[Ovmsdev] battery drain
Tamás Kovács
kommykt at gmail.com
Wed Dec 3 04:08:45 HKT 2025
Thanks for your answers.
No older logs, but now go back to the last main release. Today i changed
the rear bushing on my car, and disconnect the 12V battery from 7 to 15,
and after that ovms not start, only start when i create a usb connection,
now connected a power bank, but if i remove everything works.
The 12V battery is about 0.5 years old.
i think i have a problem with my OBD-ovms cable, 5-6 months ago i have a
similar problems i thing, this time i remove a Y OBD cable, but I don't
remember exactly symptoms.
Michael Balzer via OvmsDev <ovmsdev at lists.openvehicles.com> ezt írta
(időpont: 2025. dec. 1., H, 17:59):
> Tamás,
> first of all, are you sure these errors are new? Check your log archive
> for the error pattern. An occasional "stuck bus-off error state" is normal
> for many vehicles, when the car is off.
> The 12V battery may just coincidentally happen to fail right now. How old
> is it? If it's relatively new and/or the errors didn't occur before, it
> could be an issue with the OBD connection.
> Am 01.12.25 um 06:31 schrieb Tamás Kovács via OvmsDev:
> Hi guys!
> I have a problem with my ioniq 28kwh car, use ovms over 2 years, and now
> drain my battery last day i found the following, if i set the vehicle
> module to none, the drain is stop. i use the edge fw.
> In night the auto update fw is run and after the reboot the battery drain
> is continue. In the picture can see, 15:15 set vehucle module to none,
> auto update is run at ~3:02 (vehicle module to hyundaivfl) and i woke up
> at ~5:20 and set the vehicle module to none
> I attach a log and a screenshot of battery voltage
> What can is do? Problem with a OBD cable? I detached the ovms from the car
> for a couple off hours but when is reconnect it not connect to the wi-fi
> network, but when i connect a computer or a powerbank, the wi-fi
> connection is established, after usb disconnect network works fine, but i
> have many can errors.
> On charging i get many ovms messages, charge stopped, started.......
> Thanks:
> Kovács Tamás
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
> Fon 02330 9104094 * Handy 0176 20698926
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20251202/5a096436/attachment.htm>
