Sun May 19 12:54:10 HKT 2024
If the configuration gets more complex, you can provide a web plugin, or
a builtin page that needs to be enabled explicitly by the developer,
e.g. to be placed in the vehicle menu. That way the developer can decide
when to show/hide this from users.
Am 19.05.24 um 06:50 schrieb Michael Balzer via OvmsDev:
> A builtin web UI for this seems a bit over the top. Builtin web config
> pages should focus on user features, this is clearly a feature only
> needed during/for the development/extension of a vehicle adapter.
> Development features in the web UI are confusing for end users.
> If persistent enabling/disabling is done by a simple config command
> (e.g. "config set can poller.trace on"), that's also doable by users.
> Am 19.05.24 um 02:06 schrieb Michael Geddes:
>> I was so focused on how I calculated the value that I totally
>> missed that ‰ would be a better description.  I could also use the
>> system 'Ratio' unit... so % or ‰.
>> I'll make space to put 'Avg' on the row. Was trying to limit the
>> width for output on a mobile.  I agree it would make it easier to
>> understand.
>> Totals also makes sense.
>> Should I make this a configuration that can be set on the web-page?
>>  I'd probably use a configuration change notification so that the
>> very bit setting is sync'd with the 'configuration' value.
>> //.ichael
>> On Sat, 18 May 2024, 14:05 Michael Balzer, <dexter at expeedo.de> wrote:
>>>     I'm not sure whether the 'max' should be the maximum of the
>>>     smoothed value.. or the maximum of the raw value.
>>     It should normally be the maximum of the raw value I think, the
>>     maximum of the smoothed value cannot tell about how bad the
>>     processing of an ID can become.
>>     The naming in the table is a bit confusing I think. (besides:
>>     I've never seen "ave" as the abbreviation for average)
>>     If I understand you correctly, "time ms per s" is the time share
>>     in per mille, so something in that direction would be more clear,
>>     and "length ms" would then be "time [ms]".
>>     The totals for all averages in the table foot would also be nice.
>>     Maybe "Ave" (or avg?) also should be placed on the left, as the
>>     "peak" label now suggests being the peak of the average.
>>     Btw, keep in mind, not all "edge" users / testers are developers
>>     (e.g. the Twizy driver I'm in contact with), collecting stats
>>     feedback for vehicles from testers should be straight forward.
>>     Maybe add a data/history record, sent automatically on every
>>     drive/charge stop when the poller tracing is on?
>>     Regards,
>>     Michael
>>     Am 18.05.24 um 02:28 schrieb Michael Geddes:
>>>     You did say max/pead value.  I also halved the N for both.
>>>     This is currently the raw-value maximum.
>>>     The problem is that the middle column is the maximum of the
>>>     {{sum over 10s} / (10*1000,000)
>>>     I could easily change the 'period' to 1s and see how that goes..
>>>     was just trying to reduce the larger calculations.
>>>     Usage: poller [pause|resume|status|times|trace]
>>>     OVMS# poller time status
>>>     Poller timing is: on
>>>     Type         | Count    | Ave time  | Ave length
>>>                  | per s    | ms per s  | ms
>>>     Poll:PRI     |      1.00|      0.559|  0.543
>>>      peak        |          |      0.663|  1.528
>>>     Poll:SRX     |      0.08|      0.009|  0.038
>>>      peak        |          |      0.068|  0.146
>>>     CAN1 RX[778] |      0.11|      0.061|  0.280
>>>      peak        |          |      0.458|  1.046
>>>     CAN1 RX[7a8] |      0.04|      0.024|  0.124
>>>      peak        |          |      0.160|  0.615
>>>     CAN1 TX[770] |      0.05|      0.004|  0.016
>>>      peak        |          |      0.022|  0.102
>>>     CAN1 TX[7a0] |      0.02|      0.002|  0.011
>>>      peak        |          |      0.010|  0.098
>>>     CAN1 TX[7b3] |      0.01|      0.001|  0.006
>>>      peak        |          |      0.000|  0.099
>>>     CAN1 TX[7e2] |      0.02|      0.002|  0.011
>>>      peak        |          |      0.010|  0.099
>>>     CAN1 TX[7e4] |      0.08|      0.008|  0.048
>>>      peak        |          |      0.049|  0.107
>>>     Cmd:State    |      0.00|      0.000|  0.005
>>>      peak        |          |      0.000|  0.094
>>>     On Fri, 17 May 2024 at 15:26, Michael Geddes
>>>     <frog at bunyip.wheelycreek.net> wrote:
>>>         This is what I have now.
