Michael Geddes
Sun May 26 12:32:53 HKT 2024
Hi,
I'm trying to finalise this now .. and one last thing is that I don't get
the report coming to my mobile. I'm using the command:
MyNotify.NotifyString("info", "poller.report", buf.c_str());
Where the buffer string is just the same as the report output. Should I be
using some other format or command?
I get "alert" types (like the ioniq5 door-open alert) fine to my mobile.
Michael.
On Sun, 19 May 2024, 12:51 Michael Balzer via OvmsDev, <
> A builtin web UI for this seems a bit over the top. Builtin web config
> pages should focus on user features, this is clearly a feature only needed
> during/for the development/extension of a vehicle adapter. Development
> features in the web UI are confusing for end users.
> If persistent enabling/disabling is done by a simple config command (e.g.
> "config set can poller.trace on"), that's also doable by users.
> Am 19.05.24 um 02:06 schrieb Michael Geddes:
> I was so focused on how I calculated the value that I totally missed that
> ‰ would be a better description. I could also use the system 'Ratio'
> unit... so % or ‰.
> I'll make space to put 'Avg' on the row. Was trying to limit the width
> for output on a mobile. I agree it would make it easier to understand.
> Totals also makes sense.
> Should I make this a configuration that can be set on the web-page? I'd
> probably use a configuration change notification so that the very bit
> setting is sync'd with the 'configuration' value.
> //.ichael
> On Sat, 18 May 2024, 14:05 Michael Balzer, <dexter at expeedo.de> wrote:
>> I'm not sure whether the 'max' should be the maximum of the smoothed
>> value.. or the maximum of the raw value.
>> It should normally be the maximum of the raw value I think, the maximum
>> of the smoothed value cannot tell about how bad the processing of an ID can
>> become.
>> The naming in the table is a bit confusing I think. (besides: I've never
>> seen "ave" as the abbreviation for average)
>> If I understand you correctly, "time ms per s" is the time share in per
>> mille, so something in that direction would be more clear, and "length ms"
>> would then be "time [ms]".
>> The totals for all averages in the table foot would also be nice.
>> Maybe "Ave" (or avg?) also should be placed on the left, as the "peak"
>> label now suggests being the peak of the average.
>> Btw, keep in mind, not all "edge" users / testers are developers (e.g.
>> the Twizy driver I'm in contact with), collecting stats feedback for
>> vehicles from testers should be straight forward. Maybe add a data/history
>> record, sent automatically on every drive/charge stop when the poller
>> tracing is on?
>> Am 18.05.24 um 02:28 schrieb Michael Geddes:
>> You did say max/pead value. I also halved the N for both.
>> This is currently the raw-value maximum.
>> The problem is that the middle column is the maximum of the {{sum over
>> 10s} / (10*1000,000)
>> I could easily change the 'period' to 1s and see how that goes.. was just
>> trying to reduce the larger calculations.
>> Usage: poller [pause|resume|status|times|trace]
>> OVMS# poller time status
>> Poller timing is: on
>> Type | Count | Ave time | Ave length
>> | per s | ms per s | ms
>> Poll:PRI | 1.00| 0.559| 0.543
>> peak | | 0.663| 1.528
>> Poll:SRX | 0.08| 0.009| 0.038
>> peak | | 0.068| 0.146
>> CAN1 RX[778] | 0.11| 0.061| 0.280
>> peak | | 0.458| 1.046
>> CAN1 RX[7a8] | 0.04| 0.024| 0.124
>> peak | | 0.160| 0.615
>> CAN1 TX[770] | 0.05| 0.004| 0.016
>> peak | | 0.022| 0.102
>> CAN1 TX[7a0] | 0.02| 0.002| 0.011
>> peak | | 0.010| 0.098
>> CAN1 TX[7b3] | 0.01| 0.001| 0.006
>> peak | | 0.000| 0.099
>> CAN1 TX[7e2] | 0.02| 0.002| 0.011
>> peak | | 0.010| 0.099
>> CAN1 TX[7e4] | 0.08| 0.008| 0.048
>> peak | | 0.049| 0.107
>> Cmd:State | 0.00| 0.000| 0.005
>> peak | | 0.000| 0.094
>> On Fri, 17 May 2024 at 15:26, Michael Geddes <frog at bunyip.wheelycreek.net>
>> wrote:
>>> This is what I have now.
