Derek Caudwell
d.caudwell at gmail.com
Sat Jan 18 04:11:59 HKT 2025
In terms of a quick fix for the Leaf the can bus could be set to listen
mode when driving and if can writes are disabled.
How does this need to be done? Can the bus mode be changed after it's
registered or does it have to be deregistered in a given mode and then
registered again in the new mode?
On Sat, 18 Jan 2025, 7:54 am Simon Ehlen via OvmsDev, <
> Ok, the fact that I no longer receive “Overflow Run” messages is obviously
> because I no longer count them at all due to the missing Atomic_Increment...
> I had initially read that the counter is still recorded in
> m_overflow_count.
> Am 17.01.2025 um 19:42 schrieb Simon Ehlen via OvmsDev:
> The poller statistics can help you track this down, but you need to have
> at least 10 seconds of statistics, the more the better. Rule of thumb: PRI
> average at 0.0/second means you don't have enough data yet.
> There were again many messages with “RX Task Queue Overflow Run”.
> Here are the statistics of poller times status:
> OVMS# poll times status
> Poller timing is: on
> Type | count | Utlztn | Time
> | per s | [%] | [ms]
> Poll:PRI Avg| 1.00| 0.0043| 0.004
> Peak| | 0.0043| 0.052
> RxCan1[010] Avg| 34.26| 1.6741| 0.015
> Peak| | 1.6741| 1.182
> RxCan1[030] Avg| 34.06| 1.7085| 0.020
> Peak| | 1.7085| 1.390
> RxCan1[041] Avg| 49.89| 0.8109| 0.016
> Peak| | 0.8541| 1.098
> RxCan1[049] Avg| 50.00| 1.5970| 0.019
> Peak| | 1.7154| 32.233
> RxCan1[04c] Avg| 49.92| 0.8340| 0.014
> Peak| | 0.8933| 1.995
> RxCan1[04d] Avg| 34.43| 1.6211| 0.014
> Peak| | 1.6756| 1.318
> RxCan1[076] Avg| 50.00| 0.8362| 0.024
> Peak| | 0.8784| 2.185
> RxCan1[077] Avg| 50.00| 0.7837| 0.014
> Peak| | 0.8083| 1.156
> RxCan1[07a] Avg| 34.31| 2.1870| 0.017
> Peak| | 2.3252| 1.888
> RxCan1[07d] Avg| 50.00| 0.8001| 0.013
> Peak| | 0.8434| 1.150
> RxCan1[0c8] Avg| 49.96| 0.8359| 0.013
> Peak| | 0.8715| 1.171
> RxCan1[11a] Avg| 34.35| 1.6701| 0.020
> Peak| | 1.6981| 1.273
> RxCan1[130] Avg| 50.00| 0.7902| 0.018
> Peak| | 0.8513| 0.980
> RxCan1[139] Avg| 49.92| 0.7872| 0.013
> Peak| | 0.8219| 0.795
> RxCan1[156] Avg| 10.00| 0.1620| 0.014
> Peak| | 0.1729| 0.919
> RxCan1[160] Avg| 50.04| 0.7977| 0.014
> Peak| | 0.8232| 1.495
> RxCan1[165] Avg| 49.85| 0.7976| 0.014
> Peak| | 0.8486| 1.015
> RxCan1[167] Avg| 34.39| 1.6025| 0.016
> Peak| | 1.6888| 1.354
> RxCan1[171] Avg| 50.00| 0.8150| 0.017
> Peak| | 0.8488| 1.091
> RxCan1[178] Avg| 10.00| 0.1614| 0.014
> Peak| | 0.1702| 0.903
> RxCan1[179] Avg| 10.00| 0.1630| 0.017
> Peak| | 0.1663| 1.336
> RxCan1[180] Avg| 50.00| 0.8137| 0.014
> Peak| | 0.8605| 1.566
> RxCan1[185] Avg| 50.04| 0.8033| 0.013
> Peak| | 0.8393| 1.126
> RxCan1[1a0] Avg| 49.92| 0.7748| 0.013
> Peak| | 0.8169| 1.184
> RxCan1[1e0] Avg| 49.92| 0.7738| 0.014
> Peak| | 0.8028| 1.049
> RxCan1[1e4] Avg| 49.89| 0.9692| 0.018
> Peak| | 1.0096| 1.332
> RxCan1[1f0] Avg| 33.22| 0.5544| 0.014
> Peak| | 0.5855| 0.848
> RxCan1[200] Avg| 49.92| 0.7879| 0.015
> Peak| | 0.8345| 1.206
> RxCan1[202] Avg| 34.28| 1.7075| 0.016
> Peak| | 1.7874| 1.218
> RxCan1[204] Avg| 34.35| 1.5641| 0.013
> Peak| | 1.6427| 1.235
