Sat Jan 18 00:02:42 HKT 2025
Michael,
we've got a sufficiently fast bus/ID filter class `canfilter`, used for
the can logging filters. Reusing that would also keep the syntax
identical. And I don't think it would be applied in the CAN task, the
frames still need to be queued, just optionally not be included in the
timing stats.
A quick & dirty test could be to exclude all IDs < 0x200 from the
statistics. IDs below 0x200 will normally be used for high frequency
process data frames. But that would hide processing issues with these…
…and @Simon, there are already two suspiciously long peak times for
frames in that range in your statistics:
Type           | count  | Utlztn | Time
                | per s  | [%]    | [ms]
RxCan1[076] Avg|    0.00|  0.0000|    0.072
            Peak|        |  0.7818|   15.221
RxCan2[100] Avg|    0.00|  0.0000|    0.046
            Peak|        |  0.4506|   21.961
I'd have a look at these first. Btw, can you provide timing stats for a
longer collection period (in listen mode)?
Am 17.01.25 um 14:51 schrieb Michael Geddes:
> Yep, pretty much
> Inline  below.
> Also I wonder if something is causing the module to sleep or reboot
> and the wakeup is sending that bus wakeup Frame Michael B was talking
> about.
> //.ichael
> On Fri, 17 Jan 2025, 18:09 Michael Balzer via OvmsDev,
> <ovmsdev at lists.openvehicles.com> wrote:
>     Simon,
>     AFAIK "Pollers[Send]" is the regular "next round" request for the
>     polling task, not a frame transmission.
> Yep exactly.
>     A TX attempt in listen mode would produce a warn level log entry
>     "Cannot write <busname> when not in ACTIVE mode" for tag
>     "esp32can" or "mcp2515".
>     With the old poller, you wouldn't have had any indication of a
>     queue overflow, so the new poller may help you to identify an
>     issue in your code.
>     You need to understand the new poller not only does polls, it's
>     now the main CAN receiver for the vehicle module. That's why your
>     poller time stats include all process data frames as well, not
>     only protocol frames.
>     The overflow means either your CAN processing is too slow to keep
>     up with the packets received, or some other task is hogging the
>     CPU. That would need to be a task with an equal or higher priority
>     as the vehicle task, which has priority level 10 -- only system &
>     networking tasks are above, so that's not likely. (You can check
>     the CPU usage with the "module tasks" command.)
> I wonder whether some kind of filter before queueing the Frame might
> work. It would have to be quick and simple as it would be executing in
> the CAN task I think.
>     That means you should check your standard frame processing
>     (`IncomingFrameCanX` callbacks) for potential delays and
>     processing complexity issues.
>     The poller statistics can help you track this down, but you need
>     to have at least 10 seconds of statistics, the more the better.
>     Rule of thumb: PRI average at 0.0/second means you don't have
>     enough data yet. (-- //.ichael, correct me if I'm wrong)
> It's either that or we are rounding badly.  I can check.
>>     At the same time, calling poller times on, poller times status
>>     causes the bus to crash
>     In any case that still doesn't explain how the poller could
>     possibly cause a CAN bus (!) crash without actually doing any
>     transmissions.
>     How does the CAN bus crash manifest?
>     Regards,
>     Michael
>     Am 15.01.25 um 19:54 schrieb Simon Ehlen via OvmsDev:
>>     I put the two buses back into listen mode and drove a short
>>     distance and charged the car. As I said, there is no active
>>     polling in my code. As expected, there is therefore no indication
>>     of a failed TX attempt in the console log.
>>     I only continue to see a lot of RX Task Queue Overflow messages
>>     in the log, which I did not have before.
>>     I also see a Pollers[Send]: Task Queue Overflow entry, but since
>>     I don't see any indication of “cannot write” on that, I'm not
>>     assuming that's a “real” send.
