Sat Jan 18 17:07:44 HKT 2025
> I have commented out the line with the Atomic_Increment statement. Now
> I no longer receive any messages with “RX Task Queue Overflow Run”
> Here is the output of poller times status:
The main question is if you still get the CAN bus crash (vehicle running
into issues) with that modification in active mode. Timing statistics
were not expected to change.
Nearly 2800 frames per second is quite a lot, and most is on can1 with
many frame periods at 20 ms. Yet the total processing time averages at
30-40 ms, so there is no actual CPU capacity issue for that amount of
frames.
@Derek: can you please supply these statistics for the Leaf in drive
mode as well?
Am 18.01.25 um 02:42 schrieb Michael Geddes via OvmsDev:
> Maybe try setting CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE = 160 and
> see if that reduces the overflow?
Simons car sends at least 91 process data frame IDs on can1 and 84 on
can2. Worst case would be these come all in within the shortest possible
time span, that would mean the queue needs to be able to hold 175
frames. I'd add some headroom and round up to 200.
But keep in mind, if the Incoming processing actually occasionally gets
blocked for up to 60 ms -- as indicated by Simons statistics --, the
queue may need to be twice as large.
> I was thinking that the frame filter would be here:
> void OvmsPollers::PollerRxCallback(const CAN_frame_t* frame, bool success)
> Queue_PollerFrame(*frame, success, false);
> which I guess is executed in the task handling the CAN queue. (we
> don't know how many frames get dropped there).
Actually we do know that, or at least have some indication, as we count
the CAN transceiver queue overruns. That info is included as "Rx
overflw" in the can status output & as "rxovr" in the logs.
Adding a filter before queueing the frame would exclude the filtered IDs
from all vehicle processing. I meant adding a filter just to exclude IDs
from the timing statistics, assuming those are the culprits, as Simon
wrote the issue only appears after enabling the timing statistics and
printing them. That's why I asked if printing might need to lock the
statistics for too long in case of such a long list.
Completely blocking ID ranges from processing by the vehicle should
normally not be necessary, unless the Incoming handler is written very
poorly.
Yet, if we add that, a mutex in the CAN RX callback must be avoided, or
would need to be non-blocking:
> The only real concern is thread safety between checking and adding to
> the filter - so the check itself might have to be mutexed.
> // Check filter
> OvmsRecMutexLock lock(&m_filter_mutex);
> if (! m_filter->IsFiltered(frame))
> return;
A mutex like that could block the CAN task, which must be avoided at all
cost. I introduced CAN callbacks for vehicles & applications that need
to react to certain frames as fast as possible, e.g. to maintain control
precedence, so cannot use the standard CAN listener mechanism (frame
queueing).
The current poller callback use is OK, if (!) the atomic type really
isn't the culprit, ie doesn't block.
So if (!) an ID filter needs to be added before queueing, it needs to be
done in a way that needs no mutex. But I don't see an issue with the
vehicle passing a fixed filter when registering with the poller/buses.
The filter doesn't need to by mutable on the fly.
Am 17.01.25 um 19:42 schrieb Simon Ehlen via OvmsDev:
>> The poller statistics can help you track this down, but you need to
>> have at least 10 seconds of statistics, the more the better. Rule of
>> thumb: PRI average at 0.0/second means you don't have enough data yet.
> There were again many messages with “RX Task Queue Overflow Run”.
> Here are the statistics of poller times status:
> OVMS# poll times status
> Poller timing is: on