>>>         The one on the end is the one  MIchael B was after using an
>>>         N of 32. (up for discussion).
>>>         The middle is the time  spent in that even t per second.  It
>>>         accumulates times (in microseconds), and then every 10s it
>>>         stores it as smoothed (N=16) value.
>>>         The Count is similar (except that we store a value of '100'
>>>         as 1 event so it can be still integers and has 2 decimal
>>>         places).
>>>         Every received poll  does a 64bit difference to 32bit (for
>>>         the elapsed time) and 64bit comparison (for end-of-period).
>>>         It also does 1x 32bit smoothing and 2x 32bit adds.
>>>         Then at the end of a 10s period, it will do a 64bit add to
>>>         get the next end-of-period value, as well as the 2x 32bit
>>>         smoothing calcs.
>>>         This is from the Ioniq 5 so not any big values yet.  You can
>>>         certainly see how insignificant the TX callbacks are.
>>>         I'll leave it on for when the car is moving and gets some
>>>         faster polling.
>>>         OVMS# poll time status
>>>         Type         | Count    | Ave time  | Ave Length
>>>         Poll:PRI     |      1.00|      0.540|    0.539
>>>         Poll:SRX     |      0.03|      0.004|    0.017
>>>         CAN1 RX[778] |      0.06|      0.042|    0.175
>>>         CAN1 TX[770] |      0.04|      0.002|    0.008
>>>         Cmd:State    |      0.01|      0.001|    0.005
>>>         ----------------------8<--------------------------------
>>>         Nice smoothing class (forces N as a power of 2):
>>>           constexpr unsigned floorlog2(unsigned x)
>>>             return x == 1 ? 0 : 1+floorlog2(x >> 1);
>>>           /* Maintain a smoothed average using shifts for division.
>>>            * T should be an integer type
>>>            * N needs to be a power of 2
>>>           template <typename T, unsigned N>
>>>           class average_util_t
>>>             private:
>>>               T m_ave;
>>>             public:
>>>               average_util_t() : m_ave(0) {}
>>>               static const uint8_t _BITS = floorlog2(N);
>>>               void add( T val)
>>>                 static_assert(N == (1 << _BITS), "N must be a power
>>>         of 2");
>>>                 m_ave = (((N-1) * m_ave) + val) >> _BITS;
>>>               T get() { return m_ave; }
>>>               operator T() { return m_ave; }
>>>         On Thu, 16 May 2024 at 10:29, Michael Geddes
>>>             Thanks Michael,
>>>             My calculations give me ((2^32)-1) / (1000*1000*3600) =
>>>             only 1.2 hours of processing time in 32bit.  The initial
>>>             subtraction is 64bit anyway and I can't see a
>>>             further 64bit addition being a problem. I have the
>>>             calculations being performed in doubles at print-out
>>>             where performance is not really an issue anyway. (Though
>>>             apparently doing 64 bit division is worse than floating
>>>             point).
>>>             In addition
>>>             * I currently have this being able to be turned on and
>>>             off and reset manually (only do it when required).
>>>             *  For the lower volume commands, the smoothed average
>>>             is not going to be useful - the count is more
>>>             interesting for different reasons.
>>>             * The total time is quite useful. Ie a high average time
>>>             doesn't matter if the count is low.  The things that are
>>>             affecting performance are stuff with high total time.
