[Ovmsdev] Download log files
solterra at kezarnet.com solterra at kezarnet.com
Fri Sep 13 05:26:59 HKT 2024
Thanks for the suggestion.
It seems that something got corrupted in my setup. I had non-ASCII
characters in my config list, and I wasn't able to perform a backup
properly. After doing a factory reset, everything is back to normal.
Could you clarify what the a2l script is that you mentioned? I'd like to
check my memory and crash backtrace as you suggested.
Appreciate your help!
On 9/12/2024 1:54 AM, Michael Balzer via OvmsDev wrote:
> Via http and scp, never had issues downloading the logs.
> Maybe check your memory situation & the crash backtrace using the a2l
> script.
> Am 12.09.24 um 01:40 schrieb solterra--- via OvmsDev:
>> How are folks downloading their log files?
>> It seems like I cause a crash whenever I try to download a file from
>> the web browser.
>> Thank you