>>     I (19760210) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 5
>>     I (19764420) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 1
>>     Run 3
>>     Run 1
>>     I (19764740) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 1
>>     Run 1
>>     Run 1
>>     Run 1
>>     Run 1
>>     I (19764750) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 2
>>     Run 1
>>     Run 2
>>     I (19764870) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 1
>>     Run 2
>>     I (19765270) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 4
>>     Run 6
>>     I (19765610) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 3
>>     I (19765930) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 1
>>     Run 3
>>     Run 1
>>     I (19766260) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 50
>>     Run 48
>>     Run 27
>>     I (19766270) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 6
>>     Run 4
>>     E (19766280) can: can2: intr=4754831 rxpkt=4757493 txpkt=0
>>     errflags=0x22401c02 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0
>>     txdelay=0 txfail=0 wdgreset=1 errreset=0
>>     E (19766300) can: can2: intr=4754831 rxpkt=4757494 txpkt=0
>>     errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0
>>     I (19766300) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 7
>>     I (19766340) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 39
>>     I (19766350) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 32
>>     Run 17
>>     Run 3
>>     I (19766350) vehicle-poll: Pollers[Send]: Task Queue Overflow
>>     Run 1
>>     Run 1
>>     E (19766360) can: can2: intr=4754840 rxpkt=4757509 txpkt=0
>>     I (19766370) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 4
>>     E (19766370) can: can2: intr=4754840 rxpkt=4757510 txpkt=0
>>     I (19766430) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 30
>>     Run 36
>>     Run 26
>>     Run 4
>>     Run 3
>>     Run 2
>>     Run 1
>>     E (19766450) can: can2: intr=4754855 rxpkt=4757535 txpkt=0
>>     errflags=0x23001001 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0
>>     E (19766460) can: can2: intr=4754855 rxpkt=4757536 txpkt=0
>>     E (19766520) can: can2: intr=4754855 rxpkt=4757539 txpkt=0
>>     errflags=0x22001002 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0
>>     I (19766520) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 9
>>     Run 37
>>     Run 30
>>     Run 6
>>     Run 2
>>     Run 1
>>     Run 1
>>     Run 3
>>     I (19766530) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 1
>>     Run 1
>>     Run 1
>>     E (19766540) can: can2: intr=4754861 rxpkt=4757548 txpkt=0
>>     I (19766550) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 3
>>     E (19766560) can: can2: intr=4754861 rxpkt=4757552 txpkt=0
>>     E (19766610) can: can2: intr=4754861 rxpkt=4757553 txpkt=0
>>     I (19766610) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>     Run 4
>>     Run 5
>>     Run 33
>>     Run 34
>>     Run 12
>>     W (19767070) websocket: WebSocketHandler[0x3f8d79d8]: job queue
>>     overflow detected
>>     W (19767140) websocket: WebSocketHandler[0x3f8d79d8]: job queue
>>     overflow detected
>>     W (19767180) websocket: WebSocketHandler[0x3f8d79d8]: job queue
>>     overflow resolved, 1 drops
>>     W (19767260) websocket: WebSocketHandler[0x3f8d79d8]: job queue
>>     overflow detected
>>     W (19767310) websocket: WebSocketHandler[0x3f8d79d8]: job queue
>>     Cheers
>>     Simon
>>     Am 15.01.2025 um 19:18 schrieb Derek Caudwell via OvmsDev:
>>>     Since the following email I have high confidence the issue on
>>>     the Leaf is related/caused by the poller as there has been no
>>>     further occurrence and Chris has also experienced the car going
>>>     to neutral on the new poller firmware.
>>>     I haven't ruled out it being a fault with my car yet. Shortly
>>>     after it faulted the car was run into so has been off the road
>>>     for sometime, my first step was to replace 12V battery. The ovms
>>>     unit is now unplugged and if it does not fault over the next
>>>     month while driving I'll be reasonably confident it's ovms related.
>>>     Not sure which firmware version the poller updates were included
>>>     in but it was only after upgrading to it that the errors
>>>     occurred (which could be coincidental however it has faulted
>>>     twice more both on version 3.3.004-141-gf729d82c). For periods
>>>     where I reverted to 3.3.003 it was fine.
>>>     It might be useful to have an extra option on the enable can
>>>     write to only enable it when the car is parked/charging.
>>>     On Wed, 15 Jan 2025, 11:11 pm Michael Balzer via OvmsDev,
>>>         Derek, can you comment on this? Do you still have the issue
>>>         mentioned?