> Type | count | Utlztn | Time
> | per s | [%] | [ms]
> Poll:PRI Avg| 1.00| 0.0043| 0.004
> Peak| | 0.0043| 0.052
> RxCan1[010] Avg| 34.26| 1.6741| 0.015
> Peak| | 1.6741| 1.182
> RxCan1[030] Avg| 34.06| 1.7085| 0.020
> Peak| | 1.7085| 1.390
> RxCan1[041] Avg| 49.89| 0.8109| 0.016
> Peak| | 0.8541| 1.098
> RxCan1[049] Avg| 50.00| 1.5970| 0.019
> Peak| | 1.7154| 32.233
> RxCan1[04c] Avg| 49.92| 0.8340| 0.014
> Peak| | 0.8933| 1.995
> RxCan1[04d] Avg| 34.43| 1.6211| 0.014
> Peak| | 1.6756| 1.318
> RxCan1[076] Avg| 50.00| 0.8362| 0.024
> Peak| | 0.8784| 2.185
> RxCan1[077] Avg| 50.00| 0.7837| 0.014
> Peak| | 0.8083| 1.156
> RxCan1[07a] Avg| 34.31| 2.1870| 0.017
> Peak| | 2.3252| 1.888
> RxCan1[07d] Avg| 50.00| 0.8001| 0.013
> Peak| | 0.8434| 1.150
> RxCan1[0c8] Avg| 49.96| 0.8359| 0.013
> Peak| | 0.8715| 1.171
> RxCan1[11a] Avg| 34.35| 1.6701| 0.020
> Peak| | 1.6981| 1.273
> RxCan1[130] Avg| 50.00| 0.7902| 0.018
> Peak| | 0.8513| 0.980
> RxCan1[139] Avg| 49.92| 0.7872| 0.013
> Peak| | 0.8219| 0.795
> RxCan1[156] Avg| 10.00| 0.1620| 0.014
> Peak| | 0.1729| 0.919
> RxCan1[160] Avg| 50.04| 0.7977| 0.014
> Peak| | 0.8232| 1.495
> RxCan1[165] Avg| 49.85| 0.7976| 0.014
> Peak| | 0.8486| 1.015
> RxCan1[167] Avg| 34.39| 1.6025| 0.016
> Peak| | 1.6888| 1.354
> RxCan1[171] Avg| 50.00| 0.8150| 0.017
> Peak| | 0.8488| 1.091
> RxCan1[178] Avg| 10.00| 0.1614| 0.014
> Peak| | 0.1702| 0.903
> RxCan1[179] Avg| 10.00| 0.1630| 0.017
> Peak| | 0.1663| 1.336
> RxCan1[180] Avg| 50.00| 0.8137| 0.014
> Peak| | 0.8605| 1.566
> RxCan1[185] Avg| 50.04| 0.8033| 0.013
> Peak| | 0.8393| 1.126
> RxCan1[1a0] Avg| 49.92| 0.7748| 0.013
> Peak| | 0.8169| 1.184
> RxCan1[1e0] Avg| 49.92| 0.7738| 0.014
> Peak| | 0.8028| 1.049
> RxCan1[1e4] Avg| 49.89| 0.9692| 0.018
> Peak| | 1.0096| 1.332
> RxCan1[1f0] Avg| 33.22| 0.5544| 0.014
> Peak| | 0.5855| 0.848
> RxCan1[200] Avg| 49.92| 0.7879| 0.015
> Peak| | 0.8345| 1.206
> RxCan1[202] Avg| 34.28| 1.7075| 0.016
> Peak| | 1.7874| 1.218
> RxCan1[204] Avg| 34.35| 1.5641| 0.013
> Peak| | 1.6427| 1.235
> RxCan1[213] Avg| 49.89| 0.7814| 0.015
> Peak| | 0.8232| 0.910
> RxCan1[214] Avg| 49.92| 0.7736| 0.014
> Peak| | 0.8216| 0.800
> RxCan1[217] Avg| 34.31| 1.6294| 0.014
> Peak| | 1.7165| 1.153
> RxCan1[218] Avg| 49.86| 0.7877| 0.013
> Peak| | 0.8290| 1.068
> RxCan1[230] Avg| 50.00| 0.7596| 0.014
> Peak| | 0.7660| 1.021
> RxCan1[240] Avg| 10.00| 0.1669| 0.013
> Peak| | 0.1835| 0.887
> RxCan1[242] Avg| 24.96| 0.4764| 0.020
> Peak| | 0.4963| 1.501
> RxCan1[24a] Avg| 9.89| 0.1789| 0.015
> Peak| | 0.2009| 0.874
> RxCan1[24b] Avg| 9.89| 0.1702| 0.014
> Peak| | 0.1870| 1.195
> RxCan1[24c] Avg| 9.89| 0.2146| 0.019
> Peak| | 0.2187| 1.242
> RxCan1[25a] Avg| 10.00| 0.1603| 0.013
> Peak| | 0.1667| 0.720
> RxCan1[25b] Avg| 49.94| 0.7918| 0.017
> Peak| | 0.8454| 1.666
> RxCan1[25c] Avg| 34.24| 1.5331| 0.013
> Peak| | 1.5997| 1.538
> RxCan1[260] Avg| 10.00| 0.1626| 0.014
> Peak| | 0.1682| 0.718
> RxCan1[270] Avg| 49.90| 0.8120| 0.014
> Peak| | 0.8460| 1.671
> RxCan1[280] Avg| 49.92| 0.7777| 0.019
> Peak| | 0.8447| 1.157
> RxCan1[2e4] Avg| 19.89| 0.5778| 0.032
> Peak| | 0.6648| 2.226
> RxCan1[2ec] Avg| 10.00| 0.1701| 0.014
> Peak| | 0.1755| 0.928
> RxCan1[2ed] Avg| 10.00| 0.1650| 0.013
> Peak| | 0.1747| 0.917
> RxCan1[2ee] Avg| 9.98| 0.1544| 0.013
> Peak| | 0.1588| 1.312
> RxCan1[312] Avg| 10.00| 0.1648| 0.017
> Peak| | 0.1690| 0.922
> RxCan1[326] Avg| 9.89| 0.1603| 0.015
> Peak| | 0.1833| 1.230
> RxCan1[336] Avg| 1.00| 0.0146| 0.015
> Peak| | 0.0150| 0.349
> RxCan1[352] Avg| 6.66| 0.1223| 0.022
> Peak| | 0.1338| 1.015
> RxCan1[355] Avg| 2.00| 0.0424| 0.019
> Peak| | 0.0431| 0.786
> RxCan1[35e] Avg| 9.96| 0.1570| 0.013
> Peak| | 0.1644| 0.579
> RxCan1[365] Avg| 10.00| 0.1600| 0.014
> Peak| | 0.1653| 0.961
> RxCan1[366] Avg| 10.00| 0.1716| 0.013
> Peak| | 0.1890| 0.987
