Simon Ehlen ovms at highteq.de
Wed Jan 15 06:30:35 HKT 2025
But what is the reason that a read access to the bus can cause the bus to crash?
This is not critical during charging, it just aborts the charging process with an error.
While driving, this results in a “stop safely now” error message on the dashboard and the engine is switched off immediately.
Cheers,
Simon
Am 14.01.2025 um 23:22 schrieb Michael Geddes via OvmsDev:
> You may need to increase  the queue size for the poll task queue.
> The poller still handles the bus to vehicle notifications even if it is off.
> Any poller logging on such an intensive load of can messages is likely to be a problem.  This is part of the reason it is flagged off.
> The total % looks wrong :/
> //.ichael
> On Wed, 15 Jan 2025, 03:17 Simon Ehlen via OvmsDev, <ovmsdev at lists.openvehicles.com> wrote:
>     Hi,
>     I finally got around to merging my code with the current master (previous merge february 2024).
>     I have rebuilt my code for a Ford Focus Electric so that it uses the new OvmsPoller class.
>     However, I now see a lot of entries like this in my log:
>     I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 8
>     I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 3
>     I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>     I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 2
>     I (254448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 24
>     I (254448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>     Was this message just hidden before or do I need to make further adjustments to my code?
>     My code currently does not use active polling but reads on the busses (IncomingFrameCanX) on certain modules.
>     When I look at poller times status, it looks very extensive to me...
>     OVMS# poller times status
>     Poller timing is: on
>     Type           | count  | Utlztn | Time
>                     | per s  | [%]    | [ms]
>     Poll:PRI    Avg|    0.00|  0.0000|    0.003
>                 Peak|        |  0.0014|    0.041
>     RxCan1[010] Avg|    0.00|  0.0000|    0.020
>                 Peak|        |  1.2217|    1.089
>     RxCan1[030] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  1.2193|    1.241
>     RxCan1[041] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.6460|    1.508
>     RxCan1[049] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.6320|    0.630
>     RxCan1[04c] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.6430|    1.474
>     RxCan1[04d] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  1.2987|    1.359
>     RxCan1[076] Avg|    0.00|  0.0000|    0.072
>                 Peak|        |  0.7818|   15.221
>     RxCan1[077] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.6274|    0.955
>     RxCan1[07a] Avg|    0.00|  0.0000|    0.039
>                 Peak|        |  1.7602|    1.684
>     RxCan1[07d] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.6621|    1.913
>     RxCan1[0c8] Avg|    0.00|  0.0000|    0.026
>                 Peak|        |  0.6292|    1.412
>     RxCan1[11a] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  1.2635|    1.508
>     RxCan1[130] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.6548|    0.703
>     RxCan1[139] Avg|    0.00|  0.0000|    0.021
>                 Peak|        |  0.6002|    0.984
>     RxCan1[156] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.1225|    0.479
>     RxCan1[160] Avg|    0.00|  0.0000|    0.028
>                 Peak|        |  0.6586|    1.376
>     RxCan1[165] Avg|    0.00|  0.0000|    0.027
>                 Peak|        |  0.6368|    1.132
>     RxCan1[167] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  1.3009|    1.067
>     RxCan1[171] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.6590|    4.320
>     RxCan1[178] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.1161|    0.311
>     RxCan1[179] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.1236|    0.536
>     RxCan1[180] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.6472|    1.193
>     RxCan1[185] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.6777|    1.385
>     RxCan1[1a0] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.6486|    2.276
>     RxCan1[1e0] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.6725|    1.376
>     RxCan1[1e4] Avg|    0.00|  0.0000|    0.027
>                 Peak|        |  0.7370|    1.266
>     RxCan1[1f0] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.4253|    0.753
>     RxCan1[200] Avg|    0.00|  0.0000|    0.025
