
>>> Peak| | 0.1582| 0.850
>>> RxCan2[330] Avg| 29.95| 0.5311| 0.015
>>> Peak| | 0.5565| 4.522
>>> RxCan2[340] Avg| 7.75| 0.1693| 0.024
>>> Peak| | 0.1868| 1.148
>>> RxCan2[345] Avg| 1.60| 0.0292| 0.016
>>> Peak| | 0.0316| 0.471
>>> RxCan2[350] Avg| 0.00| 0.0000| 0.019
>>> Peak| | 0.0000| 0.188
>>> RxCan2[35e] Avg| 4.70| 0.0851| 0.019
>>> Peak| | 0.0911| 1.023
>>> RxCan2[360] Avg| 1.60| 0.0258| 0.015
>>> Peak| | 0.0284| 0.306
>>> RxCan2[361] Avg| 7.75| 0.1341| 0.017
>>> Peak| | 0.1487| 0.761
>>> RxCan2[363] Avg| 1.20| 0.0203| 0.016
>>> Peak| | 0.0220| 0.421
>>> RxCan2[370] Avg| 0.85| 0.0140| 0.016
>>> Peak| | 0.0162| 0.354
>>> RxCan2[381] Avg| 3.15| 0.0512| 0.016
>>> Peak| | 0.0546| 0.416
>>> RxCan2[3a0] Avg| 15.60| 0.2548| 0.015
>>> Peak| | 0.2890| 0.976
>>> RxCan2[3d0] Avg| 9.35| 0.1553| 0.019
>>> Peak| | 0.1612| 1.115
>>> RxCan2[3d5] Avg| 5.15| 0.0836| 0.016
>>> Peak| | 0.0867| 0.479
>>> RxCan2[3e0] Avg| 0.00| 0.0000| 0.014
>>> Peak| | 0.0000| 0.142
>>> RxCan2[400] Avg| 3.55| 0.0613| 0.017
>>> Peak| | 0.0695| 0.501
>>> RxCan2[405] Avg| 3.50| 0.0584| 0.018
>>> Peak| | 0.0626| 0.686
>>> RxCan2[40a] Avg| 7.10| 0.1278| 0.017
>>> Peak| | 0.1389| 1.244
>>> RxCan2[415] Avg| 1.60| 0.0258| 0.014
>>> Peak| | 0.0287| 0.266
>>> RxCan2[435] Avg| 0.85| 0.0165| 0.019
>>> Peak| | 0.0167| 0.367
>>> RxCan2[440] Avg| 0.85| 0.0128| 0.019
>>> Peak| | 0.0141| 0.885
>>> RxCan2[465] Avg| 0.95| 0.0177| 0.016
>>> Peak| | 0.0195| 0.721
>>> RxCan2[466] Avg| 0.95| 0.0147| 0.014
>>> Peak| | 0.0160| 0.184
>>> RxCan2[467] Avg| 0.95| 0.0172| 0.017
>>> Peak| | 0.0188| 0.391
>>> RxCan2[501] Avg| 1.45| 0.0273| 0.016
>>> Peak| | 0.0327| 0.996
>>> RxCan2[503] Avg| 1.45| 0.0288| 0.020
>>> Peak| | 0.0338| 0.970
>>> RxCan2[504] Avg| 1.40| 0.0241| 0.015
>>> Peak| | 0.0263| 0.609
>>> RxCan2[505] Avg| 1.40| 0.0255| 0.015
>>> Peak| | 0.0296| 0.866
>>> RxCan2[508] Avg| 1.35| 0.0237| 0.017
>>> Peak| | 0.0237| 0.384
>>> RxCan2[511] Avg| 1.35| 0.0226| 0.016
>>> Peak| | 0.0228| 0.426
>>> RxCan2[51e] Avg| 1.40| 0.0221| 0.014
>>> Peak| | 0.0245| 0.211
>>> RxCan2[581] Avg| 0.80| 0.0189| 0.019
>>> Peak| | 0.0290| 1.217
>>> RxCan2[606] Avg| 0.00| 0.0000| 0.014
>>> RxCan2[657] Avg| 0.00| 0.0000| 0.014
>>> Peak| | 0.0000| 0.137
>>> Cmd:State Avg| 0.00| 0.0000| 0.002
>>> Peak| | 0.0000| 0.024
>>> Total Avg| 2748.42| 58.3344| 28.718
>>>> @Simon: it would be an option to try commenting out the
>>>> overflow counting, to see if that's causing the issue.