>>>             Stuff which is happening 100 times a second needs to be
>>>             a much lower average than once a second.
>>>             * A measure like 'time per minute/second' and possibly
>>>             count per minute/seconds as a smoothed average would
>>>             potentially be more useful. (or in addition?)
>>>             I think we could do _that_ in a reasonably efficient
>>>             manner using a 64 bit 'last measured time', a 32 bit
>>>             accumulated value and the stored 32 bit rolling average.
>>>             It would boils down to some iterative (integer) sums and
>>>             multiplications plus a divide by n ^ (time periods
>>>             passed) - which is a shift - and which can be optimised
>>>             to '0' if 'time-periods-passed' is more than
>>>             32/(bits-per-n) - effectively limiting the number of
>>>             iterations.
>>>             The one issue I can see is that we need to calculate
>>>             'number of time-periods passed' which is a 64 bit
>>>             subtraction followed by a 32 bit division (not
>>>             optimisable to a simple shift).
>>>             * I'm also happy to keep a rolling (32bit) average time.
>>>                Even if you assume averages in the 100ms, 32bit is
>>>             going to happily support an N of 64 or even 128.
>>>                Am I right in thinking that the choice of N is highly
>>>             dependent on frequency. For things happening 100 times
>>>             per second, you might want an N like 128.. where things
>>>             happening once per
>>>                second, you might want an N of 4 or 8.  The other
>>>             things we keep track of in this manner we have a better
>>>             idea of the frequency of the thing.
>>>             How about we have (per record type):
>>>               * total count (since last reset?) (32 bit)
>>>               * smoothed average of time per instance (32 bit)
>>>               * ?xx? total accumulated time since last reset (64bit)
>>>             ?? <-- with the below stats this is much less useful
>>>               * last-measured-time (64 bit)
>>>               * accumulated count since last time-period (16bit -
>>>             but maybe 32bit anyway for byte alignment?)
>>>               * smoothed average of count per time-period (32bit)
>>>               * accumulated time since last time-period (32bit)
>>>               * smoothed average of time per time-period (32bit)
>>>             It's possible to keep the
>>>             Is this going to be too much per record type?  The
>>>             number of 'records' we are keeping is quite low (so 10
>>>             to 20 maybe) - so it's not a huge memory burden.
>>>             Thoughts?
>>>             //.ichael
>>>             On Thu, 16 May 2024 at 03:09, Michael Balzer via OvmsDev
>>>             <ovmsdev at lists.openvehicles.com> wrote:
>>>                 esp_timer_get_time() is the right choice for
>>>                 precision timing.
>>>                 I'd say uint32 is enough though, even if counting
>>>                 microseconds that can hold a total of more than 71
>>>                 hours of actual processing time. uint64 has a
>>>                 significant performance penalty, although I don't
>>>                 recall the overhead for simple additions.
>>>                 Also & more important, the average wouldn't be my
>>>                 main focus, but the maximum processing time seen per
>>>                 ID, which seems to be missing in your draft.
>>>                 Second thought on the average… the exact overall
>>>                 average really has a minor meaning, I'd rather see
>>>                 the current average, adapting to the current mode of
>>>                 operation (drive/charge/…). I suggest feeding the
>>>                 measurements to a low pass filter to get the
>>>                 smoothed average of the last n measurements. Pattern:
>>>                 runavg = ((N-1) * runavg + newval) / N
>>>                 By using a low power of 2 for N (e.g. 8 or 16), you
>>>                 can replace the division by a simple bit shift, and
>>>                 have enough headroom to use 32 bit integers.
>>>                 Regards,
>>>                 Michael
>>>                 Am 15.05.24 um 06:51 schrieb Michael Geddes via OvmsDev:
>>>>                 Formatting aside, I have implemented what I think
>>>>                 Michael B was suggesting.  This is a sample run on
>>>>                 the Ioniq 5 (which doesn't have unsolicited RX
>>>>                 events).
