    Michael Geddes
    Sat Jan 18 09:42:34 HKT 2025
Ok, a few thoughts on various things.
if m_poll.entry.txmoduleid  is 0, or the incoming moduleid doesn't match
the min/max range (it should be 0 because no polls were done), then it
won't call the ISOTP (or VWTP) protocol response code.. so afaict it
shouldn't be sending anything.
Maybe try setting CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE = 160   and see if
that reduces the overflow?  Though really it shouldn't alter what is
happening - though may it will confirm if the atomic commands are an issue
- though I would have thought they would be much, much less overhead than a
critical section!!??  The overflow should be more a pressure relief valve
than anything. The log itself is on the Info level of vehicle-poll  but
unless somehow the logs are part of the problem.
 it would make sense to move the task queue overflow check down a bit into
the switch for
case OvmsPoller::OvmsPollEntryType::Poll:
This would make sense as currently it will be checking it for every message.
 I was thinking that the frame filter would be here:
void OvmsPollers::PollerRxCallback(const CAN_frame_t* frame, bool success)
  Queue_PollerFrame(*frame, success, false);
which I guess is executed in  the task handling the CAN queue.  (we don't
know how many frames get dropped there).
The only real concern is thread safety between checking and adding to the
filter - so the check itself might have to be mutexed.
  // Check filter
  OvmsRecMutexLock lock(&m_filter_mutex);
    if (! m_filter->IsFiltered(frame))
      return;
//.ichael
On Wed, 15 Jan 2025 at 14:15, Simon Ehlen via OvmsDev <
> Thanks Mark for the explanation.
> So does this mean that OVMS tries to acknowledge all incoming messages in
> active mode?
> This seems to me to clearly exceed the capacity of OVMS with the mass of
> incoming messages.
> In fact, I am currently opening the bus in active mode, as I was hoping to
> get my code to revive the BMS in OVMS to work.
> However, unlike the other data, I only get the cell voltages when I
> actively poll them.
> To be on the safe side, I will now open the bus in read mode again.
> However, I am still wondering what in the poller change has altered the
> OVMS in such a way that the bus is now crashing completely.
> Currently I have undone the changes since february 2024, this only
> concerns code from the public repository, there was no change from me in
> that period.
> Now the OVMS is running stable again and there are neither queue overflows
> nor bus crashes.
> I had also previously increased the following queue sizes, but
> unfortunately this was not successful:
> CONFIG_OVMS_HW_EVENT_QUEUE_SIZE=120
> CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=80
> CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=80
> Cheers,
> Simon
> Am 15.01.2025 um 02:08 schrieb Mark Webb-Johnson:
> Note sure if this helps, but some comments:
>    - Remember than CAN protocol in normal mode is an ‘active’ protocol.
>    Nodes on the bus are actively acknowledging messages (and that includes
>    OVMS), even if they never write messages. So in normal mode there is no
>    absolute ‘read access’. For example, opening the CAN port at the wrong baud
>    rate, even if not writing messages, will mess up the bus.
>    - However, if you open the CAN port in ‘listen’ mode, then it is truly
>    read-only. In that mode it will not acknowledge messages, and cannot write
>    on the bus at all. I’ve never seen an OVMS mess up a bus in listen mode,
>    even if the baud rate is wrong. I think the only way for that to happen
>    would be a hardware layer issue (cabling, termination, etc).
> On 15 Jan 2025, at 6:30 AM, Simon Ehlen via OvmsDev
> <ovmsdev at lists.openvehicles.com> <ovmsdev at lists.openvehicles.com> wrote:
> But what is the reason that a read access to the bus can cause the bus to
> crash?
> This is not critical during charging, it just aborts the charging process
> with an error.
> While driving, this results in a “stop safely now” error message on the
> dashboard and the engine is switched off immediately.
> Cheers,
> Simon
> Am 14.01.2025 um 23:22 schrieb Michael Geddes via OvmsDev:
> You may need to increase  the queue size for the poll task queue.