>>> OVMS# poll time status
>>> | per s | [%] | [ms]
>>> Poll:PRI Avg| 1.00| 0.0045| 0.004
>>> Peak| | 0.0046| 0.064
>>> RxCan1[010] Avg| 34.26| 2.2574| 0.021
>>> Peak| | 2.2574| 4.609
>>> RxCan1[030] Avg| 34.26| 2.3820| 0.021
>>> Peak| | 2.3820| 1.135
>>> RxCan1[041] Avg| 49.89| 1.2059| 0.021
>>> Peak| | 1.2295| 5.331
>>> RxCan1[049] Avg| 49.96| 1.2400| 0.030
>>> Peak| | 1.2699| 1.402
>>> RxCan1[04c] Avg| 49.92| 1.1752| 0.021
>>> Peak| | 1.2072| 4.502
>>> RxCan1[04d] Avg| 34.31| 2.4433| 0.022
>>> Peak| | 2.4773| 1.368
>>> RxCan1[076] Avg| 49.96| 1.2071| 0.024
>>> Peak| | 1.2554| 2.007
>>> RxCan1[077] Avg| 49.96| 1.2012| 0.022
>>> Peak| | 1.2492| 1.955
>>> RxCan1[07a] Avg| 34.35| 2.9251| 0.030
>>> Peak| | 3.1103| 1.829
>>> RxCan1[07d] Avg| 49.96| 1.1954| 0.022
>>> Peak| | 1.2282| 1.074
>>> RxCan1[0c8] Avg| 49.89| 1.2491| 0.021
>>> Peak| | 1.3169| 1.181
>>> RxCan1[11a] Avg| 34.39| 2.4423| 0.024
>>> Peak| | 2.5693| 1.491
>>> RxCan1[130] Avg| 49.95| 1.1312| 0.020
>>> Peak| | 1.1684| 1.218
>>> RxCan1[139] Avg| 49.92| 1.1547| 0.021
>>> Peak| | 1.1778| 1.199
>>> RxCan1[156] Avg| 9.96| 0.2391| 0.023
>>> Peak| | 0.2591| 1.943
>>> RxCan1[160] Avg| 49.96| 1.1657| 0.031
>>> Peak| | 1.2017| 2.158
>>> RxCan1[165] Avg| 49.96| 1.1257| 0.021
>>> Peak| | 1.1652| 1.471
>>> RxCan1[167] Avg| 34.31| 2.2871| 0.021
>>> Peak| | 2.3374| 1.776
>>> RxCan1[171] Avg| 49.96| 1.1879| 0.023
>>> Peak| | 1.2268| 1.166
>>> RxCan1[178] Avg| 10.00| 0.2371| 0.029
>>> Peak| | 0.2459| 1.516
>>> RxCan1[179] Avg| 10.00| 0.2196| 0.021
>>> Peak| | 0.2260| 0.758
>>> RxCan1[180] Avg| 49.96| 1.1703| 0.022
>>> Peak| | 1.2103| 1.481
>>> RxCan1[185] Avg| 49.95| 1.1127| 0.020
>>> Peak| | 1.1636| 1.292
>>> RxCan1[1a0] Avg| 49.96| 1.1009| 0.020
>>> Peak| | 1.1468| 1.060
>>> RxCan1[1e0] Avg| 49.96| 1.1744| 0.021
>>> Peak| | 1.2027| 1.240
>>> RxCan1[1e4] Avg| 49.96| 1.3733| 0.032
>>> Peak| | 1.4085| 1.523
>>> RxCan1[1f0] Avg| 33.30| 0.7625| 0.023
>>> Peak| | 0.8004| 3.349
>>> RxCan1[200] Avg| 49.92| 1.1462| 0.021
>>> Peak| | 1.1809| 1.254
>>> RxCan1[202] Avg| 34.39| 2.4034| 0.028
>>> Peak| | 2.5611| 1.472
>>> RxCan1[204] Avg| 34.30| 2.2541| 0.022
>>> Peak| | 2.2924| 2.015
>>> RxCan1[213] Avg| 49.96| 1.1599| 0.027
>>> Peak| | 1.1794| 1.714
>>> RxCan1[214] Avg| 49.96| 1.1537| 0.022
>>> Peak| | 1.1941| 1.439
>>> RxCan1[217] Avg| 34.39| 2.2490| 0.020
>>> Peak| | 2.2856| 3.766