>>>>                 This uses the call esp_timer_get_time() got get a
>>>>                 64bit *microseconds* since started value - and
>>>>                 works out the time to execute that way. It's
>>>>                 looking at absolute time and not time in the Task -
>>>>                 so other things going on at the same time in other
>>>>                 tasks will have an effect.  (The normal tick count
>>>>                 doesn't have nearly enough resolution to be useful
>>>>                 - any other ideas on measurement?) I've got total
>>>>                 accumulated time displaying in seconds and the
>>>>                 average in milliseconds currently - but I can
>>>>                 change that easy enough.
>>>>                 The cumulative time is stored as uint64_t which
>>>>                 will be plenty, as 32bit wouldn't be nearly enough.
>>>>                 OVMS# *poller time on*
>>>>                 Poller timing is now on
>>>>                 OVMS# *poller time status*
>>>>                 Poll [PRI]   : n=390 tot=0.2s ave=0.586ms
>>>>                 Poll [SRX]   : n=316 tot=0.1s ave=0.196ms
>>>>                 CAN1 RX[0778]    : n=382 tot=0.2s ave=0.615ms
>>>>                 CAN1 RX[07a8]    : n=48 tot=0.0s ave=0.510ms
>>>>                 CAN1 RX[07bb]    : n=162 tot=0.1s ave=0.519ms
>>>>                 CAN1 RX[07ce]    : n=33 tot=0.0s ave=0.469ms
>>>>                 CAN1 RX[07ea]    : n=408 tot=0.2s ave=0.467ms
>>>>                 CAN1 RX[07ec]    : n=486 tot=0.2s ave=0.477ms
>>>>                 CAN3 RX[07df]    : n=769 tot=0.2s ave=0.261ms
>>>>                 CAN1 TX[0770]    : n=191 tot=0.0s ave=0.054ms
>>>>                 CAN1 TX[07a0]    : n=16 tot=0.0s ave=0.047ms
>>>>                 CAN1 TX[07b3]    : n=31 tot=0.0s ave=0.069ms
>>>>                 CAN1 TX[07c6]    : n=11 tot=0.0s ave=0.044ms
>>>>                 CAN1 TX[07e2]    : n=82 tot=0.0s ave=0.067ms
>>>>                 CAN1 TX[07e4]    : n=54 tot=0.0s ave=0.044ms
>>>>                 Set State    : n=7 tot=0.0s ave=0.104ms
>>>>                 This is probably going to be quite useful in
>>>>                 general!  The TX call-backs don't seem to be
>>>>                 significant here. (oh, I should probably implement
>>>>                 a reset of the values too).
>>>>                 //.ichael
>>>>                 On Sun, 12 May 2024 at 22:58, Michael Geddes
>>>>                     Yeah - I certainly wasn't going to put a hard
>>>>                     limit. Just a log above a certain time, that
>>>>                     being said, the idea of just collecting stats
>>>>                     (being able to turn it on via a  "poller timer"
>>>>                     set of commands) would be much more useful.
>>>>                     I'll look into that.
>>>>                     Average time is probably a good stat - and
>>>>                     certainly what we care about.
>>>>                     I actually am hopeful that those couple of
>>>>                     things I did might help reduce that average
>>>>                     time quite a bit (that short-cutting the isotp
>>>>                     protocol handling especially).
>>>>                     That p/r with logging changes might help reduce
>>>>                     the unproductive log time further, but
>>>>                     also makes it possible to turn on the poller
>>>>                     logging without the RX task logs kicking in.
>>>>                     //.ichael
>>>>                     On Sun, 12 May 2024 at 22:29, Michael Balzer
>>>>                     via OvmsDev <ovmsdev at lists.openvehicles.com> wrote:
>>>>                         Warning / gathering debug statistics about
>>>>                         slow processing can be helpful, but there
>>>>                         must not be a hard limit. Frame/poll
>>>>                         response processing may need disk or
>>>>                         network I/O, and the vehicle task may be
>>>>                         starving from punctual high loads on higher
>>>>                         priority tasks (e.g. networking) or by
>>>>                         needing to wait for some semaphore --
>>>>                         that's outside the application's control,
>>>>                         and must not lead to termination/recreation
>>>>                         of the task (in case you're heading towards
>>>>                         that direction).