> The poller still handles the bus to vehicle notifications even if it is
> off.
> Any poller logging on such an intensive load of can messages is likely to
> be a problem.  This is part of the reason it is flagged off.
> The total % looks wrong :/
> //.ichael
> On Wed, 15 Jan 2025, 03:17 Simon Ehlen via OvmsDev, <
>> Hi,
>> I finally got around to merging my code with the current master (previous
>> merge february 2024).
>> I have rebuilt my code for a Ford Focus Electric so that it uses the new
>> OvmsPoller class.
>> However, I now see a lot of entries like this in my log:
>> I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 8
>> I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 3
>> I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>> I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 2
>> I (254448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 24
>> I (254448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>> Was this message just hidden before or do I need to make further
>> adjustments to my code?
>> My code currently does not use active polling but reads on the busses
>> (IncomingFrameCanX) on certain modules.
>> When I look at poller times status, it looks very extensive to me...
>> OVMS# poller times status
>> Poller timing is: on
>> Type           | count  | Utlztn | Time
>>                 | per s  | [%]    | [ms]
>> Poll:PRI    Avg|    0.00|  0.0000|    0.003
>>             Peak|        |  0.0014|    0.041
>> RxCan1[010] Avg|    0.00|  0.0000|    0.020
>>             Peak|        |  1.2217|    1.089
>> RxCan1[030] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  1.2193|    1.241
>> RxCan1[041] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.6460|    1.508
>> RxCan1[049] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.6320|    0.630
>> RxCan1[04c] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.6430|    1.474
>> RxCan1[04d] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  1.2987|    1.359
>> RxCan1[076] Avg|    0.00|  0.0000|    0.072
>>             Peak|        |  0.7818|   15.221
>> RxCan1[077] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.6274|    0.955
>> RxCan1[07a] Avg|    0.00|  0.0000|    0.039
>>             Peak|        |  1.7602|    1.684
>> RxCan1[07d] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.6621|    1.913
>> RxCan1[0c8] Avg|    0.00|  0.0000|    0.026
>>             Peak|        |  0.6292|    1.412
>> RxCan1[11a] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  1.2635|    1.508
>> RxCan1[130] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.6548|    0.703
>> RxCan1[139] Avg|    0.00|  0.0000|    0.021
>>             Peak|        |  0.6002|    0.984
>> RxCan1[156] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.1225|    0.479
>> RxCan1[160] Avg|    0.00|  0.0000|    0.028
>>             Peak|        |  0.6586|    1.376
>> RxCan1[165] Avg|    0.00|  0.0000|    0.027
>>             Peak|        |  0.6368|    1.132
>> RxCan1[167] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  1.3009|    1.067
>> RxCan1[171] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.6590|    4.320
>> RxCan1[178] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.1161|    0.311
>> RxCan1[179] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.1236|    0.536
>> RxCan1[180] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.6472|    1.193
>> RxCan1[185] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.6777|    1.385
>> RxCan1[1a0] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.6486|    2.276
>> RxCan1[1e0] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.6725|    1.376
>> RxCan1[1e4] Avg|    0.00|  0.0000|    0.027
>>             Peak|        |  0.7370|    1.266
>> RxCan1[1f0] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.4253|    0.753
>> RxCan1[200] Avg|    0.00|  0.0000|    0.025
>>             Peak|        |  0.6262|    0.791
>> RxCan1[202] Avg|    0.00|  0.0000|    0.021
>>             Peak|        |  1.2915|    1.257
>> RxCan1[204] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  1.2620|    1.010
>> RxCan1[213] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.6331|    1.185
