[Ovmsdev] Can bus error while read canbus
Michael Geddes
Sat Nov 2 11:59:54 HKT 2024
Ahh.. yes.
I've had a look and I believe I've got it. I'll just need to make sure that
the "can can? listen" and "can can? active" commands go through the
poller so that it starts up the polling thread (with a bit of conditional
compilation for the where the poller is not compiled in).
I'm assuming that you do, in fact, call these commands?
On a side note, I've been working on a whole bunch of stuff to allow users
to program a whole vehicle implementation with duktape and commands... so
if somebody were interested in testing that (the bit that I'm struggling to
find time for at the moment) I'd be happy for the help.
On Sat, 2 Nov 2024 at 00:24, didier--- via OvmsDev <
> Ok, maybe I found something. There is no vehicle selected in the config
> because I am not using the OVMS box to monitor continously my car, I simply
> do spot check and manual queries. But if I select a car and deselect it,
> the poller started....
> Didier
> Le vendredi 1 novembre 2024 à 12 h 14 min 49 s HAE, didier--- via OvmsDev <
> ovmsdev at lists.openvehicles.com> a écrit :
> Hi,
> Is there a way to manually start a OBD Poller or what is the condition for
> not having an active Poller ?
> Didier
> Le jeudi 31 octobre 2024 à 14 h 06 min 36 s HAE, didier at ernotte.com <
> didier at ernotte.com> a écrit :
> Hi Michael,
> It seems like there is no poller.
> *OVMS#* log level debug
> Logging level for * set to debug
> I (185165) webcommand: HttpCommandStream[0x3f8d8ae4]: 3314760 bytes free,
> executing: log level debug
> I (193855) webserver: HTTP POST /api/execute
> I (193865) webcommand: HttpCommandStream[0x3f8e2890]: 3314548 bytes free,
> executing: poller status
> *OVMS#* poller status
> No OBD Pollers active.
> I (198035) webserver: HTTP POST /api/execute
> I (198035) webcommand: HttpCommandStream[0x3f8e2890]: 3312220 bytes free,
> executing: poller resume
> D (198045) vehicle-poll: Pollers: Queue Command()
> D (198045) vehicle-poll: Pollers: Command Resume (user)
> *OVMS#* poller resume
> Vehicle OBD Polling Resume Requested
> I (214195) webserver: HTTP POST /api/execute
> I (214195) webcommand: HttpCommandStream[0x3f8e2890]: 3316368 bytes free,
> D (217755) websocket: WebSocket[0x3f8e32ec] handler 0x3f8e3668 closed; 3
> clients active
> D (217755) events: Signal(server.web.socket.closed)
> D (217755) websocket: WebSocket[0x3f8d5e74] handler 0x3f8e2c90 closed; 2
> clients active
> D (217765) events: Signal(server.web.socket.closed)
> Didier
> Le jeudi 31 octobre 2024 à 02 h 58 min 01 s HAE, Michael Balzer via
> OvmsDev <ovmsdev at lists.openvehicles.com> a écrit :
> Didier,
> the error message tells the now separated poller isn't started and also
> cannot be started for the request.
> Check "poller status":
> OVMS# poller status
> Poller on Can1
> List: active
> State: 0
> Last Request: 1s (ticks)
> Time between polling ticks: 1000ms
> Last Poll Received: 0s (ticks) ago
> Poll Queue Length: 0
> OBD polling is Resumed
> Enable logging for tag "vehicle-poll" and issue "poller trace on" or
> possibly "poller trace all" if that doesn't show the cause.
> Am 30.10.24 um 22:55 schrieb didier--- via OvmsDev:
> Hi,
> I don't know what changed on my OVMS box, but I am no longer abl to read
> manually (in the shell) any PID with the "obdii can1 request...". I receive
> the tranmission failure error. But it used to work fine a couple of days
> ago. Other commands works great like "re obdii scan start...", so the
> connection with the OMVS box, communication on the OBD2 port, etc works
> fine. What could go wrong ? I tried to download the lasted image. Same
> error.
> Here is a session that I did :
> *OVMS#* re obdii scan start 1 7e4 dd00 de00 -r7ec
> Scan started: bus 1, ecu 7e4, rxid 7ec-7ec, polltype 22, PID dd00-de00 (step 1), timeout 3 seconds
> I (804831) webcommand: HttpCommandStream[0x3f8d76b0]: 3317288 bytes free,
> executing: re obdii scan start 1 7e4 dd00 de00 -r7ec
> I (810981) re-pid: Scan of 7e4 complete
> I (817271) webserver: HTTP POST /api/execute
> *OVMS#* re obdii scan status Scan complete (7e4 dd00-de00) Scan started :
> 2024-10-30 17:46:53 EDT Last response: 2024-10-30 17:46:53 EDT
> 7e4[7ec]:dd00 70 e8 79 bb 7e4[7ec]:dd01 01 1c f8 7e4[7ec]:dd02 3a
> 7e4[7ec]:dd04 3d 7e4[7ec]:dd05 3a 7e4[7ec]:dd06 e7 7e4[7ec]:dd08 00
> 7e4[7ec]:dd09 00
> I (817271) webcommand: HttpCommandStream[0x3f8d7350]: 3314968 bytes free,
> executing: re obdii scan status
> I (821941) webserver: HTTP POST /api/execute
> I (821941) webcommand: HttpCommandStream[0x3f8d7414]: 3318624 bytes free,
> executing: obdii can1 request device 7E4 7EC 22dd00
> *OVMS#* obdii can1 request device 7E4 7EC 22dd00 7e4[7ec] 22dd00: ERROR:
> transmission failure (CAN bus error)
> Didier
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241102/9d52285d/attachment.htm>