>>> The one on the end is the one MIchael B was after using an N of 32. (up
>>> for discussion).
>>> The middle is the time spent in that even t per second. It accumulates
>>> times (in microseconds), and then every 10s it stores it as smoothed (N=16)
>>> value.
>>> The Count is similar (except that we store a value of '100' as 1 event
>>> so it can be still integers and has 2 decimal places).
>>> Every received poll does a 64bit difference to 32bit (for the elapsed
>>> time) and 64bit comparison (for end-of-period).
>>> It also does 1x 32bit smoothing and 2x 32bit adds.
>>> Then at the end of a 10s period, it will do a 64bit add to get the next
>>> end-of-period value, as well as the 2x 32bit smoothing calcs.
>>> This is from the Ioniq 5 so not any big values yet. You can certainly
>>> see how insignificant the TX callbacks are.
>>> I'll leave it on for when the car is moving and gets some faster polling.
>>> OVMS# poll time status
>>> Type | Count | Ave time | Ave Length
>>> Poll:PRI | 1.00| 0.540| 0.539
>>> Poll:SRX | 0.03| 0.004| 0.017
>>> CAN1 RX[778] | 0.06| 0.042| 0.175
>>> CAN1 TX[770] | 0.04| 0.002| 0.008
>>> Cmd:State | 0.01| 0.001| 0.005
>>> ----------------------8<--------------------------------
>>> Nice smoothing class (forces N as a power of 2):
>>> constexpr unsigned floorlog2(unsigned x)
>>> return x == 1 ? 0 : 1+floorlog2(x >> 1);
>>> /* Maintain a smoothed average using shifts for division.
>>> * T should be an integer type
>>> * N needs to be a power of 2
>>> template <typename T, unsigned N>
>>> class average_util_t
>>> private:
>>> T m_ave;
>>> public:
>>> average_util_t() : m_ave(0) {}
>>> static const uint8_t _BITS = floorlog2(N);
>>> void add( T val)
>>> static_assert(N == (1 << _BITS), "N must be a power of 2");
>>> m_ave = (((N-1) * m_ave) + val) >> _BITS;
>>> T get() { return m_ave; }
>>> operator T() { return m_ave; }
>>> On Thu, 16 May 2024 at 10:29, Michael Geddes <
>>> frog at bunyip.wheelycreek.net> wrote:
>>>> Thanks Michael,
>>>> My calculations give me ((2^32)-1) / (1000*1000*3600) = only 1.2 hours
>>>> of processing time in 32bit. The initial subtraction is 64bit anyway and I
>>>> can't see a further 64bit addition being a problem. I have the calculations
>>>> being performed in doubles at print-out where performance is not really an
>>>> issue anyway. (Though apparently doing 64 bit division is worse than
>>>> floating point).
>>>> In addition
>>>> * I currently have this being able to be turned on and off and reset
>>>> manually (only do it when required).
>>>> * For the lower volume commands, the smoothed average is not going to
>>>> be useful - the count is more interesting for different reasons.
>>>> * The total time is quite useful. Ie a high average time doesn't matter
>>>> if the count is low. The things that are affecting performance are stuff
>>>> with high total time. Stuff which is happening 100 times a second needs to
>>>> be a much lower average than once a second.
>>>> * A measure like 'time per minute/second' and possibly count per
>>>> minute/seconds as a smoothed average would potentially be more useful. (or
>>>> in addition?)
>>>> I think we could do _that_ in a reasonably efficient manner using a 64
>>>> bit 'last measured time', a 32 bit accumulated value and the stored 32 bit
>>>> rolling average.
>>>> It would boils down to some iterative (integer) sums and
>>>> multiplications plus a divide by n ^ (time periods passed) - which is a
>>>> shift - and which can be optimised to '0' if 'time-periods-passed' is more
>>>> than 32/(bits-per-n) - effectively limiting the number of iterations.
>>>> The one issue I can see is that we need to calculate 'number of
>>>> time-periods passed' which is a 64 bit subtraction followed by a 32 bit
>>>> division (not optimisable to a simple shift).
>>>> * I'm also happy to keep a rolling (32bit) average time.
