    Derek Caudwell
    d.caudwell at gmail.com
    Mon Jan 20 02:07:57 HKT 2025
Hi Michael
I just used the firmware stock with no changes to the poller settings.
The Leaf is using high speeds on both buses:
RegisterCanBus(1,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS);
  RegisterCanBus(2,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS);
On Sun, 19 Jan 2025, 10:15 pm Michael Balzer via OvmsDev, <
> Michael,
> I suggest adding a standard bool member variable to reflect if any filter
> is defined, so `PollerRxCallback()` can just skip the filter test while
> that is false. A mutex has some overhead, even if used non-blocking, and a
> bool variable only read there will be sufficient to signal "apply
> filtering" to the callback. With the simple bool test, all vehicles that
> don't need filtering (i.e. most vehicles) will have a neglectible impact
> from this.
> Regarding the overhead: the GCC atomic implementation should use the
> xtensa CPU builtin atomic support (SCOMPARE1 register & S32C1I
> instruction), so should be pretty fast and not use any interrupt disabling,
> see:
>    - https://gcc.gnu.org/wiki/Atomic (xtensa atomic support since gcc
>    4.4.0)
>    https://www.cadence.com/content/dam/cadence-www/global/en_US/documents/tools/silicon-solutions/compute-ip/isa-summary.pdf
>    (section 4.3.13)
> So I still doubt the queue overflow is the real culprit.
> But having the filter option doesn't hurt (with my suggestion above), and
> your changes to the queue processing look promising as well.
> @Derek: what was your poller tracing & timing setup when you had the bus
> issue on the Leaf? I still think that was something related to your car or
> setup. There are currently 11 Leafs on my server running "edge" releases
> including the new poller, all without (reported) issues.
> Am 19.01.25 um 04:26 schrieb Michael Geddes:
> P/R Created
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/1100
> Let me know if you want me to split it up or ANY changes and I'll get onto
> it asap.
> Maybe somebody could grab the code and check it out in the context of
> specifying some filters.  This will prevent those messages from coming to
> the vehicle implementation at all.. and even from going through the poller
> queue.  It is non-blocking meaning that the filter is briefly
> inopperational while the filter is being modified.
> On Sun, 19 Jan 2025 at 11:02, Michael Geddes <frog at bunyip.wheelycreek.net>
> wrote:
>> On Sat, 18 Jan 2025 at 17:08, Michael Balzer via OvmsDev <
>>> I have commented out the line with the Atomic_Increment statement. Now I
>>> no longer receive any messages with “RX Task Queue Overflow Run”
>>> Here is the output of poller times status:
>>> The main question is if you still get the CAN bus crash (vehicle running
>>> into issues) with that modification in active mode. Timing statistics were
>>> not expected to change.
>> I have a feeling that the atomic operations are along the lines of:
>> * Set Interrupts off
>> * atomic operation
>> * Set interrupts on
>> Which means no real 'blocking' .. just not allowing interrupts and
>> therefor task switching for a couple of instructions.
>>> Nearly 2800 frames per second is quite a lot, and most is on can1 with
>>> many frame periods at 20 ms. Yet the total processing time averages at
>>> 30-40 ms, so there is no actual CPU capacity issue for that amount of
>>> frames.
>>> @Derek: can you please supply these statistics for the Leaf in drive
>>> mode as well?
>>> Am 18.01.25 um 02:42 schrieb Michael Geddes via OvmsDev:
>>> Maybe try setting CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE = 160   and see
>>> if that reduces the overflow?
>>> Simons car sends at least 91 process data frame IDs on can1 and 84 on
>>> can2. Worst case would be these come all in within the shortest possible
>>> time span, that would mean the queue needs to be able to hold 175 frames.
>>> I'd add some headroom and round up to 200.
>>> But keep in mind, if the Incoming processing actually occasionally gets
>>> blocked for up to 60 ms -- as indicated by Simons statistics --, the queue
>>> may need to be twice as large.
>>>  I was thinking that the frame filter would be here:
>>> void OvmsPollers::PollerRxCallback(const CAN_frame_t* frame, bool
>>> success)
>>>   Queue_PollerFrame(*frame, success, false);
>>> which I guess is executed in  the task handling the CAN queue.  (we
>>> don't know how many frames get dropped there).
>>> Actually we do know that, or at least have some indication, as we count
>>> the CAN transceiver queue overruns. That info is included as "Rx overflw"
>>> in the can status output & as "rxovr" in the logs.
>>> Adding a filter before queueing the frame would exclude the filtered IDs
>>> from all vehicle processing. I meant adding a filter just to exclude IDs
>>> from the timing statistics, assuming those are the culprits, as Simon wrote
>>> the issue only appears after enabling the timing statistics and printing
>>> them. That's why I asked if printing might need to lock the statistics for
>>> too long in case of such a long list.
>>> Completely blocking ID ranges from processing by the vehicle should
>>> normally not be necessary, unless the Incoming handler is written very
>>> poorly.
>>> Yet, if we add that, a mutex in the CAN RX callback must be avoided, or
>>> would need to be non-blocking:
>>> The only real concern is thread safety between checking and adding to
>>> the filter - so the check itself might have to be mutexed.
>>> success)
>>>   // Check filter
>>>   OvmsRecMutexLock lock(&m_filter_mutex);
>>>     if (! m_filter->IsFiltered(frame))
>>>       return;
>>> A mutex like that could block the CAN task, which must be avoided at all
>>> cost. I introduced CAN callbacks for vehicles & applications that need to
>>> react to certain frames as fast as possible, e.g. to maintain control
>>> precedence, so cannot use the standard CAN listener mechanism (frame
>>> queueing).
>>> The current poller callback use is OK, if (!) the atomic type really
>>> isn't the culprit, ie doesn't block.
>>> So if (!) an ID filter needs to be added before queueing, it needs to be
>>> done in a way that needs no mutex. But I don't see an issue with the
>>> vehicle passing a fixed filter when registering with the poller/buses. The
>>> filter doesn't need to by mutable on the fly.
>>> Am 17.01.25 um 19:42 schrieb Simon Ehlen via OvmsDev:
>>> The poller statistics can help you track this down, but you need to have
>>> at least 10 seconds of statistics, the more the better. Rule of thumb: PRI
>>> average at 0.0/second means you don't have enough data yet.
>>> There were again many messages with “RX Task Queue Overflow Run”.
