[Ovmsdev] Firmware release 3.3.005 / CAN SAE timing
Sat Apr 12 15:37:21 HKT 2025
Chris,
as you changed two parameters at once, you cannot currently tell which
helped.
I suggest keeping the improved 12V level and returning to the old CAN
timing to see if that makes a difference.
Reviewing your report & findings, I'd say your issue was caused by the
12V dips.
Am 11.04.25 um 20:01 schrieb Chris Box:
> On 2025-04-06 11:03, Michael Balzer via OvmsDev wrote:
>> Did the changed CAN timing to better follow the SAE recommendations
>> actually have any benefits?
> I haven't experienced any Leaf errors using the SAE timing over the
> past month. As a result my intention is to continue with this new
> timing, although I can't prove the timing is the reason for the lack
> of issues. I also improved 12 volt levels.
> If you're looking for hard data, please advise what I should do to
> gather that data. It's not particularly clear to me, because I
> understand that "normal" can bus statistics for the Leaf include some
> expected errors.
> Thanks
> Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250412/77d922f4/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250412/77d922f4/attachment.sig>