>> RxCan1[214] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.9977|   34.527
>> RxCan1[217] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  1.2825|    1.328
>> RxCan1[218] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.6328|    1.110
>> RxCan1[230] Avg|    0.00|  0.0000|    0.019
>>             Peak|        |  0.6742|    5.119
>> RxCan1[240] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.1163|    0.343
>> RxCan1[242] Avg|    0.00|  0.0000|    0.025
>>             Peak|        |  0.3501|    1.015
>> RxCan1[24a] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.1212|    0.338
>> RxCan1[24b] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.1289|    0.330
>> RxCan1[24c] Avg|    0.00|  0.0000|    0.033
>>             Peak|        |  0.1714|    1.189
>> RxCan1[25a] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.1289|    0.510
>> RxCan1[25b] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.6685|    0.930
>> RxCan1[25c] Avg|    0.00|  0.0000|    0.027
>>             Peak|        |  1.3298|    2.670
>> RxCan1[260] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.1271|    0.401
>> RxCan1[270] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.6439|    0.898
>> RxCan1[280] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.6502|    1.156
>> RxCan1[2e4] Avg|    0.00|  0.0000|    0.035
>>             Peak|        |  0.3389|    0.811
>> RxCan1[2ec] Avg|    0.00|  0.0000|    0.027
>>             Peak|        |  0.1417|    0.784
>> RxCan1[2ed] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.1364|    0.746
>> RxCan1[2ee] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.1406|    0.965
>> RxCan1[312] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.1293|    0.978
>> RxCan1[326] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.1298|    0.518
>> RxCan1[336] Avg|    0.00|  0.0000|    0.028
>>             Peak|        |  0.0106|    0.329
>> RxCan1[352] Avg|    0.00|  0.0000|    0.030
>>             Peak|        |  0.1054|    0.800
>> RxCan1[355] Avg|    0.00|  0.0000|    0.027
>>             Peak|        |  0.0270|    0.546
>> RxCan1[35e] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.1288|    0.573
>> RxCan1[365] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.1297|    0.358
>> RxCan1[366] Avg|    0.00|  0.0000|    0.026
>>             Peak|        |  0.1429|    1.001
>> RxCan1[367] Avg|    0.00|  0.0000|    0.026
>>             Peak|        |  0.1472|    0.828
>> RxCan1[368] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.1323|    0.931
>> RxCan1[369] Avg|    0.00|  0.0000|    0.026
>>             Peak|        |  0.1498|    1.072
>> RxCan1[380] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.1285|    0.348
>> RxCan1[38b] Avg|    0.00|  0.0000|    0.021
>>             Peak|        |  0.3298|    1.168
>> RxCan1[3b3] Avg|    0.00|  0.0000|    0.025
>>             Peak|        |  0.1348|    0.920
>> RxCan1[400] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.0481|    0.445
>> RxCan1[405] Avg|    0.00|  0.0000|    0.034
>>             Peak|        |  0.0723|    0.473
>> RxCan1[40a] Avg|    0.00|  0.0000|    0.025
>>             Peak|        |  0.1040|    0.543
>> RxCan1[410] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.1339|    0.678
>> RxCan1[411] Avg|    0.00|  0.0000|    0.025
>>             Peak|        |  0.1376|    0.573
>> RxCan1[416] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.1284|    0.346
>> RxCan1[421] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.1323|    0.643
>> RxCan1[42d] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.1362|    1.146
>> RxCan1[42f] Avg|    0.00|  0.0000|    0.027
>>             Peak|        |  0.1503|    1.762
>> RxCan1[430] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.1352|    0.347
>> RxCan1[434] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.1312|    0.580
>> RxCan1[435] Avg|    0.00|  0.0000|    0.029
>>             Peak|        |  0.1109|    1.133
>> RxCan1[43e] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.2776|    0.686
>> RxCan1[440] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.0118|    0.276
>> RxCan1[465] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.0118|    0.279