> RxCan1[213] Avg| 49.89| 0.7814| 0.015
> Peak| | 0.8232| 0.910
> RxCan1[214] Avg| 49.92| 0.7736| 0.014
> Peak| | 0.8216| 0.800
> RxCan1[217] Avg| 34.31| 1.6294| 0.014
> Peak| | 1.7165| 1.153
> RxCan1[218] Avg| 49.86| 0.7877| 0.013
> Peak| | 0.8290| 1.068
> RxCan1[230] Avg| 50.00| 0.7596| 0.014
> Peak| | 0.7660| 1.021
> RxCan1[240] Avg| 10.00| 0.1669| 0.013
> Peak| | 0.1835| 0.887
> RxCan1[242] Avg| 24.96| 0.4764| 0.020
> Peak| | 0.4963| 1.501
> RxCan1[24a] Avg| 9.89| 0.1789| 0.015
> Peak| | 0.2009| 0.874
> RxCan1[24b] Avg| 9.89| 0.1702| 0.014
> Peak| | 0.1870| 1.195
> RxCan1[24c] Avg| 9.89| 0.2146| 0.019
> Peak| | 0.2187| 1.242
> RxCan1[25a] Avg| 10.00| 0.1603| 0.013
> Peak| | 0.1667| 0.720
> RxCan1[25b] Avg| 49.94| 0.7918| 0.017
> Peak| | 0.8454| 1.666
> RxCan1[25c] Avg| 34.24| 1.5331| 0.013
> Peak| | 1.5997| 1.538
> RxCan1[260] Avg| 10.00| 0.1626| 0.014
> Peak| | 0.1682| 0.718
> RxCan1[270] Avg| 49.90| 0.8120| 0.014
> Peak| | 0.8460| 1.671
> RxCan1[280] Avg| 49.92| 0.7777| 0.019
> Peak| | 0.8447| 1.157
> RxCan1[2e4] Avg| 19.89| 0.5778| 0.032
> Peak| | 0.6648| 2.226
> RxCan1[2ec] Avg| 10.00| 0.1701| 0.014
> Peak| | 0.1755| 0.928
> RxCan1[2ed] Avg| 10.00| 0.1650| 0.013
> Peak| | 0.1747| 0.917
> RxCan1[2ee] Avg| 9.98| 0.1544| 0.013
> Peak| | 0.1588| 1.312
> RxCan1[312] Avg| 10.00| 0.1648| 0.017
> Peak| | 0.1690| 0.922
> RxCan1[326] Avg| 9.89| 0.1603| 0.015
> Peak| | 0.1833| 1.230
> RxCan1[336] Avg| 1.00| 0.0146| 0.015
> Peak| | 0.0150| 0.349
> RxCan1[352] Avg| 6.66| 0.1223| 0.022
> Peak| | 0.1338| 1.015
> RxCan1[355] Avg| 2.00| 0.0424| 0.019
> Peak| | 0.0431| 0.786
> RxCan1[35e] Avg| 9.96| 0.1570| 0.013
> Peak| | 0.1644| 0.579
> RxCan1[365] Avg| 10.00| 0.1600| 0.014
> Peak| | 0.1653| 0.961
> RxCan1[366] Avg| 10.00| 0.1716| 0.013
> Peak| | 0.1890| 0.987
> RxCan1[367] Avg| 9.93| 0.1793| 0.015
> Peak| | 0.1864| 0.984
> RxCan1[368] Avg| 10.00| 0.1645| 0.014
> Peak| | 0.1778| 0.768
> RxCan1[369] Avg| 10.00| 0.1562| 0.016
> Peak| | 0.1606| 0.724
> RxCan1[380] Avg| 10.00| 0.1619| 0.014
> Peak| | 0.1644| 0.605
> RxCan1[38b] Avg| 25.00| 0.3991| 0.016
> Peak| | 0.4280| 1.448
> RxCan1[3b3] Avg| 10.00| 0.1537| 0.013
> Peak| | 0.1610| 0.380
> RxCan1[400] Avg| 4.00| 0.0626| 0.014
> Peak| | 0.0626| 0.251
> RxCan1[405] Avg| 3.90| 0.1019| 0.028
> Peak| | 0.1019| 0.781
> RxCan1[40a] Avg| 7.90| 0.1256| 0.020
> Peak| | 0.1256| 0.991
> RxCan1[410] Avg| 10.00| 0.1643| 0.016
> Peak| | 0.1839| 1.634
> RxCan1[411] Avg| 10.00| 0.1532| 0.013
> Peak| | 0.1645| 0.824
> RxCan1[416] Avg| 10.00| 0.1516| 0.016
> Peak| | 0.1582| 0.807
> RxCan1[421] Avg| 10.00| 0.1648| 0.013
> Peak| | 0.1740| 0.839
> RxCan1[42d] Avg| 10.00| 0.1548| 0.014
> Peak| | 0.1658| 0.741
> RxCan1[42f] Avg| 10.00| 0.1527| 0.013
> Peak| | 0.1578| 0.667
> RxCan1[430] Avg| 10.00| 0.1730| 0.016
> Peak| | 0.1880| 1.209
> RxCan1[434] Avg| 10.00| 0.1620| 0.021
> Peak| | 0.1712| 1.140
> RxCan1[435] Avg| 6.66| 0.1104| 0.014
> Peak| | 0.1121| 1.011
> RxCan1[43e] Avg| 20.00| 0.3194| 0.013
> Peak| | 0.3434| 1.212
> RxCan1[440] Avg| 1.00| 0.0160| 0.014
> Peak| | 0.0175| 0.315
> RxCan1[465] Avg| 1.00| 0.0172| 0.015
> Peak| | 0.0194| 0.404