> RxCan1[367] Avg| 9.93| 0.1793| 0.015
> Peak| | 0.1864| 0.984
> RxCan1[368] Avg| 10.00| 0.1645| 0.014
> Peak| | 0.1778| 0.768
> RxCan1[369] Avg| 10.00| 0.1562| 0.016
> Peak| | 0.1606| 0.724
> RxCan1[380] Avg| 10.00| 0.1619| 0.014
> Peak| | 0.1644| 0.605
> RxCan1[38b] Avg| 25.00| 0.3991| 0.016
> Peak| | 0.4280| 1.448
> RxCan1[3b3] Avg| 10.00| 0.1537| 0.013
> Peak| | 0.1610| 0.380
> RxCan1[400] Avg| 4.00| 0.0626| 0.014
> Peak| | 0.0626| 0.251
> RxCan1[405] Avg| 3.90| 0.1019| 0.028
> Peak| | 0.1019| 0.781
> RxCan1[40a] Avg| 7.90| 0.1256| 0.020
> Peak| | 0.1256| 0.991
> RxCan1[410] Avg| 10.00| 0.1643| 0.016
> Peak| | 0.1839| 1.634
> RxCan1[411] Avg| 10.00| 0.1532| 0.013
> Peak| | 0.1645| 0.824
> RxCan1[416] Avg| 10.00| 0.1516| 0.016
> Peak| | 0.1582| 0.807
> RxCan1[421] Avg| 10.00| 0.1648| 0.013
> Peak| | 0.1740| 0.839
> RxCan1[42d] Avg| 10.00| 0.1548| 0.014
> Peak| | 0.1658| 0.741
> RxCan1[42f] Avg| 10.00| 0.1527| 0.013
> Peak| | 0.1578| 0.667
> RxCan1[430] Avg| 10.00| 0.1730| 0.016
> Peak| | 0.1880| 1.209
> RxCan1[434] Avg| 10.00| 0.1620| 0.021
> Peak| | 0.1712| 1.140
> RxCan1[435] Avg| 6.66| 0.1104| 0.014
> Peak| | 0.1121| 1.011
> RxCan1[43e] Avg| 20.00| 0.3194| 0.013
> Peak| | 0.3434| 1.212
> RxCan1[440] Avg| 1.00| 0.0160| 0.014
> Peak| | 0.0175| 0.315
> RxCan1[465] Avg| 1.00| 0.0172| 0.015
> Peak| | 0.0194| 0.404
> RxCan1[466] Avg| 1.00| 0.0198| 0.015
> Peak| | 0.0252| 0.890
> RxCan1[467] Avg| 1.00| 0.0152| 0.014
> Peak| | 0.0160| 0.217
> RxCan1[472] Avg| 0.70| 0.0533| 0.075
> Peak| | 0.0546| 0.990
> RxCan1[473] Avg| 0.65| 0.0325| 0.051
> Peak| | 0.0361| 0.774
> RxCan1[474] Avg| 1.00| 0.0146| 0.014
> Peak| | 0.0151| 0.189
> RxCan1[475] Avg| 2.00| 0.0332| 0.015
> Peak| | 0.0362| 0.513
> RxCan1[476] Avg| 2.00| 0.0305| 0.014
> Peak| | 0.0307| 0.249
> RxCan1[477] Avg| 2.00| 0.0309| 0.014
> Peak| | 0.0311| 0.438
> RxCan1[595] Avg| 1.00| 0.0151| 0.014
> Peak| | 0.0160| 0.230
> RxCan1[59e] Avg| 1.00| 0.0179| 0.015
> Peak| | 0.0209| 0.716
> RxCan1[5a2] Avg| 1.00| 0.0154| 0.016
> Peak| | 0.0184| 0.699
> RxCan1[5ba] Avg| 1.00| 0.0159| 0.017
> Peak| | 0.0174| 0.485
> RxCan2[010] Avg| 0.00| 0.0000| 0.015
> Peak| | 0.0000| 0.146
> RxCan2[020] Avg| 31.10| 0.5159| 0.015
> Peak| | 0.5730| 0.992
> RxCan2[030] Avg| 20.70| 0.3506| 0.016
> Peak| | 0.3956| 1.055
> RxCan2[03a] Avg| 18.65| 0.3157| 0.014
> Peak| | 0.3292| 0.702
> RxCan2[040] Avg| 18.60| 0.3111| 0.015
> Peak| | 0.3474| 0.953
> RxCan2[060] Avg| 18.60| 0.3182| 0.014
> Peak| | 0.3569| 0.694
> RxCan2[070] Avg| 15.55| 0.4581| 0.017
> Peak| | 0.6859| 39.212
> RxCan2[080] Avg| 15.50| 0.5041| 0.029
> Peak| | 0.5414| 1.555
> RxCan2[083] Avg| 18.70| 0.3083| 0.014
> Peak| | 0.3325| 0.557
> RxCan2[090] Avg| 23.40| 0.3961| 0.014
> Peak| | 0.4445| 1.218
> RxCan2[0a0] Avg| 15.55| 0.2734| 0.014
> Peak| | 0.3144| 1.062
> RxCan2[100] Avg| 15.50| 0.2645| 0.016
> Peak| | 0.2875| 1.021
> RxCan2[108] Avg| 23.40| 0.4231| 0.016
> Peak| | 0.4680| 1.297
> RxCan2[110] Avg| 15.55| 0.2467| 0.014
> Peak| | 0.2684| 0.475
> RxCan2[130] Avg| 13.30| 0.2231| 0.014
> Peak| | 0.2447| 0.512
> RxCan2[150] Avg| 15.50| 0.2533| 0.015
> Peak| | 0.2836| 0.823
> RxCan2[160] Avg| 4.70| 0.0784| 0.014
> Peak| | 0.0863| 0.608
> RxCan2[180] Avg| 15.55| 0.2713| 0.015
> Peak| | 0.2841| 0.884
> RxCan2[190] Avg| 15.50| 0.2596| 0.014
> Peak| | 0.2825| 0.743
> RxCan2[1a0] Avg| 0.95| 0.0164| 0.015
> Peak| | 0.0164| 0.346
> RxCan2[1a4] Avg| 18.65| 0.3232| 0.015
> Peak| | 0.3515| 0.989
> RxCan2[1a8] Avg| 11.60| 0.1911| 0.016
> Peak| | 0.2012| 0.757
> RxCan2[1b0] Avg| 9.35| 0.1558| 0.016
> Peak| | 0.1641| 0.795
> RxCan2[1b4] Avg| 9.35| 0.1543| 0.015
> Peak| | 0.1617| 1.217
> RxCan2[1b8] Avg| 11.65| 0.2003| 0.014
> Peak| | 0.2236| 1.549
> RxCan2[1c0] Avg| 9.40| 0.1532| 0.016
> Peak| | 0.1673| 0.955
> RxCan2[1e0] Avg| 9.30| 0.1582| 0.015
