Tue Feb 4 15:08:53 HKT 2025
Chris, Derek,
as you're checking the Leaf code, also have a look at this:
Am 15.01.25 um 11:11 schrieb Michael Balzer via OvmsDev:
> Speaking of the Leaf, the code there actually does something fishy in
> `CommandWakeup()`:
> unsigned char data = 0;
> m_can1->WriteStandard(0x5C0, *_8_*, &data); //Wakes up the VCM (by
> spoofing empty battery request heating)
Am 04.02.25 um 02:00 schrieb Derek Caudwell via OvmsDev:
> Hi Chris
> I can't see any issue with setting the poll state to OFF if the
> charger state is either CHARGER_STATUS_IDLE or
> CHARGER_STATUS_PLUGGED_IN_TIMER_WAIT, particularly if the can bus goes
> to sleep in these states.
> Kind regards
> Derek
> On Tue, 4 Feb 2025 at 11:47, Chris Box via OvmsDev
> <ovmsdev at lists.openvehicles.com> wrote:
> On 2025-02-03 07:34, Michael Balzer wrote:
>> This is the moment the vehicle state change was detected:
>>> 2025-02-02 21:08:14.372 GMT D (338493292) events:
>>> Signal(vehicle.charge.stop)
>> The event is emitted automatically by the vehicle framework when
>> metric "v.c.charging" (ms_v_charge_inprogress) changes from true
>> to false.
>> I don't know the Leaf code, but I think that should directly lead
>> to a poller state change, but doesn't.
> In vehicle_nissanleaf.cpp
> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/vehicle_nissanleaf/src/vehicle_nissanleaf.cpp>
> there are four places where we have
> "StandardMetrics.ms_v_charge_inprogress->SetValue(false);"
> They're all in the same switch statement block.
> Two of them also say "PollSetState(POLLSTATE_OFF);"
> These are CHARGER_STATUS_INTERRUPTED and CHARGER_STATUS_FINISHED.
> The two that don't set poll state are CHARGER_STATUS_IDLE and
> CHARGER_STATUS_PLUGGED_IN_TIMER_WAIT.
> For anyone that knows the Leaf code, does it seem reasonable to
> add PollSetState(POLLSTATE_OFF) to both of those? I note there's a
> mysterious comment "Separate from vehicle_nissanleaf_poll1() to
> make it clearer what is going on." but I can find no record of
> such a function in the current repo.
> Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250204/5db5558c/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250204/5db5558c/attachment.sig>