> RxCan1[466] Avg| 1.00| 0.0198| 0.015
> Peak| | 0.0252| 0.890
> RxCan1[467] Avg| 1.00| 0.0152| 0.014
> Peak| | 0.0160| 0.217
> RxCan1[472] Avg| 0.70| 0.0533| 0.075
> Peak| | 0.0546| 0.990
> RxCan1[473] Avg| 0.65| 0.0325| 0.051
> Peak| | 0.0361| 0.774
> RxCan1[474] Avg| 1.00| 0.0146| 0.014
> Peak| | 0.0151| 0.189
> RxCan1[475] Avg| 2.00| 0.0332| 0.015
> Peak| | 0.0362| 0.513
> RxCan1[476] Avg| 2.00| 0.0305| 0.014
> Peak| | 0.0307| 0.249
> RxCan1[477] Avg| 2.00| 0.0309| 0.014
> Peak| | 0.0311| 0.438
> RxCan1[595] Avg| 1.00| 0.0151| 0.014
> Peak| | 0.0160| 0.230
> RxCan1[59e] Avg| 1.00| 0.0179| 0.015
> Peak| | 0.0209| 0.716
> RxCan1[5a2] Avg| 1.00| 0.0154| 0.016
> Peak| | 0.0184| 0.699
> RxCan1[5ba] Avg| 1.00| 0.0159| 0.017
> Peak| | 0.0174| 0.485
> RxCan2[010] Avg| 0.00| 0.0000| 0.015
> Peak| | 0.0000| 0.146
> RxCan2[020] Avg| 31.10| 0.5159| 0.015
> Peak| | 0.5730| 0.992
> RxCan2[030] Avg| 20.70| 0.3506| 0.016
> Peak| | 0.3956| 1.055
> RxCan2[03a] Avg| 18.65| 0.3157| 0.014
> Peak| | 0.3292| 0.702
> RxCan2[040] Avg| 18.60| 0.3111| 0.015
> Peak| | 0.3474| 0.953
> RxCan2[060] Avg| 18.60| 0.3182| 0.014
> Peak| | 0.3569| 0.694
> RxCan2[070] Avg| 15.55| 0.4581| 0.017
> Peak| | 0.6859| 39.212
> RxCan2[080] Avg| 15.50| 0.5041| 0.029
> Peak| | 0.5414| 1.555
> RxCan2[083] Avg| 18.70| 0.3083| 0.014
> Peak| | 0.3325| 0.557
> RxCan2[090] Avg| 23.40| 0.3961| 0.014
> Peak| | 0.4445| 1.218
> RxCan2[0a0] Avg| 15.55| 0.2734| 0.014
> Peak| | 0.3144| 1.062
> RxCan2[100] Avg| 15.50| 0.2645| 0.016
> Peak| | 0.2875| 1.021
> RxCan2[108] Avg| 23.40| 0.4231| 0.016
> Peak| | 0.4680| 1.297
> RxCan2[110] Avg| 15.55| 0.2467| 0.014
> Peak| | 0.2684| 0.475
> RxCan2[130] Avg| 13.30| 0.2231| 0.014
> Peak| | 0.2447| 0.512
> RxCan2[150] Avg| 15.50| 0.2533| 0.015
> Peak| | 0.2836| 0.823
> RxCan2[160] Avg| 4.70| 0.0784| 0.014
> Peak| | 0.0863| 0.608
> RxCan2[180] Avg| 15.55| 0.2713| 0.015
> Peak| | 0.2841| 0.884
> RxCan2[190] Avg| 15.50| 0.2596| 0.014
> Peak| | 0.2825| 0.743
> RxCan2[1a0] Avg| 0.95| 0.0164| 0.015
> Peak| | 0.0164| 0.346
> RxCan2[1a4] Avg| 18.65| 0.3232| 0.015
> Peak| | 0.3515| 0.989
> RxCan2[1a8] Avg| 11.60| 0.1911| 0.016
> Peak| | 0.2012| 0.757
> RxCan2[1b0] Avg| 9.35| 0.1558| 0.016
> Peak| | 0.1641| 0.795
> RxCan2[1b4] Avg| 9.35| 0.1543| 0.015
> Peak| | 0.1617| 1.217
> RxCan2[1b8] Avg| 11.65| 0.2003| 0.014
> Peak| | 0.2236| 1.549
> RxCan2[1c0] Avg| 9.40| 0.1532| 0.016
> Peak| | 0.1673| 0.955
> RxCan2[1e0] Avg| 9.30| 0.1582| 0.015
> Peak| | 0.1708| 0.661
> RxCan2[215] Avg| 7.80| 0.1409| 0.016
> Peak| | 0.1531| 0.660
> RxCan2[217] Avg| 7.80| 0.1239| 0.014
> Peak| | 0.1333| 0.520
> RxCan2[220] Avg| 6.20| 0.1041| 0.015
> Peak| | 0.1094| 0.652
> RxCan2[225] Avg| 23.40| 0.4648| 0.015
> Peak| | 0.4696| 4.288
> RxCan2[230] Avg| 6.20| 0.3120| 0.048
> Peak| | 0.3377| 1.065
> RxCan2[240] Avg| 7.70| 0.1248| 0.014
> Peak| | 0.1364| 0.635
> RxCan2[241] Avg| 18.60| 0.3258| 0.014
> Peak| | 0.3343| 1.288
> RxCan2[250] Avg| 4.70| 0.0761| 0.014
> Peak| | 0.0809| 0.322
> RxCan2[255] Avg| 11.75| 0.2058| 0.014
> Peak| | 0.2283| 0.937
> RxCan2[265] Avg| 11.65| 0.1964| 0.014
> Peak| | 0.2068| 0.965
> RxCan2[270] Avg| 4.70| 0.0808| 0.016