> Peak| | 0.1708| 0.661
> RxCan2[215] Avg| 7.80| 0.1409| 0.016
> Peak| | 0.1531| 0.660
> RxCan2[217] Avg| 7.80| 0.1239| 0.014
> Peak| | 0.1333| 0.520
> RxCan2[220] Avg| 6.20| 0.1041| 0.015
> Peak| | 0.1094| 0.652
> RxCan2[225] Avg| 23.40| 0.4648| 0.015
> Peak| | 0.4696| 4.288
> RxCan2[230] Avg| 6.20| 0.3120| 0.048
> Peak| | 0.3377| 1.065
> RxCan2[240] Avg| 7.70| 0.1248| 0.014
> Peak| | 0.1364| 0.635
> RxCan2[241] Avg| 18.60| 0.3258| 0.014
> Peak| | 0.3343| 1.288
> RxCan2[250] Avg| 4.70| 0.0761| 0.014
> Peak| | 0.0809| 0.322
> RxCan2[255] Avg| 11.75| 0.2058| 0.014
> Peak| | 0.2283| 0.937
> RxCan2[265] Avg| 11.65| 0.1964| 0.014
> Peak| | 0.2068| 0.965
> RxCan2[270] Avg| 4.70| 0.0808| 0.016
> Peak| | 0.0949| 0.729
> RxCan2[290] Avg| 3.15| 0.0498| 0.015
> Peak| | 0.0504| 0.449
> RxCan2[295] Avg| 6.25| 0.1019| 0.014
> Peak| | 0.1094| 0.859
> RxCan2[2a0] Avg| 3.15| 0.0550| 0.014
> Peak| | 0.0551| 0.779
> RxCan2[2a7] Avg| 11.65| 0.1929| 0.014
> Peak| | 0.2080| 0.775
> RxCan2[2b0] Avg| 3.00| 0.0497| 0.015
> Peak| | 0.0562| 0.528
> RxCan2[2c0] Avg| 3.10| 0.0534| 0.016
> Peak| | 0.0592| 0.501
> RxCan2[2e0] Avg| 1.55| 0.0247| 0.014
> Peak| | 0.0289| 0.319
> RxCan2[2f0] Avg| 1.55| 0.0244| 0.014
> Peak| | 0.0273| 0.192
> RxCan2[2f5] Avg| 11.65| 0.2078| 0.016
> Peak| | 0.2333| 0.879
> RxCan2[300] Avg| 1.60| 0.0266| 0.018
> Peak| | 0.0278| 0.724
> RxCan2[310] Avg| 1.55| 0.0276| 0.016
> Peak| | 0.0285| 0.759
> RxCan2[320] Avg| 1.60| 0.0240| 0.014
> Peak| | 0.0258| 0.179
> RxCan2[326] Avg| 9.30| 0.1550| 0.014
> Peak| | 0.1582| 0.850
> RxCan2[330] Avg| 29.95| 0.5311| 0.015
> Peak| | 0.5565| 4.522
> RxCan2[340] Avg| 7.75| 0.1693| 0.024
> Peak| | 0.1868| 1.148
> RxCan2[345] Avg| 1.60| 0.0292| 0.016
> Peak| | 0.0316| 0.471
> RxCan2[350] Avg| 0.00| 0.0000| 0.019
> Peak| | 0.0000| 0.188
> RxCan2[35e] Avg| 4.70| 0.0851| 0.019
> Peak| | 0.0911| 1.023
> RxCan2[360] Avg| 1.60| 0.0258| 0.015
> Peak| | 0.0284| 0.306
> RxCan2[361] Avg| 7.75| 0.1341| 0.017
> Peak| | 0.1487| 0.761
> RxCan2[363] Avg| 1.20| 0.0203| 0.016
> Peak| | 0.0220| 0.421
> RxCan2[370] Avg| 0.85| 0.0140| 0.016
> Peak| | 0.0162| 0.354
> RxCan2[381] Avg| 3.15| 0.0512| 0.016
> Peak| | 0.0546| 0.416
> RxCan2[3a0] Avg| 15.60| 0.2548| 0.015
> Peak| | 0.2890| 0.976
> RxCan2[3d0] Avg| 9.35| 0.1553| 0.019
> Peak| | 0.1612| 1.115
> RxCan2[3d5] Avg| 5.15| 0.0836| 0.016
> Peak| | 0.0867| 0.479
> RxCan2[3e0] Avg| 0.00| 0.0000| 0.014
> Peak| | 0.0000| 0.142
> RxCan2[400] Avg| 3.55| 0.0613| 0.017
> Peak| | 0.0695| 0.501
> RxCan2[405] Avg| 3.50| 0.0584| 0.018
> Peak| | 0.0626| 0.686
> RxCan2[40a] Avg| 7.10| 0.1278| 0.017
> Peak| | 0.1389| 1.244
> RxCan2[415] Avg| 1.60| 0.0258| 0.014
> Peak| | 0.0287| 0.266
> RxCan2[435] Avg| 0.85| 0.0165| 0.019
> Peak| | 0.0167| 0.367
> RxCan2[440] Avg| 0.85| 0.0128| 0.019
> Peak| | 0.0141| 0.885
> RxCan2[465] Avg| 0.95| 0.0177| 0.016
> Peak| | 0.0195| 0.721
> RxCan2[466] Avg| 0.95| 0.0147| 0.014
> Peak| | 0.0160| 0.184
> RxCan2[467] Avg| 0.95| 0.0172| 0.017
> Peak| | 0.0188| 0.391
> RxCan2[501] Avg| 1.45| 0.0273| 0.016
> Peak| | 0.0327| 0.996
> RxCan2[503] Avg| 1.45| 0.0288| 0.020
> Peak| | 0.0338| 0.970
> RxCan2[504] Avg| 1.40| 0.0241| 0.015
> Peak| | 0.0263| 0.609
> RxCan2[505] Avg| 1.40| 0.0255| 0.015
> Peak| | 0.0296| 0.866
> RxCan2[508] Avg| 1.35| 0.0237| 0.017
> Peak| | 0.0237| 0.384
> RxCan2[511] Avg| 1.35| 0.0226| 0.016
> Peak| | 0.0228| 0.426
> RxCan2[51e] Avg| 1.40| 0.0221| 0.014
> Peak| | 0.0245| 0.211
> RxCan2[581] Avg| 0.80| 0.0189| 0.019
> Peak| | 0.0290| 1.217
> RxCan2[606] Avg| 0.00| 0.0000| 0.014
> RxCan2[657] Avg| 0.00| 0.0000| 0.014
> Peak| | 0.0000| 0.137
> Cmd:State Avg| 0.00| 0.0000| 0.002
> Peak| | 0.0000| 0.024
> Total Avg| 2748.42| 58.3344| 28.718
>> @Simon: it would be an option to try commenting out the overflow
>> counting, to see if that's causing the issue.
