[Ovmsdev] battery drain
Tue Dec 2 00:58:57 HKT 2025
Tamás,
first of all, are you sure these errors are new? Check your log archive
for the error pattern. An occasional "stuck bus-off error state" is
normal for many vehicles, when the car is off.
The 12V battery may just coincidentally happen to fail right now. How
old is it? If it's relatively new and/or the errors didn't occur before,
it could be an issue with the OBD connection.
Am 01.12.25 um 06:31 schrieb Tamás Kovács via OvmsDev:
> Hi guys!
> I have a problem with my ioniq 28kwh car, use ovms over 2 years, and
> now drain my battery last day i found the following, if i set the
> vehicle module to none, the drain is stop. i use the edge fw.
> In night the auto update fw is run and after the reboot the battery
> drain is continue. In the picture can see, 15:15 set vehucle module to
> none,  auto update is run at ~3:02 (vehicle module to hyundaivfl) and
> i woke up at ~5:20 and set the vehicle module to none
> I attach a log and a screenshot of battery voltage
> What can is do? Problem with a OBD cable? I detached the ovms from the
> car for a couple off hours but when is reconnect it not connect to the
> wi-fi network, but when i connect a computer or a powerbank, the
>  wi-fi connection is established, after usb disconnect network works
> fine, but i have many can errors.
> On charging i get many ovms messages, charge stopped, started.......
> Thanks:
> Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20251201/17db7ec1/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20251201/17db7ec1/attachment.sig>