>>> RxCan1[218] Avg| 49.96| 1.1291| 0.021
>>> Peak| | 1.1646| 1.547
>>> RxCan1[230] Avg| 49.96| 1.1272| 0.020
>>> Peak| | 1.2237| 1.295
>>> RxCan1[240] Avg| 10.00| 0.2191| 0.021
>>> Peak| | 0.2226| 1.067
>>> RxCan1[242] Avg| 24.96| 0.6911| 0.024
>>> Peak| | 0.7161| 1.180
>>> RxCan1[24a] Avg| 9.96| 0.2345| 0.024
>>> Peak| | 0.2535| 0.779
>>> RxCan1[24b] Avg| 9.96| 0.2433| 0.023
>>> Peak| | 0.2697| 2.085
>>> RxCan1[24c] Avg| 9.96| 0.3103| 0.029
>>> Peak| | 0.3203| 0.809
>>> RxCan1[25a] Avg| 10.00| 0.2346| 0.022
>>> Peak| | 0.2405| 1.223
>>> RxCan1[25b] Avg| 49.89| 1.2121| 0.020
>>> Peak| | 1.3659| 19.523
>>> RxCan1[25c] Avg| 34.31| 2.4193| 0.019
>>> Peak| | 2.8022| 58.153
>>> RxCan1[260] Avg| 9.93| 0.2149| 0.024
>>> Peak| | 0.2174| 1.096
>>> RxCan1[270] Avg| 49.96| 1.2042| 0.026
>>> Peak| | 1.2755| 20.612
>>> RxCan1[280] Avg| 49.96| 1.0922| 0.020
>>> Peak| | 1.1312| 1.266
>>> RxCan1[2e4] Avg| 19.96| 0.6942| 0.044
>>> Peak| | 0.8604| 1.533
>>> RxCan1[2ec] Avg| 10.00| 0.3727| 0.025
>>> Peak| | 0.5154| 28.819
>>> RxCan1[2ed] Avg| 10.00| 0.2298| 0.023
>>> Peak| | 0.2378| 1.345
>>> RxCan1[2ee] Avg| 9.96| 0.2172| 0.019
>>> Peak| | 0.2210| 1.058
>>> RxCan1[312] Avg| 10.00| 0.2206| 0.020
>>> Peak| | 0.2396| 1.060
>>> RxCan1[326] Avg| 9.96| 0.2099| 0.020
>>> Peak| | 0.2158| 0.507
>>> RxCan1[336] Avg| 1.00| 0.0212| 0.020
>>> Peak| | 0.0233| 0.315
>>> RxCan1[352] Avg| 6.64| 0.1675| 0.024
>>> Peak| | 0.1818| 1.048
>>> RxCan1[355] Avg| 2.00| 0.0540| 0.027
>>> Peak| | 0.0619| 1.209
>>> RxCan1[35e] Avg| 9.98| 0.2221| 0.021
>>> Peak| | 0.2284| 1.186
>>> RxCan1[365] Avg| 10.00| 0.2282| 0.023
>>> Peak| | 0.2335| 0.769
>>> RxCan1[366] Avg| 10.00| 0.3163| 0.022
>>> Peak| | 0.6330| 23.587
>>> RxCan1[367] Avg| 10.00| 0.2417| 0.021
>>> Peak| | 0.2568| 1.417
>>> RxCan1[368] Avg| 9.96| 0.2187| 0.019
>>> Peak| | 0.2250| 1.135
>>> RxCan1[369] Avg| 9.99| 0.2277| 0.021
>>> Peak| | 0.2334| 0.667
>>> RxCan1[380] Avg| 9.96| 0.2133| 0.020
>>> Peak| | 0.2161| 0.560
>>> RxCan1[38b] Avg| 24.92| 0.5622| 0.022
>>> Peak| | 0.5716| 1.618
>>> RxCan1[3b3] Avg| 10.00| 0.2132| 0.023
>>> Peak| | 0.2194| 1.106
>>> RxCan1[400] Avg| 4.00| 0.0885| 0.019
>>> Peak| | 0.0885| 0.570
>>> RxCan1[405] Avg| 3.70| 0.1414| 0.036
>>> Peak| | 0.1414| 0.710
>>> RxCan1[40a] Avg| 8.00| 0.1887| 0.021
>>> Peak| | 0.1887| 1.027
>>> RxCan1[410] Avg| 10.00| 0.2141| 0.023