>>>> Even if you assume averages in the 100ms, 32bit is going to happily
>>>> support an N of 64 or even 128.
>>>> Am I right in thinking that the choice of N is highly dependent on
>>>> frequency. For things happening 100 times per second, you might want an N
>>>> like 128.. where things happening once per
>>>> second, you might want an N of 4 or 8. The other things we keep
>>>> track of in this manner we have a better idea of the frequency of the thing.
>>>> How about we have (per record type):
>>>> * total count (since last reset?) (32 bit)
>>>> * smoothed average of time per instance (32 bit)
>>>> * ?xx? total accumulated time since last reset (64bit) ?? <-- with
>>>> the below stats this is much less useful
>>>> * last-measured-time (64 bit)
>>>> * accumulated count since last time-period (16bit - but maybe 32bit
>>>> anyway for byte alignment?)
>>>> * smoothed average of count per time-period (32bit)
>>>> * accumulated time since last time-period (32bit)
>>>> * smoothed average of time per time-period (32bit)
>>>> It's possible to keep the
>>>> Is this going to be too much per record type? The number of 'records'
>>>> we are keeping is quite low (so 10 to 20 maybe) - so it's not a huge memory
>>>> burden.
>>>> Thoughts?
>>>> //.ichael
>>>> On Thu, 16 May 2024 at 03:09, Michael Balzer via OvmsDev <
>>>>> esp_timer_get_time() is the right choice for precision timing.
>>>>> I'd say uint32 is enough though, even if counting microseconds that
>>>>> can hold a total of more than 71 hours of actual processing time. uint64
>>>>> has a significant performance penalty, although I don't recall the overhead
>>>>> for simple additions.
>>>>> Also & more important, the average wouldn't be my main focus, but the
>>>>> maximum processing time seen per ID, which seems to be missing in your
>>>>> draft.
>>>>> Second thought on the average… the exact overall average really has a
>>>>> minor meaning, I'd rather see the current average, adapting to the current
>>>>> mode of operation (drive/charge/…). I suggest feeding the measurements to a
>>>>> low pass filter to get the smoothed average of the last n measurements.
>>>>> Pattern:
>>>>> runavg = ((N-1) * runavg + newval) / N
>>>>> By using a low power of 2 for N (e.g. 8 or 16), you can replace the
>>>>> division by a simple bit shift, and have enough headroom to use 32 bit
>>>>> integers.
>>>>> Regards,
>>>>> Michael
>>>>> Am 15.05.24 um 06:51 schrieb Michael Geddes via OvmsDev:
>>>>> Formatting aside, I have implemented what I think Michael B was
>>>>> suggesting. This is a sample run on the Ioniq 5 (which doesn't have
>>>>> unsolicited RX events).
>>>>> This uses the call esp_timer_get_time() got get a 64bit *microseconds*
>>>>> since started value - and works out the time to execute that way. It's
>>>>> looking at absolute time and not time in the Task - so other things going
>>>>> on at the same time in other tasks will have an effect. (The normal tick
>>>>> count doesn't have nearly enough resolution to be useful - any other ideas
>>>>> on measurement?) I've got total accumulated time displaying in seconds and
>>>>> the average in milliseconds currently - but I can change that easy enough.
>>>>> The cumulative time is stored as uint64_t which will be plenty, as
>>>>> 32bit wouldn't be nearly enough.