>>> Here are the statistics of poller times status:
>>> OVMS# poll times status
>>> Poller timing is: on
>>> Type           | count  | Utlztn | Time
>>>                | per s  | [%]    | [ms]
>>> Poll:PRI    Avg|    1.00|  0.0043|    0.004
>>>            Peak|        |  0.0043|    0.052
>>> RxCan1[010] Avg|   34.26|  1.6741|    0.015
>>>            Peak|        |  1.6741|    1.182
>>> RxCan1[030] Avg|   34.06|  1.7085|    0.020
>>>            Peak|        |  1.7085|    1.390
>>> RxCan1[041] Avg|   49.89|  0.8109|    0.016
>>>            Peak|        |  0.8541|    1.098
>>> RxCan1[049] Avg|   50.00|  1.5970|    0.019
>>>            Peak|        |  1.7154|   32.233
>>> RxCan1[04c] Avg|   49.92|  0.8340|    0.014
>>>            Peak|        |  0.8933|    1.995
>>> RxCan1[04d] Avg|   34.43|  1.6211|    0.014
>>>            Peak|        |  1.6756|    1.318
>>> RxCan1[076] Avg|   50.00|  0.8362|    0.024
>>>            Peak|        |  0.8784|    2.185
>>> RxCan1[077] Avg|   50.00|  0.7837|    0.014
>>>            Peak|        |  0.8083|    1.156
>>> RxCan1[07a] Avg|   34.31|  2.1870|    0.017
>>>            Peak|        |  2.3252|    1.888
>>> RxCan1[07d] Avg|   50.00|  0.8001|    0.013
>>>            Peak|        |  0.8434|    1.150
>>> RxCan1[0c8] Avg|   49.96|  0.8359|    0.013
>>>            Peak|        |  0.8715|    1.171
>>> RxCan1[11a] Avg|   34.35|  1.6701|    0.020
>>>            Peak|        |  1.6981|    1.273
>>> RxCan1[130] Avg|   50.00|  0.7902|    0.018
>>>            Peak|        |  0.8513|    0.980
>>> RxCan1[139] Avg|   49.92|  0.7872|    0.013
>>>            Peak|        |  0.8219|    0.795
>>> RxCan1[156] Avg|   10.00|  0.1620|    0.014
>>>            Peak|        |  0.1729|    0.919
>>> RxCan1[160] Avg|   50.04|  0.7977|    0.014
>>>            Peak|        |  0.8232|    1.495
>>> RxCan1[165] Avg|   49.85|  0.7976|    0.014
>>>            Peak|        |  0.8486|    1.015
>>> RxCan1[167] Avg|   34.39|  1.6025|    0.016
>>>            Peak|        |  1.6888|    1.354
>>> RxCan1[171] Avg|   50.00|  0.8150|    0.017
>>>            Peak|        |  0.8488|    1.091
>>> RxCan1[178] Avg|   10.00|  0.1614|    0.014
>>>            Peak|        |  0.1702|    0.903
>>> RxCan1[179] Avg|   10.00|  0.1630|    0.017
>>>            Peak|        |  0.1663|    1.336
>>> RxCan1[180] Avg|   50.00|  0.8137|    0.014
>>>            Peak|        |  0.8605|    1.566
>>> RxCan1[185] Avg|   50.04|  0.8033|    0.013
>>>            Peak|        |  0.8393|    1.126
>>> RxCan1[1a0] Avg|   49.92|  0.7748|    0.013
>>>            Peak|        |  0.8169|    1.184
>>> RxCan1[1e0] Avg|   49.92|  0.7738|    0.014
>>>            Peak|        |  0.8028|    1.049
>>> RxCan1[1e4] Avg|   49.89|  0.9692|    0.018
>>>            Peak|        |  1.0096|    1.332
>>> RxCan1[1f0] Avg|   33.22|  0.5544|    0.014
>>>            Peak|        |  0.5855|    0.848
>>> RxCan1[200] Avg|   49.92|  0.7879|    0.015
>>>            Peak|        |  0.8345|    1.206
>>> RxCan1[202] Avg|   34.28|  1.7075|    0.016
>>>            Peak|        |  1.7874|    1.218
>>> RxCan1[204] Avg|   34.35|  1.5641|    0.013
>>>            Peak|        |  1.6427|    1.235
>>> RxCan1[213] Avg|   49.89|  0.7814|    0.015
>>>            Peak|        |  0.8232|    0.910
>>> RxCan1[214] Avg|   49.92|  0.7736|    0.014
>>>            Peak|        |  0.8216|    0.800
>>> RxCan1[217] Avg|   34.31|  1.6294|    0.014
>>>            Peak|        |  1.7165|    1.153
>>> RxCan1[218] Avg|   49.86|  0.7877|    0.013
>>>            Peak|        |  0.8290|    1.068
>>> RxCan1[230] Avg|   50.00|  0.7596|    0.014
>>>            Peak|        |  0.7660|    1.021
>>> RxCan1[240] Avg|   10.00|  0.1669|    0.013
>>>            Peak|        |  0.1835|    0.887
>>> RxCan1[242] Avg|   24.96|  0.4764|    0.020
>>>            Peak|        |  0.4963|    1.501
>>> RxCan1[24a] Avg|    9.89|  0.1789|    0.015
>>>            Peak|        |  0.2009|    0.874
>>> RxCan1[24b] Avg|    9.89|  0.1702|    0.014
>>>            Peak|        |  0.1870|    1.195
>>> RxCan1[24c] Avg|    9.89|  0.2146|    0.019
>>>            Peak|        |  0.2187|    1.242
>>> RxCan1[25a] Avg|   10.00|  0.1603|    0.013
>>>            Peak|        |  0.1667|    0.720
>>> RxCan1[25b] Avg|   49.94|  0.7918|    0.017
>>>            Peak|        |  0.8454|    1.666
>>> RxCan1[25c] Avg|   34.24|  1.5331|    0.013
>>>            Peak|        |  1.5997|    1.538
>>> RxCan1[260] Avg|   10.00|  0.1626|    0.014
>>>            Peak|        |  0.1682|    0.718
>>> RxCan1[270] Avg|   49.90|  0.8120|    0.014
>>>            Peak|        |  0.8460|    1.671
>>> RxCan1[280] Avg|   49.92|  0.7777|    0.019
>>>            Peak|        |  0.8447|    1.157
>>> RxCan1[2e4] Avg|   19.89|  0.5778|    0.032
>>>            Peak|        |  0.6648|    2.226
>>> RxCan1[2ec] Avg|   10.00|  0.1701|    0.014
>>>            Peak|        |  0.1755|    0.928
>>> RxCan1[2ed] Avg|   10.00|  0.1650|    0.013
>>>            Peak|        |  0.1747|    0.917
>>> RxCan1[2ee] Avg|    9.98|  0.1544|    0.013
>>>            Peak|        |  0.1588|    1.312
>>> RxCan1[312] Avg|   10.00|  0.1648|    0.017
>>>            Peak|        |  0.1690|    0.922
>>> RxCan1[326] Avg|    9.89|  0.1603|    0.015
>>>            Peak|        |  0.1833|    1.230