>>> Peak| | 0.2188| 0.984
>>> RxCan1[411] Avg| 10.00| 0.2325| 0.023
>>> Peak| | 0.2447| 0.660
>>> RxCan1[416] Avg| 10.00| 0.2326| 0.022
>>> Peak| | 0.2389| 0.774
>>> RxCan1[421] Avg| 10.00| 0.2245| 0.021
>>> Peak| | 0.2271| 1.160
>>> RxCan1[42d] Avg| 10.00| 0.2315| 0.021
>>> Peak| | 0.2411| 0.677
>>> RxCan1[42f] Avg| 10.00| 0.2480| 0.020
>>> Peak| | 0.2975| 8.093
>>> RxCan1[430] Avg| 10.00| 0.2203| 0.019
>>> Peak| | 0.2302| 0.847
>>> RxCan1[434] Avg| 10.00| 0.2331| 0.019
>>> Peak| | 0.2620| 1.150
>>> RxCan1[435] Avg| 6.68| 0.1445| 0.020
>>> Peak| | 0.1486| 1.063
>>> RxCan1[43e] Avg| 20.00| 0.4515| 0.021
>>> Peak| | 0.4632| 1.013
>>> RxCan1[440] Avg| 1.00| 0.0210| 0.019
>>> Peak| | 0.0218| 0.294
>>> RxCan1[465] Avg| 0.95| 0.0214| 0.023
>>> Peak| | 0.0215| 0.587
>>> RxCan1[466] Avg| 0.95| 0.0211| 0.021
>>> Peak| | 0.0215| 0.350
>>> RxCan1[467] Avg| 0.95| 0.0191| 0.020
>>> Peak| | 0.0201| 0.444
>>> RxCan1[472] Avg| 0.68| 0.0588| 0.085
>>> Peak| | 0.0606| 1.170
>>> RxCan1[473] Avg| 0.66| 0.0407| 0.062
>>> Peak| | 0.0492| 1.329
>>> RxCan1[474] Avg| 1.00| 0.0218| 0.021
>>> Peak| | 0.0237| 0.278
>>> RxCan1[475] Avg| 1.96| 0.0466| 0.024
>>> Peak| | 0.0570| 1.112
>>> RxCan1[476] Avg| 2.00| 0.0454| 0.020
>>> Peak| | 0.0497| 0.409
>>> RxCan1[477] Avg| 2.00| 0.0497| 0.022
>>> Peak| | 0.0595| 0.864
>>> RxCan1[595] Avg| 1.00| 0.0223| 0.021
>>> Peak| | 0.0241| 0.296
>>> RxCan1[59e] Avg| 1.00| 0.0233| 0.024
>>> Peak| | 0.0289| 0.713
>>> RxCan1[5a2] Avg| 1.00| 0.0200| 0.020
>>> Peak| | 0.0204| 0.264
>>> RxCan1[5ba] Avg| 1.00| 0.0206| 0.021
>>> Peak| | 0.0238| 0.515
>>> RxCan2[020] Avg| 33.30| 0.7938| 0.022
>>> Peak| | 0.7938| 4.793
>>> RxCan2[030] Avg| 22.20| 0.5229| 0.022
>>> Peak| | 0.5229| 0.985
>>> RxCan2[03a] Avg| 19.90| 0.4700| 0.022
>>> Peak| | 0.4700| 0.804
>>> RxCan2[040] Avg| 19.90| 0.4678| 0.023
>>> Peak| | 0.4678| 1.222
>>> RxCan2[060] Avg| 20.00| 0.6480| 0.050
>>> Peak| | 0.6480| 20.997
>>> RxCan2[070] Avg| 16.60| 0.3944| 0.022
>>> Peak| | 0.3944| 1.053
>>> RxCan2[080] Avg| 16.70| 0.7032| 0.041
>>> Peak| | 0.7032| 1.611
>>> RxCan2[083] Avg| 20.10| 0.4329| 0.021
>>> Peak| | 0.4329| 0.520
>>> RxCan2[090] Avg| 24.90| 0.5674| 0.017
>>> Peak| | 0.5674| 1.149
>>> RxCan2[0a0] Avg| 16.60| 0.3836| 0.023
>>> Peak| | 0.3836| 0.933
>>> RxCan2[100] Avg| 16.50| 0.3661| 0.021
>>> Peak| | 0.3661| 0.740
>>> RxCan2[108] Avg| 24.90| 0.5923| 0.025