> OVMS# poll time status
> | per s | [%] | [ms]
> Poll:PRI Avg| 1.00| 0.0045| 0.004
> Peak| | 0.0046| 0.064
> RxCan1[010] Avg| 34.26| 2.2574| 0.021
> Peak| | 2.2574| 4.609
> RxCan1[030] Avg| 34.26| 2.3820| 0.021
> Peak| | 2.3820| 1.135
> RxCan1[041] Avg| 49.89| 1.2059| 0.021
> Peak| | 1.2295| 5.331
> RxCan1[049] Avg| 49.96| 1.2400| 0.030
> Peak| | 1.2699| 1.402
> RxCan1[04c] Avg| 49.92| 1.1752| 0.021
> Peak| | 1.2072| 4.502
> RxCan1[04d] Avg| 34.31| 2.4433| 0.022
> Peak| | 2.4773| 1.368
> RxCan1[076] Avg| 49.96| 1.2071| 0.024
> Peak| | 1.2554| 2.007
> RxCan1[077] Avg| 49.96| 1.2012| 0.022
> Peak| | 1.2492| 1.955
> RxCan1[07a] Avg| 34.35| 2.9251| 0.030
> Peak| | 3.1103| 1.829
> RxCan1[07d] Avg| 49.96| 1.1954| 0.022
> Peak| | 1.2282| 1.074
> RxCan1[0c8] Avg| 49.89| 1.2491| 0.021
> Peak| | 1.3169| 1.181
> RxCan1[11a] Avg| 34.39| 2.4423| 0.024
> Peak| | 2.5693| 1.491
> RxCan1[130] Avg| 49.95| 1.1312| 0.020
> Peak| | 1.1684| 1.218
> RxCan1[139] Avg| 49.92| 1.1547| 0.021
> Peak| | 1.1778| 1.199
> RxCan1[156] Avg| 9.96| 0.2391| 0.023
> Peak| | 0.2591| 1.943
> RxCan1[160] Avg| 49.96| 1.1657| 0.031
> Peak| | 1.2017| 2.158
> RxCan1[165] Avg| 49.96| 1.1257| 0.021
> Peak| | 1.1652| 1.471
> RxCan1[167] Avg| 34.31| 2.2871| 0.021
> Peak| | 2.3374| 1.776
> RxCan1[171] Avg| 49.96| 1.1879| 0.023
> Peak| | 1.2268| 1.166
> RxCan1[178] Avg| 10.00| 0.2371| 0.029
> Peak| | 0.2459| 1.516
> RxCan1[179] Avg| 10.00| 0.2196| 0.021
> Peak| | 0.2260| 0.758
> RxCan1[180] Avg| 49.96| 1.1703| 0.022
> Peak| | 1.2103| 1.481
> RxCan1[185] Avg| 49.95| 1.1127| 0.020
> Peak| | 1.1636| 1.292
> RxCan1[1a0] Avg| 49.96| 1.1009| 0.020
> Peak| | 1.1468| 1.060
> RxCan1[1e0] Avg| 49.96| 1.1744| 0.021
> Peak| | 1.2027| 1.240
> RxCan1[1e4] Avg| 49.96| 1.3733| 0.032
> Peak| | 1.4085| 1.523
> RxCan1[1f0] Avg| 33.30| 0.7625| 0.023
> Peak| | 0.8004| 3.349
> RxCan1[200] Avg| 49.92| 1.1462| 0.021
> Peak| | 1.1809| 1.254
> RxCan1[202] Avg| 34.39| 2.4034| 0.028
> Peak| | 2.5611| 1.472
> RxCan1[204] Avg| 34.30| 2.2541| 0.022
> Peak| | 2.2924| 2.015
> RxCan1[213] Avg| 49.96| 1.1599| 0.027
> Peak| | 1.1794| 1.714
> RxCan1[214] Avg| 49.96| 1.1537| 0.022
> Peak| | 1.1941| 1.439
> RxCan1[217] Avg| 34.39| 2.2490| 0.020
> Peak| | 2.2856| 3.766
> RxCan1[218] Avg| 49.96| 1.1291| 0.021
> Peak| | 1.1646| 1.547
> RxCan1[230] Avg| 49.96| 1.1272| 0.020
> Peak| | 1.2237| 1.295
> RxCan1[240] Avg| 10.00| 0.2191| 0.021
> Peak| | 0.2226| 1.067
> RxCan1[242] Avg| 24.96| 0.6911| 0.024
> Peak| | 0.7161| 1.180
> RxCan1[24a] Avg| 9.96| 0.2345| 0.024
> Peak| | 0.2535| 0.779
> RxCan1[24b] Avg| 9.96| 0.2433| 0.023
> Peak| | 0.2697| 2.085
> RxCan1[24c] Avg| 9.96| 0.3103| 0.029
> Peak| | 0.3203| 0.809
> RxCan1[25a] Avg| 10.00| 0.2346| 0.022
> Peak| | 0.2405| 1.223
> RxCan1[25b] Avg| 49.89| 1.2121| 0.020
> Peak| | 1.3659| 19.523
> RxCan1[25c] Avg| 34.31| 2.4193| 0.019
> Peak| | 2.8022| 58.153
> RxCan1[260] Avg| 9.93| 0.2149| 0.024
> Peak| | 0.2174| 1.096
> RxCan1[270] Avg| 49.96| 1.2042| 0.026
> Peak| | 1.2755| 20.612
> RxCan1[280] Avg| 49.96| 1.0922| 0.020
> Peak| | 1.1312| 1.266
> RxCan1[2e4] Avg| 19.96| 0.6942| 0.044
> Peak| | 0.8604| 1.533
> RxCan1[2ec] Avg| 10.00| 0.3727| 0.025
> Peak| | 0.5154| 28.819
> RxCan1[2ed] Avg| 10.00| 0.2298| 0.023
> Peak| | 0.2378| 1.345
> RxCan1[2ee] Avg| 9.96| 0.2172| 0.019
> Peak| | 0.2210| 1.058
> RxCan1[312] Avg| 10.00| 0.2206| 0.020
> Peak| | 0.2396| 1.060
> RxCan1[326] Avg| 9.96| 0.2099| 0.020
> Peak| | 0.2158| 0.507
> RxCan1[336] Avg| 1.00| 0.0212| 0.020
> Peak| | 0.0233| 0.315
> RxCan1[352] Avg| 6.64| 0.1675| 0.024
> Peak| | 0.1818| 1.048
> RxCan1[355] Avg| 2.00| 0.0540| 0.027
> Peak| | 0.0619| 1.209
> RxCan1[35e] Avg| 9.98| 0.2221| 0.021
> Peak| | 0.2284| 1.186
