Michael,
did you notice the Leaf is special in polling two buses (1 & 2) by
default? No other vehicle does that. Possibly some sort of deadlock
situation with interleaved bus responses?
Any frame dropped is an indicator for something bad happening, as that
means there's already a rather long backlog = response processing is too
slow.
On alerting when the queue grows, see `OvmsDuktape::EventScript()` -- I
added an alert there for this situation, when the Duktape queue grows
larger than 10 entries. But you probably should restrict the actual log
message creation e.g. using a modulo 10 check.
Maybe Derek can provide a CAN log catching the specific overflow case
along with the system log? That should show which frames lead to the
processing delay.
Am 06.05.24 um 01:45 schrieb Michael Geddes:
> I realise that I was only using the standard cable to test - which
> probably is not sufficient - I haven't looked closely at how the Leaf
> OBD to Db9 cable is different from standard.
> Ah, my bad out the queue length. We are definitely queueing more
> messages though. From my log of when the overflow happened, the
> poller was in state 0 which means OFF - ie nothing was being sent!!
> I'll look at the TX message thing - opt in sounds good - though it
> shouldn't be playing that much of a part here as the TXs are
> infrequent in this case (or zero when the leaf is off or driving) - On
> the ioniq 5 when I'm using the HUD - I'm polling quite frequently -
> multiple times per second and that seems to be fine!.
> I did find an issue with the throttling .. but it would still mostly
> apply the throttling where it matters, so again, it shouldn't be the
> problem (also, we aren't transmitting in the leaf case).
> The change I made to the logging of RX messages showed how many in a
> row were dropped... and it was mostly 1 only in a run - which means
> even if it is a short time between - that means that the drops are
> being interleaved by at least one success!
> Sooo.. I'm still wondering what is going on. Some things I'm going to
> try:
> * If the number of messages on the Can bus (coming in through RX)
> means that the queue is slowly getting longer and not quite catching
> up, then making the queue longer will help it last longer... but only
> pushes the problem down the road.
> - Add 'current queue length' to the poller status information to see
> if this is indeed the case?
> - Add some kind of alert when the queue reaches a % full?
> * Once you start overflowing and getting overflow log messages, I
> wonder if this is then contributing to the problem.
> - Push the overflow logging into Poller Task which can look at how
> many drops occurred since last received item.
> * Split up the flags for the poller messages into 2:
> - Messages that are/could be happening in the TX/RX tasks
> - Other noisy messages that always happen in the poller task.
> Thoughts on what else we might measure to figure out what is going on?
> //.ichael
> On Sun, 5 May 2024, 19:29 Michael Balzer via OvmsDev,
> <ovmsdev at lists.openvehicles.com> wrote:
> Michael,
> the queue size isn't in bytes, it's in messages:
>> * @param uxQueueLength The maximum number of items that the
>> queue can contain.
>> * @param uxItemSize The number of bytes each item in the queue
>> will require.
> Also, from the time stamps in Dereks log excerpt, there were quite
> some dropped frames in that time window -- at least 23 frames in
> 40 ms, that's bad.
> Queue sizes are currently:
> CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=60
> CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=60
> The new poller now channels all TX callbacks through the task
> queue additionally to RX and commands. So setting the queue size
> to be larger than the CAN RX queue size seems appropriate.
> Nevertheless, an overflow with more than 60 waiting messages still
> indicates some too long processing time in the vehicle task.
> TX callbacks previously were done directly in the CAN context, and
> no current vehicle overrides the empty default handler, so this
> imposed almost no additional overhead. By requiring a queue entry
> for each TX callback, this feature now has a potentially high
> impact for all vehicles. If passing these to the task is actually
> necessary, it needs to become an opt-in feature, so only vehicles
> subscribing to the callback actually need to cope with that
> additional load & potential processing delays involved.
> Am 05.05.24 um 11:59 schrieb Michael Geddes via OvmsDev:
>> OK.
>> I did some logging changes to confirm that it's only _just_
>> getting overwhelmed..ie dropping 1 (or occasionally 2) RX frames
>> in a row but then picking the next ones up...
>> So increasing the queue size (I doubled it but maybe that was
>> excessive) seems to do the trick. I think the queue size is in
>> bytes and the queue packet size has increased at least a little bit.
>> On Sat, 4 May 2024, 09:24 Michael Geddes,
>> <frog at bunyip.wheelycreek.net> wrote:
>> Hey Derek,
>> I do have a friend with a Leaf in his EV collection, so I
>> can try grab some more info from his car and work out exactly
>> what (tf) is going on.