>>> Peak| | 0.5923| 0.859
>>> RxCan2[110] Avg| 16.70| 0.3906| 0.023
>>> Peak| | 0.3906| 0.697
>>> RxCan2[130] Avg| 14.40| 0.3341| 0.022
>>> Peak| | 0.3341| 0.829
>>> RxCan2[150] Avg| 16.50| 0.4025| 0.020
>>> Peak| | 0.4025| 1.120
>>> RxCan2[160] Avg| 4.90| 0.1252| 0.025
>>> Peak| | 0.1252| 0.502
>>> RxCan2[180] Avg| 16.60| 0.3899| 0.023
>>> Peak| | 0.3899| 0.799
>>> RxCan2[190] Avg| 16.60| 0.3892| 0.025
>>> Peak| | 0.3892| 1.172
>>> RxCan2[1a0] Avg| 1.00| 0.0281| 0.025
>>> Peak| | 0.0281| 0.695
>>> RxCan2[1a4] Avg| 20.00| 0.4525| 0.022
>>> Peak| | 0.4525| 1.231
>>> RxCan2[1a8] Avg| 12.50| 0.2886| 0.020
>>> Peak| | 0.2886| 1.048
>>> RxCan2[1b0] Avg| 10.00| 0.2300| 0.023
>>> Peak| | 0.2300| 0.579
>>> RxCan2[1b4] Avg| 10.00| 0.2334| 0.022
>>> Peak| | 0.2334| 0.947
>>> RxCan2[1b8] Avg| 12.40| 0.2970| 0.023
>>> Peak| | 0.2970| 0.909
>>> RxCan2[1c0] Avg| 10.00| 0.2257| 0.021
>>> Peak| | 0.2257| 0.983
>>> RxCan2[1e0] Avg| 10.00| 0.2141| 0.023
>>> Peak| | 0.2141| 0.556
>>> RxCan2[215] Avg| 8.30| 0.2047| 0.025
>>> Peak| | 0.2047| 0.786
>>> RxCan2[217] Avg| 8.30| 0.2033| 0.022
>>> Peak| | 0.2033| 1.135
>>> RxCan2[220] Avg| 6.70| 0.1647| 0.020
>>> Peak| | 0.1647| 0.961
>>> RxCan2[225] Avg| 24.90| 0.6136| 0.026
>>> Peak| | 0.6136| 1.018
>>> RxCan2[230] Avg| 6.70| 0.4045| 0.057
>>> Peak| | 0.4045| 1.532
>>> RxCan2[240] Avg| 8.20| 0.1849| 0.021
>>> Peak| | 0.1849| 0.510
>>> RxCan2[241] Avg| 20.00| 0.4312| 0.021
>>> Peak| | 0.4312| 5.110
>>> RxCan2[250] Avg| 5.00| 0.1072| 0.021
>>> Peak| | 0.1072| 0.320
>>> RxCan2[255] Avg| 12.50| 0.3091| 0.022
>>> Peak| | 0.3091| 0.904
>>> RxCan2[265] Avg| 12.50| 0.2819| 0.021
>>> Peak| | 0.2819| 1.035
>>> RxCan2[270] Avg| 5.00| 0.1189| 0.022
>>> Peak| | 0.1189| 0.631
>>> RxCan2[290] Avg| 3.30| 0.0740| 0.023
>>> Peak| | 0.0740| 0.455
>>> RxCan2[295] Avg| 6.60| 0.1431| 0.023
>>> Peak| | 0.1431| 0.504
>>> RxCan2[2a0] Avg| 3.30| 0.0686| 0.020
>>> Peak| | 0.0686| 0.445
>>> RxCan2[2a7] Avg| 12.50| 0.2869| 0.021
>>> Peak| | 0.2869| 0.660
>>> RxCan2[2b0] Avg| 3.20| 0.0707| 0.023
>>> Peak| | 0.0707| 0.331
>>> RxCan2[2c0] Avg| 3.20| 0.0988| 0.026
>>> Peak| | 0.0988| 0.932
>>> RxCan2[2e0] Avg| 1.60| 0.0388| 0.024
>>> Peak| | 0.0388| 0.393
>>> RxCan2[2f0] Avg| 1.70| 0.0376| 0.021
>>> Peak| | 0.0376| 0.282
>>> RxCan2[2f5] Avg| 12.50| 0.2833| 0.021
>>> Peak| | 0.2833| 0.855
>>> RxCan2[300] Avg| 1.70| 0.0398| 0.023