>                 Peak|        |  0.6262|    0.791
>     RxCan1[202] Avg|    0.00|  0.0000|    0.021
>                 Peak|        |  1.2915|    1.257
>     RxCan1[204] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  1.2620|    1.010
>     RxCan1[213] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.6331|    1.185
>     RxCan1[214] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.9977|   34.527
>     RxCan1[217] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  1.2825|    1.328
>     RxCan1[218] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.6328|    1.110
>     RxCan1[230] Avg|    0.00|  0.0000|    0.019
>                 Peak|        |  0.6742|    5.119
>     RxCan1[240] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.1163|    0.343
>     RxCan1[242] Avg|    0.00|  0.0000|    0.025
>                 Peak|        |  0.3501|    1.015
>     RxCan1[24a] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.1212|    0.338
>     RxCan1[24b] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.1289|    0.330
>     RxCan1[24c] Avg|    0.00|  0.0000|    0.033
>                 Peak|        |  0.1714|    1.189
>     RxCan1[25a] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.1289|    0.510
>     RxCan1[25b] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.6685|    0.930
>     RxCan1[25c] Avg|    0.00|  0.0000|    0.027
>                 Peak|        |  1.3298|    2.670
>     RxCan1[260] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.1271|    0.401
>     RxCan1[270] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.6439|    0.898
>     RxCan1[280] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.6502|    1.156
>     RxCan1[2e4] Avg|    0.00|  0.0000|    0.035
>                 Peak|        |  0.3389|    0.811
>     RxCan1[2ec] Avg|    0.00|  0.0000|    0.027
>                 Peak|        |  0.1417|    0.784
>     RxCan1[2ed] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.1364|    0.746
>     RxCan1[2ee] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.1406|    0.965
>     RxCan1[312] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.1293|    0.978
>     RxCan1[326] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.1298|    0.518
>     RxCan1[336] Avg|    0.00|  0.0000|    0.028
>                 Peak|        |  0.0106|    0.329
>     RxCan1[352] Avg|    0.00|  0.0000|    0.030
>                 Peak|        |  0.1054|    0.800
>     RxCan1[355] Avg|    0.00|  0.0000|    0.027
>                 Peak|        |  0.0270|    0.546
>     RxCan1[35e] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.1288|    0.573
>     RxCan1[365] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.1297|    0.358
>     RxCan1[366] Avg|    0.00|  0.0000|    0.026
>                 Peak|        |  0.1429|    1.001
>     RxCan1[367] Avg|    0.00|  0.0000|    0.026
>                 Peak|        |  0.1472|    0.828
>     RxCan1[368] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.1323|    0.931
>     RxCan1[369] Avg|    0.00|  0.0000|    0.026
>                 Peak|        |  0.1498|    1.072
>     RxCan1[380] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.1285|    0.348
>     RxCan1[38b] Avg|    0.00|  0.0000|    0.021
>                 Peak|        |  0.3298|    1.168
>     RxCan1[3b3] Avg|    0.00|  0.0000|    0.025
>                 Peak|        |  0.1348|    0.920
>     RxCan1[400] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.0481|    0.445
>     RxCan1[405] Avg|    0.00|  0.0000|    0.034
>                 Peak|        |  0.0723|    0.473
>     RxCan1[40a] Avg|    0.00|  0.0000|    0.025
>                 Peak|        |  0.1040|    0.543
>     RxCan1[410] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.1339|    0.678
>     RxCan1[411] Avg|    0.00|  0.0000|    0.025
>                 Peak|        |  0.1376|    0.573
>     RxCan1[416] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.1284|    0.346
>     RxCan1[421] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.1323|    0.643
>     RxCan1[42d] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.1362|    1.146
>     RxCan1[42f] Avg|    0.00|  0.0000|    0.027
>                 Peak|        |  0.1503|    1.762
>     RxCan1[430] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.1352|    0.347
>     RxCan1[434] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.1312|    0.580
>     RxCan1[435] Avg|    0.00|  0.0000|    0.029
>                 Peak|        |  0.1109|    1.133