>> On Sat, 4 May 2024 at 08:13, <frog at bunyip.wheelycreek.net> wrote:
>> HI Derek,
>> For a start, I’m very sorry that the ovms put your car in
>> limp mode. That’s quite bad.
>> Just FYI those overflows that you have copied are about
>> receiving and not sending information, so maybe the
>> poller thread is being overwhelmed or stalled somehow.
>> I’ve been looking at the code and wondered if you have
>> the ‘can write’ flag set to true or not? (Though it
>> shouldn’t make that much difference)
>> Even if it were somehow mistakenly polling (ie in the
>> wrong pollstate), it should not be doing it that
>> frequently – (at most once a minute). And the poll
>> throttle would still be on 1 per second.. so that should
>> put a limit on sends.. and so it is really worrying that
>> somehow that is not happening :/
>> If you have more logs that you send me that don’t just
>> include that particular overflow message that would be
>> good. Did it crash/reboot? Maybe it crashed repeatedly?
>> //.ichael
>> *From:*OvmsDev <ovmsdev-bounces at lists.openvehicles.com>
>> *On Behalf Of *Derek Caudwell via OvmsDev
>> *Sent:* Friday, May 3, 2024 6:54 PM
>> *To:* OVMS Developers <ovmsdev at lists.openvehicles.com>
>> *Cc:* Derek Caudwell <d.caudwell at gmail.com>
>> *Subject:* Re: [Ovmsdev] OVMS Poller module/singleton
>> Hi Michael,
>> When running firmware 3.3.004-74-gbd4e7196 on my Nissan
>> Leaf I suspect (but can't be 100% sure as it's only been
>> 24h without fault) the new poller caused the car to throw
>> the attached faults from overloading the can bus whilst
>> driving. The fault was sufficient to send the car into
>> limp mode and could not be driven until cleared with
>> LeafSpy. Ovms should not be polling in the driving state,
>> so I'm not sure why the poller is overflowing.
>> The ovms log repeats this overflow in rapid succession
>> right before the failure occurred. I have since reverted
>> to an earlier version and it might be advisable for
>> other Leaf owners to do so until the new poller is fully
>> operational.
>> 2024-05-02 12:22:28.316 NZST I (36847486) vehicle-poll:
>> Poller[Frame]: Task Queue Overflow
>> 2024-05-02 12:22:28.326 NZST I (36847496) vehicle-poll:
>> 2024-05-02 12:22:28.336 NZST I (36847506) vehicle-poll:
>> 2024-05-02 12:22:28.346 NZST I (36847516) vehicle-poll:
>> 2024-05-02 12:22:28.356 NZST I (36847526) vehicle-poll:
>> On Fri, 3 May 2024 at 05:40, Michael Balzer via OvmsDev
>> A task may delete itself by calling vTaskDelete(NULL)
>> as the final statement, and that's normally a better
>> way to shutdown a task, if you can signal the task it
>> should terminate. Deleting a task from outside may
>> always result in resources taken by the task not
>> being freed, as the task gets terminated wherever it
>> just is.
>> As the vehicle task also needs to access vehicle data
>> memory, vehicle destruction should not begin until
>> the task has finished, otherwise a task job already
>> running while the vehicle destruction takes place may
>> run into an illegal memory access (access after
>> free). Keep in mind, destructors are executed bottom
>> up, so waiting for the task shutdown within the
>> destructor won't help.
>> Also, I think "MyCan.DeregisterCallback(TAG)" in
>> ShuttingDown() is now obsolete.
>> Am 02.05.24 um 15:23 schrieb Michael Geddes:
>> Thanks.
>> On that race condition... do you think we are
>> better to just delete the task or I saw one
>> recommendation that
>> We can delete it outside the while loop in the
>> task itself!
>> //.ichael
>> On Tue, 30 Apr 2024, 17:46 Michael Balzer via
>> OvmsDev, <ovmsdev at lists.openvehicles.com> wrote:
>> OK, understood & merged, thanks for the quick
>> fix/workaround.
>> I'll ask the Twizy driver to test this.
>> PS: side note: there's a shutdown race
>> condition arising from `while
>> (!m_is_shutdown)` in the new
>> `OvmsVehicle::VehicleTask()`: if the task
>> receives a message while m_is_shutdown
>> already has been set, it will exit the loop
>> and return from the task function, which
>> isn't allowed. I think FreeRTOS will abort in
>> that case.
>> Am 30.04.24 um 08:55 schrieb Michael Geddes:
>> No it will start the poll thread of the
>> poller fine for those that don't use it.