>>> Peak| | 0.0398| 0.488
>>> RxCan2[310] Avg| 1.60| 0.0480| 0.026
>>> Peak| | 0.0480| 0.937
>>> RxCan2[320] Avg| 1.70| 0.0346| 0.020
>>> Peak| | 0.0346| 0.370
>>> RxCan2[326] Avg| 9.90| 0.2200| 0.022
>>> Peak| | 0.2200| 0.502
>>> RxCan2[330] Avg| 32.30| 0.7323| 0.021
>>> Peak| | 0.7323| 1.130
>>> RxCan2[340] Avg| 8.20| 0.2375| 0.028
>>> Peak| | 0.2375| 0.578
>>> RxCan2[345] Avg| 1.60| 0.0393| 0.022
>>> Peak| | 0.0393| 0.590
>>> RxCan2[35e] Avg| 5.00| 0.1303| 0.023
>>> Peak| | 0.1303| 0.943
>>> RxCan2[360] Avg| 1.70| 0.0381| 0.025
>>> Peak| | 0.0381| 0.922
>>> RxCan2[361] Avg| 8.20| 0.1907| 0.023
>>> Peak| | 0.1907| 1.119
>>> RxCan2[363] Avg| 1.30| 0.0337| 0.024
>>> Peak| | 0.0337| 0.425
>>> RxCan2[370] Avg| 0.90| 0.0194| 0.022
>>> Peak| | 0.0194| 0.246
>>> RxCan2[381] Avg| 3.20| 0.0684| 0.024
>>> Peak| | 0.0684| 0.828
>>> RxCan2[3a0] Avg| 16.60| 0.3734| 0.022
>>> Peak| | 0.3734| 0.636
>>> RxCan2[3d0] Avg| 10.00| 0.2262| 0.023
>>> Peak| | 0.2262| 0.663
>>> RxCan2[3d5] Avg| 5.60| 0.1335| 0.022
>>> Peak| | 0.1335| 1.222
>>> RxCan2[400] Avg| 4.00| 0.0949| 0.022
>>> Peak| | 0.0949| 0.715
>>> RxCan2[405] Avg| 3.70| 0.0861| 0.022
>>> Peak| | 0.0861| 0.443
>>> RxCan2[40a] Avg| 8.00| 0.1853| 0.021
>>> Peak| | 0.1853| 0.552
>>> RxCan2[415] Avg| 1.60| 0.0341| 0.021
>>> Peak| | 0.0341| 0.273
>>> RxCan2[435] Avg| 0.90| 0.0220| 0.025
>>> Peak| | 0.0220| 0.354
>>> RxCan2[440] Avg| 0.90| 0.0199| 0.021
>>> Peak| | 0.0199| 0.266
>>> RxCan2[465] Avg| 0.90| 0.0234| 0.028
>>> Peak| | 0.0234| 0.633
>>> RxCan2[466] Avg| 1.00| 0.0222| 0.021
>>> Peak| | 0.0222| 0.322
>>> RxCan2[467] Avg| 1.00| 0.0221| 0.020
>>> Peak| | 0.0221| 0.355
>>> RxCan2[501] Avg| 1.50| 0.0335| 0.023
>>> Peak| | 0.0335| 0.393
>>> RxCan2[503] Avg| 1.50| 0.0370| 0.022
>>> Peak| | 0.0370| 0.546
>>> RxCan2[504] Avg| 1.40| 0.0328| 0.022
>>> Peak| | 0.0328| 0.489
>>> RxCan2[505] Avg| 1.40| 0.0290| 0.021
>>> Peak| | 0.0290| 0.354
>>> RxCan2[508] Avg| 1.40| 0.0318| 0.023
>>> Peak| | 0.0318| 0.408
>>> RxCan2[511] Avg| 1.40| 0.0306| 0.022
>>> Peak| | 0.0306| 0.328
>>> RxCan2[51e] Avg| 1.40| 0.0310| 0.022
>>> Peak| | 0.0310| 0.269
>>> RxCan2[581] Avg| 1.00| 0.0222| 0.022
>>> Peak| | 0.0222| 0.256
>>> Total Avg| 2795.57| 82.7745| 40.174
>>> Cheers,
>>> Simon
>>> Am 17.01.2025 um 17:49 schrieb Michael Balzer via OvmsDev:
>>>> OK, I've got a new idea: CAN timing.
