[Ovmsdev] Issue with PubSub Example Script
solterra at kezarnet.com
Wed Sep 11 17:18:58 HKT 2024
Thank you. Found my bug!
On 9/11/2024 1:44 AM, Michael Balzer via OvmsDev wrote:
> See
> https://docs.openvehicles.com/en/latest/userguide/scripting.html#global-context
> …although that's not as clear as it should be.
> "print to the system console as an informational message" actually
> means it's sent to the system log.
> The log line has level "info" and since refactoring the Duktape
> modules, the tag is "ovms-duk-util". Example:
> 2024-09-09 17:46:13.170 CEST I (511230380) ovms-duk-util: [lib/tasmotasp.js:73:processResult] TasmotaSP getPowerState: power=off
> See DukOvmsPrint() for the implementation.
> Am 11.09.24 um 01:36 schrieb solterra--- via OvmsDev:
>> I'm currently working on a script that utilizes PubSub, but I'm
>> running into an issue where the background function doesn't seem to
>> display any output in the shell. I'm following the example from the
>> website:
>> |var myTicker = function(msg, data) { print("Event: " + msg + "\n");
>> }; PubSub.subscribe("ticker.10", myTicker); |
>> For some reason, I can't get the |myTicker| function to output
>> anything when triggered. It seems like the print statements aren't
>> being executed as expected.
>> Has anyone encountered this before, or does anyone have suggestions
>> on what might be causing this issue?
>> Thanks in advance!
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240911/904832ac/attachment.htm>