>>> RxCan1[336] Avg|    1.00|  0.0146|    0.015
>>>            Peak|        |  0.0150|    0.349
>>> RxCan1[352] Avg|    6.66|  0.1223|    0.022
>>>            Peak|        |  0.1338|    1.015
>>> RxCan1[355] Avg|    2.00|  0.0424|    0.019
>>>            Peak|        |  0.0431|    0.786
>>> RxCan1[35e] Avg|    9.96|  0.1570|    0.013
>>>            Peak|        |  0.1644|    0.579
>>> RxCan1[365] Avg|   10.00|  0.1600|    0.014
>>>            Peak|        |  0.1653|    0.961
>>> RxCan1[366] Avg|   10.00|  0.1716|    0.013
>>>            Peak|        |  0.1890|    0.987
>>> RxCan1[367] Avg|    9.93|  0.1793|    0.015
>>>            Peak|        |  0.1864|    0.984
>>> RxCan1[368] Avg|   10.00|  0.1645|    0.014
>>>            Peak|        |  0.1778|    0.768
>>> RxCan1[369] Avg|   10.00|  0.1562|    0.016
>>>            Peak|        |  0.1606|    0.724
>>> RxCan1[380] Avg|   10.00|  0.1619|    0.014
>>>            Peak|        |  0.1644|    0.605
>>> RxCan1[38b] Avg|   25.00|  0.3991|    0.016
>>>            Peak|        |  0.4280|    1.448
>>> RxCan1[3b3] Avg|   10.00|  0.1537|    0.013
>>>            Peak|        |  0.1610|    0.380
>>> RxCan1[400] Avg|    4.00|  0.0626|    0.014
>>>            Peak|        |  0.0626|    0.251
>>> RxCan1[405] Avg|    3.90|  0.1019|    0.028
>>>            Peak|        |  0.1019|    0.781
>>> RxCan1[40a] Avg|    7.90|  0.1256|    0.020
>>>            Peak|        |  0.1256|    0.991
>>> RxCan1[410] Avg|   10.00|  0.1643|    0.016
>>>            Peak|        |  0.1839|    1.634
>>> RxCan1[411] Avg|   10.00|  0.1532|    0.013
>>>            Peak|        |  0.1645|    0.824
>>> RxCan1[416] Avg|   10.00|  0.1516|    0.016
>>>            Peak|        |  0.1582|    0.807
>>> RxCan1[421] Avg|   10.00|  0.1648|    0.013
>>>            Peak|        |  0.1740|    0.839
>>> RxCan1[42d] Avg|   10.00|  0.1548|    0.014
>>>            Peak|        |  0.1658|    0.741
>>> RxCan1[42f] Avg|   10.00|  0.1527|    0.013
>>>            Peak|        |  0.1578|    0.667
>>> RxCan1[430] Avg|   10.00|  0.1730|    0.016
>>>            Peak|        |  0.1880|    1.209
>>> RxCan1[434] Avg|   10.00|  0.1620|    0.021
>>>            Peak|        |  0.1712|    1.140
>>> RxCan1[435] Avg|    6.66|  0.1104|    0.014
>>>            Peak|        |  0.1121|    1.011
>>> RxCan1[43e] Avg|   20.00|  0.3194|    0.013
>>>            Peak|        |  0.3434|    1.212
>>> RxCan1[440] Avg|    1.00|  0.0160|    0.014
>>>            Peak|        |  0.0175|    0.315
>>> RxCan1[465] Avg|    1.00|  0.0172|    0.015
>>>            Peak|        |  0.0194|    0.404
>>> RxCan1[466] Avg|    1.00|  0.0198|    0.015
>>>            Peak|        |  0.0252|    0.890
>>> RxCan1[467] Avg|    1.00|  0.0152|    0.014
>>>            Peak|        |  0.0160|    0.217
>>> RxCan1[472] Avg|    0.70|  0.0533|    0.075
>>>            Peak|        |  0.0546|    0.990
>>> RxCan1[473] Avg|    0.65|  0.0325|    0.051
>>>            Peak|        |  0.0361|    0.774
>>> RxCan1[474] Avg|    1.00|  0.0146|    0.014
>>>            Peak|        |  0.0151|    0.189
>>> RxCan1[475] Avg|    2.00|  0.0332|    0.015
>>>            Peak|        |  0.0362|    0.513
>>> RxCan1[476] Avg|    2.00|  0.0305|    0.014
>>>            Peak|        |  0.0307|    0.249
>>> RxCan1[477] Avg|    2.00|  0.0309|    0.014
>>>            Peak|        |  0.0311|    0.438
>>> RxCan1[595] Avg|    1.00|  0.0151|    0.014
>>>            Peak|        |  0.0160|    0.230
>>> RxCan1[59e] Avg|    1.00|  0.0179|    0.015
>>>            Peak|        |  0.0209|    0.716
>>> RxCan1[5a2] Avg|    1.00|  0.0154|    0.016
>>>            Peak|        |  0.0184|    0.699
>>> RxCan1[5ba] Avg|    1.00|  0.0159|    0.017
>>>            Peak|        |  0.0174|    0.485
>>> RxCan2[010] Avg|    0.00|  0.0000|    0.015
>>>            Peak|        |  0.0000|    0.146
>>> RxCan2[020] Avg|   31.10|  0.5159|    0.015
>>>            Peak|        |  0.5730|    0.992
>>> RxCan2[030] Avg|   20.70|  0.3506|    0.016
>>>            Peak|        |  0.3956|    1.055
>>> RxCan2[03a] Avg|   18.65|  0.3157|    0.014
>>>            Peak|        |  0.3292|    0.702
>>> RxCan2[040] Avg|   18.60|  0.3111|    0.015
>>>            Peak|        |  0.3474|    0.953
>>> RxCan2[060] Avg|   18.60|  0.3182|    0.014
>>>            Peak|        |  0.3569|    0.694
>>> RxCan2[070] Avg|   15.55|  0.4581|    0.017
>>>            Peak|        |  0.6859|   39.212
>>> RxCan2[080] Avg|   15.50|  0.5041|    0.029
>>>            Peak|        |  0.5414|    1.555
>>> RxCan2[083] Avg|   18.70|  0.3083|    0.014
>>>            Peak|        |  0.3325|    0.557
>>> RxCan2[090] Avg|   23.40|  0.3961|    0.014
>>>            Peak|        |  0.4445|    1.218
>>> RxCan2[0a0] Avg|   15.55|  0.2734|    0.014
>>>            Peak|        |  0.3144|    1.062
>>> RxCan2[100] Avg|   15.50|  0.2645|    0.016
>>>            Peak|        |  0.2875|    1.021
>>> RxCan2[108] Avg|   23.40|  0.4231|    0.016
>>>            Peak|        |  0.4680|    1.297
>>> RxCan2[110] Avg|   15.55|  0.2467|    0.014
>>>            Peak|        |  0.2684|    0.475
>>> RxCan2[130] Avg|   13.30|  0.2231|    0.014
>>>            Peak|        |  0.2447|    0.512
>>> RxCan2[150] Avg|   15.50|  0.2533|    0.015
>>>            Peak|        |  0.2836|    0.823
>>> RxCan2[160] Avg|    4.70|  0.0784|    0.014