> RxCan1[365] Avg| 10.00| 0.2282| 0.023
> Peak| | 0.2335| 0.769
> RxCan1[366] Avg| 10.00| 0.3163| 0.022
> Peak| | 0.6330| 23.587
> RxCan1[367] Avg| 10.00| 0.2417| 0.021
> Peak| | 0.2568| 1.417
> RxCan1[368] Avg| 9.96| 0.2187| 0.019
> Peak| | 0.2250| 1.135
> RxCan1[369] Avg| 9.99| 0.2277| 0.021
> Peak| | 0.2334| 0.667
> RxCan1[380] Avg| 9.96| 0.2133| 0.020
> Peak| | 0.2161| 0.560
> RxCan1[38b] Avg| 24.92| 0.5622| 0.022
> Peak| | 0.5716| 1.618
> RxCan1[3b3] Avg| 10.00| 0.2132| 0.023
> Peak| | 0.2194| 1.106
> RxCan1[400] Avg| 4.00| 0.0885| 0.019
> Peak| | 0.0885| 0.570
> RxCan1[405] Avg| 3.70| 0.1414| 0.036
> Peak| | 0.1414| 0.710
> RxCan1[40a] Avg| 8.00| 0.1887| 0.021
> Peak| | 0.1887| 1.027
> RxCan1[410] Avg| 10.00| 0.2141| 0.023
> Peak| | 0.2188| 0.984
> RxCan1[411] Avg| 10.00| 0.2325| 0.023
> Peak| | 0.2447| 0.660
> RxCan1[416] Avg| 10.00| 0.2326| 0.022
> Peak| | 0.2389| 0.774
> RxCan1[421] Avg| 10.00| 0.2245| 0.021
> Peak| | 0.2271| 1.160
> RxCan1[42d] Avg| 10.00| 0.2315| 0.021
> Peak| | 0.2411| 0.677
> RxCan1[42f] Avg| 10.00| 0.2480| 0.020
> Peak| | 0.2975| 8.093
> RxCan1[430] Avg| 10.00| 0.2203| 0.019
> Peak| | 0.2302| 0.847
> RxCan1[434] Avg| 10.00| 0.2331| 0.019
> Peak| | 0.2620| 1.150
> RxCan1[435] Avg| 6.68| 0.1445| 0.020
> Peak| | 0.1486| 1.063
> RxCan1[43e] Avg| 20.00| 0.4515| 0.021
> Peak| | 0.4632| 1.013
> RxCan1[440] Avg| 1.00| 0.0210| 0.019
> Peak| | 0.0218| 0.294
> RxCan1[465] Avg| 0.95| 0.0214| 0.023
> Peak| | 0.0215| 0.587
> RxCan1[466] Avg| 0.95| 0.0211| 0.021
> Peak| | 0.0215| 0.350
> RxCan1[467] Avg| 0.95| 0.0191| 0.020
> Peak| | 0.0201| 0.444
> RxCan1[472] Avg| 0.68| 0.0588| 0.085
> Peak| | 0.0606| 1.170
> RxCan1[473] Avg| 0.66| 0.0407| 0.062
> Peak| | 0.0492| 1.329
> RxCan1[474] Avg| 1.00| 0.0218| 0.021
> Peak| | 0.0237| 0.278
> RxCan1[475] Avg| 1.96| 0.0466| 0.024
> Peak| | 0.0570| 1.112
> RxCan1[476] Avg| 2.00| 0.0454| 0.020
> Peak| | 0.0497| 0.409
> RxCan1[477] Avg| 2.00| 0.0497| 0.022
> Peak| | 0.0595| 0.864
> RxCan1[595] Avg| 1.00| 0.0223| 0.021
> Peak| | 0.0241| 0.296
> RxCan1[59e] Avg| 1.00| 0.0233| 0.024
> Peak| | 0.0289| 0.713
> RxCan1[5a2] Avg| 1.00| 0.0200| 0.020
> Peak| | 0.0204| 0.264
> RxCan1[5ba] Avg| 1.00| 0.0206| 0.021
> Peak| | 0.0238| 0.515
> RxCan2[020] Avg| 33.30| 0.7938| 0.022
> Peak| | 0.7938| 4.793
> RxCan2[030] Avg| 22.20| 0.5229| 0.022
> Peak| | 0.5229| 0.985
> RxCan2[03a] Avg| 19.90| 0.4700| 0.022
> Peak| | 0.4700| 0.804
> RxCan2[040] Avg| 19.90| 0.4678| 0.023
> Peak| | 0.4678| 1.222
> RxCan2[060] Avg| 20.00| 0.6480| 0.050
> Peak| | 0.6480| 20.997
> RxCan2[070] Avg| 16.60| 0.3944| 0.022
> Peak| | 0.3944| 1.053
> RxCan2[080] Avg| 16.70| 0.7032| 0.041
> Peak| | 0.7032| 1.611
> RxCan2[083] Avg| 20.10| 0.4329| 0.021
> Peak| | 0.4329| 0.520
> RxCan2[090] Avg| 24.90| 0.5674| 0.017
> Peak| | 0.5674| 1.149
> RxCan2[0a0] Avg| 16.60| 0.3836| 0.023
> Peak| | 0.3836| 0.933
> RxCan2[100] Avg| 16.50| 0.3661| 0.021
> Peak| | 0.3661| 0.740
> RxCan2[108] Avg| 24.90| 0.5923| 0.025
> Peak| | 0.5923| 0.859
> RxCan2[110] Avg| 16.70| 0.3906| 0.023
> Peak| | 0.3906| 0.697
> RxCan2[130] Avg| 14.40| 0.3341| 0.022
> Peak| | 0.3341| 0.829
> RxCan2[150] Avg| 16.50| 0.4025| 0.020
> Peak| | 0.4025| 1.120
> RxCan2[160] Avg| 4.90| 0.1252| 0.025
> Peak| | 0.1252| 0.502
> RxCan2[180] Avg| 16.60| 0.3899| 0.023
> Peak| | 0.3899| 0.799
> RxCan2[190] Avg| 16.60| 0.3892| 0.025
> Peak| | 0.3892| 1.172
> RxCan2[1a0] Avg| 1.00| 0.0281| 0.025
> Peak| | 0.0281| 0.695
> RxCan2[1a4] Avg| 20.00| 0.4525| 0.022
> Peak| | 0.4525| 1.231
> RxCan2[1a8] Avg| 12.50| 0.2886| 0.020
> Peak| | 0.2886| 1.048
> RxCan2[1b0] Avg| 10.00| 0.2300| 0.023
> Peak| | 0.2300| 0.579
> RxCan2[1b4] Avg| 10.00| 0.2334| 0.022
> Peak| | 0.2334| 0.947