>> That's the last commit.... so that should
>> be covered. When the callback is
>> registered the thread is force started.
>> This is not to say that what you are
>> suggesting isn't a better way forward...
>> just that it should work.
>> On Tue, 30 Apr 2024, 14:51 Michael Balzer
>> via OvmsDev,
>> Michael,
>> (taking this back to the list, as
>> other developers may have helpful
>> ideas or suggestions)
>> from a first check, your new patch
>> (PR #1008) won't help for vehicles
>> that don't use the poller, like the
>> generic DBC vehicle or the Fiat 500
>> (plus possibly non-public third party
>> vehicles). As the poller is normally
>> compiled in, these would need a run
>> time switch to re-enable the vehicle
>> task, or more suitably default into
>> that configuration and switch to the
>> poller task only when the poller gets
>> initialized.
>> How about moving the task back into
>> the vehicle class, but keeping your
>> task message extensions while doing
>> so, and adding a way for the poller
>> to hook into the task? The dedicated
>> vehicle task is an essential part of
>> the vehicle framework, but I do
>> remember some occasions where a
>> general way to pass custom messages
>> to the vehicle task would have been
>> helpful to use the task for more than
>> CAN processing.
>> If the poller shall become avaible as
>> a separate service that can be used
>> without any vehicle instance
>> (currently not a defined use case),
>> the construct of a CAN processor task
>> that can be extended for custom
>> messages (or a message processor task
>> that can subscribe to CAN frames)
>> could be factored out into a
>> dedicated class or template. The
>> poller could then create his own
>> instance of that class, if it cannot
>> hook into an existing one.
>> Btw, in case you're not aware of
>> this, FreeRTOS also provides queue
>> sets
>> (https://www.freertos.org/RTOS-queue-sets.html).
>> We haven't used them in the OVMS yet,
>> but they could be useful, especially
>> if message unions become large or
>> tasks shall be able to dynamically
>> subscribe to different message sources.
>> Am 30.04.24 um 01:20 schrieb Michael
>> Geddes:
>> It might be worth reverting, but,
>> I've got a patch suggestion that
>> I'll push up which will let me
>> know if I understand everything
>> and which might provide a solution.
>> If this isn't going to work then
>> revert. (P/R coming)
>> While the poller was still a part
>> of the vehicle class it was
>> probably still all ok. The
>> poller had taken over what I
>> assume you are talking about as
>> the vehicle task. A call-back
>> fromthe poller was calling
>> IncomingPollRxFrame which was
>> then coming from the (now) poller
>> task (is that correct?)
>> While we have OVMS_COMP_POLLER
>> config defined, we could just use
>> the poller task to provide the
>> IncomingPollRxFrame call-back
>> from the poller (was vehicle?) task.
>> The problem is when
>> OVMS_COMP_POLLER is undefined, we
>> need an alternate (maybe we could
>> use the 'Event' loop then) which
>> is when I hacked that bad solution.
>> //.ichael
>> I was thinking though that
>> because everything is being
>> queued we could divert some calls
>> into the car
>> On Mon, 29 Apr 2024, 18:58
>> Michael Balzer,
>> <dexter at expeedo.de> wrote:
>> Michael,
>> I've found a severe design
>> flaw with your poller change.
>> Sorry, I should have seen
>> that before, and shouldn't
>> have merged this.
>> You have moved the standard
>> CAN frame processing from the
>> vehicle task into the CAN
>> task by changing the vehicle
>> from a CAN listener to a CAN
>> callback processor. That will
>> break all kind of things,
>> vehicles like the Twizy,
>> Smart and many others rely on
>> frame processing being done
>> in the dedicated vehicle task.
>> This especially induces
>> issues regarding CAN
>> processing capacity, as the
>> vehicles rely on having a
>> separate context and not
>> needing to decouple complex
>> processing of incoming
>> frames. So this will degrade
>> the CAN processing
>> performance seriously in many
>> cases, where additional steps
>> involving file or network I/O
>> need to be done.
>> So this needs to be changed back.
>> I assumed you introduced a
>> new dedicated poller task but
>> kept the vehicle task intact.
>> From your naming
>> (OvmsVehicle::IncomingPollRxFrame),
>> it seems you misinterpreted
>> the vehicle task's purpose as
>> only being used for polling.
>> I assume this isn't a small
>> change…? If so we should
>> revert the poller merge, to
>> avoid having a defunctional
>> edge build state until the fix.