>>>         Speaking of the Leaf, the code there actually does something
>>>         fishy in `CommandWakeup()`:
>>>           unsigned char data = 0;
>>>           m_can1->WriteStandard(0x5C0, *_8_*, &data); //Wakes up the
>>>         VCM (by spoofing empty battery request heating)
>>>         And there are CAN transmissions from command execution in
>>>         the Leaf code, so to be sure there is no TX, listen mode is
>>>         needed there as well.
>>>         Regarding CAN trace, you can try with the monitor channel
>>>         and use the USB console to record the log output. That way
>>>         you should be able to at least rule out there are regular
>>>         transmissions -- assuming not every TX will cause an
>>>         immediate crash.
>>>         Another / probably better option: when in listen mode, the
>>>         log will also tell you about TX attempts, as the driver will
>>>         issue a warning on each.
>>>         The CAN monitor log may also tell you about bus errors detected.
>>>         Regards,
>>>         Michael
>>>         Am 15.01.25 um 10:44 schrieb Simon Ehlen via OvmsDev:
>>>>         There is at least one more Leaf from Derek that has also
>>>>         ended up in limp mode since the new poller.
>>>>         There, too, no polling was actually carried out while driving.
>>>>         I'm not familiar with the framework at all, but does this
>>>>         perhaps offer you enough of an approach to recognize a
>>>>         commonality?
>>>>         Unfortunately I do not have a tool to create a CAN trace.
>>>>         I can't use the OVMS for this, as it no longer responds
>>>>         after a bus crash until I have disconnected it from the OBD
>>>>         and plugged it back in.
>>>>         Cheers,
>>>>         Simon
>>>>         Am 15.01.2025 um 10:18 schrieb Michael Balzer via OvmsDev:
>>>>>         The frame acknowledging is done automatically by the CAN
>>>>>         transceiver when in active mode, this is part of the CAN
>>>>>         protocol to indicate bit errors to the sender.
>>>>>         So normally a failure of the system to process received
>>>>>         frames fast enough cannot cause any issue on the bus. But
>>>>>         the ESP32 has a range of known hardware issues, especially
>>>>>         in the embedded CAN transceiver, I wouldn't be surprised
>>>>>         if there are more, or if our driver lacks some workaround
>>>>>         for these.
>>>>>         Maybe the new poller has some bug that causes false
>>>>>         transmissions from process data frames received. But many
>>>>>         vehicles send process data frames, and we've had no issue
>>>>>         reports like this on any of them, and ECUs also normally
>>>>>         simply ignore out of sequence protocol frames.
>>>>>         You could record a CAN trace to see if there are
>>>>>         transmissions, and what kind. If you don't poll and don't
>>>>>         send frames from your code, there should be none. If the
>>>>>         bus still crashes, that would be an indicator for
>>>>>         something going wrong in the transceiver.
>>>>>         Regards,
>>>>>         Michael
>>>>>         Am 15.01.25 um 07:15 schrieb Simon Ehlen via OvmsDev:
>>>>>>         Thanks Mark for the explanation.
>>>>>>         So does this mean that OVMS tries to acknowledge all
>>>>>>         incoming messages in active mode?
>>>>>>         This seems to me to clearly exceed the capacity of OVMS
>>>>>>         with the mass of incoming messages.
>>>>>>         In fact, I am currently opening the bus in active mode,
>>>>>>         as I was hoping to get my code to revive the BMS in OVMS
>>>>>>         to work.
>>>>>>         However, unlike the other data, I only get the cell
>>>>>>         voltages when I actively poll them.
>>>>>>         To be on the safe side, I will now open the bus in read
>>>>>>         mode again.
>>>>>>         However, I am still wondering what in the poller change
>>>>>>         has altered the OVMS in such a way that the bus is now
>>>>>>         crashing completely.
>>>>>>         Currently I have undone the changes since february 2024,
>>>>>>         this only concerns code from the public repository, there
>>>>>>         was no change from me in that period.
>>>>>>         Now the OVMS is running stable again and there are
>>>>>>         neither queue overflows nor bus crashes.