>     RxCan1[43e] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.2776|    0.686
>     RxCan1[440] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.0118|    0.276
>     RxCan1[465] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.0118|    0.279
>     RxCan1[466] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0123|    0.310
>     RxCan1[467] Avg|    0.00|  0.0000|    0.025
>                 Peak|        |  0.0132|    0.314
>     RxCan1[472] Avg|    0.00|  0.0000|    0.101
>                 Peak|        |  0.0307|    1.105
>     RxCan1[473] Avg|    0.00|  0.0000|    0.051
>                 Peak|        |  0.0107|    0.575
>     RxCan1[474] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.0097|    0.289
>     RxCan1[475] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0220|    0.327
>     RxCan1[476] Avg|    0.00|  0.0000|    0.050
>                 Peak|        |  0.0762|    5.329
>     RxCan1[477] Avg|    0.00|  0.0000|    0.032
>                 Peak|        |  0.0283|    0.669
>     RxCan1[595] Avg|    0.00|  0.0000|    0.026
>                 Peak|        |  0.0103|    0.297
>     RxCan1[59e] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.0114|    0.263
>     RxCan1[5a2] Avg|    0.00|  0.0000|    0.026
>                 Peak|        |  0.0119|    0.505
>     RxCan1[5ba] Avg|    0.00|  0.0000|    0.025
>                 Peak|        |  0.0139|    0.549
>     RxCan2[020] Avg|    0.00|  0.0000|    0.026
>                 Peak|        |  0.4923|    1.133
>     RxCan2[030] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.3297|    1.136
>     RxCan2[03a] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.2792|    1.275
>     RxCan2[040] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.2834|    1.080
>     RxCan2[060] Avg|    0.00|  0.0000|    0.029
>                 Peak|        |  0.3037|    0.991
>     RxCan2[070] Avg|    0.00|  0.0000|    0.025
>                 Peak|        |  0.2291|    0.460
>     RxCan2[080] Avg|    0.00|  0.0000|    0.043
>                 Peak|        |  0.4015|    1.007
>     RxCan2[083] Avg|    0.00|  0.0000|    0.026
>                 Peak|        |  0.2957|    0.788
>     RxCan2[090] Avg|    0.00|  0.0000|    0.027
>                 Peak|        |  0.3951|    1.231
>     RxCan2[0a0] Avg|    0.00|  0.0000|    0.026
>                 Peak|        |  0.2560|    0.722
>     RxCan2[100] Avg|    0.00|  0.0000|    0.046
>                 Peak|        |  0.4506|   21.961
>     RxCan2[108] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.3713|    1.125
>     RxCan2[110] Avg|    0.00|  0.0000|    0.029
>                 Peak|        |  0.2443|    0.755
>     RxCan2[130] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.2052|    1.097
>     RxCan2[150] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.2246|    0.371
>     RxCan2[160] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.0755|    1.125
>     RxCan2[180] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.2350|    0.936
>     RxCan2[190] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.2275|    0.592
>     RxCan2[1a0] Avg|    0.00|  0.0000|    0.025
>                 Peak|        |  0.0125|    0.273
>     RxCan2[1a4] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.2806|    0.632
>     RxCan2[1a8] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.1683|    0.740
>     RxCan2[1b0] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.1360|    0.490
>     RxCan2[1b4] Avg|    0.00|  0.0000|    0.027
>                 Peak|        |  0.1556|    1.119
>     RxCan2[1b8] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.1704|    0.616
>     RxCan2[1c0] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.1317|    0.488
>     RxCan2[1e0] Avg|    0.00|  0.0000|    0.025
>                 Peak|        |  0.1460|    0.675
>     RxCan2[215] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.1191|    0.567
>     RxCan2[217] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.1167|    0.869
>     RxCan2[220] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0918|    0.313
>     RxCan2[225] Avg|    0.00|  0.0000|    0.025
>                 Peak|        |  0.3635|    1.018
>     RxCan2[230] Avg|    0.00|  0.0000|    0.057
>                 Peak|        |  0.2192|    1.063
>     RxCan2[240] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.1173|    0.760
>     RxCan2[241] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.2830|    1.144
>     RxCan2[250] Avg|    0.00|  0.0000|    0.026
>                 Peak|        |  0.0701|    0.698