>>>>                         I have no idea how much processing time the
>>>>                         current vehicles actually need in their
>>>>                         respective worst cases. Your draft is
>>>>                         probably too lax, poll responses and frames
>>>>                         normally need to be processed much faster.
>>>>                         I'd say 10 ms is already too slow, but any
>>>>                         wait for a queue/semaphore will already
>>>>                         mean at least 10 ms (FreeRTOS tick).
>>>>                         Probably best to begin with just collecting
>>>>                         stats.
>>>>                         Btw, to help in narrowing down the actual
>>>>                         problem case, the profiler could collect
>>>>                         max times per RX message ID.
>>>>                         Regards,
>>>>                         Michael
>>>>                         Am 12.05.24 um 10:41 schrieb Michael Geddes:
>>>>>                         I have a question for Michael B  (or
>>>>>                         whoever) - I have a commit lined up that
>>>>>                         would add a bit of a time check to the
>>>>>                         poller loop. What do we expect the
>>>>>                         maximum time to execute a poller loop
>>>>>                         command should be?
>>>>>                         This is a rough idea (in ms) I have..
>>>>>                         based on nothing much really, so any ideas
>>>>>                         would be appreciated:
>>>>>                             int
>>>>>                         TardyMaxTime_ms(OvmsPoller::OvmsPollEntryType
>>>>>                         entry_type)
>>>>>                               switch (entry_type)
>>>>>                                 case
>>>>>                         OvmsPoller::OvmsPollEntryType::Poll:
>>>>>                         return 80;
>>>>>                                 case
>>>>>                         OvmsPoller::OvmsPollEntryType::FrameRx:
>>>>>                         return 30;
>>>>>                                 case
>>>>>                         OvmsPoller::OvmsPollEntryType::FrameTx:
>>>>>                         return 20;
>>>>>                                 case
>>>>>                         OvmsPoller::OvmsPollEntryType::Command:
>>>>>                         return 10;
>>>>>                                 case
>>>>>                         OvmsPoller::OvmsPollEntryType::PollState:
>>>>>                         return 15;
>>>>>                         default: return 80;
>>>>>                         //.ichael
>>>>>                         On Mon, 6 May 2024 at 07:45, Michael
>>>>>                         Geddes <frog at bunyip.wheelycreek.net> wrote:
>>>>>                             I realise that I was only using the
>>>>>                             standard cable to test - which
>>>>>                             probably is not sufficient - I haven't
>>>>>                             looked closely at how the Leaf OBD to
>>>>>                             Db9 cable is different from standard.
>>>>>                             Ah, my bad out the queue length.  We
>>>>>                             are definitely queueing more messages
>>>>>                             though.   From my log of when the
>>>>>                             overflow happened, the poller was in
>>>>>                             state 0 which means OFF - ie nothing
>>>>>                             was being sent!!
>>>>>                             I'll look at the TX message thing -
>>>>>                             opt in sounds good - though it
>>>>>                             shouldn't be playing that much of a
>>>>>                             part here as the TXs are infrequent in
>>>>>                             this case (or zero when the leaf is
>>>>>                             off or driving) - On the ioniq 5 when
>>>>>                             I'm using the HUD - I'm polling quite
>>>>>                             frequently - multiple times per second
>>>>>                             and that seems to be fine!.
>>>>>                             I did find an issue with the
>>>>>                             throttling .. but  it would still
>>>>>                             mostly apply the throttling where it
>>>>>                             matters, so again, it shouldn't be the
>>>>>                             problem (also, we aren't transmitting
>>>>>                             in the leaf case).
