[Ovmsdev] Instructions for building the "new idf" version?
Craig Leres leres at xse.com
Sun Sep 22 04:05:06 HKT 2024
On 9/21/24 12:52, Ludovic LANGE via OvmsDev wrote:
> I understand that you're trying to setup the toolchain, but I'm
> wondering it you're doing it the way ESP-IDF "wants" you to ( https://
> docs.espressif.com/projects/esp-idf/en/latest/esp32/get-started/linux-
> macos-setup.html#get-started-set-up-tools ).
> There is a relationship between ESP-IDF's version, and the toolchain.
> And during the install of a specific ESP-IDF version it will (locally)
> install the proper toolchain. (Note: I don't think they deliver a
> FreeBSD version... and I don't have an Ubuntu box to test. But at least
> on my macos setup it works like this - and the env variable
> IDF_TOOLS_PATH points to the toolchain).
> You can find the proper versions here : https://github.com/espressif/
> esp-idf/blob/master/tools/tools.json (change `master` with the ESP-IDF
> version you need) - Only Linux, MacOS, Windows.
> Maybe you could start with a proper Linux install with the `|
> install.sh`| command, then replicate the version on FreeBSD.
>     $ switch-idf 5.2.2
>     $ xtensa-esp32-elf-cc --version
>     xtensa-esp-elf-cc (crosstool-NG esp-13.2.0_20230928) 13.2.0
>     Copyright (C) 2023 Free Software Foundation, Inc.
>     $ switch-idf 5.3.0
>     xtensa-esp-elf-cc (crosstool-NG esp-13.2.0_20240530) 13.2.0
> Let me know if it helps.
No, espressif does not provide FreeBSD versions of their toolchains.
And yes, that is helpful; looking at tools/tools.json for 5.3.1 I see
it's still using 13.2.0_20240530 so I focus on that version.
Here's some info about what I'm upgrading from:
    https://www.freshports.org/devel/xtensa-esp32-elf/
It is a lot of work to make this guy build within the FreeBSD ports
system, I have to identify and pre-download all of the source blobs
prior to the build because ports aren't allowed to use the network
during the build... (And it doesn't help that bootstrapping a cross
compiler takes a long time.)
		Craig