>>>            Peak|        |  0.0863|    0.608
>>> RxCan2[180] Avg|   15.55|  0.2713|    0.015
>>>            Peak|        |  0.2841|    0.884
>>> RxCan2[190] Avg|   15.50|  0.2596|    0.014
>>>            Peak|        |  0.2825|    0.743
>>> RxCan2[1a0] Avg|    0.95|  0.0164|    0.015
>>>            Peak|        |  0.0164|    0.346
>>> RxCan2[1a4] Avg|   18.65|  0.3232|    0.015
>>>            Peak|        |  0.3515|    0.989
>>> RxCan2[1a8] Avg|   11.60|  0.1911|    0.016
>>>            Peak|        |  0.2012|    0.757
>>> RxCan2[1b0] Avg|    9.35|  0.1558|    0.016
>>>            Peak|        |  0.1641|    0.795
>>> RxCan2[1b4] Avg|    9.35|  0.1543|    0.015
>>>            Peak|        |  0.1617|    1.217
>>> RxCan2[1b8] Avg|   11.65|  0.2003|    0.014
>>>            Peak|        |  0.2236|    1.549
>>> RxCan2[1c0] Avg|    9.40|  0.1532|    0.016
>>>            Peak|        |  0.1673|    0.955
>>> RxCan2[1e0] Avg|    9.30|  0.1582|    0.015
>>>            Peak|        |  0.1708|    0.661
>>> RxCan2[215] Avg|    7.80|  0.1409|    0.016
>>>            Peak|        |  0.1531|    0.660
>>> RxCan2[217] Avg|    7.80|  0.1239|    0.014
>>>            Peak|        |  0.1333|    0.520
>>> RxCan2[220] Avg|    6.20|  0.1041|    0.015
>>>            Peak|        |  0.1094|    0.652
>>> RxCan2[225] Avg|   23.40|  0.4648|    0.015
>>>            Peak|        |  0.4696|    4.288
>>> RxCan2[230] Avg|    6.20|  0.3120|    0.048
>>>            Peak|        |  0.3377|    1.065
>>> RxCan2[240] Avg|    7.70|  0.1248|    0.014
>>>            Peak|        |  0.1364|    0.635
>>> RxCan2[241] Avg|   18.60|  0.3258|    0.014
>>>            Peak|        |  0.3343|    1.288
>>> RxCan2[250] Avg|    4.70|  0.0761|    0.014
>>>            Peak|        |  0.0809|    0.322
>>> RxCan2[255] Avg|   11.75|  0.2058|    0.014
>>>            Peak|        |  0.2283|    0.937
>>> RxCan2[265] Avg|   11.65|  0.1964|    0.014
>>>            Peak|        |  0.2068|    0.965
>>> RxCan2[270] Avg|    4.70|  0.0808|    0.016
>>>            Peak|        |  0.0949|    0.729
>>> RxCan2[290] Avg|    3.15|  0.0498|    0.015
>>>            Peak|        |  0.0504|    0.449
>>> RxCan2[295] Avg|    6.25|  0.1019|    0.014
>>>            Peak|        |  0.1094|    0.859
>>> RxCan2[2a0] Avg|    3.15|  0.0550|    0.014
>>>            Peak|        |  0.0551|    0.779
>>> RxCan2[2a7] Avg|   11.65|  0.1929|    0.014
>>>            Peak|        |  0.2080|    0.775
>>> RxCan2[2b0] Avg|    3.00|  0.0497|    0.015
>>>            Peak|        |  0.0562|    0.528
>>> RxCan2[2c0] Avg|    3.10|  0.0534|    0.016
>>>            Peak|        |  0.0592|    0.501
>>> RxCan2[2e0] Avg|    1.55|  0.0247|    0.014
>>>            Peak|        |  0.0289|    0.319
>>> RxCan2[2f0] Avg|    1.55|  0.0244|    0.014
>>>            Peak|        |  0.0273|    0.192
>>> RxCan2[2f5] Avg|   11.65|  0.2078|    0.016
>>>            Peak|        |  0.2333|    0.879
>>> RxCan2[300] Avg|    1.60|  0.0266|    0.018
>>>            Peak|        |  0.0278|    0.724
>>> RxCan2[310] Avg|    1.55|  0.0276|    0.016
>>>            Peak|        |  0.0285|    0.759
>>> RxCan2[320] Avg|    1.60|  0.0240|    0.014
>>>            Peak|        |  0.0258|    0.179
>>> RxCan2[326] Avg|    9.30|  0.1550|    0.014
>>>            Peak|        |  0.1582|    0.850
>>> RxCan2[330] Avg|   29.95|  0.5311|    0.015
>>>            Peak|        |  0.5565|    4.522
>>> RxCan2[340] Avg|    7.75|  0.1693|    0.024
>>>            Peak|        |  0.1868|    1.148
>>> RxCan2[345] Avg|    1.60|  0.0292|    0.016
>>>            Peak|        |  0.0316|    0.471
>>> RxCan2[350] Avg|    0.00|  0.0000|    0.019
>>>            Peak|        |  0.0000|    0.188
>>> RxCan2[35e] Avg|    4.70|  0.0851|    0.019
>>>            Peak|        |  0.0911|    1.023
>>> RxCan2[360] Avg|    1.60|  0.0258|    0.015
>>>            Peak|        |  0.0284|    0.306
>>> RxCan2[361] Avg|    7.75|  0.1341|    0.017
>>>            Peak|        |  0.1487|    0.761
>>> RxCan2[363] Avg|    1.20|  0.0203|    0.016
>>>            Peak|        |  0.0220|    0.421
>>> RxCan2[370] Avg|    0.85|  0.0140|    0.016
>>>            Peak|        |  0.0162|    0.354
>>> RxCan2[381] Avg|    3.15|  0.0512|    0.016
>>>            Peak|        |  0.0546|    0.416
>>> RxCan2[3a0] Avg|   15.60|  0.2548|    0.015
>>>            Peak|        |  0.2890|    0.976
>>> RxCan2[3d0] Avg|    9.35|  0.1553|    0.019
>>>            Peak|        |  0.1612|    1.115
>>> RxCan2[3d5] Avg|    5.15|  0.0836|    0.016
>>>            Peak|        |  0.0867|    0.479
>>> RxCan2[3e0] Avg|    0.00|  0.0000|    0.014
>>>            Peak|        |  0.0000|    0.142
>>> RxCan2[400] Avg|    3.55|  0.0613|    0.017
>>>            Peak|        |  0.0695|    0.501
>>> RxCan2[405] Avg|    3.50|  0.0584|    0.018
>>>            Peak|        |  0.0626|    0.686
>>> RxCan2[40a] Avg|    7.10|  0.1278|    0.017
>>>            Peak|        |  0.1389|    1.244
>>> RxCan2[415] Avg|    1.60|  0.0258|    0.014
>>>            Peak|        |  0.0287|    0.266
>>> RxCan2[435] Avg|    0.85|  0.0165|    0.019
>>>            Peak|        |  0.0167|    0.367
>>> RxCan2[440] Avg|    0.85|  0.0128|    0.019
>>>            Peak|        |  0.0141|    0.885
>>> RxCan2[465] Avg|    0.95|  0.0177|    0.016