> Peak| | 0.0949| 0.729
> RxCan2[290] Avg| 3.15| 0.0498| 0.015
> Peak| | 0.0504| 0.449
> RxCan2[295] Avg| 6.25| 0.1019| 0.014
> Peak| | 0.1094| 0.859
> RxCan2[2a0] Avg| 3.15| 0.0550| 0.014
> Peak| | 0.0551| 0.779
> RxCan2[2a7] Avg| 11.65| 0.1929| 0.014
> Peak| | 0.2080| 0.775
> RxCan2[2b0] Avg| 3.00| 0.0497| 0.015
> Peak| | 0.0562| 0.528
> RxCan2[2c0] Avg| 3.10| 0.0534| 0.016
> Peak| | 0.0592| 0.501
> RxCan2[2e0] Avg| 1.55| 0.0247| 0.014
> Peak| | 0.0289| 0.319
> RxCan2[2f0] Avg| 1.55| 0.0244| 0.014
> Peak| | 0.0273| 0.192
> RxCan2[2f5] Avg| 11.65| 0.2078| 0.016
> Peak| | 0.2333| 0.879
> RxCan2[300] Avg| 1.60| 0.0266| 0.018
> Peak| | 0.0278| 0.724
> RxCan2[310] Avg| 1.55| 0.0276| 0.016
> Peak| | 0.0285| 0.759
> RxCan2[320] Avg| 1.60| 0.0240| 0.014
> Peak| | 0.0258| 0.179
> RxCan2[326] Avg| 9.30| 0.1550| 0.014
> Peak| | 0.1582| 0.850
> RxCan2[330] Avg| 29.95| 0.5311| 0.015
> Peak| | 0.5565| 4.522
> RxCan2[340] Avg| 7.75| 0.1693| 0.024
> Peak| | 0.1868| 1.148
> RxCan2[345] Avg| 1.60| 0.0292| 0.016
> Peak| | 0.0316| 0.471
> RxCan2[350] Avg| 0.00| 0.0000| 0.019
> Peak| | 0.0000| 0.188
> RxCan2[35e] Avg| 4.70| 0.0851| 0.019
> Peak| | 0.0911| 1.023
> RxCan2[360] Avg| 1.60| 0.0258| 0.015
> Peak| | 0.0284| 0.306
> RxCan2[361] Avg| 7.75| 0.1341| 0.017
> Peak| | 0.1487| 0.761
> RxCan2[363] Avg| 1.20| 0.0203| 0.016
> Peak| | 0.0220| 0.421
> RxCan2[370] Avg| 0.85| 0.0140| 0.016
> Peak| | 0.0162| 0.354
> RxCan2[381] Avg| 3.15| 0.0512| 0.016
> Peak| | 0.0546| 0.416
> RxCan2[3a0] Avg| 15.60| 0.2548| 0.015
> Peak| | 0.2890| 0.976
> RxCan2[3d0] Avg| 9.35| 0.1553| 0.019
> Peak| | 0.1612| 1.115
> RxCan2[3d5] Avg| 5.15| 0.0836| 0.016
> Peak| | 0.0867| 0.479
> RxCan2[3e0] Avg| 0.00| 0.0000| 0.014
> Peak| | 0.0000| 0.142
> RxCan2[400] Avg| 3.55| 0.0613| 0.017
> Peak| | 0.0695| 0.501
> RxCan2[405] Avg| 3.50| 0.0584| 0.018
> Peak| | 0.0626| 0.686
> RxCan2[40a] Avg| 7.10| 0.1278| 0.017
> Peak| | 0.1389| 1.244
> RxCan2[415] Avg| 1.60| 0.0258| 0.014
> Peak| | 0.0287| 0.266
> RxCan2[435] Avg| 0.85| 0.0165| 0.019
> Peak| | 0.0167| 0.367
> RxCan2[440] Avg| 0.85| 0.0128| 0.019
> Peak| | 0.0141| 0.885
> RxCan2[465] Avg| 0.95| 0.0177| 0.016
> Peak| | 0.0195| 0.721
> RxCan2[466] Avg| 0.95| 0.0147| 0.014
> Peak| | 0.0160| 0.184
> RxCan2[467] Avg| 0.95| 0.0172| 0.017
> Peak| | 0.0188| 0.391
> RxCan2[501] Avg| 1.45| 0.0273| 0.016
> Peak| | 0.0327| 0.996
> RxCan2[503] Avg| 1.45| 0.0288| 0.020
> Peak| | 0.0338| 0.970
> RxCan2[504] Avg| 1.40| 0.0241| 0.015
> Peak| | 0.0263| 0.609
> RxCan2[505] Avg| 1.40| 0.0255| 0.015
> Peak| | 0.0296| 0.866
> RxCan2[508] Avg| 1.35| 0.0237| 0.017
> Peak| | 0.0237| 0.384
> RxCan2[511] Avg| 1.35| 0.0226| 0.016
> Peak| | 0.0228| 0.426
> RxCan2[51e] Avg| 1.40| 0.0221| 0.014
> Peak| | 0.0245| 0.211
> RxCan2[581] Avg| 0.80| 0.0189| 0.019
> Peak| | 0.0290| 1.217
> RxCan2[606] Avg| 0.00| 0.0000| 0.014
> RxCan2[657] Avg| 0.00| 0.0000| 0.014
> Peak| | 0.0000| 0.137
> Cmd:State Avg| 0.00| 0.0000| 0.002
> Peak| | 0.0000| 0.024
> Total Avg| 2748.42| 58.3344| 28.718
> @Simon: it would be an option to try commenting out the overflow counting,
> to see if that's causing the issue.
