Michael Geddes
Sun May 12 16:41:12 HKT 2024
I have a question for Michael B (or whoever) - I have a commit lined up
that would add a bit of a time check to the poller loop. What do we expect
the maximum time to execute a poller loop command should be?
This is a rough idea (in ms) I have.. based on nothing much really, so any
ideas would be appreciated:
int TardyMaxTime_ms(OvmsPoller::OvmsPollEntryType entry_type)
switch (entry_type)
case OvmsPoller::OvmsPollEntryType::Poll: return 80;
case OvmsPoller::OvmsPollEntryType::FrameRx: return 30;
case OvmsPoller::OvmsPollEntryType::FrameTx: return 20;
case OvmsPoller::OvmsPollEntryType::Command: return 10;
case OvmsPoller::OvmsPollEntryType::PollState: return 15;
default: return 80;
//.ichael
On Mon, 6 May 2024 at 07:45, Michael Geddes <frog at bunyip.wheelycreek.net>
wrote:
> I realise that I was only using the standard cable to test - which
> probably is not sufficient - I haven't looked closely at how the Leaf OBD
> to Db9 cable is different from standard.
> Ah, my bad out the queue length. We are definitely queueing more
> messages though. From my log of when the overflow happened, the poller
> was in state 0 which means OFF - ie nothing was being sent!!
> I'll look at the TX message thing - opt in sounds good - though it
> shouldn't be playing that much of a part here as the TXs are infrequent in
> this case (or zero when the leaf is off or driving) - On the ioniq 5 when
> I'm using the HUD - I'm polling quite frequently - multiple times per
> second and that seems to be fine!.
> I did find an issue with the throttling .. but it would still mostly
> apply the throttling where it matters, so again, it shouldn't be the
> problem (also, we aren't transmitting in the leaf case).
> The change I made to the logging of RX messages showed how many in a row
> were dropped... and it was mostly 1 only in a run - which means even if it
> is a short time between - that means that the drops are being interleaved
> by at least one success!
> Sooo.. I'm still wondering what is going on. Some things I'm going to try:
> * If the number of messages on the Can bus (coming in through RX) means
> that the queue is slowly getting longer and not quite catching up, then
> making the queue longer will help it last longer... but only pushes the
> problem down the road.
> - Add 'current queue length' to the poller status information to see if
> this is indeed the case?
> - Add some kind of alert when the queue reaches a % full?
> * Once you start overflowing and getting overflow log messages, I wonder
> if this is then contributing to the problem.
> - Push the overflow logging into Poller Task which can look at how many
> drops occurred since last received item.
> * Split up the flags for the poller messages into 2:
> - Messages that are/could be happening in the TX/RX tasks
> - Other noisy messages that always happen in the poller task.
> Thoughts on what else we might measure to figure out what is going on?
> //.ichael
> On Sun, 5 May 2024, 19:29 Michael Balzer via OvmsDev, <
> ovmsdev at lists.openvehicles.com> wrote:
>> Michael,
>> the queue size isn't in bytes, it's in messages:
>> * @param uxQueueLength The maximum number of items that the queue can
>> contain.
>> * @param uxItemSize The number of bytes each item in the queue will
>> require.
>> Also, from the time stamps in Dereks log excerpt, there were quite some
>> dropped frames in that time window -- at least 23 frames in 40 ms, that's
>> bad.
>> Queue sizes are currently:
>> CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=60
>> CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=60
>> The new poller now channels all TX callbacks through the task queue
>> additionally to RX and commands. So setting the queue size to be larger
>> than the CAN RX queue size seems appropriate.
>> Nevertheless, an overflow with more than 60 waiting messages still
>> indicates some too long processing time in the vehicle task.
>> TX callbacks previously were done directly in the CAN context, and no
>> current vehicle overrides the empty default handler, so this imposed almost
>> no additional overhead. By requiring a queue entry for each TX callback,
>> this feature now has a potentially high impact for all vehicles. If passing
>> these to the task is actually necessary, it needs to become an opt-in
>> feature, so only vehicles subscribing to the callback actually need to cope
>> with that additional load & potential processing delays involved.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240512/1ac719a1/attachment.htm>