>>>            Peak|        |  0.0195|    0.721
>>> RxCan2[466] Avg|    0.95|  0.0147|    0.014
>>>            Peak|        |  0.0160|    0.184
>>> RxCan2[467] Avg|    0.95|  0.0172|    0.017
>>>            Peak|        |  0.0188|    0.391
>>> RxCan2[501] Avg|    1.45|  0.0273|    0.016
>>>            Peak|        |  0.0327|    0.996
>>> RxCan2[503] Avg|    1.45|  0.0288|    0.020
>>>            Peak|        |  0.0338|    0.970
>>> RxCan2[504] Avg|    1.40|  0.0241|    0.015
>>>            Peak|        |  0.0263|    0.609
>>> RxCan2[505] Avg|    1.40|  0.0255|    0.015
>>>            Peak|        |  0.0296|    0.866
>>> RxCan2[508] Avg|    1.35|  0.0237|    0.017
>>>            Peak|        |  0.0237|    0.384
>>> RxCan2[511] Avg|    1.35|  0.0226|    0.016
>>>            Peak|        |  0.0228|    0.426
>>> RxCan2[51e] Avg|    1.40|  0.0221|    0.014
>>>            Peak|        |  0.0245|    0.211
>>> RxCan2[581] Avg|    0.80|  0.0189|    0.019
>>>            Peak|        |  0.0290|    1.217
>>> RxCan2[606] Avg|    0.00|  0.0000|    0.014
>>> RxCan2[657] Avg|    0.00|  0.0000|    0.014
>>>            Peak|        |  0.0000|    0.137
>>> Cmd:State   Avg|    0.00|  0.0000|    0.002
>>>            Peak|        |  0.0000|    0.024
>>>       Total Avg| 2748.42| 58.3344|   28.718
>>> @Simon: it would be an option to try commenting out the overflow
>>> counting, to see if that's causing the issue.
>>> OVMS# poll time status
>>>                | per s  | [%]    | [ms]
>>> Poll:PRI    Avg|    1.00|  0.0045|    0.004
>>>            Peak|        |  0.0046|    0.064
>>> RxCan1[010] Avg|   34.26|  2.2574|    0.021
>>>            Peak|        |  2.2574|    4.609
>>> RxCan1[030] Avg|   34.26|  2.3820|    0.021
>>>            Peak|        |  2.3820|    1.135
>>> RxCan1[041] Avg|   49.89|  1.2059|    0.021
>>>            Peak|        |  1.2295|    5.331
>>> RxCan1[049] Avg|   49.96|  1.2400|    0.030
>>>            Peak|        |  1.2699|    1.402
>>> RxCan1[04c] Avg|   49.92|  1.1752|    0.021
>>>            Peak|        |  1.2072|    4.502
>>> RxCan1[04d] Avg|   34.31|  2.4433|    0.022
>>>            Peak|        |  2.4773|    1.368
>>> RxCan1[076] Avg|   49.96|  1.2071|    0.024
>>>            Peak|        |  1.2554|    2.007
>>> RxCan1[077] Avg|   49.96|  1.2012|    0.022
>>>            Peak|        |  1.2492|    1.955
>>> RxCan1[07a] Avg|   34.35|  2.9251|    0.030
>>>            Peak|        |  3.1103|    1.829
>>> RxCan1[07d] Avg|   49.96|  1.1954|    0.022
>>>            Peak|        |  1.2282|    1.074
>>> RxCan1[0c8] Avg|   49.89|  1.2491|    0.021
>>>            Peak|        |  1.3169|    1.181
>>> RxCan1[11a] Avg|   34.39|  2.4423|    0.024
>>>            Peak|        |  2.5693|    1.491
>>> RxCan1[130] Avg|   49.95|  1.1312|    0.020
>>>            Peak|        |  1.1684|    1.218
>>> RxCan1[139] Avg|   49.92|  1.1547|    0.021
>>>            Peak|        |  1.1778|    1.199
>>> RxCan1[156] Avg|    9.96|  0.2391|    0.023
>>>            Peak|        |  0.2591|    1.943
>>> RxCan1[160] Avg|   49.96|  1.1657|    0.031
>>>            Peak|        |  1.2017|    2.158
>>> RxCan1[165] Avg|   49.96|  1.1257|    0.021
>>>            Peak|        |  1.1652|    1.471
>>> RxCan1[167] Avg|   34.31|  2.2871|    0.021
>>>            Peak|        |  2.3374|    1.776
>>> RxCan1[171] Avg|   49.96|  1.1879|    0.023
>>>            Peak|        |  1.2268|    1.166
>>> RxCan1[178] Avg|   10.00|  0.2371|    0.029
>>>            Peak|        |  0.2459|    1.516
>>> RxCan1[179] Avg|   10.00|  0.2196|    0.021
>>>            Peak|        |  0.2260|    0.758
>>> RxCan1[180] Avg|   49.96|  1.1703|    0.022
>>>            Peak|        |  1.2103|    1.481
>>> RxCan1[185] Avg|   49.95|  1.1127|    0.020
>>>            Peak|        |  1.1636|    1.292
>>> RxCan1[1a0] Avg|   49.96|  1.1009|    0.020
>>>            Peak|        |  1.1468|    1.060
>>> RxCan1[1e0] Avg|   49.96|  1.1744|    0.021
>>>            Peak|        |  1.2027|    1.240
>>> RxCan1[1e4] Avg|   49.96|  1.3733|    0.032
>>>            Peak|        |  1.4085|    1.523
>>> RxCan1[1f0] Avg|   33.30|  0.7625|    0.023
>>>            Peak|        |  0.8004|    3.349
>>> RxCan1[200] Avg|   49.92|  1.1462|    0.021
>>>            Peak|        |  1.1809|    1.254
>>> RxCan1[202] Avg|   34.39|  2.4034|    0.028
>>>            Peak|        |  2.5611|    1.472
>>> RxCan1[204] Avg|   34.30|  2.2541|    0.022
>>>            Peak|        |  2.2924|    2.015
>>> RxCan1[213] Avg|   49.96|  1.1599|    0.027
>>>            Peak|        |  1.1794|    1.714
>>> RxCan1[214] Avg|   49.96|  1.1537|    0.022
>>>            Peak|        |  1.1941|    1.439
>>> RxCan1[217] Avg|   34.39|  2.2490|    0.020
>>>            Peak|        |  2.2856|    3.766
>>> RxCan1[218] Avg|   49.96|  1.1291|    0.021
>>>            Peak|        |  1.1646|    1.547
>>> RxCan1[230] Avg|   49.96|  1.1272|    0.020
>>>            Peak|        |  1.2237|    1.295
>>> RxCan1[240] Avg|   10.00|  0.2191|    0.021
>>>            Peak|        |  0.2226|    1.067
>>> RxCan1[242] Avg|   24.96|  0.6911|    0.024
>>>            Peak|        |  0.7161|    1.180
>>> RxCan1[24a] Avg|    9.96|  0.2345|    0.024
>>>            Peak|        |  0.2535|    0.779
>>> RxCan1[24b] Avg|    9.96|  0.2433|    0.023
>>>            Peak|        |  0.2697|    2.085
