[Ovmsdev] Issue with PubSub Example Script
Wed Sep 11 13:44:37 HKT 2024
See
https://docs.openvehicles.com/en/latest/userguide/scripting.html#global-context
…although that's not as clear as it should be.
"print to the system console as an informational message" actually means
it's sent to the system log.
The log line has level "info" and since refactoring the Duktape modules,
the tag is "ovms-duk-util". Example:
2024-09-09 17:46:13.170 CEST I (511230380) ovms-duk-util: [lib/tasmotasp.js:73:processResult] TasmotaSP getPowerState: power=off
See DukOvmsPrint() for the implementation.
Am 11.09.24 um 01:36 schrieb solterra--- via OvmsDev:
> I'm currently working on a script that utilizes PubSub, but I'm
> running into an issue where the background function doesn't seem to
> display any output in the shell. I'm following the example from the
> website:
> |var myTicker = function(msg, data) { print("Event: " + msg + "\n");
> }; PubSub.subscribe("ticker.10", myTicker); |
> For some reason, I can't get the |myTicker| function to output
> anything when triggered. It seems like the print statements aren't
> being executed as expected.
> Has anyone encountered this before, or does anyone have suggestions on
> what might be causing this issue?
> Thanks in advance!
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240911/bb06b002/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240911/bb06b002/attachment.sig>