>>>>> OVMS# *poller time on*
>>>>> Poller timing is now on
>>>>> OVMS# *poller time status*
>>>>> Poll [PRI] : n=390 tot=0.2s ave=0.586ms
>>>>> Poll [SRX] : n=316 tot=0.1s ave=0.196ms
>>>>> CAN1 RX[0778] : n=382 tot=0.2s ave=0.615ms
>>>>> CAN1 RX[07a8] : n=48 tot=0.0s ave=0.510ms
>>>>> CAN1 RX[07bb] : n=162 tot=0.1s ave=0.519ms
>>>>> CAN1 RX[07ce] : n=33 tot=0.0s ave=0.469ms
>>>>> CAN1 RX[07ea] : n=408 tot=0.2s ave=0.467ms
>>>>> CAN1 RX[07ec] : n=486 tot=0.2s ave=0.477ms
>>>>> CAN3 RX[07df] : n=769 tot=0.2s ave=0.261ms
>>>>> CAN1 TX[0770] : n=191 tot=0.0s ave=0.054ms
>>>>> CAN1 TX[07a0] : n=16 tot=0.0s ave=0.047ms
>>>>> CAN1 TX[07b3] : n=31 tot=0.0s ave=0.069ms
>>>>> CAN1 TX[07c6] : n=11 tot=0.0s ave=0.044ms
>>>>> CAN1 TX[07e2] : n=82 tot=0.0s ave=0.067ms
>>>>> CAN1 TX[07e4] : n=54 tot=0.0s ave=0.044ms
>>>>> Set State : n=7 tot=0.0s ave=0.104ms
>>>>> This is probably going to be quite useful in general! The TX
>>>>> call-backs don't seem to be significant here. (oh, I should probably
>>>>> implement a reset of the values too).
>>>>> //.ichael
>>>>> On Sun, 12 May 2024 at 22:58, Michael Geddes <
>>>>>> Yeah - I certainly wasn't going to put a hard limit. Just a log above
>>>>>> a certain time, that being said, the idea of just collecting stats (being
>>>>>> able to turn it on via a "poller timer" set of commands) would be much
>>>>>> more useful. I'll look into that.
>>>>>> Average time is probably a good stat - and certainly what we care
>>>>>> about.
>>>>>> I actually am hopeful that those couple of things I did might help
>>>>>> reduce that average time quite a bit (that short-cutting the isotp protocol
>>>>>> handling especially).
>>>>>> That p/r with logging changes might help reduce the unproductive log
>>>>>> time further, but also makes it possible to turn on the poller logging
>>>>>> without the RX task logs kicking in.
>>>>>> //.ichael
>>>>>> On Sun, 12 May 2024 at 22:29, Michael Balzer via OvmsDev <
>>>>>>> Warning / gathering debug statistics about slow processing can be
>>>>>>> helpful, but there must not be a hard limit. Frame/poll response processing
>>>>>>> may need disk or network I/O, and the vehicle task may be starving from
>>>>>>> punctual high loads on higher priority tasks (e.g. networking) or by
>>>>>>> needing to wait for some semaphore -- that's outside the application's
>>>>>>> control, and must not lead to termination/recreation of the task (in case
>>>>>>> you're heading towards that direction).
>>>>>>> I have no idea how much processing time the current vehicles
>>>>>>> actually need in their respective worst cases. Your draft is probably too
>>>>>>> lax, poll responses and frames normally need to be processed much faster.
>>>>>>> I'd say 10 ms is already too slow, but any wait for a queue/semaphore will
>>>>>>> already mean at least 10 ms (FreeRTOS tick). Probably best to begin with
>>>>>>> just collecting stats.
>>>>>>> Btw, to help in narrowing down the actual problem case, the profiler
>>>>>>> could collect max times per RX message ID.
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 12.05.24 um 10:41 schrieb Michael Geddes:
>>>>>>> I have a question for Michael B (or whoever) - I have a commit
>>>>>>> lined up that would add a bit of a time check to the poller loop. What do
>>>>>>> we expect the maximum time to execute a poller loop command should be?
>>>>>>> This is a rough idea (in ms) I have.. based on nothing much really,
>>>>>>> so any ideas would be appreciated:
>>>>>>> int TardyMaxTime_ms(OvmsPoller::OvmsPollEntryType entry_type)
>>>>>>> switch (entry_type)
>>>>>>> case OvmsPoller::OvmsPollEntryType::Poll: return 80;
>>>>>>> case OvmsPoller::OvmsPollEntryType::FrameRx: return 30;
>>>>>>> case OvmsPoller::OvmsPollEntryType::FrameTx: return 20;
>>>>>>> case OvmsPoller::OvmsPollEntryType::Command: return 10;
>>>>>>> case OvmsPoller::OvmsPollEntryType::PollState: return 15;
>>>>>>> default: return 80;
>>>>>>> //.ichael
>>>>>>> On Mon, 6 May 2024 at 07:45, Michael Geddes <
>>>>>>>> I realise that I was only using the standard cable to test - which
>>>>>>>> probably is not sufficient - I haven't looked closely at how the Leaf OBD
>>>>>>>> to Db9 cable is different from standard.