>>>>>>         I had also previously increased the following queue
>>>>>>         sizes, but unfortunately this was not successful:
>>>>>>         CONFIG_OVMS_HW_EVENT_QUEUE_SIZE=120
>>>>>>         CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=80
>>>>>>         CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=80
>>>>>>         Cheers,
>>>>>>         Simon
>>>>>>         Am 15.01.2025 um 02:08 schrieb Mark Webb-Johnson:
>>>>>>>         Note sure if this helps, but some comments:
>>>>>>>           * Remember than CAN protocol in normal mode is an
>>>>>>>             ‘active’ protocol. Nodes on the bus are actively
>>>>>>>             acknowledging messages (and that includes OVMS),
>>>>>>>             even if they never write messages. So in normal mode
>>>>>>>             there is no absolute ‘read access’. For example,
>>>>>>>             opening the CAN port at the wrong baud rate, even if
>>>>>>>             not writing messages, will mess up the bus.
>>>>>>>           * However, if you open the CAN port in ‘listen’ mode,
>>>>>>>             then it is truly read-only. In that mode it will not
>>>>>>>             acknowledge messages, and cannot write on the bus at
>>>>>>>             all. I’ve never seen an OVMS mess up a bus in listen
>>>>>>>             mode, even if the baud rate is wrong. I think the
>>>>>>>             only way for that to happen would be a hardware
>>>>>>>             layer issue (cabling, termination, etc).
>>>>>>>         Regards, Mark.
>>>>>>>>         On 15 Jan 2025, at 6:30 AM, Simon Ehlen via OvmsDev
>>>>>>>>         <mailto:ovmsdev at lists.openvehicles.com> wrote:
>>>>>>>>         But what is the reason that a read access to the bus
>>>>>>>>         can cause the bus to crash?
>>>>>>>>         This is not critical during charging, it just aborts
>>>>>>>>         the charging process with an error.
>>>>>>>>         While driving, this results in a “stop safely now”
>>>>>>>>         error message on the dashboard and the engine is
>>>>>>>>         switched off immediately.
>>>>>>>>         Cheers,
>>>>>>>>         Simon
>>>>>>>>         Am 14.01.2025 um 23:22 schrieb Michael Geddes via OvmsDev:
>>>>>>>>>         You may need to increase  the queue size for the poll
>>>>>>>>>         task queue.
>>>>>>>>>         The poller still handles the bus to vehicle
>>>>>>>>>         notifications even if it is off.
>>>>>>>>>         Any poller logging on such an intensive load of can
>>>>>>>>>         messages is likely to be a problem.  This is part of
>>>>>>>>>         the reason it is flagged off.
>>>>>>>>>         The total % looks wrong :/
>>>>>>>>>         //.ichael
>>>>>>>>>         On Wed, 15 Jan 2025, 03:17 Simon Ehlen via OvmsDev,
>>>>>>>>>             Hi,
>>>>>>>>>             I finally got around to merging my code with the
>>>>>>>>>             current master (previous merge february 2024).
>>>>>>>>>             I have rebuilt my code for a Ford Focus Electric
>>>>>>>>>             so that it uses the new OvmsPoller class.
>>>>>>>>>             However, I now see a lot of entries like this in
>>>>>>>>>             my log:
>>>>>>>>>             I (246448) vehicle-poll: Poller[Frame]: RX Task
>>>>>>>>>             Queue Overflow Run 8
>>>>>>>>>             Queue Overflow Run 3
>>>>>>>>>             Queue Overflow Run 1
>>>>>>>>>             Queue Overflow Run 2
>>>>>>>>>             I (254448) vehicle-poll: Poller[Frame]: RX Task
>>>>>>>>>             Queue Overflow Run 24
>>>>>>>>>             Was this message just hidden before or do I need
>>>>>>>>>             to make further adjustments to my code?
>>>>>>>>>             My code currently does not use active polling but
>>>>>>>>>             reads on the busses (IncomingFrameCanX) on certain
>>>>>>>>>             modules.
>>>>>>>>>             When I look at poller times status, it looks very
>>>>>>>>>             extensive to me...