> I have commented out the line with the Atomic_Increment statement. Now I
> no longer receive any messages with “RX Task Queue Overflow Run”
> Here is the output of poller times status:
> OVMS# poll time status
> | per s | [%] | [ms]
> Poll:PRI Avg| 1.00| 0.0045| 0.004
> Peak| | 0.0046| 0.064
> RxCan1[010] Avg| 34.26| 2.2574| 0.021
> Peak| | 2.2574| 4.609
> RxCan1[030] Avg| 34.26| 2.3820| 0.021
> Peak| | 2.3820| 1.135
> RxCan1[041] Avg| 49.89| 1.2059| 0.021
> Peak| | 1.2295| 5.331
> RxCan1[049] Avg| 49.96| 1.2400| 0.030
> Peak| | 1.2699| 1.402
> RxCan1[04c] Avg| 49.92| 1.1752| 0.021
> Peak| | 1.2072| 4.502
> RxCan1[04d] Avg| 34.31| 2.4433| 0.022
> Peak| | 2.4773| 1.368
> RxCan1[076] Avg| 49.96| 1.2071| 0.024
> Peak| | 1.2554| 2.007
> RxCan1[077] Avg| 49.96| 1.2012| 0.022
> Peak| | 1.2492| 1.955
> RxCan1[07a] Avg| 34.35| 2.9251| 0.030
> Peak| | 3.1103| 1.829
> RxCan1[07d] Avg| 49.96| 1.1954| 0.022
> Peak| | 1.2282| 1.074
> RxCan1[0c8] Avg| 49.89| 1.2491| 0.021
> Peak| | 1.3169| 1.181
> RxCan1[11a] Avg| 34.39| 2.4423| 0.024
> Peak| | 2.5693| 1.491
> RxCan1[130] Avg| 49.95| 1.1312| 0.020
> Peak| | 1.1684| 1.218
> RxCan1[139] Avg| 49.92| 1.1547| 0.021
> Peak| | 1.1778| 1.199
> RxCan1[156] Avg| 9.96| 0.2391| 0.023
> Peak| | 0.2591| 1.943
> RxCan1[160] Avg| 49.96| 1.1657| 0.031
> Peak| | 1.2017| 2.158
> RxCan1[165] Avg| 49.96| 1.1257| 0.021
> Peak| | 1.1652| 1.471
> RxCan1[167] Avg| 34.31| 2.2871| 0.021
> Peak| | 2.3374| 1.776
> RxCan1[171] Avg| 49.96| 1.1879| 0.023
> Peak| | 1.2268| 1.166
> RxCan1[178] Avg| 10.00| 0.2371| 0.029
> Peak| | 0.2459| 1.516
> RxCan1[179] Avg| 10.00| 0.2196| 0.021
> Peak| | 0.2260| 0.758
> RxCan1[180] Avg| 49.96| 1.1703| 0.022
> Peak| | 1.2103| 1.481
> RxCan1[185] Avg| 49.95| 1.1127| 0.020
> Peak| | 1.1636| 1.292
> RxCan1[1a0] Avg| 49.96| 1.1009| 0.020
> Peak| | 1.1468| 1.060
> RxCan1[1e0] Avg| 49.96| 1.1744| 0.021
> Peak| | 1.2027| 1.240
> RxCan1[1e4] Avg| 49.96| 1.3733| 0.032
> Peak| | 1.4085| 1.523
> RxCan1[1f0] Avg| 33.30| 0.7625| 0.023
> Peak| | 0.8004| 3.349
> RxCan1[200] Avg| 49.92| 1.1462| 0.021
> Peak| | 1.1809| 1.254
> RxCan1[202] Avg| 34.39| 2.4034| 0.028
> Peak| | 2.5611| 1.472
> RxCan1[204] Avg| 34.30| 2.2541| 0.022
> Peak| | 2.2924| 2.015
> RxCan1[213] Avg| 49.96| 1.1599| 0.027
> Peak| | 1.1794| 1.714
> RxCan1[214] Avg| 49.96| 1.1537| 0.022
> Peak| | 1.1941| 1.439
> RxCan1[217] Avg| 34.39| 2.2490| 0.020
> Peak| | 2.2856| 3.766
> RxCan1[218] Avg| 49.96| 1.1291| 0.021
> Peak| | 1.1646| 1.547
> RxCan1[230] Avg| 49.96| 1.1272| 0.020
> Peak| | 1.2237| 1.295
> RxCan1[240] Avg| 10.00| 0.2191| 0.021
> Peak| | 0.2226| 1.067
> RxCan1[242] Avg| 24.96| 0.6911| 0.024
> Peak| | 0.7161| 1.180
> RxCan1[24a] Avg| 9.96| 0.2345| 0.024
> Peak| | 0.2535| 0.779
> RxCan1[24b] Avg| 9.96| 0.2433| 0.023
> Peak| | 0.2697| 2.085
> RxCan1[24c] Avg| 9.96| 0.3103| 0.029
> Peak| | 0.3203| 0.809
> RxCan1[25a] Avg| 10.00| 0.2346| 0.022
> Peak| | 0.2405| 1.223
> RxCan1[25b] Avg| 49.89| 1.2121| 0.020
> Peak| | 1.3659| 19.523
> RxCan1[25c] Avg| 34.31| 2.4193| 0.019
> Peak| | 2.8022| 58.153
> RxCan1[260] Avg| 9.93| 0.2149| 0.024
> Peak| | 0.2174| 1.096
> RxCan1[270] Avg| 49.96| 1.2042| 0.026
> Peak| | 1.2755| 20.612
> RxCan1[280] Avg| 49.96| 1.0922| 0.020
> Peak| | 1.1312| 1.266
> RxCan1[2e4] Avg| 19.96| 0.6942| 0.044
> Peak| | 0.8604| 1.533
> RxCan1[2ec] Avg| 10.00| 0.3727| 0.025
> Peak| | 0.5154| 28.819
> RxCan1[2ed] Avg| 10.00| 0.2298| 0.023
> Peak| | 0.2378| 1.345
> RxCan1[2ee] Avg| 9.96| 0.2172| 0.019
> Peak| | 0.2210| 1.058
> RxCan1[312] Avg| 10.00| 0.2206| 0.020
> Peak| | 0.2396| 1.060
> RxCan1[326] Avg| 9.96| 0.2099| 0.020
> Peak| | 0.2158| 0.507
> RxCan1[336] Avg| 1.00| 0.0212| 0.020
> Peak| | 0.0233| 0.315
> RxCan1[352] Avg| 6.64| 0.1675| 0.024