>>> RxCan1[24c] Avg|    9.96|  0.3103|    0.029
>>>            Peak|        |  0.3203|    0.809
>>> RxCan1[25a] Avg|   10.00|  0.2346|    0.022
>>>            Peak|        |  0.2405|    1.223
>>> RxCan1[25b] Avg|   49.89|  1.2121|    0.020
>>>            Peak|        |  1.3659|   19.523
>>> RxCan1[25c] Avg|   34.31|  2.4193|    0.019
>>>            Peak|        |  2.8022|   58.153
>>> RxCan1[260] Avg|    9.93|  0.2149|    0.024
>>>            Peak|        |  0.2174|    1.096
>>> RxCan1[270] Avg|   49.96|  1.2042|    0.026
>>>            Peak|        |  1.2755|   20.612
>>> RxCan1[280] Avg|   49.96|  1.0922|    0.020
>>>            Peak|        |  1.1312|    1.266
>>> RxCan1[2e4] Avg|   19.96|  0.6942|    0.044
>>>            Peak|        |  0.8604|    1.533
>>> RxCan1[2ec] Avg|   10.00|  0.3727|    0.025
>>>            Peak|        |  0.5154|   28.819
>>> RxCan1[2ed] Avg|   10.00|  0.2298|    0.023
>>>            Peak|        |  0.2378|    1.345
>>> RxCan1[2ee] Avg|    9.96|  0.2172|    0.019
>>>            Peak|        |  0.2210|    1.058
>>> RxCan1[312] Avg|   10.00|  0.2206|    0.020
>>>            Peak|        |  0.2396|    1.060
>>> RxCan1[326] Avg|    9.96|  0.2099|    0.020
>>>            Peak|        |  0.2158|    0.507
>>> RxCan1[336] Avg|    1.00|  0.0212|    0.020
>>>            Peak|        |  0.0233|    0.315
>>> RxCan1[352] Avg|    6.64|  0.1675|    0.024
>>>            Peak|        |  0.1818|    1.048
>>> RxCan1[355] Avg|    2.00|  0.0540|    0.027
>>>            Peak|        |  0.0619|    1.209
>>> RxCan1[35e] Avg|    9.98|  0.2221|    0.021
>>>            Peak|        |  0.2284|    1.186
>>> RxCan1[365] Avg|   10.00|  0.2282|    0.023
>>>            Peak|        |  0.2335|    0.769
>>> RxCan1[366] Avg|   10.00|  0.3163|    0.022
>>>            Peak|        |  0.6330|   23.587
>>> RxCan1[367] Avg|   10.00|  0.2417|    0.021
>>>            Peak|        |  0.2568|    1.417
>>> RxCan1[368] Avg|    9.96|  0.2187|    0.019
>>>            Peak|        |  0.2250|    1.135
>>> RxCan1[369] Avg|    9.99|  0.2277|    0.021
>>>            Peak|        |  0.2334|    0.667
>>> RxCan1[380] Avg|    9.96|  0.2133|    0.020
>>>            Peak|        |  0.2161|    0.560
>>> RxCan1[38b] Avg|   24.92|  0.5622|    0.022
>>>            Peak|        |  0.5716|    1.618
>>> RxCan1[3b3] Avg|   10.00|  0.2132|    0.023
>>>            Peak|        |  0.2194|    1.106
>>> RxCan1[400] Avg|    4.00|  0.0885|    0.019
>>>            Peak|        |  0.0885|    0.570
>>> RxCan1[405] Avg|    3.70|  0.1414|    0.036
>>>            Peak|        |  0.1414|    0.710
>>> RxCan1[40a] Avg|    8.00|  0.1887|    0.021
>>>            Peak|        |  0.1887|    1.027
>>> RxCan1[410] Avg|   10.00|  0.2141|    0.023
>>>            Peak|        |  0.2188|    0.984
>>> RxCan1[411] Avg|   10.00|  0.2325|    0.023
>>>            Peak|        |  0.2447|    0.660
>>> RxCan1[416] Avg|   10.00|  0.2326|    0.022
>>>            Peak|        |  0.2389|    0.774
>>> RxCan1[421] Avg|   10.00|  0.2245|    0.021
>>>            Peak|        |  0.2271|    1.160
>>> RxCan1[42d] Avg|   10.00|  0.2315|    0.021
>>>            Peak|        |  0.2411|    0.677
>>> RxCan1[42f] Avg|   10.00|  0.2480|    0.020
>>>            Peak|        |  0.2975|    8.093
>>> RxCan1[430] Avg|   10.00|  0.2203|    0.019
>>>            Peak|        |  0.2302|    0.847
>>> RxCan1[434] Avg|   10.00|  0.2331|    0.019
>>>            Peak|        |  0.2620|    1.150
>>> RxCan1[435] Avg|    6.68|  0.1445|    0.020
>>>            Peak|        |  0.1486|    1.063
>>> RxCan1[43e] Avg|   20.00|  0.4515|    0.021
>>>            Peak|        |  0.4632|    1.013
>>> RxCan1[440] Avg|    1.00|  0.0210|    0.019
>>>            Peak|        |  0.0218|    0.294
>>> RxCan1[465] Avg|    0.95|  0.0214|    0.023
>>>            Peak|        |  0.0215|    0.587
>>> RxCan1[466] Avg|    0.95|  0.0211|    0.021
>>>            Peak|        |  0.0215|    0.350
>>> RxCan1[467] Avg|    0.95|  0.0191|    0.020
>>>            Peak|        |  0.0201|    0.444
>>> RxCan1[472] Avg|    0.68|  0.0588|    0.085
>>>            Peak|        |  0.0606|    1.170
>>> RxCan1[473] Avg|    0.66|  0.0407|    0.062
>>>            Peak|        |  0.0492|    1.329
>>> RxCan1[474] Avg|    1.00|  0.0218|    0.021
>>>            Peak|        |  0.0237|    0.278
>>> RxCan1[475] Avg|    1.96|  0.0466|    0.024
>>>            Peak|        |  0.0570|    1.112
>>> RxCan1[476] Avg|    2.00|  0.0454|    0.020
>>>            Peak|        |  0.0497|    0.409
>>> RxCan1[477] Avg|    2.00|  0.0497|    0.022
>>>            Peak|        |  0.0595|    0.864
>>> RxCan1[595] Avg|    1.00|  0.0223|    0.021
>>>            Peak|        |  0.0241|    0.296
>>> RxCan1[59e] Avg|    1.00|  0.0233|    0.024
>>>            Peak|        |  0.0289|    0.713
>>> RxCan1[5a2] Avg|    1.00|  0.0200|    0.020
>>>            Peak|        |  0.0204|    0.264
>>> RxCan1[5ba] Avg|    1.00|  0.0206|    0.021
>>>            Peak|        |  0.0238|    0.515
>>> RxCan2[020] Avg|   33.30|  0.7938|    0.022
>>>            Peak|        |  0.7938|    4.793
>>> RxCan2[030] Avg|   22.20|  0.5229|    0.022
>>>            Peak|        |  0.5229|    0.985
>>> RxCan2[03a] Avg|   19.90|  0.4700|    0.022
>>>            Peak|        |  0.4700|    0.804
