Michael Geddes
Wed Jan 15 06:57:55 HKT 2025
Ohhh. That's bad. Are you seeing a bus reset coming through?
Maybe someone else more familiar with the hardware and bus mechanisms might
help.
Michael.
On Wed, 15 Jan 2025, 06:31 Simon Ehlen via OvmsDev, <
> But what is the reason that a read access to the bus can cause the bus to
> crash?
> This is not critical during charging, it just aborts the charging process
> with an error.
> While driving, this results in a “stop safely now” error message on the
> dashboard and the engine is switched off immediately.
> Cheers,
> Simon
> Am 14.01.2025 um 23:22 schrieb Michael Geddes via OvmsDev:
> You may need to increase the queue size for the poll task queue.
> The poller still handles the bus to vehicle notifications even if it is
> off.
> Any poller logging on such an intensive load of can messages is likely to
> be a problem. This is part of the reason it is flagged off.
> The total % looks wrong :/
> //.ichael
> On Wed, 15 Jan 2025, 03:17 Simon Ehlen via OvmsDev, <
>> Hi,
>> I finally got around to merging my code with the current master (previous
>> merge february 2024).
>> I have rebuilt my code for a Ford Focus Electric so that it uses the new
>> OvmsPoller class.
>> However, I now see a lot of entries like this in my log:
>> I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 8
>> I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 3
>> I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>> I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 2
>> I (254448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 24
>> I (254448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>> Was this message just hidden before or do I need to make further
>> adjustments to my code?
>> My code currently does not use active polling but reads on the busses
>> (IncomingFrameCanX) on certain modules.
>> When I look at poller times status, it looks very extensive to me...
>> OVMS# poller times status
>> Poller timing is: on
>> Type | count | Utlztn | Time
>> | per s | [%] | [ms]
>> Poll:PRI Avg| 0.00| 0.0000| 0.003
>> Peak| | 0.0014| 0.041
>> RxCan1[010] Avg| 0.00| 0.0000| 0.020
>> Peak| | 1.2217| 1.089
>> RxCan1[030] Avg| 0.00| 0.0000| 0.024
>> Peak| | 1.2193| 1.241
>> RxCan1[041] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.6460| 1.508
>> RxCan1[049] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.6320| 0.630
>> RxCan1[04c] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.6430| 1.474
>> RxCan1[04d] Avg| 0.00| 0.0000| 0.022
>> Peak| | 1.2987| 1.359
>> RxCan1[076] Avg| 0.00| 0.0000| 0.072
>> Peak| | 0.7818| 15.221
>> RxCan1[077] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.6274| 0.955
>> RxCan1[07a] Avg| 0.00| 0.0000| 0.039
>> Peak| | 1.7602| 1.684
>> RxCan1[07d] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.6621| 1.913
>> RxCan1[0c8] Avg| 0.00| 0.0000| 0.026
>> Peak| | 0.6292| 1.412
>> RxCan1[11a] Avg| 0.00| 0.0000| 0.023
>> Peak| | 1.2635| 1.508
>> RxCan1[130] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.6548| 0.703
>> RxCan1[139] Avg| 0.00| 0.0000| 0.021
>> Peak| | 0.6002| 0.984
>> RxCan1[156] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.1225| 0.479
>> RxCan1[160] Avg| 0.00| 0.0000| 0.028
>> Peak| | 0.6586| 1.376
>> RxCan1[165] Avg| 0.00| 0.0000| 0.027
>> Peak| | 0.6368| 1.132
>> RxCan1[167] Avg| 0.00| 0.0000| 0.024
>> Peak| | 1.3009| 1.067
>> RxCan1[171] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.6590| 4.320
>> RxCan1[178] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.1161| 0.311
>> RxCan1[179] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.1236| 0.536
>> RxCan1[180] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.6472| 1.193