> Peak| | 0.1818| 1.048
> RxCan1[355] Avg| 2.00| 0.0540| 0.027
> Peak| | 0.0619| 1.209
> RxCan1[35e] Avg| 9.98| 0.2221| 0.021
> Peak| | 0.2284| 1.186
> RxCan1[365] Avg| 10.00| 0.2282| 0.023
> Peak| | 0.2335| 0.769
> RxCan1[366] Avg| 10.00| 0.3163| 0.022
> Peak| | 0.6330| 23.587
> RxCan1[367] Avg| 10.00| 0.2417| 0.021
> Peak| | 0.2568| 1.417
> RxCan1[368] Avg| 9.96| 0.2187| 0.019
> Peak| | 0.2250| 1.135
> RxCan1[369] Avg| 9.99| 0.2277| 0.021
> Peak| | 0.2334| 0.667
> RxCan1[380] Avg| 9.96| 0.2133| 0.020
> Peak| | 0.2161| 0.560
> RxCan1[38b] Avg| 24.92| 0.5622| 0.022
> Peak| | 0.5716| 1.618
> RxCan1[3b3] Avg| 10.00| 0.2132| 0.023
> Peak| | 0.2194| 1.106
> RxCan1[400] Avg| 4.00| 0.0885| 0.019
> Peak| | 0.0885| 0.570
> RxCan1[405] Avg| 3.70| 0.1414| 0.036
> Peak| | 0.1414| 0.710
> RxCan1[40a] Avg| 8.00| 0.1887| 0.021
> Peak| | 0.1887| 1.027
> RxCan1[410] Avg| 10.00| 0.2141| 0.023
> Peak| | 0.2188| 0.984
> RxCan1[411] Avg| 10.00| 0.2325| 0.023
> Peak| | 0.2447| 0.660
> RxCan1[416] Avg| 10.00| 0.2326| 0.022
> Peak| | 0.2389| 0.774
> RxCan1[421] Avg| 10.00| 0.2245| 0.021
> Peak| | 0.2271| 1.160
> RxCan1[42d] Avg| 10.00| 0.2315| 0.021
> Peak| | 0.2411| 0.677
> RxCan1[42f] Avg| 10.00| 0.2480| 0.020
> Peak| | 0.2975| 8.093
> RxCan1[430] Avg| 10.00| 0.2203| 0.019
> Peak| | 0.2302| 0.847
> RxCan1[434] Avg| 10.00| 0.2331| 0.019
> Peak| | 0.2620| 1.150
> RxCan1[435] Avg| 6.68| 0.1445| 0.020
> Peak| | 0.1486| 1.063
> RxCan1[43e] Avg| 20.00| 0.4515| 0.021
> Peak| | 0.4632| 1.013
> RxCan1[440] Avg| 1.00| 0.0210| 0.019
> Peak| | 0.0218| 0.294
> RxCan1[465] Avg| 0.95| 0.0214| 0.023
> Peak| | 0.0215| 0.587
> RxCan1[466] Avg| 0.95| 0.0211| 0.021
> Peak| | 0.0215| 0.350
> RxCan1[467] Avg| 0.95| 0.0191| 0.020
> Peak| | 0.0201| 0.444
> RxCan1[472] Avg| 0.68| 0.0588| 0.085
> Peak| | 0.0606| 1.170
> RxCan1[473] Avg| 0.66| 0.0407| 0.062
> Peak| | 0.0492| 1.329
> RxCan1[474] Avg| 1.00| 0.0218| 0.021
> Peak| | 0.0237| 0.278
> RxCan1[475] Avg| 1.96| 0.0466| 0.024
> Peak| | 0.0570| 1.112
> RxCan1[476] Avg| 2.00| 0.0454| 0.020
> Peak| | 0.0497| 0.409
> RxCan1[477] Avg| 2.00| 0.0497| 0.022
> Peak| | 0.0595| 0.864
> RxCan1[595] Avg| 1.00| 0.0223| 0.021
> Peak| | 0.0241| 0.296
> RxCan1[59e] Avg| 1.00| 0.0233| 0.024
> Peak| | 0.0289| 0.713
> RxCan1[5a2] Avg| 1.00| 0.0200| 0.020
> Peak| | 0.0204| 0.264
> RxCan1[5ba] Avg| 1.00| 0.0206| 0.021
> Peak| | 0.0238| 0.515
> RxCan2[020] Avg| 33.30| 0.7938| 0.022
> Peak| | 0.7938| 4.793
> RxCan2[030] Avg| 22.20| 0.5229| 0.022
> Peak| | 0.5229| 0.985
> RxCan2[03a] Avg| 19.90| 0.4700| 0.022
> Peak| | 0.4700| 0.804
> RxCan2[040] Avg| 19.90| 0.4678| 0.023
> Peak| | 0.4678| 1.222
> RxCan2[060] Avg| 20.00| 0.6480| 0.050
> Peak| | 0.6480| 20.997
> RxCan2[070] Avg| 16.60| 0.3944| 0.022
> Peak| | 0.3944| 1.053
> RxCan2[080] Avg| 16.70| 0.7032| 0.041
> Peak| | 0.7032| 1.611
> RxCan2[083] Avg| 20.10| 0.4329| 0.021
> Peak| | 0.4329| 0.520
> RxCan2[090] Avg| 24.90| 0.5674| 0.017
> Peak| | 0.5674| 1.149
> RxCan2[0a0] Avg| 16.60| 0.3836| 0.023
> Peak| | 0.3836| 0.933
> RxCan2[100] Avg| 16.50| 0.3661| 0.021
> Peak| | 0.3661| 0.740
> RxCan2[108] Avg| 24.90| 0.5923| 0.025
> Peak| | 0.5923| 0.859
> RxCan2[110] Avg| 16.70| 0.3906| 0.023
> Peak| | 0.3906| 0.697
> RxCan2[130] Avg| 14.40| 0.3341| 0.022
> Peak| | 0.3341| 0.829
> RxCan2[150] Avg| 16.50| 0.4025| 0.020
> Peak| | 0.4025| 1.120
> RxCan2[160] Avg| 4.90| 0.1252| 0.025
> Peak| | 0.1252| 0.502
> RxCan2[180] Avg| 16.60| 0.3899| 0.023
> Peak| | 0.3899| 0.799
> RxCan2[190] Avg| 16.60| 0.3892| 0.025
> Peak| | 0.3892| 1.172
> RxCan2[1a0] Avg| 1.00| 0.0281| 0.025
> Peak| | 0.0281| 0.695
> RxCan2[1a4] Avg| 20.00| 0.4525| 0.022
> Peak| | 0.4525| 1.231
> RxCan2[1a8] Avg| 12.50| 0.2886| 0.020
> Peak| | 0.2886| 1.048