>>> RxCan2[040] Avg|   19.90|  0.4678|    0.023
>>>            Peak|        |  0.4678|    1.222
>>> RxCan2[060] Avg|   20.00|  0.6480|    0.050
>>>            Peak|        |  0.6480|   20.997
>>> RxCan2[070] Avg|   16.60|  0.3944|    0.022
>>>            Peak|        |  0.3944|    1.053
>>> RxCan2[080] Avg|   16.70|  0.7032|    0.041
>>>            Peak|        |  0.7032|    1.611
>>> RxCan2[083] Avg|   20.10|  0.4329|    0.021
>>>            Peak|        |  0.4329|    0.520
>>> RxCan2[090] Avg|   24.90|  0.5674|    0.017
>>>            Peak|        |  0.5674|    1.149
>>> RxCan2[0a0] Avg|   16.60|  0.3836|    0.023
>>>            Peak|        |  0.3836|    0.933
>>> RxCan2[100] Avg|   16.50|  0.3661|    0.021
>>>            Peak|        |  0.3661|    0.740
>>> RxCan2[108] Avg|   24.90|  0.5923|    0.025
>>>            Peak|        |  0.5923|    0.859
>>> RxCan2[110] Avg|   16.70|  0.3906|    0.023
>>>            Peak|        |  0.3906|    0.697
>>> RxCan2[130] Avg|   14.40|  0.3341|    0.022
>>>            Peak|        |  0.3341|    0.829
>>> RxCan2[150] Avg|   16.50|  0.4025|    0.020
>>>            Peak|        |  0.4025|    1.120
>>> RxCan2[160] Avg|    4.90|  0.1252|    0.025
>>>            Peak|        |  0.1252|    0.502
>>> RxCan2[180] Avg|   16.60|  0.3899|    0.023
>>>            Peak|        |  0.3899|    0.799
>>> RxCan2[190] Avg|   16.60|  0.3892|    0.025
>>>            Peak|        |  0.3892|    1.172
>>> RxCan2[1a0] Avg|    1.00|  0.0281|    0.025
>>>            Peak|        |  0.0281|    0.695
>>> RxCan2[1a4] Avg|   20.00|  0.4525|    0.022
>>>            Peak|        |  0.4525|    1.231
>>> RxCan2[1a8] Avg|   12.50|  0.2886|    0.020
>>>            Peak|        |  0.2886|    1.048
>>> RxCan2[1b0] Avg|   10.00|  0.2300|    0.023
>>>            Peak|        |  0.2300|    0.579
>>> RxCan2[1b4] Avg|   10.00|  0.2334|    0.022
>>>            Peak|        |  0.2334|    0.947
>>> RxCan2[1b8] Avg|   12.40|  0.2970|    0.023
>>>            Peak|        |  0.2970|    0.909
>>> RxCan2[1c0] Avg|   10.00|  0.2257|    0.021
>>>            Peak|        |  0.2257|    0.983
>>> RxCan2[1e0] Avg|   10.00|  0.2141|    0.023
>>>            Peak|        |  0.2141|    0.556
>>> RxCan2[215] Avg|    8.30|  0.2047|    0.025
>>>            Peak|        |  0.2047|    0.786
>>> RxCan2[217] Avg|    8.30|  0.2033|    0.022
>>>            Peak|        |  0.2033|    1.135
>>> RxCan2[220] Avg|    6.70|  0.1647|    0.020
>>>            Peak|        |  0.1647|    0.961
>>> RxCan2[225] Avg|   24.90|  0.6136|    0.026
>>>            Peak|        |  0.6136|    1.018
>>> RxCan2[230] Avg|    6.70|  0.4045|    0.057
>>>            Peak|        |  0.4045|    1.532
>>> RxCan2[240] Avg|    8.20|  0.1849|    0.021
>>>            Peak|        |  0.1849|    0.510
>>> RxCan2[241] Avg|   20.00|  0.4312|    0.021
>>>            Peak|        |  0.4312|    5.110
>>> RxCan2[250] Avg|    5.00|  0.1072|    0.021
>>>            Peak|        |  0.1072|    0.320
>>> RxCan2[255] Avg|   12.50|  0.3091|    0.022
>>>            Peak|        |  0.3091|    0.904
>>> RxCan2[265] Avg|   12.50|  0.2819|    0.021
>>>            Peak|        |  0.2819|    1.035
>>> RxCan2[270] Avg|    5.00|  0.1189|    0.022
>>>            Peak|        |  0.1189|    0.631
>>> RxCan2[290] Avg|    3.30|  0.0740|    0.023
>>>            Peak|        |  0.0740|    0.455
>>> RxCan2[295] Avg|    6.60|  0.1431|    0.023
>>>            Peak|        |  0.1431|    0.504
>>> RxCan2[2a0] Avg|    3.30|  0.0686|    0.020
>>>            Peak|        |  0.0686|    0.445
>>> RxCan2[2a7] Avg|   12.50|  0.2869|    0.021
>>>            Peak|        |  0.2869|    0.660
>>> RxCan2[2b0] Avg|    3.20|  0.0707|    0.023
>>>            Peak|        |  0.0707|    0.331
>>> RxCan2[2c0] Avg|    3.20|  0.0988|    0.026
>>>            Peak|        |  0.0988|    0.932
>>> RxCan2[2e0] Avg|    1.60|  0.0388|    0.024
>>>            Peak|        |  0.0388|    0.393
>>> RxCan2[2f0] Avg|    1.70|  0.0376|    0.021
>>>            Peak|        |  0.0376|    0.282
>>> RxCan2[2f5] Avg|   12.50|  0.2833|    0.021
>>>            Peak|        |  0.2833|    0.855
>>> RxCan2[300] Avg|    1.70|  0.0398|    0.023
>>>            Peak|        |  0.0398|    0.488
>>> RxCan2[310] Avg|    1.60|  0.0480|    0.026
>>>            Peak|        |  0.0480|    0.937
>>> RxCan2[320] Avg|    1.70|  0.0346|    0.020
>>>            Peak|        |  0.0346|    0.370
>>> RxCan2[326] Avg|    9.90|  0.2200|    0.022
>>>            Peak|        |  0.2200|    0.502
>>> RxCan2[330] Avg|   32.30|  0.7323|    0.021
>>>            Peak|        |  0.7323|    1.130
>>> RxCan2[340] Avg|    8.20|  0.2375|    0.028
>>>            Peak|        |  0.2375|    0.578
>>> RxCan2[345] Avg|    1.60|  0.0393|    0.022
>>>            Peak|        |  0.0393|    0.590
>>> RxCan2[35e] Avg|    5.00|  0.1303|    0.023
>>>            Peak|        |  0.1303|    0.943
>>> RxCan2[360] Avg|    1.70|  0.0381|    0.025
>>>            Peak|        |  0.0381|    0.922
>>> RxCan2[361] Avg|    8.20|  0.1907|    0.023
>>>            Peak|        |  0.1907|    1.119
>>> RxCan2[363] Avg|    1.30|  0.0337|    0.024
>>>            Peak|        |  0.0337|    0.425
>>> RxCan2[370] Avg|    0.90|  0.0194|    0.022
>>>            Peak|        |  0.0194|    0.246
>>> RxCan2[381] Avg|    3.20|  0.0684|    0.024