>> RxCan1[185] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.6777| 1.385
>> RxCan1[1a0] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.6486| 2.276
>> RxCan1[1e0] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.6725| 1.376
>> RxCan1[1e4] Avg| 0.00| 0.0000| 0.027
>> Peak| | 0.7370| 1.266
>> RxCan1[1f0] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.4253| 0.753
>> RxCan1[200] Avg| 0.00| 0.0000| 0.025
>> Peak| | 0.6262| 0.791
>> RxCan1[202] Avg| 0.00| 0.0000| 0.021
>> Peak| | 1.2915| 1.257
>> RxCan1[204] Avg| 0.00| 0.0000| 0.022
>> Peak| | 1.2620| 1.010
>> RxCan1[213] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.6331| 1.185
>> RxCan1[214] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.9977| 34.527
>> RxCan1[217] Avg| 0.00| 0.0000| 0.024
>> Peak| | 1.2825| 1.328
>> RxCan1[218] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.6328| 1.110
>> RxCan1[230] Avg| 0.00| 0.0000| 0.019
>> Peak| | 0.6742| 5.119
>> RxCan1[240] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.1163| 0.343
>> RxCan1[242] Avg| 0.00| 0.0000| 0.025
>> Peak| | 0.3501| 1.015
>> RxCan1[24a] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.1212| 0.338
>> RxCan1[24b] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.1289| 0.330
>> RxCan1[24c] Avg| 0.00| 0.0000| 0.033
>> Peak| | 0.1714| 1.189
>> RxCan1[25a] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.1289| 0.510
>> RxCan1[25b] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.6685| 0.930
>> RxCan1[25c] Avg| 0.00| 0.0000| 0.027
>> Peak| | 1.3298| 2.670
>> RxCan1[260] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.1271| 0.401
>> RxCan1[270] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.6439| 0.898
>> RxCan1[280] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.6502| 1.156
>> RxCan1[2e4] Avg| 0.00| 0.0000| 0.035
>> Peak| | 0.3389| 0.811
>> RxCan1[2ec] Avg| 0.00| 0.0000| 0.027
>> Peak| | 0.1417| 0.784
>> RxCan1[2ed] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.1364| 0.746
>> RxCan1[2ee] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.1406| 0.965
>> RxCan1[312] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.1293| 0.978
>> RxCan1[326] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.1298| 0.518
>> RxCan1[336] Avg| 0.00| 0.0000| 0.028
>> Peak| | 0.0106| 0.329
>> RxCan1[352] Avg| 0.00| 0.0000| 0.030
>> Peak| | 0.1054| 0.800
>> RxCan1[355] Avg| 0.00| 0.0000| 0.027
>> Peak| | 0.0270| 0.546
>> RxCan1[35e] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.1288| 0.573
>> RxCan1[365] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.1297| 0.358
>> RxCan1[366] Avg| 0.00| 0.0000| 0.026
>> Peak| | 0.1429| 1.001
>> RxCan1[367] Avg| 0.00| 0.0000| 0.026
>> Peak| | 0.1472| 0.828
>> RxCan1[368] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.1323| 0.931
>> RxCan1[369] Avg| 0.00| 0.0000| 0.026
>> Peak| | 0.1498| 1.072
>> RxCan1[380] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.1285| 0.348
>> RxCan1[38b] Avg| 0.00| 0.0000| 0.021
>> Peak| | 0.3298| 1.168
>> RxCan1[3b3] Avg| 0.00| 0.0000| 0.025
>> Peak| | 0.1348| 0.920
>> RxCan1[400] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.0481| 0.445
>> RxCan1[405] Avg| 0.00| 0.0000| 0.034
>> Peak| | 0.0723| 0.473
>> RxCan1[40a] Avg| 0.00| 0.0000| 0.025
>> Peak| | 0.1040| 0.543
>> RxCan1[410] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.1339| 0.678
>> RxCan1[411] Avg| 0.00| 0.0000| 0.025
>> Peak| | 0.1376| 0.573
>> RxCan1[416] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.1284| 0.346
>> RxCan1[421] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.1323| 0.643
>> RxCan1[42d] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.1362| 1.146
>> RxCan1[42f] Avg| 0.00| 0.0000| 0.027
>> Peak| | 0.1503| 1.762