> RxCan2[1b0] Avg| 10.00| 0.2300| 0.023
> Peak| | 0.2300| 0.579
> RxCan2[1b4] Avg| 10.00| 0.2334| 0.022
> Peak| | 0.2334| 0.947
> RxCan2[1b8] Avg| 12.40| 0.2970| 0.023
> Peak| | 0.2970| 0.909
> RxCan2[1c0] Avg| 10.00| 0.2257| 0.021
> Peak| | 0.2257| 0.983
> RxCan2[1e0] Avg| 10.00| 0.2141| 0.023
> Peak| | 0.2141| 0.556
> RxCan2[215] Avg| 8.30| 0.2047| 0.025
> Peak| | 0.2047| 0.786
> RxCan2[217] Avg| 8.30| 0.2033| 0.022
> Peak| | 0.2033| 1.135
> RxCan2[220] Avg| 6.70| 0.1647| 0.020
> Peak| | 0.1647| 0.961
> RxCan2[225] Avg| 24.90| 0.6136| 0.026
> Peak| | 0.6136| 1.018
> RxCan2[230] Avg| 6.70| 0.4045| 0.057
> Peak| | 0.4045| 1.532
> RxCan2[240] Avg| 8.20| 0.1849| 0.021
> Peak| | 0.1849| 0.510
> RxCan2[241] Avg| 20.00| 0.4312| 0.021
> Peak| | 0.4312| 5.110
> RxCan2[250] Avg| 5.00| 0.1072| 0.021
> Peak| | 0.1072| 0.320
> RxCan2[255] Avg| 12.50| 0.3091| 0.022
> Peak| | 0.3091| 0.904
> RxCan2[265] Avg| 12.50| 0.2819| 0.021
> Peak| | 0.2819| 1.035
> RxCan2[270] Avg| 5.00| 0.1189| 0.022
> Peak| | 0.1189| 0.631
> RxCan2[290] Avg| 3.30| 0.0740| 0.023
> Peak| | 0.0740| 0.455
> RxCan2[295] Avg| 6.60| 0.1431| 0.023
> Peak| | 0.1431| 0.504
> RxCan2[2a0] Avg| 3.30| 0.0686| 0.020
> Peak| | 0.0686| 0.445
> RxCan2[2a7] Avg| 12.50| 0.2869| 0.021
> Peak| | 0.2869| 0.660
> RxCan2[2b0] Avg| 3.20| 0.0707| 0.023
> Peak| | 0.0707| 0.331
> RxCan2[2c0] Avg| 3.20| 0.0988| 0.026
> Peak| | 0.0988| 0.932
> RxCan2[2e0] Avg| 1.60| 0.0388| 0.024
> Peak| | 0.0388| 0.393
> RxCan2[2f0] Avg| 1.70| 0.0376| 0.021
> Peak| | 0.0376| 0.282
> RxCan2[2f5] Avg| 12.50| 0.2833| 0.021
> Peak| | 0.2833| 0.855
> RxCan2[300] Avg| 1.70| 0.0398| 0.023
> Peak| | 0.0398| 0.488
> RxCan2[310] Avg| 1.60| 0.0480| 0.026
> Peak| | 0.0480| 0.937
> RxCan2[320] Avg| 1.70| 0.0346| 0.020
> Peak| | 0.0346| 0.370
> RxCan2[326] Avg| 9.90| 0.2200| 0.022
> Peak| | 0.2200| 0.502
> RxCan2[330] Avg| 32.30| 0.7323| 0.021
> Peak| | 0.7323| 1.130
> RxCan2[340] Avg| 8.20| 0.2375| 0.028
> Peak| | 0.2375| 0.578
> RxCan2[345] Avg| 1.60| 0.0393| 0.022
> Peak| | 0.0393| 0.590
> RxCan2[35e] Avg| 5.00| 0.1303| 0.023
> Peak| | 0.1303| 0.943
> RxCan2[360] Avg| 1.70| 0.0381| 0.025
> Peak| | 0.0381| 0.922
> RxCan2[361] Avg| 8.20| 0.1907| 0.023
> Peak| | 0.1907| 1.119
> RxCan2[363] Avg| 1.30| 0.0337| 0.024
> Peak| | 0.0337| 0.425
> RxCan2[370] Avg| 0.90| 0.0194| 0.022
> Peak| | 0.0194| 0.246
> RxCan2[381] Avg| 3.20| 0.0684| 0.024
> Peak| | 0.0684| 0.828
> RxCan2[3a0] Avg| 16.60| 0.3734| 0.022
> Peak| | 0.3734| 0.636
> RxCan2[3d0] Avg| 10.00| 0.2262| 0.023
> Peak| | 0.2262| 0.663
> RxCan2[3d5] Avg| 5.60| 0.1335| 0.022
> Peak| | 0.1335| 1.222
> RxCan2[400] Avg| 4.00| 0.0949| 0.022
> Peak| | 0.0949| 0.715
> RxCan2[405] Avg| 3.70| 0.0861| 0.022
> Peak| | 0.0861| 0.443
> RxCan2[40a] Avg| 8.00| 0.1853| 0.021
> Peak| | 0.1853| 0.552
> RxCan2[415] Avg| 1.60| 0.0341| 0.021
> Peak| | 0.0341| 0.273
> RxCan2[435] Avg| 0.90| 0.0220| 0.025
> Peak| | 0.0220| 0.354
> RxCan2[440] Avg| 0.90| 0.0199| 0.021
> Peak| | 0.0199| 0.266
> RxCan2[465] Avg| 0.90| 0.0234| 0.028
> Peak| | 0.0234| 0.633
> RxCan2[466] Avg| 1.00| 0.0222| 0.021
> Peak| | 0.0222| 0.322
> RxCan2[467] Avg| 1.00| 0.0221| 0.020
> Peak| | 0.0221| 0.355
> RxCan2[501] Avg| 1.50| 0.0335| 0.023
> Peak| | 0.0335| 0.393
> RxCan2[503] Avg| 1.50| 0.0370| 0.022
> Peak| | 0.0370| 0.546
> RxCan2[504] Avg| 1.40| 0.0328| 0.022
> Peak| | 0.0328| 0.489
> RxCan2[505] Avg| 1.40| 0.0290| 0.021
> Peak| | 0.0290| 0.354
> RxCan2[508] Avg| 1.40| 0.0318| 0.023
> Peak| | 0.0318| 0.408
> RxCan2[511] Avg| 1.40| 0.0306| 0.022
> Peak| | 0.0306| 0.328
> RxCan2[51e] Avg| 1.40| 0.0310| 0.022
> Peak| | 0.0310| 0.269
> RxCan2[581] Avg| 1.00| 0.0222| 0.022
> Peak| | 0.0222| 0.256
> Total Avg| 2795.57| 82.7745| 40.174
> Cheers,
> Simon