>>>>>>>>>             OVMS# poller times status
>>>>>>>>>             Poller timing is: on
>>>>>>>>>             | per s  | [%]    | [ms]
>>>>>>>>>             Poll:PRI Avg|    0.00| 0.0000|    0.003
>>>>>>>>>             Peak|        | 0.0014|    0.041
>>>>>>>>>             RxCan1[010] Avg|    0.00| 0.0000|    0.020
>>>>>>>>>             Peak|        | 1.2217|    1.089
>>>>>>>>>             RxCan1[030] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 1.2193|    1.241
>>>>>>>>>             RxCan1[041] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.6460|    1.508
>>>>>>>>>             RxCan1[049] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.6320|    0.630
>>>>>>>>>             RxCan1[04c] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.6430|    1.474
>>>>>>>>>             RxCan1[04d] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 1.2987|    1.359
>>>>>>>>>             RxCan1[077] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.6274|    0.955
>>>>>>>>>             RxCan1[07a] Avg|    0.00| 0.0000|    0.039
>>>>>>>>>             Peak|        | 1.7602|    1.684
>>>>>>>>>             RxCan1[07d] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.6621|    1.913
>>>>>>>>>             RxCan1[0c8] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>             Peak|        | 0.6292|    1.412
>>>>>>>>>             RxCan1[11a] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 1.2635|    1.508
>>>>>>>>>             RxCan1[130] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.6548|    0.703
>>>>>>>>>             RxCan1[139] Avg|    0.00| 0.0000|    0.021
>>>>>>>>>             Peak|        | 0.6002|    0.984
>>>>>>>>>             RxCan1[156] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.1225|    0.479
>>>>>>>>>             RxCan1[160] Avg|    0.00| 0.0000|    0.028
>>>>>>>>>             Peak|        | 0.6586|    1.376
>>>>>>>>>             RxCan1[165] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>             Peak|        | 0.6368|    1.132
>>>>>>>>>             RxCan1[167] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 1.3009|    1.067
>>>>>>>>>             RxCan1[171] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.6590|    4.320
>>>>>>>>>             RxCan1[178] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.1161|    0.311
>>>>>>>>>             RxCan1[179] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.1236|    0.536
>>>>>>>>>             RxCan1[180] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.6472|    1.193
>>>>>>>>>             RxCan1[185] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.6777|    1.385
>>>>>>>>>             RxCan1[1a0] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.6486|    2.276
>>>>>>>>>             RxCan1[1e0] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.6725|    1.376
>>>>>>>>>             RxCan1[1e4] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>             Peak|        | 0.7370|    1.266
>>>>>>>>>             RxCan1[1f0] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.4253|    0.753
>>>>>>>>>             RxCan1[200] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>             Peak|        | 0.6262|    0.791
>>>>>>>>>             RxCan1[202] Avg|    0.00| 0.0000|    0.021
>>>>>>>>>             Peak|        | 1.2915|    1.257
>>>>>>>>>             RxCan1[204] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 1.2620|    1.010
>>>>>>>>>             RxCan1[213] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.6331|    1.185
>>>>>>>>>             RxCan1[214] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.9977|   34.527
>>>>>>>>>             RxCan1[217] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 1.2825|    1.328
>>>>>>>>>             RxCan1[218] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.6328|    1.110
>>>>>>>>>             RxCan1[230] Avg|    0.00| 0.0000|    0.019
>>>>>>>>>             Peak|        | 0.6742|    5.119
>>>>>>>>>             RxCan1[240] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.1163|    0.343
>>>>>>>>>             RxCan1[242] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>             Peak|        | 0.3501|    1.015
>>>>>>>>>             RxCan1[24a] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.1212|    0.338
>>>>>>>>>             RxCan1[24b] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.1289|    0.330
>>>>>>>>>             RxCan1[24c] Avg|    0.00| 0.0000|    0.033
>>>>>>>>>             Peak|        | 0.1714|    1.189
>>>>>>>>>             RxCan1[25a] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.1289|    0.510
>>>>>>>>>             RxCan1[25b] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.6685|    0.930
>>>>>>>>>             RxCan1[25c] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>             Peak|        | 1.3298|    2.670
>>>>>>>>>             RxCan1[260] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.1271|    0.401
