[Ovmsdev] Handling pilot signal interruption
Tue Jan 14 20:03:56 HKT 2025
Chris,
not owning a Leaf or having any info on it, so just an idea: assuming
the charge current remains zero in this case, you could inhibit the
charge stop based on that condition.
Am 14.01.25 um 11:45 schrieb Chris B via OvmsDev:
> Hi everyone
> First, thank you for working to build OVMS. It's an amazing achievement.
> I only started using it late last year. I've encountered just two
> issues, and fixed the first of those in PR#1081.
> I'd like to ask for your opinion on how to fix issue #1086
> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/1086>.
> There's a shortcoming in Nissan hardware that means that timed climate
> control start can cause the charging pilot signal to disappear for a
> tenth of a second. This makes the car think it has just been plugged
> in, and it commences charging.
> OVMS then notices it is charging beyond the target SOC and commands
> the car to stop. This is fine, except it also ends the climate control
> before it has even had a chance to get going.
> My first idea for a workaround is to implement a configurable time
> period during which SOC limit isn't applied.
> Another idea is to implement detection for pilot interruption, and
> inhibit SOC limit for 30 minutes after that occurs.
> What do you think should be done here?
> Thanks,
> Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250114/e7b74745/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250114/e7b74745/attachment.sig>
