[Ovmsdev] Instructions for building the "new idf" version?
Ludovic LANGE
ll-ovmsdev at lange.nom.fr
Sun Sep 22 03:52:47 HKT 2024
Hi Craig,
I understand that you're trying to setup the toolchain, but I'm
wondering it you're doing it the way ESP-IDF "wants" you to (
https://docs.espressif.com/projects/esp-idf/en/latest/esp32/get-started/linux-macos-setup.html#get-started-set-up-tools
There is a relationship between ESP-IDF's version, and the toolchain.
And during the install of a specific ESP-IDF version it will (locally)
install the proper toolchain. (Note: I don't think they deliver a
FreeBSD version... and I don't have an Ubuntu box to test. But at least
on my macos setup it works like this - and the env variable
IDF_TOOLS_PATH points to the toolchain).
You can find the proper versions here :
https://github.com/espressif/esp-idf/blob/master/tools/tools.json
(change `master` with the ESP-IDF version you need) - Only Linux, MacOS,
Windows.
Maybe you could start with a proper Linux install with the
`|install.sh`| command, then replicate the version on FreeBSD.
Oh, and I encourage you to isolate your multiple builds / versions so
that you do not mixup crosstool version and non-corresponding ESP-IDF
version.
Now to strictly answer your question :-) , here are the version I'm using:
$ switch-idf 3.3
$ xtensa-esp32-elf-cc --version
xtensa-esp32-elf-cc (crosstool-NG crosstool-ng-1.22.0-97-gc752ad5) 5.2.0
Copyright (C) 2015 Free Software Foundation, Inc.
$ switch-idf 5.0
xtensa-esp32-elf-cc (crosstool-NG esp-2022r1) 11.2.0
Copyright (C) 2021 Free Software Foundation, Inc.
$ switch-idf 5.0.1
$ switch-idf 5.0.2
$ switch-idf 5.0.6
$ switch-idf 5.1.4
xtensa-esp32-elf-cc (crosstool-NG esp-12.2.0_20230208) 12.2.0
Copyright (C) 2022 Free Software Foundation, Inc.
$ switch-idf 5.2.2
xtensa-esp-elf-cc (crosstool-NG esp-13.2.0_20230928) 13.2.0
Copyright (C) 2023 Free Software Foundation, Inc.
$ switch-idf 5.3.0
xtensa-esp-elf-cc (crosstool-NG esp-13.2.0_20240530) 13.2.0
Let me know if it helps.
Le 21/09/2024 à 21:34, Craig Leres via OvmsDev a écrit :
> On 9/21/24 02:26, Michael Geddes via OvmsDev wrote:
>> I'm using esp-idf from https://github.com/espressif/esp-idf.git
>> <https://github.com/espressif/esp-idf.git>
>> The previous was some months ago on release/v5.2 a36d8bc742 which ran
>> on an ovms unit not connected to a car.
>> I've just done a compile off v5.3 .. with a series of patches that
>> I've got from Ludovic and some extras from myself.
>> I've also used the latest mongoose which is annoyingly problematic as
>> they re-did the whole way it was put together making it impossible
>> just to apply patches. I've re-implemented some of the good things
>> they used to have wrt defines and there are a couple of things that
>> ovms team added that would be required. One of those is that the
>> 'certificate' is meant to be a filename and there was a patch to the
>> ovms version that allowed that filename string to be the certificate
>> itself.
> The work on supporting the latest version of esp-idf sounds great.
> However I'm working on a earlier step -- the toolchain.
> crosstool-ng-1.22.0-97-gc752ad5 is based around gcc 5.2.0, I'd like to
> move to esp-13.2.0_20240530 (gcc 13.2.0) or esp-14.2.0_20240906 (gcc
> 14.2.0).
> What does "xtensa-esp32-elf-cc --version" say for you?
> Craig
> [On my FreeBSD system]
> ice 10 % xtensa-esp32-elf-cc --version
> This is free software; see the source for copying conditions. There is NO
> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
> PURPOSE.
> [On my ubuntu test box]
> sea 15 % bin/xtensa-esp32-elf-cc --version
> PURPOSE.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240921/d4479a16/attachment-0001.htm>