>> RxCan1[430] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.1352| 0.347
>> RxCan1[434] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.1312| 0.580
>> RxCan1[435] Avg| 0.00| 0.0000| 0.029
>> Peak| | 0.1109| 1.133
>> RxCan1[43e] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.2776| 0.686
>> RxCan1[440] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.0118| 0.276
>> RxCan1[465] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.0118| 0.279
>> RxCan1[466] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0123| 0.310
>> RxCan1[467] Avg| 0.00| 0.0000| 0.025
>> Peak| | 0.0132| 0.314
>> RxCan1[472] Avg| 0.00| 0.0000| 0.101
>> Peak| | 0.0307| 1.105
>> RxCan1[473] Avg| 0.00| 0.0000| 0.051
>> Peak| | 0.0107| 0.575
>> RxCan1[474] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.0097| 0.289
>> RxCan1[475] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0220| 0.327
>> RxCan1[476] Avg| 0.00| 0.0000| 0.050
>> Peak| | 0.0762| 5.329
>> RxCan1[477] Avg| 0.00| 0.0000| 0.032
>> Peak| | 0.0283| 0.669
>> RxCan1[595] Avg| 0.00| 0.0000| 0.026
>> Peak| | 0.0103| 0.297
>> RxCan1[59e] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.0114| 0.263
>> RxCan1[5a2] Avg| 0.00| 0.0000| 0.026
>> Peak| | 0.0119| 0.505
>> RxCan1[5ba] Avg| 0.00| 0.0000| 0.025
>> Peak| | 0.0139| 0.549
>> RxCan2[020] Avg| 0.00| 0.0000| 0.026
>> Peak| | 0.4923| 1.133
>> RxCan2[030] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.3297| 1.136
>> RxCan2[03a] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.2792| 1.275
>> RxCan2[040] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.2834| 1.080
>> RxCan2[060] Avg| 0.00| 0.0000| 0.029
>> Peak| | 0.3037| 0.991
>> RxCan2[070] Avg| 0.00| 0.0000| 0.025
>> Peak| | 0.2291| 0.460
>> RxCan2[080] Avg| 0.00| 0.0000| 0.043
>> Peak| | 0.4015| 1.007
>> RxCan2[083] Avg| 0.00| 0.0000| 0.026
>> Peak| | 0.2957| 0.788
>> RxCan2[090] Avg| 0.00| 0.0000| 0.027
>> Peak| | 0.3951| 1.231
>> RxCan2[0a0] Avg| 0.00| 0.0000| 0.026
>> Peak| | 0.2560| 0.722
>> RxCan2[100] Avg| 0.00| 0.0000| 0.046
>> Peak| | 0.4506| 21.961
>> RxCan2[108] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.3713| 1.125
>> RxCan2[110] Avg| 0.00| 0.0000| 0.029
>> Peak| | 0.2443| 0.755
>> RxCan2[130] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.2052| 1.097
>> RxCan2[150] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.2246| 0.371
>> RxCan2[160] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.0755| 1.125
>> RxCan2[180] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.2350| 0.936
>> RxCan2[190] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.2275| 0.592
>> RxCan2[1a0] Avg| 0.00| 0.0000| 0.025
>> Peak| | 0.0125| 0.273
>> RxCan2[1a4] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.2806| 0.632
>> RxCan2[1a8] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.1683| 0.740
>> RxCan2[1b0] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.1360| 0.490
>> RxCan2[1b4] Avg| 0.00| 0.0000| 0.027
>> Peak| | 0.1556| 1.119
>> RxCan2[1b8] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.1704| 0.616
>> RxCan2[1c0] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.1317| 0.488
>> RxCan2[1e0] Avg| 0.00| 0.0000| 0.025
>> Peak| | 0.1460| 0.675
>> RxCan2[215] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.1191| 0.567
>> RxCan2[217] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.1167| 0.869
>> RxCan2[220] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0918| 0.313
>> RxCan2[225] Avg| 0.00| 0.0000| 0.025
>> Peak| | 0.3635| 1.018
>> RxCan2[230] Avg| 0.00| 0.0000| 0.057
>> Peak| | 0.2192| 1.063
>> RxCan2[240] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.1173| 0.760
>> RxCan2[241] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.2830| 1.144