>>>> Comparing our esp32can bit timing to the esp-idf
>>>> driver's, there seem to be some differences:
>>>> https://github.com/espressif/esp-idf/blob/master/components/hal/include/hal/twai_types_deprecated.h#L75
>>>> Transceivers are normally tolerant to small timing
>>>> offsets. Maybe being off a little bit has no effect
>>>> under normal conditions, but it has when the
>>>> transceiver has to cope with a filled RX queue. That
>>>> could be causing the transceiver to slide just out of
>>>> sync. If the timing gets garbled, the transceiver would
>>>> signal errors in the packets to the bus, possibly so
>>>> many the vehicle ECUs decide to raise an error condition.
>>>> Is that plausible?
>>>> On why the new poller could be causing this (in
>>>> combination with too slow processing by the vehicle):
>>>> as mentioned, the standard CAN listener mechanism
>>>> doesn't care about queue overflows. The poller does.
>>>> `OvmsPollers::Queue_PollerFrame()` does a log call when
>>>> Tx/Rx tracing is enabled, that could even block, but
>>>> tracing is optional and only meant for debugging. Not
>>>> optional is the overflow counting using an atomic uint32.
>>>> The atomic types are said to be fast, but I never
>>>> checked their actual implementation on the ESP32. Maybe
>>>> they can block as well?
>>>> Regards,
>>>> Michael
>>>> Am 17.01.25 um 15:37 schrieb Chris Box via OvmsDev:
>>>>> Yes, I can confirm I've had one experience of the Leaf
>>>>> switching to Neutral while driving, with a yellow
>>>>> warning symbol on the dash. It refused to reselect
>>>>> Drive until I had switched the car off and back on.
>>>>> Derek wasn't so lucky and he need to clear fault codes
>>>>> before the car would work.
>>>>> On returning home, I found OVMS was not accessible
>>>>> over a network. I didn't try a USB cable. Unplugging
>>>>> and reinserting the OBD cable caused OVMS to rejoin
>>>>> Wi-Fi. However the SD logs showed nothing from the
>>>>> time of the event. CAN writes are enabled, so it can
>>>>> perform SOC limiting.
>>>>> My car has been using this firmware since 21st
>>>>> November, based on the git master of that day. As a
>>>>> relatively new user of OVMS (only since October) I
>>>>> don't have much experience of older firmware.
>>>>> Perhaps a safeguard should be implemented before
>>>>> releasing a new stable firmware that will be
>>>>> automatically downloaded by Leaf owners. But I don't
>>>>> have the expertise to know what that safeguard should
>>>>> be. Derek's suggestion of 'only CAN write when parked'
>>>>> appears to be a good idea.
>>>>> Chris
>>>>> On 2025-01-15 18:18, Derek Caudwell via OvmsDev wrote:
>>>>>> Since the following email I have high confidence the
>>>>>> issue on the Leaf is related/caused by the poller as
>>>>>> there has been no further occurrence and Chris has
>>>>>> also experienced the car going to neutral on the new
>>>>>> poller firmware.
>>>>>> I haven't ruled out it being a fault with my car yet.
>>>>>> Shortly after it faulted the car was run into so has
>>>>>> been off the road for sometime, my first step was to
>>>>>> replace 12V battery. The ovms unit is now unplugged
>>>>>> and if it does not fault over the next month while
>>>>>> driving I'll be reasonably confident
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250119/5ee399f0/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250119/5ee399f0/attachment-0001.sig>