>>>>>>>> Ah, my bad out the queue length. We are definitely queueing more
>>>>>>>> messages though. From my log of when the overflow happened, the poller
>>>>>>>> was in state 0 which means OFF - ie nothing was being sent!!
>>>>>>>> I'll look at the TX message thing - opt in sounds good - though it
>>>>>>>> shouldn't be playing that much of a part here as the TXs are infrequent in
>>>>>>>> this case (or zero when the leaf is off or driving) - On the ioniq 5 when
>>>>>>>> I'm using the HUD - I'm polling quite frequently - multiple times per
>>>>>>>> second and that seems to be fine!.
>>>>>>>> I did find an issue with the throttling .. but it would still
>>>>>>>> mostly apply the throttling where it matters, so again, it shouldn't be the
>>>>>>>> problem (also, we aren't transmitting in the leaf case).
>>>>>>>> The change I made to the logging of RX messages showed how many in
>>>>>>>> a row were dropped... and it was mostly 1 only in a run - which means even
>>>>>>>> if it is a short time between - that means that the drops are being
>>>>>>>> interleaved by at least one success!
>>>>>>>> Sooo.. I'm still wondering what is going on. Some things I'm going
>>>>>>>> to try:
>>>>>>>> * If the number of messages on the Can bus (coming in through RX)
>>>>>>>> means that the queue is slowly getting longer and not quite catching up,
>>>>>>>> then making the queue longer will help it last longer... but only pushes
>>>>>>>> the problem down the road.
>>>>>>>> - Add 'current queue length' to the poller status information to
>>>>>>>> see if this is indeed the case?
>>>>>>>> - Add some kind of alert when the queue reaches a % full?
>>>>>>>> * Once you start overflowing and getting overflow log messages, I
>>>>>>>> wonder if this is then contributing to the problem.
>>>>>>>> - Push the overflow logging into Poller Task which can look at
>>>>>>>> how many drops occurred since last received item.
>>>>>>>> * Split up the flags for the poller messages into 2:
>>>>>>>> - Messages that are/could be happening in the TX/RX tasks
>>>>>>>> - Other noisy messages that always happen in the poller task.
>>>>>>>> Thoughts on what else we might measure to figure out what is going
>>>>>>>> on?
>>>>>>>> //.ichael
>>>>>>>> On Sun, 5 May 2024, 19:29 Michael Balzer via OvmsDev, <
>>>>>>>>> Michael,
>>>>>>>>> the queue size isn't in bytes, it's in messages:
>>>>>>>>> * @param uxQueueLength The maximum number of items that the queue
>>>>>>>>> can contain.
>>>>>>>>> * @param uxItemSize The number of bytes each item in the queue
>>>>>>>>> will require.
>>>>>>>>> Also, from the time stamps in Dereks log excerpt, there were quite
>>>>>>>>> some dropped frames in that time window -- at least 23 frames in 40 ms,
>>>>>>>>> that's bad.
>>>>>>>>> Queue sizes are currently:
>>>>>>>>> CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=60
>>>>>>>>> CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=60
>>>>>>>>> The new poller now channels all TX callbacks through the task
>>>>>>>>> queue additionally to RX and commands. So setting the queue size to be
>>>>>>>>> larger than the CAN RX queue size seems appropriate.
>>>>>>>>> Nevertheless, an overflow with more than 60 waiting messages still
>>>>>>>>> indicates some too long processing time in the vehicle task.
>>>>>>>>> TX callbacks previously were done directly in the CAN context, and
>>>>>>>>> no current vehicle overrides the empty default handler, so this imposed
>>>>>>>>> almost no additional overhead. By requiring a queue entry for each TX
>>>>>>>>> callback, this feature now has a potentially high impact for all vehicles.
>>>>>>>>> If passing these to the task is actually necessary, it needs to become an
>>>>>>>>> opt-in feature, so only vehicles subscribing to the callback actually need
>>>>>>>>> to cope with that additional load & potential processing delays involved.
>>>>>>>>> Regards,
>>>>>>>>> Michael
>>>>>>> OvmsDev mailing list
>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240526/d017a95e/attachment-0001.htm>