>>>>>>>>>             RxCan1[270] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.6439|    0.898
>>>>>>>>>             RxCan1[280] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.6502|    1.156
>>>>>>>>>             RxCan1[2e4] Avg|    0.00| 0.0000|    0.035
>>>>>>>>>             Peak|        | 0.3389|    0.811
>>>>>>>>>             RxCan1[2ec] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>             Peak|        | 0.1417|    0.784
>>>>>>>>>             RxCan1[2ed] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.1364|    0.746
>>>>>>>>>             RxCan1[2ee] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.1406|    0.965
>>>>>>>>>             RxCan1[312] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.1293|    0.978
>>>>>>>>>             RxCan1[326] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.1298|    0.518
>>>>>>>>>             RxCan1[336] Avg|    0.00| 0.0000|    0.028
>>>>>>>>>             Peak|        | 0.0106|    0.329
>>>>>>>>>             RxCan1[352] Avg|    0.00| 0.0000|    0.030
>>>>>>>>>             Peak|        | 0.1054|    0.800
>>>>>>>>>             RxCan1[355] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>             Peak|        | 0.0270|    0.546
>>>>>>>>>             RxCan1[35e] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.1288|    0.573
>>>>>>>>>             RxCan1[365] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.1297|    0.358
>>>>>>>>>             RxCan1[366] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>             Peak|        | 0.1429|    1.001
>>>>>>>>>             RxCan1[367] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>             Peak|        | 0.1472|    0.828
>>>>>>>>>             RxCan1[368] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.1323|    0.931
>>>>>>>>>             RxCan1[369] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>             Peak|        | 0.1498|    1.072
>>>>>>>>>             RxCan1[380] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.1285|    0.348
>>>>>>>>>             RxCan1[38b] Avg|    0.00| 0.0000|    0.021
>>>>>>>>>             Peak|        | 0.3298|    1.168
>>>>>>>>>             RxCan1[3b3] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>             Peak|        | 0.1348|    0.920
>>>>>>>>>             RxCan1[400] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.0481|    0.445
>>>>>>>>>             RxCan1[405] Avg|    0.00| 0.0000|    0.034
>>>>>>>>>             Peak|        | 0.0723|    0.473
>>>>>>>>>             RxCan1[40a] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>             Peak|        | 0.1040|    0.543
>>>>>>>>>             RxCan1[410] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.1339|    0.678
>>>>>>>>>             RxCan1[411] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>             Peak|        | 0.1376|    0.573
>>>>>>>>>             RxCan1[416] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.1284|    0.346
>>>>>>>>>             RxCan1[421] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.1323|    0.643
>>>>>>>>>             RxCan1[42d] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.1362|    1.146
>>>>>>>>>             RxCan1[42f] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>             Peak|        | 0.1503|    1.762
>>>>>>>>>             RxCan1[430] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.1352|    0.347
>>>>>>>>>             RxCan1[434] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.1312|    0.580
>>>>>>>>>             RxCan1[435] Avg|    0.00| 0.0000|    0.029
>>>>>>>>>             Peak|        | 0.1109|    1.133
>>>>>>>>>             RxCan1[43e] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.2776|    0.686
>>>>>>>>>             RxCan1[440] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.0118|    0.276
>>>>>>>>>             RxCan1[465] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.0118|    0.279
>>>>>>>>>             RxCan1[466] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0123|    0.310
>>>>>>>>>             RxCan1[467] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>             Peak|        | 0.0132|    0.314
>>>>>>>>>             RxCan1[472] Avg|    0.00| 0.0000|    0.101
>>>>>>>>>             Peak|        | 0.0307|    1.105
>>>>>>>>>             RxCan1[473] Avg|    0.00| 0.0000|    0.051
>>>>>>>>>             Peak|        | 0.0107|    0.575
>>>>>>>>>             RxCan1[474] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.0097|    0.289
>>>>>>>>>             RxCan1[475] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0220|    0.327
>>>>>>>>>             RxCan1[476] Avg|    0.00| 0.0000|    0.050
>>>>>>>>>             Peak|        | 0.0762|    5.329
>>>>>>>>>             RxCan1[477] Avg|    0.00| 0.0000|    0.032
>>>>>>>>>             Peak|        | 0.0283|    0.669
>>>>>>>>>             RxCan1[595] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>             Peak|        | 0.0103|    0.297