>> RxCan1[466] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0123|    0.310
>> RxCan1[467] Avg|    0.00|  0.0000|    0.025
>>             Peak|        |  0.0132|    0.314
>> RxCan1[472] Avg|    0.00|  0.0000|    0.101
>>             Peak|        |  0.0307|    1.105
>> RxCan1[473] Avg|    0.00|  0.0000|    0.051
>>             Peak|        |  0.0107|    0.575
>> RxCan1[474] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.0097|    0.289
>> RxCan1[475] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0220|    0.327
>> RxCan1[476] Avg|    0.00|  0.0000|    0.050
>>             Peak|        |  0.0762|    5.329
>> RxCan1[477] Avg|    0.00|  0.0000|    0.032
>>             Peak|        |  0.0283|    0.669
>> RxCan1[595] Avg|    0.00|  0.0000|    0.026
>>             Peak|        |  0.0103|    0.297
>> RxCan1[59e] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.0114|    0.263
>> RxCan1[5a2] Avg|    0.00|  0.0000|    0.026
>>             Peak|        |  0.0119|    0.505
>> RxCan1[5ba] Avg|    0.00|  0.0000|    0.025
>>             Peak|        |  0.0139|    0.549
>> RxCan2[020] Avg|    0.00|  0.0000|    0.026
>>             Peak|        |  0.4923|    1.133
>> RxCan2[030] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.3297|    1.136
>> RxCan2[03a] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.2792|    1.275
>> RxCan2[040] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.2834|    1.080
>> RxCan2[060] Avg|    0.00|  0.0000|    0.029
>>             Peak|        |  0.3037|    0.991
>> RxCan2[070] Avg|    0.00|  0.0000|    0.025
>>             Peak|        |  0.2291|    0.460
>> RxCan2[080] Avg|    0.00|  0.0000|    0.043
>>             Peak|        |  0.4015|    1.007
>> RxCan2[083] Avg|    0.00|  0.0000|    0.026
>>             Peak|        |  0.2957|    0.788
>> RxCan2[090] Avg|    0.00|  0.0000|    0.027
>>             Peak|        |  0.3951|    1.231
>> RxCan2[0a0] Avg|    0.00|  0.0000|    0.026
>>             Peak|        |  0.2560|    0.722
>> RxCan2[100] Avg|    0.00|  0.0000|    0.046
>>             Peak|        |  0.4506|   21.961
>> RxCan2[108] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.3713|    1.125
>> RxCan2[110] Avg|    0.00|  0.0000|    0.029
>>             Peak|        |  0.2443|    0.755
>> RxCan2[130] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.2052|    1.097
>> RxCan2[150] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.2246|    0.371
>> RxCan2[160] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.0755|    1.125
>> RxCan2[180] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.2350|    0.936
>> RxCan2[190] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.2275|    0.592
>> RxCan2[1a0] Avg|    0.00|  0.0000|    0.025
>>             Peak|        |  0.0125|    0.273
>> RxCan2[1a4] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.2806|    0.632
>> RxCan2[1a8] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.1683|    0.740
>> RxCan2[1b0] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.1360|    0.490
>> RxCan2[1b4] Avg|    0.00|  0.0000|    0.027
>>             Peak|        |  0.1556|    1.119
>> RxCan2[1b8] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.1704|    0.616
>> RxCan2[1c0] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.1317|    0.488
>> RxCan2[1e0] Avg|    0.00|  0.0000|    0.025
>>             Peak|        |  0.1460|    0.675
>> RxCan2[215] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.1191|    0.567
>> RxCan2[217] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.1167|    0.869
>> RxCan2[220] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0918|    0.313
>> RxCan2[225] Avg|    0.00|  0.0000|    0.025
>>             Peak|        |  0.3635|    1.018
>> RxCan2[230] Avg|    0.00|  0.0000|    0.057
>>             Peak|        |  0.2192|    1.063
>> RxCan2[240] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.1173|    0.760
>> RxCan2[241] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.2830|    1.144
>> RxCan2[250] Avg|    0.00|  0.0000|    0.026
>>             Peak|        |  0.0701|    0.698
>> RxCan2[255] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.1755|    1.063
