[Ovmsdev] Can bus error while read canbus
didier at ernotte.com
Sat Nov 2 21:44:06 HKT 2024
Since the can1 is active at boot up time I don't even use this command. I mostly use the PID scanner, the shell with obdii command, and the logger/vfs command to capture log. I have programmed everything I need to query PID in javascript using web plugin.I can definitively give a hand testing the vehicle implementation with ducktape.
Didier
Le samedi 2 novembre 2024 à 00 h 00 min 18 s HAE, Michael Geddes <frog at bunyip.wheelycreek.net> a écrit :
Ahh.. yes.
I've had a look and I believe I've got it. I'll just need to make sure that the "can can? listen" and "can can? active" commands go through thepoller so that it starts up the polling thread (with a bit of conditional compilation for the where the poller is not compiled in).
I'm assuming that you do, in fact, call these commands?
On a side note, I've been working on a whole bunch of stuff to allow users to program a whole vehicle implementation with duktape and commands... so if somebody were interested in testing that (the bit that I'm struggling to find time for at the moment) I'd be happy for the help.
On Sat, 2 Nov 2024 at 00:24, didier--- via OvmsDev <ovmsdev at lists.openvehicles.com> wrote:
Ok, maybe I found something. There is no vehicle selected in the config because I am not using the OVMS box to monitor continously my car, I simply do spot check and manual queries. But if I select a car and deselect it, the poller started....
Didier
Le vendredi 1 novembre 2024 à 12 h 14 min 49 s HAE, didier--- via OvmsDev <ovmsdev at lists.openvehicles.com> a écrit :
Hi,
Is there a way to manually start a OBD Poller or what is the condition for not having an active Poller ?
Didier
Le jeudi 31 octobre 2024 à 14 h 06 min 36 s HAE, didier at ernotte.com <didier at ernotte.com> a écrit :
Hi Michael,
It seems like there is no poller.
OVMS# log level debug
Logging level for * set to debug
I (185165) webcommand: HttpCommandStream[0x3f8d8ae4]: 3314760 bytes free, executing: log level debugI (193855) webserver: HTTP POST /api/executeI (193865) webcommand: HttpCommandStream[0x3f8e2890]: 3314548 bytes free, executing: poller statusOVMS# poller status
No OBD Pollers active.I (198035) webserver: HTTP POST /api/executeI (198035) webcommand: HttpCommandStream[0x3f8e2890]: 3312220 bytes free, executing: poller resumeD (198045) vehicle-poll: Pollers: Queue Command()D (198045) vehicle-poll: Pollers: Command Resume (user)OVMS# poller resume
Vehicle OBD Polling Resume RequestedI (214195) webserver: HTTP POST /api/executeOVMS# poller status
No OBD Pollers active.I (214195) webcommand: HttpCommandStream[0x3f8e2890]: 3316368 bytes free, executing: poller statusD (217755) websocket: WebSocket[0x3f8e32ec] handler 0x3f8e3668 closed; 3 clients activeD (217755) events: Signal(server.web.socket.closed)D (217755) websocket: WebSocket[0x3f8d5e74] handler 0x3f8e2c90 closed; 2 clients activeD (217765) events: Signal(server.web.socket.closed)Didier
Le jeudi 31 octobre 2024 à 02 h 58 min 01 s HAE, Michael Balzer via OvmsDev <ovmsdev at lists.openvehicles.com> a écrit :
Didier,
the error message tells the now separated poller isn't started and also cannot be started for the request.
Check "poller status":
OVMS# poller status
Poller on Can1
List: active
State: 0
Last Request: 1s (ticks)
Time between polling ticks: 1000ms
Last Poll Received: 0s (ticks) ago
Poll Queue Length: 0
OBD polling is Resumed
Enable logging for tag "vehicle-poll" and issue "poller trace on" or possibly "poller trace all" if that doesn't show the cause.
Am 30.10.24 um 22:55 schrieb didier--- via OvmsDev:
Hi,
I don't know what changed on my OVMS box, but I am no longer abl to read manually (in the shell) any PID with the "obdii can1 request...". I receive the tranmission failure error. But it used to work fine a couple of days ago. Other commands works great like "re obdii scan start...", so the connection with the OMVS box, communication on the OBD2 port, etc works fine. What could go wrong ? I tried to download the lasted image. Same error.
Here is a session that I did :
OVMS# re obdii scan start 1 7e4 dd00 de00 -r7ec
Scan started: bus 1, ecu 7e4, rxid 7ec-7ec, polltype 22, PID dd00-de00 (step 1), timeout 3 seconds
I (804831) webcommand: HttpCommandStream[0x3f8d76b0]: 3317288 bytes free, executing: re obdii scan start 1 7e4 dd00 de00 -r7ecI (810981) re-pid: Scan of 7e4 completeI (817271) webserver: HTTP POST /api/executeOVMS# re obdii scan statusScan complete (7e4 dd00-de00)Scan started : 2024-10-30 17:46:53 EDTLast response: 2024-10-30 17:46:53 EDT7e4[7ec]:dd00 70 e8 79 bb7e4[7ec]:dd01 01 1c f87e4[7ec]:dd02 3a7e4[7ec]:dd04 3d7e4[7ec]:dd05 3a7e4[7ec]:dd06 e77e4[7ec]:dd08 007e4[7ec]:dd09 00I (817271) webcommand: HttpCommandStream[0x3f8d7350]: 3314968 bytes free, executing: re obdii scan statusI (821941) webserver: HTTP POST /api/executeI (821941) webcommand: HttpCommandStream[0x3f8d7414]: 3318624 bytes free, executing: obdii can1 request device 7E4 7EC 22dd00OVMS# obdii can1 request device 7E4 7EC 22dd007e4[7ec] 22dd00: ERROR: transmission failure (CAN bus error) Didier
OvmsDev mailing list
OvmsDev at lists.openvehicles.com
Fon 02330 9104094 * Handy 0176 20698926 _______________________________________________
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241102/54cb0b70/attachment-0001.htm>