>>>>>                             The change I made to the logging of RX
>>>>>                             messages showed how many in a row were
>>>>>                             dropped... and it was mostly 1 only in
>>>>>                             a run - which means even if it is a
>>>>>                             short time between - that means that
>>>>>                             the drops are being interleaved by at
>>>>>                             least one success!
>>>>>                             Sooo.. I'm still wondering what is
>>>>>                             going on. Some things I'm going to try:
>>>>>                             * If the number of messages on the Can
>>>>>                             bus (coming in through RX) means that
>>>>>                             the queue is slowly getting longer and
>>>>>                             not quite catching up, then making the
>>>>>                             queue longer will help it last
>>>>>                             longer... but only pushes the problem
>>>>>                             down the road.
>>>>>                               - Add 'current queue length' to the
>>>>>                             poller status information to see if
>>>>>                             this is indeed the case?
>>>>>                               - Add some kind of alert when the
>>>>>                             queue reaches a % full?
>>>>>                             * Once you start overflowing and
>>>>>                             getting overflow log messages, I
>>>>>                             wonder if this is then contributing to
>>>>>                             the problem.
>>>>>                               - Push the overflow logging into
>>>>>                             Poller Task which can look at how many
>>>>>                             drops occurred since last received item.
>>>>>                             * Split up the flags for the poller
>>>>>                             messages into 2:
>>>>>                                - Messages that are/could be
>>>>>                             happening in the TX/RX tasks
>>>>>                                - Other noisy messages that always
>>>>>                             happen in the poller task.
>>>>>                             Thoughts on what else we might measure
>>>>>                             to figure out what is going on?
>>>>>                             //.ichael
>>>>>                             On Sun, 5 May 2024, 19:29 Michael
>>>>>                             Balzer via OvmsDev,
>>>>>                                 Michael,
>>>>>                                 the queue size isn't in bytes,
>>>>>                                 it's in messages:
>>>>>>                                  * @param uxQueueLength The
>>>>>>                                 maximum number of items that the
>>>>>>                                 queue can contain.
>>>>>>                                  * @param uxItemSize The number
>>>>>>                                 of bytes each item in the queue
>>>>>>                                 will require.
>>>>>                                 Also, from the time stamps in
>>>>>                                 Dereks log excerpt, there were
>>>>>                                 quite some dropped frames in that
>>>>>                                 time window -- at least 23 frames
>>>>>                                 in 40 ms, that's bad.
>>>>>                                 Queue sizes are currently:
>>>>>                                 CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=60
>>>>>                                 CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=60
>>>>>                                 The new poller now channels all TX
>>>>>                                 callbacks through the task queue
>>>>>                                 additionally to RX and commands.
>>>>>                                 So setting the queue size to be
>>>>>                                 larger than the CAN RX queue size
>>>>>                                 seems appropriate.
>>>>>                                 Nevertheless, an overflow with
>>>>>                                 more than 60 waiting messages
>>>>>                                 still indicates some too long
>>>>>                                 processing time in the vehicle task.
>>>>>                                 TX callbacks previously were done
>>>>>                                 directly in the CAN context, and
>>>>>                                 no current vehicle overrides the
>>>>>                                 empty default handler, so this
>>>>>                                 imposed almost no additional
>>>>>                                 overhead. By requiring a queue
>>>>>                                 entry for each TX callback, this
>>>>>                                 feature now has a potentially high
>>>>>                                 impact for all vehicles. If
>>>>>                                 passing these to the task is
>>>>>                                 actually necessary, it needs to
>>>>>                                 become an opt-in feature, so only
>>>>>                                 vehicles subscribing to the
>>>>>                                 callback actually need to cope
>>>>>                                 with that additional load &
>>>>>                                 potential processing delays involved.
>>>>>                                 Regards,
>>>>>                                 Michael
>>>>                         Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>                         Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>>>                         _______________________________________________
>>>>                         OvmsDev mailing list
>>>>                         OvmsDev at lists.openvehicles.com
>>>>                         http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240519/bcd6d078/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240519/bcd6d078/attachment-0001.sig>