>> RxCan2[265] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.1771|    0.729
>> RxCan2[270] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0667|    0.307
>> RxCan2[290] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.0410|    0.280
>> RxCan2[295] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0881|    0.299
>> RxCan2[2a0] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0420|    0.268
>> RxCan2[2a7] Avg|    0.00|  0.0000|    0.021
>>             Peak|        |  0.1716|    0.454
>> RxCan2[2b0] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0424|    0.300
>> RxCan2[2c0] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.0470|    0.298
>> RxCan2[2e0] Avg|    0.00|  0.0000|    0.030
>>             Peak|        |  0.0324|    1.152
>> RxCan2[2f0] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.0229|    0.359
>> RxCan2[2f5] Avg|    0.00|  0.0000|    0.026
>>             Peak|        |  0.1882|    0.673
>> RxCan2[300] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.0186|    0.263
>> RxCan2[310] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.0210|    0.265
>> RxCan2[320] Avg|    0.00|  0.0000|    0.025
>>             Peak|        |  0.0207|    0.354
>> RxCan2[326] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.1466|    0.686
>> RxCan2[330] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.4580|    0.708
>> RxCan2[340] Avg|    0.00|  0.0000|    0.031
>>             Peak|        |  0.1621|    0.785
>> RxCan2[345] Avg|    0.00|  0.0000|    0.021
>>             Peak|        |  0.0199|    0.261
>> RxCan2[35e] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0686|    0.449
>> RxCan2[360] Avg|    0.00|  0.0000|    0.025
>>             Peak|        |  0.0204|    0.289
>> RxCan2[361] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.1166|    0.316
>> RxCan2[363] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0146|    0.304
>> RxCan2[370] Avg|    0.00|  0.0000|    0.024
>>             Peak|        |  0.0099|    0.278
>> RxCan2[381] Avg|    0.00|  0.0000|    0.025
>>             Peak|        |  0.0468|    0.459
>> RxCan2[3a0] Avg|    0.00|  0.0000|    0.021
>>             Peak|        |  0.2339|    0.617
>> RxCan2[3d0] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.1351|    0.351
>> RxCan2[3d5] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0796|    0.692
>> RxCan2[400] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0537|    0.307
>> RxCan2[405] Avg|    0.00|  0.0000|    0.021
>>             Peak|        |  0.0513|    0.303
>> RxCan2[40a] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.1099|    0.313
>> RxCan2[415] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.0204|    0.251
>> RxCan2[435] Avg|    0.00|  0.0000|    0.028
>>             Peak|        |  0.0113|    0.342
>> RxCan2[440] Avg|    0.00|  0.0000|    0.027
>>             Peak|        |  0.0110|    0.299
>> RxCan2[465] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0122|    0.295
>> RxCan2[466] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.0117|    0.267
>> RxCan2[467] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.0164|    0.325
>> RxCan2[501] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0236|    0.276
>> RxCan2[503] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0248|    0.349
>> RxCan2[504] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0230|    0.312
>> RxCan2[505] Avg|    0.00|  0.0000|    0.025
>>             Peak|        |  0.0256|    0.310
>> RxCan2[508] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0281|    0.329
>> RxCan2[511] Avg|    0.00|  0.0000|    0.022
>>             Peak|        |  0.0232|    0.282
>> RxCan2[51e] Avg|    0.00|  0.0000|    0.023
>>             Peak|        |  0.0248|    0.298
>> RxCan2[581] Avg|    0.00|  0.0000|    0.025
>>             Peak|        |  0.0166|    0.286
>>        Total Avg|    0.00|  0.0000|   43.563
>> At the same time, calling poller times on, poller times status causes the
>> bus to crash, although no polls are actively being sent at all.
>> Cheers,
>> Simon
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250118/aa505219/attachment-0001.htm>