>>>>>>>>>             RxCan1[59e] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.0114|    0.263
>>>>>>>>>             RxCan1[5a2] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>             Peak|        | 0.0119|    0.505
>>>>>>>>>             RxCan1[5ba] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>             Peak|        | 0.0139|    0.549
>>>>>>>>>             RxCan2[020] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>             Peak|        | 0.4923|    1.133
>>>>>>>>>             RxCan2[030] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.3297|    1.136
>>>>>>>>>             RxCan2[03a] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.2792|    1.275
>>>>>>>>>             RxCan2[040] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.2834|    1.080
>>>>>>>>>             RxCan2[060] Avg|    0.00| 0.0000|    0.029
>>>>>>>>>             Peak|        | 0.3037|    0.991
>>>>>>>>>             RxCan2[070] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>             Peak|        | 0.2291|    0.460
>>>>>>>>>             RxCan2[080] Avg|    0.00| 0.0000|    0.043
>>>>>>>>>             Peak|        | 0.4015|    1.007
>>>>>>>>>             RxCan2[083] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>             Peak|        | 0.2957|    0.788
>>>>>>>>>             RxCan2[090] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>             Peak|        | 0.3951|    1.231
>>>>>>>>>             RxCan2[0a0] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>             Peak|        | 0.2560|    0.722
>>>>>>>>>             RxCan2[108] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.3713|    1.125
>>>>>>>>>             RxCan2[110] Avg|    0.00| 0.0000|    0.029
>>>>>>>>>             Peak|        | 0.2443|    0.755
>>>>>>>>>             RxCan2[130] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.2052|    1.097
>>>>>>>>>             RxCan2[150] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.2246|    0.371
>>>>>>>>>             RxCan2[160] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.0755|    1.125
>>>>>>>>>             RxCan2[180] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.2350|    0.936
>>>>>>>>>             RxCan2[190] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.2275|    0.592
>>>>>>>>>             RxCan2[1a0] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>             Peak|        | 0.0125|    0.273
>>>>>>>>>             RxCan2[1a4] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.2806|    0.632
>>>>>>>>>             RxCan2[1a8] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.1683|    0.740
>>>>>>>>>             RxCan2[1b0] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.1360|    0.490
>>>>>>>>>             RxCan2[1b4] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>             Peak|        | 0.1556|    1.119
>>>>>>>>>             RxCan2[1b8] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.1704|    0.616
>>>>>>>>>             RxCan2[1c0] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.1317|    0.488
>>>>>>>>>             RxCan2[1e0] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>             Peak|        | 0.1460|    0.675
>>>>>>>>>             RxCan2[215] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.1191|    0.567
>>>>>>>>>             RxCan2[217] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.1167|    0.869
>>>>>>>>>             RxCan2[220] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0918|    0.313
>>>>>>>>>             RxCan2[225] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>             Peak|        | 0.3635|    1.018
>>>>>>>>>             RxCan2[230] Avg|    0.00| 0.0000|    0.057
>>>>>>>>>             Peak|        | 0.2192|    1.063
>>>>>>>>>             RxCan2[240] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.1173|    0.760
>>>>>>>>>             RxCan2[241] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.2830|    1.144
>>>>>>>>>             RxCan2[250] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>             Peak|        | 0.0701|    0.698
>>>>>>>>>             RxCan2[255] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.1755|    1.063
>>>>>>>>>             RxCan2[265] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.1771|    0.729
>>>>>>>>>             RxCan2[270] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0667|    0.307
>>>>>>>>>             RxCan2[290] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.0410|    0.280
>>>>>>>>>             RxCan2[295] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0881|    0.299
>>>>>>>>>             RxCan2[2a0] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0420|    0.268
>>>>>>>>>             RxCan2[2a7] Avg|    0.00| 0.0000|    0.021
>>>>>>>>>             Peak|        | 0.1716|    0.454
>>>>>>>>>             RxCan2[2b0] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0424|    0.300