> Am 17.01.2025 um 17:49 schrieb Michael Balzer via OvmsDev:
> OK, I've got a new idea: CAN timing.
> Comparing our esp32can bit timing to the esp-idf driver's, there seem to
> be some differences:
> https://github.com/espressif/esp-idf/blob/master/components/hal/include/hal/twai_types_deprecated.h#L75
> Transceivers are normally tolerant to small timing offsets. Maybe being
> off a little bit has no effect under normal conditions, but it has when the
> transceiver has to cope with a filled RX queue. That could be causing the
> transceiver to slide just out of sync. If the timing gets garbled, the
> transceiver would signal errors in the packets to the bus, possibly so many
> the vehicle ECUs decide to raise an error condition.
> Is that plausible?
> On why the new poller could be causing this (in combination with too slow
> processing by the vehicle): as mentioned, the standard CAN listener
> mechanism doesn't care about queue overflows. The poller does.
> `OvmsPollers::Queue_PollerFrame()` does a log call when Tx/Rx tracing is
> enabled, that could even block, but tracing is optional and only meant for
> debugging. Not optional is the overflow counting using an atomic uint32.
> The atomic types are said to be fast, but I never checked their actual
> implementation on the ESP32. Maybe they can block as well?
> Am 17.01.25 um 15:37 schrieb Chris Box via OvmsDev:
> Yes, I can confirm I've had one experience of the Leaf switching to
> Neutral while driving, with a yellow warning symbol on the dash. It refused
> to reselect Drive until I had switched the car off and back on. Derek
> wasn't so lucky and he need to clear fault codes before the car would work.
> On returning home, I found OVMS was not accessible over a network. I
> didn't try a USB cable. Unplugging and reinserting the OBD cable caused
> OVMS to rejoin Wi-Fi. However the SD logs showed nothing from the time of
> the event. CAN writes are enabled, so it can perform SOC limiting.
> My car has been using this firmware since 21st November, based on the git
> master of that day. As a relatively new user of OVMS (only since October) I
> don't have much experience of older firmware.
> Perhaps a safeguard should be implemented before releasing a new stable
> firmware that will be automatically downloaded by Leaf owners. But I don't
> have the expertise to know what that safeguard should be. Derek's
> suggestion of 'only CAN write when parked' appears to be a good idea.
> Chris
> On 2025-01-15 18:18, Derek Caudwell via OvmsDev wrote:
> Since the following email I have high confidence the issue on the Leaf is
> related/caused by the poller as there has been no further occurrence and
> Chris has also experienced the car going to neutral on the new poller
> firmware.
> I haven't ruled out it being a fault with my car yet. Shortly after it
> faulted the car was run into so has been off the road for sometime, my
> first step was to replace 12V battery. The ovms unit is now unplugged and
> if it does not fault over the next month while driving I'll be reasonably
> confident it's ovms related.
> Not sure which firmware version the poller updates were included in but it
> was only after upgrading to it that the errors occurred (which could be
> coincidental however it has faulted twice more both on version
> 3.3.004-141-gf729d82c). For periods where I reverted to 3.3.003 it was fine.
> It might be useful to have an extra option on the enable can write to only
> enable it when the car is parked/charging.
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke <https://www.google.com/maps/search/Am+Rahmen+5+*+D-58313+Herdecke?entry=gmail&source=g>
> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250118/d16ab36f/attachment-0001.htm>