>     RxCan2[255] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.1755|    1.063
>     RxCan2[265] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.1771|    0.729
>     RxCan2[270] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0667|    0.307
>     RxCan2[290] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.0410|    0.280
>     RxCan2[295] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0881|    0.299
>     RxCan2[2a0] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0420|    0.268
>     RxCan2[2a7] Avg|    0.00|  0.0000|    0.021
>                 Peak|        |  0.1716|    0.454
>     RxCan2[2b0] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0424|    0.300
>     RxCan2[2c0] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.0470|    0.298
>     RxCan2[2e0] Avg|    0.00|  0.0000|    0.030
>                 Peak|        |  0.0324|    1.152
>     RxCan2[2f0] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.0229|    0.359
>     RxCan2[2f5] Avg|    0.00|  0.0000|    0.026
>                 Peak|        |  0.1882|    0.673
>     RxCan2[300] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.0186|    0.263
>     RxCan2[310] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.0210|    0.265
>     RxCan2[320] Avg|    0.00|  0.0000|    0.025
>                 Peak|        |  0.0207|    0.354
>     RxCan2[326] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.1466|    0.686
>     RxCan2[330] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.4580|    0.708
>     RxCan2[340] Avg|    0.00|  0.0000|    0.031
>                 Peak|        |  0.1621|    0.785
>     RxCan2[345] Avg|    0.00|  0.0000|    0.021
>                 Peak|        |  0.0199|    0.261
>     RxCan2[35e] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0686|    0.449
>     RxCan2[360] Avg|    0.00|  0.0000|    0.025
>                 Peak|        |  0.0204|    0.289
>     RxCan2[361] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.1166|    0.316
>     RxCan2[363] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0146|    0.304
>     RxCan2[370] Avg|    0.00|  0.0000|    0.024
>                 Peak|        |  0.0099|    0.278
>     RxCan2[381] Avg|    0.00|  0.0000|    0.025
>                 Peak|        |  0.0468|    0.459
>     RxCan2[3a0] Avg|    0.00|  0.0000|    0.021
>                 Peak|        |  0.2339|    0.617
>     RxCan2[3d0] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.1351|    0.351
>     RxCan2[3d5] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0796|    0.692
>     RxCan2[400] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0537|    0.307
>     RxCan2[405] Avg|    0.00|  0.0000|    0.021
>                 Peak|        |  0.0513|    0.303
>     RxCan2[40a] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.1099|    0.313
>     RxCan2[415] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.0204|    0.251
>     RxCan2[435] Avg|    0.00|  0.0000|    0.028
>                 Peak|        |  0.0113|    0.342
>     RxCan2[440] Avg|    0.00|  0.0000|    0.027
>                 Peak|        |  0.0110|    0.299
>     RxCan2[465] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0122|    0.295
>     RxCan2[466] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.0117|    0.267
>     RxCan2[467] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.0164|    0.325
>     RxCan2[501] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0236|    0.276
>     RxCan2[503] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0248|    0.349
>     RxCan2[504] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0230|    0.312
>     RxCan2[505] Avg|    0.00|  0.0000|    0.025
>                 Peak|        |  0.0256|    0.310
>     RxCan2[508] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0281|    0.329
>     RxCan2[511] Avg|    0.00|  0.0000|    0.022
>                 Peak|        |  0.0232|    0.282
>     RxCan2[51e] Avg|    0.00|  0.0000|    0.023
>                 Peak|        |  0.0248|    0.298
>     RxCan2[581] Avg|    0.00|  0.0000|    0.025
>                 Peak|        |  0.0166|    0.286
>            Total Avg|    0.00|  0.0000|   43.563
>     At the same time, calling poller times on, poller times status causes the bus to crash, although no polls are actively being sent at all.
>     Cheers,
>     Simon
>     _______________________________________________
>     OvmsDev mailing list
>     OvmsDev at lists.openvehicles.com
>     http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250114/016f128a/attachment-0001.htm>