> RxCan2[1b8] Avg| 12.40| 0.2970| 0.023
> Peak| | 0.2970| 0.909
> RxCan2[1c0] Avg| 10.00| 0.2257| 0.021
> Peak| | 0.2257| 0.983
> RxCan2[1e0] Avg| 10.00| 0.2141| 0.023
> Peak| | 0.2141| 0.556
> RxCan2[215] Avg| 8.30| 0.2047| 0.025
> Peak| | 0.2047| 0.786
> RxCan2[217] Avg| 8.30| 0.2033| 0.022
> Peak| | 0.2033| 1.135
> RxCan2[220] Avg| 6.70| 0.1647| 0.020
> Peak| | 0.1647| 0.961
> RxCan2[225] Avg| 24.90| 0.6136| 0.026
> Peak| | 0.6136| 1.018
> RxCan2[230] Avg| 6.70| 0.4045| 0.057
> Peak| | 0.4045| 1.532
> RxCan2[240] Avg| 8.20| 0.1849| 0.021
> Peak| | 0.1849| 0.510
> RxCan2[241] Avg| 20.00| 0.4312| 0.021
> Peak| | 0.4312| 5.110
> RxCan2[250] Avg| 5.00| 0.1072| 0.021
> Peak| | 0.1072| 0.320
> RxCan2[255] Avg| 12.50| 0.3091| 0.022
> Peak| | 0.3091| 0.904
> RxCan2[265] Avg| 12.50| 0.2819| 0.021
> Peak| | 0.2819| 1.035
> RxCan2[270] Avg| 5.00| 0.1189| 0.022
> Peak| | 0.1189| 0.631
> RxCan2[290] Avg| 3.30| 0.0740| 0.023
> Peak| | 0.0740| 0.455
> RxCan2[295] Avg| 6.60| 0.1431| 0.023
> Peak| | 0.1431| 0.504
> RxCan2[2a0] Avg| 3.30| 0.0686| 0.020
> Peak| | 0.0686| 0.445
> RxCan2[2a7] Avg| 12.50| 0.2869| 0.021
> Peak| | 0.2869| 0.660
> RxCan2[2b0] Avg| 3.20| 0.0707| 0.023
> Peak| | 0.0707| 0.331
> RxCan2[2c0] Avg| 3.20| 0.0988| 0.026
> Peak| | 0.0988| 0.932
> RxCan2[2e0] Avg| 1.60| 0.0388| 0.024
> Peak| | 0.0388| 0.393
> RxCan2[2f0] Avg| 1.70| 0.0376| 0.021
> Peak| | 0.0376| 0.282
> RxCan2[2f5] Avg| 12.50| 0.2833| 0.021
> Peak| | 0.2833| 0.855
> RxCan2[300] Avg| 1.70| 0.0398| 0.023
> Peak| | 0.0398| 0.488
> RxCan2[310] Avg| 1.60| 0.0480| 0.026
> Peak| | 0.0480| 0.937
> RxCan2[320] Avg| 1.70| 0.0346| 0.020
> Peak| | 0.0346| 0.370
> RxCan2[326] Avg| 9.90| 0.2200| 0.022
> Peak| | 0.2200| 0.502
> RxCan2[330] Avg| 32.30| 0.7323| 0.021
> Peak| | 0.7323| 1.130
> RxCan2[340] Avg| 8.20| 0.2375| 0.028
> Peak| | 0.2375| 0.578
> RxCan2[345] Avg| 1.60| 0.0393| 0.022
> Peak| | 0.0393| 0.590
> RxCan2[35e] Avg| 5.00| 0.1303| 0.023
> Peak| | 0.1303| 0.943
> RxCan2[360] Avg| 1.70| 0.0381| 0.025
> Peak| | 0.0381| 0.922
> RxCan2[361] Avg| 8.20| 0.1907| 0.023
> Peak| | 0.1907| 1.119
> RxCan2[363] Avg| 1.30| 0.0337| 0.024
> Peak| | 0.0337| 0.425
> RxCan2[370] Avg| 0.90| 0.0194| 0.022
> Peak| | 0.0194| 0.246
> RxCan2[381] Avg| 3.20| 0.0684| 0.024
> Peak| | 0.0684| 0.828
> RxCan2[3a0] Avg| 16.60| 0.3734| 0.022
> Peak| | 0.3734| 0.636
> RxCan2[3d0] Avg| 10.00| 0.2262| 0.023
> Peak| | 0.2262| 0.663
> RxCan2[3d5] Avg| 5.60| 0.1335| 0.022
> Peak| | 0.1335| 1.222
> RxCan2[400] Avg| 4.00| 0.0949| 0.022
> Peak| | 0.0949| 0.715
> RxCan2[405] Avg| 3.70| 0.0861| 0.022
> Peak| | 0.0861| 0.443
> RxCan2[40a] Avg| 8.00| 0.1853| 0.021
> Peak| | 0.1853| 0.552
> RxCan2[415] Avg| 1.60| 0.0341| 0.021
> Peak| | 0.0341| 0.273
> RxCan2[435] Avg| 0.90| 0.0220| 0.025
> Peak| | 0.0220| 0.354
> RxCan2[440] Avg| 0.90| 0.0199| 0.021
> Peak| | 0.0199| 0.266
> RxCan2[465] Avg| 0.90| 0.0234| 0.028
> Peak| | 0.0234| 0.633
> RxCan2[466] Avg| 1.00| 0.0222| 0.021
> Peak| | 0.0222| 0.322
> RxCan2[467] Avg| 1.00| 0.0221| 0.020
> Peak| | 0.0221| 0.355
> RxCan2[501] Avg| 1.50| 0.0335| 0.023
> Peak| | 0.0335| 0.393
> RxCan2[503] Avg| 1.50| 0.0370| 0.022
> Peak| | 0.0370| 0.546
> RxCan2[504] Avg| 1.40| 0.0328| 0.022
> Peak| | 0.0328| 0.489
> RxCan2[505] Avg| 1.40| 0.0290| 0.021
> Peak| | 0.0290| 0.354
> RxCan2[508] Avg| 1.40| 0.0318| 0.023
> Peak| | 0.0318| 0.408
> RxCan2[511] Avg| 1.40| 0.0306| 0.022
> Peak| | 0.0306| 0.328
> RxCan2[51e] Avg| 1.40| 0.0310| 0.022
> Peak| | 0.0310| 0.269
> RxCan2[581] Avg| 1.00| 0.0222| 0.022
> Peak| | 0.0222| 0.256
> Total Avg| 2795.57| 82.7745| 40.174
> Cheers,
> Simon
> Am 17.01.2025 um 17:49 schrieb Michael Balzer via OvmsDev:
>> OK, I've got a new idea: CAN timing.