>>>            Peak|        |  0.0684|    0.828
>>> RxCan2[3a0] Avg|   16.60|  0.3734|    0.022
>>>            Peak|        |  0.3734|    0.636
>>> RxCan2[3d0] Avg|   10.00|  0.2262|    0.023
>>>            Peak|        |  0.2262|    0.663
>>> RxCan2[3d5] Avg|    5.60|  0.1335|    0.022
>>>            Peak|        |  0.1335|    1.222
>>> RxCan2[400] Avg|    4.00|  0.0949|    0.022
>>>            Peak|        |  0.0949|    0.715
>>> RxCan2[405] Avg|    3.70|  0.0861|    0.022
>>>            Peak|        |  0.0861|    0.443
>>> RxCan2[40a] Avg|    8.00|  0.1853|    0.021
>>>            Peak|        |  0.1853|    0.552
>>> RxCan2[415] Avg|    1.60|  0.0341|    0.021
>>>            Peak|        |  0.0341|    0.273
>>> RxCan2[435] Avg|    0.90|  0.0220|    0.025
>>>            Peak|        |  0.0220|    0.354
>>> RxCan2[440] Avg|    0.90|  0.0199|    0.021
>>>            Peak|        |  0.0199|    0.266
>>> RxCan2[465] Avg|    0.90|  0.0234|    0.028
>>>            Peak|        |  0.0234|    0.633
>>> RxCan2[466] Avg|    1.00|  0.0222|    0.021
>>>            Peak|        |  0.0222|    0.322
>>> RxCan2[467] Avg|    1.00|  0.0221|    0.020
>>>            Peak|        |  0.0221|    0.355
>>> RxCan2[501] Avg|    1.50|  0.0335|    0.023
>>>            Peak|        |  0.0335|    0.393
>>> RxCan2[503] Avg|    1.50|  0.0370|    0.022
>>>            Peak|        |  0.0370|    0.546
>>> RxCan2[504] Avg|    1.40|  0.0328|    0.022
>>>            Peak|        |  0.0328|    0.489
>>> RxCan2[505] Avg|    1.40|  0.0290|    0.021
>>>            Peak|        |  0.0290|    0.354
>>> RxCan2[508] Avg|    1.40|  0.0318|    0.023
>>>            Peak|        |  0.0318|    0.408
>>> RxCan2[511] Avg|    1.40|  0.0306|    0.022
>>>            Peak|        |  0.0306|    0.328
>>> RxCan2[51e] Avg|    1.40|  0.0310|    0.022
>>>            Peak|        |  0.0310|    0.269
>>> RxCan2[581] Avg|    1.00|  0.0222|    0.022
>>>            Peak|        |  0.0222|    0.256
>>>       Total Avg| 2795.57| 82.7745|   40.174
>>> Cheers,
>>> Simon
>>> Am 17.01.2025 um 17:49 schrieb Michael Balzer via OvmsDev:
>>> OK, I've got a new idea: CAN timing.
>>> Comparing our esp32can bit timing to the esp-idf driver's, there seem to
>>> be some differences:
>>> https://github.com/espressif/esp-idf/blob/master/components/hal/include/hal/twai_types_deprecated.h#L75
>>> Transceivers are normally tolerant to small timing offsets. Maybe being
>>> off a little bit has no effect under normal conditions, but it has when the
>>> transceiver has to cope with a filled RX queue. That could be causing the
>>> transceiver to slide just out of sync. If the timing gets garbled, the
>>> transceiver would signal errors in the packets to the bus, possibly so many
>>> the vehicle ECUs decide to raise an error condition.
>>> Is that plausible?
>>> On why the new poller could be causing this (in combination with too
>>> slow processing by the vehicle): as mentioned, the standard CAN listener
>>> mechanism doesn't care about queue overflows. The poller does.
>>> `OvmsPollers::Queue_PollerFrame()` does a log call when Tx/Rx tracing is
>>> enabled, that could even block, but tracing is optional and only meant for
>>> debugging. Not optional is the overflow counting using an atomic uint32.
>>> The atomic types are said to be fast, but I never checked their actual
>>> implementation on the ESP32. Maybe they can block as well?
>>> Am 17.01.25 um 15:37 schrieb Chris Box via OvmsDev:
>>> Yes, I can confirm I've had one experience of the Leaf switching to
>>> Neutral while driving, with a yellow warning symbol on the dash. It refused
>>> to reselect Drive until I had switched the car off and back on. Derek
>>> wasn't so lucky and he need to clear fault codes before the car would work.
>>> On returning home, I found OVMS was not accessible over a network. I
>>> didn't try a USB cable. Unplugging and reinserting the OBD cable caused
>>> OVMS to rejoin Wi-Fi. However the SD logs showed nothing from the time of
>>> the event. CAN writes are enabled, so it can perform SOC limiting.
>>> My car has been using this firmware since 21st November, based on the
>>> git master of that day. As a relatively new user of OVMS (only since
>>> October) I don't have much experience of older firmware.
>>> Perhaps a safeguard should be implemented before releasing a new stable
>>> firmware that will be automatically downloaded by Leaf owners. But I don't
>>> have the expertise to know what that safeguard should be. Derek's
>>> suggestion of 'only CAN write when parked' appears to be a good idea.
>>> Chris
>>> On 2025-01-15 18:18, Derek Caudwell via OvmsDev wrote:
>>> Since the following email I have high confidence the issue on the Leaf
>>> is related/caused by the poller as there has been no further occurrence and
>>> Chris has also experienced the car going to neutral on the new poller
>>> firmware.
>>> I haven't ruled out it being a fault with my car yet. Shortly after it
>>> faulted the car was run into so has been off the road for sometime, my
>>> first step was to replace 12V battery. The ovms unit is now unplugged and
>>> if it does not fault over the next month while driving I'll be reasonably
>>> confident
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250120/862e21ed/attachment-0001.htm>