>>>>>>>>>             RxCan2[2c0] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.0470|    0.298
>>>>>>>>>             RxCan2[2e0] Avg|    0.00| 0.0000|    0.030
>>>>>>>>>             Peak|        | 0.0324|    1.152
>>>>>>>>>             RxCan2[2f0] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.0229|    0.359
>>>>>>>>>             RxCan2[2f5] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>             Peak|        | 0.1882|    0.673
>>>>>>>>>             RxCan2[300] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.0186|    0.263
>>>>>>>>>             RxCan2[310] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.0210|    0.265
>>>>>>>>>             RxCan2[320] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>             Peak|        | 0.0207|    0.354
>>>>>>>>>             RxCan2[326] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.1466|    0.686
>>>>>>>>>             RxCan2[330] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.4580|    0.708
>>>>>>>>>             RxCan2[340] Avg|    0.00| 0.0000|    0.031
>>>>>>>>>             Peak|        | 0.1621|    0.785
>>>>>>>>>             RxCan2[345] Avg|    0.00| 0.0000|    0.021
>>>>>>>>>             Peak|        | 0.0199|    0.261
>>>>>>>>>             RxCan2[35e] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0686|    0.449
>>>>>>>>>             RxCan2[360] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>             Peak|        | 0.0204|    0.289
>>>>>>>>>             RxCan2[361] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.1166|    0.316
>>>>>>>>>             RxCan2[363] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0146|    0.304
>>>>>>>>>             RxCan2[370] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>             Peak|        | 0.0099|    0.278
>>>>>>>>>             RxCan2[381] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>             Peak|        | 0.0468|    0.459
>>>>>>>>>             RxCan2[3a0] Avg|    0.00| 0.0000|    0.021
>>>>>>>>>             Peak|        | 0.2339|    0.617
>>>>>>>>>             RxCan2[3d0] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.1351|    0.351
>>>>>>>>>             RxCan2[3d5] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0796|    0.692
>>>>>>>>>             RxCan2[400] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0537|    0.307
>>>>>>>>>             RxCan2[405] Avg|    0.00| 0.0000|    0.021
>>>>>>>>>             Peak|        | 0.0513|    0.303
>>>>>>>>>             RxCan2[40a] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.1099|    0.313
>>>>>>>>>             RxCan2[415] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.0204|    0.251
>>>>>>>>>             RxCan2[435] Avg|    0.00| 0.0000|    0.028
>>>>>>>>>             Peak|        | 0.0113|    0.342
>>>>>>>>>             RxCan2[440] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>             Peak|        | 0.0110|    0.299
>>>>>>>>>             RxCan2[465] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0122|    0.295
>>>>>>>>>             RxCan2[466] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.0117|    0.267
>>>>>>>>>             RxCan2[467] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.0164|    0.325
>>>>>>>>>             RxCan2[501] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0236|    0.276
>>>>>>>>>             RxCan2[503] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0248|    0.349
>>>>>>>>>             RxCan2[504] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0230|    0.312
>>>>>>>>>             RxCan2[505] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>             Peak|        | 0.0256|    0.310
>>>>>>>>>             RxCan2[508] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0281|    0.329
>>>>>>>>>             RxCan2[511] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>             Peak|        | 0.0232|    0.282
>>>>>>>>>             RxCan2[51e] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>             Peak|        | 0.0248|    0.298
>>>>>>>>>             RxCan2[581] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>             Peak|        | 0.0166|    0.286
>>>>>>>>>                    Total Avg|    0.00| 0.0000|   43.563
>>>>>>>>>             times status causes the bus to crash, although no
>>>>>>>>>             polls are actively being sent at all.
>>>>>>>>>             Cheers,
>>>>>>>>>             Simon
>>>>>>>>>             _______________________________________________
>>>>>>>>>             OvmsDev mailing list
>>>>>>>>>             OvmsDev at lists.openvehicles.com
>>>>>>>>>             http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>         Michael Balzer *Am Rahmen 5 * D-58313 Herdecke <https://www.google.com/maps/search/Am+Rahmen+5+*+D-58313+Herdecke?entry=gmail&source=g>
>>>>>         Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250117/22d3c223/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250117/22d3c223/attachment-0001.sig>