>> RxCan2[250] Avg| 0.00| 0.0000| 0.026
>> Peak| | 0.0701| 0.698
>> RxCan2[255] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.1755| 1.063
>> RxCan2[265] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.1771| 0.729
>> RxCan2[270] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0667| 0.307
>> RxCan2[290] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.0410| 0.280
>> RxCan2[295] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0881| 0.299
>> RxCan2[2a0] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0420| 0.268
>> RxCan2[2a7] Avg| 0.00| 0.0000| 0.021
>> Peak| | 0.1716| 0.454
>> RxCan2[2b0] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0424| 0.300
>> RxCan2[2c0] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.0470| 0.298
>> RxCan2[2e0] Avg| 0.00| 0.0000| 0.030
>> Peak| | 0.0324| 1.152
>> RxCan2[2f0] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.0229| 0.359
>> RxCan2[2f5] Avg| 0.00| 0.0000| 0.026
>> Peak| | 0.1882| 0.673
>> RxCan2[300] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.0186| 0.263
>> RxCan2[310] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.0210| 0.265
>> RxCan2[320] Avg| 0.00| 0.0000| 0.025
>> Peak| | 0.0207| 0.354
>> RxCan2[326] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.1466| 0.686
>> RxCan2[330] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.4580| 0.708
>> RxCan2[340] Avg| 0.00| 0.0000| 0.031
>> Peak| | 0.1621| 0.785
>> RxCan2[345] Avg| 0.00| 0.0000| 0.021
>> Peak| | 0.0199| 0.261
>> RxCan2[35e] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0686| 0.449
>> RxCan2[360] Avg| 0.00| 0.0000| 0.025
>> Peak| | 0.0204| 0.289
>> RxCan2[361] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.1166| 0.316
>> RxCan2[363] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0146| 0.304
>> RxCan2[370] Avg| 0.00| 0.0000| 0.024
>> Peak| | 0.0099| 0.278
>> RxCan2[381] Avg| 0.00| 0.0000| 0.025
>> Peak| | 0.0468| 0.459
>> RxCan2[3a0] Avg| 0.00| 0.0000| 0.021
>> Peak| | 0.2339| 0.617
>> RxCan2[3d0] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.1351| 0.351
>> RxCan2[3d5] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0796| 0.692
>> RxCan2[400] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0537| 0.307
>> RxCan2[405] Avg| 0.00| 0.0000| 0.021
>> Peak| | 0.0513| 0.303
>> RxCan2[40a] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.1099| 0.313
>> RxCan2[415] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.0204| 0.251
>> RxCan2[435] Avg| 0.00| 0.0000| 0.028
>> Peak| | 0.0113| 0.342
>> RxCan2[440] Avg| 0.00| 0.0000| 0.027
>> Peak| | 0.0110| 0.299
>> RxCan2[465] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0122| 0.295
>> RxCan2[466] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.0117| 0.267
>> RxCan2[467] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.0164| 0.325
>> RxCan2[501] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0236| 0.276
>> RxCan2[503] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0248| 0.349
>> RxCan2[504] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0230| 0.312
>> RxCan2[505] Avg| 0.00| 0.0000| 0.025
>> Peak| | 0.0256| 0.310
>> RxCan2[508] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0281| 0.329
>> RxCan2[511] Avg| 0.00| 0.0000| 0.022
>> Peak| | 0.0232| 0.282
>> RxCan2[51e] Avg| 0.00| 0.0000| 0.023
>> Peak| | 0.0248| 0.298
>> RxCan2[581] Avg| 0.00| 0.0000| 0.025
>> Peak| | 0.0166| 0.286
>> Total Avg| 0.00| 0.0000| 43.563
>> At the same time, calling poller times on, poller times status causes the
>> bus to crash, although no polls are actively being sent at all.
>> Cheers,
>> Simon
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250115/98fda11d/attachment-0001.htm>