>> Comparing our esp32can bit timing to the esp-idf driver's, there seem
>> to be some differences:
>> https://github.com/espressif/esp-idf/blob/master/components/hal/include/hal/twai_types_deprecated.h#L75
>> Transceivers are normally tolerant to small timing offsets. Maybe
>> being off a little bit has no effect under normal conditions, but it
>> has when the transceiver has to cope with a filled RX queue. That
>> could be causing the transceiver to slide just out of sync. If the
>> timing gets garbled, the transceiver would signal errors in the
>> packets to the bus, possibly so many the vehicle ECUs decide to raise
>> an error condition.
>> Is that plausible?
>> On why the new poller could be causing this (in combination with too
>> slow processing by the vehicle): as mentioned, the standard CAN
>> listener mechanism doesn't care about queue overflows. The poller
>> does. `OvmsPollers::Queue_PollerFrame()` does a log call when Tx/Rx
>> tracing is enabled, that could even block, but tracing is optional
>> and only meant for debugging. Not optional is the overflow counting
>> using an atomic uint32.
>> The atomic types are said to be fast, but I never checked their
>> actual implementation on the ESP32. Maybe they can block as well?
>> Am 17.01.25 um 15:37 schrieb Chris Box via OvmsDev:
>>> Yes, I can confirm I've had one experience of the Leaf switching to
>>> Neutral while driving, with a yellow warning symbol on the dash. It
>>> refused to reselect Drive until I had switched the car off and back
>>> on. Derek wasn't so lucky and he need to clear fault codes before
>>> the car would work.
>>> On returning home, I found OVMS was not accessible over a network. I
>>> didn't try a USB cable. Unplugging and reinserting the OBD cable
>>> caused OVMS to rejoin Wi-Fi. However the SD logs showed nothing from
>>> the time of the event. CAN writes are enabled, so it can perform SOC
>>> limiting.
>>> My car has been using this firmware since 21st November, based on
>>> the git master of that day. As a relatively new user of OVMS (only
>>> since October) I don't have much experience of older firmware.
>>> Perhaps a safeguard should be implemented before releasing a new
>>> stable firmware that will be automatically downloaded by Leaf
>>> owners. But I don't have the expertise to know what that safeguard
>>> should be. Derek's suggestion of 'only CAN write when parked'
>>> appears to be a good idea.
>>> Chris
>>> On 2025-01-15 18:18, Derek Caudwell via OvmsDev wrote:
>>>> Since the following email I have high confidence the issue on the
>>>> Leaf is related/caused by the poller as there has been no further
>>>> occurrence and Chris has also experienced the car going to neutral
>>>> on the new poller firmware.
>>>> I haven't ruled out it being a fault with my car yet. Shortly after
>>>> it faulted the car was run into so has been off the road for
>>>> sometime, my first step was to replace 12V battery. The ovms unit
>>>> is now unplugged and if it does not fault over the next month while
>>>> driving I'll be reasonably confident it's ovms related.
>>>> Not sure which firmware version the poller updates were included in
>>>> but it was only after upgrading to it that the errors occurred
>>>> (which could be coincidental however it has faulted twice more both
>>>> on version 3.3.004-141-gf729d82c). For periods where I reverted to
>>>> 3.3.003 it was fine.
>>>> It might be useful to have an extra option on the enable can write
>>>> to only enable it when the car is parked/charging.
>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250118/b59191f7/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250118/b59191f7/attachment-0001.sig>