>> Secondly: logging is
>> generally expensive
>> regardless of the log level
>> control and log channels
>> enabled. Any log message
>> needs to be queued to the log
>> system, so involves a lock
>> and a potential wait state
>> (for the queue) & resulting
>> context switch (= minimum
>> delay of 10 ms). Therefore,
>> logging must be avoided as
>> far as possible in any time
>> critical context, and is
>> forbidden under some
>> circumstances, e.g. in a
>> timer callback (see FreeRTOS
>> docs on this). The log system
>> load multiplies with
>> connected web clients or
>> enabled file logging and
>> enabled debug / verbose level
>> logging -- that quickly
>> becomes too much, usually
>> triggering the task watchdog.
>> Your logging of nearly all
>> bus events passing to/from
>> the poller (especially the
>> log entry in
>> Queue_PollerFrame) becomes an
>> issue on any vehicle that has
>> high frequency running
>> process data frames on the
>> bus, like the Twizy or Smart.
>> As a counter measure, I've
>> just added a runtime control
>> for all the poller's verbose
>> logging (by default now off),
>> and changed some debug level
>> logs to verbose. Not sure if
>> I've catched all that may
>> need to be silenced by
>> default. Please check all
>> your log calls and place them
>> under the new "trace" control
>> flag wherever appropriate.
>> This won't help avoiding
>> issues with process data
>> frame buses though.
>> Shall I revert the poller
>> merge for now?
>> Am 29.04.24 um 06:18 schrieb
>> Michael Geddes:
>> Btw I included the log
>> changes in the p/r which
>> is a few small commits
>> for the poller.
>> 07:20 Michael Geddes,
>> wrote:
>> Hey Michael,
>> I've got to work now
>> (it's Monday), but I
>> suspect those 'giving
>> up' are from
>> unsolicited messages
>> on the bus.
>> I can re-order things
>> so that the message
>> will likely be
>> 'dropped (no poll
>> entry)' rather than
>> the time-out message.
>> And make it a
>> verbose log.
>> //.ichael
>> On Mon, 29 Apr 2024
>> at 00:25, Michael
>> Balzer
>> wrote:
>> Michael,
>> forwarding the
>> Twizy logs to you
>> directly, as they
>> contain the user
>> location.
>> He has just
>> verified it's the
>> new version, he
>> says the module
>> stops responding
>> as soon as he
>> turns on the Twizy.
>> His description
>> of his actions is
>> a bit ambiguous,
>> and it seems he
>> didn't enable
>> logging to the
>> file persistently.
>> According to the
>> server, these
>> were the version
>> boot times:
>> 2024-04-28
>> 15:30:56 0
>> 3.3.004-32-g125e0841/ota_0/edge
>> (build idf
>> v3.3.4-849-g6e214dc335
>> Apr 26 2024 19:16:50)
>> 2024-04-28
>> 16:21:08 0
>> (build idf
>> 2024-04-28
>> 16:38:33 0
>> 3.3.004-63-gf3595561/ota_1/edge
>> (build idf
>> Apr 27 2024 07:44:50)
>> 2024-04-28
>> 16:40:57 0
>> (build idf
>> 2024-04-28
>> 16:43:14 0
>> (build idf
>> 2024-04-28
>> 16:46:39 0
>> (build idf
>> 2024-04-28
>> 16:54:44 0
>> (build idf
>> Attached is also
>> his crash debug
>> log -- a2ll
>> doesn't tell much
>> about what
>> happened, but
>> maybe you get an
>> idea from this.
>> After the boot at
>> 16:46, there are
>> immediately lots
>> of these messages:
>> 2024-04-28
>> 16:46:33.792 CEST
>> D (39042)
>> vehicle-poll:
>> Poller: Queue
>> PollerFrame()
>> 2024-04-28
>> 16:46:33.792 CEST
>> D (39042)
>> vehicle-poll:
>> [1]Poller:
>> Incoming - giving up
>> Am 28.04.24 um
>> 16:44 schrieb
>> Michael Geddes:
>> Ah. OK.
>> I could try
>> to fix the
>> vin thing
>> using the new
>> way of doing
>> it and get
>> rid of a
>> semaphore?
>> It would at
>> least
>> identify the
>> problem possibly?
>> On Sun, 28
>> Apr 2024,
>> 22:32 Michael
>> Balzer via
>> OvmsDev,
>> wrote:
>> Not sure
>> if that's
>> the
>> problem,
>> but I've
>> found a
>> different
>> behaviour
>> with the
>> new
>> PollSetState()
>> implementation.
>> The old
>> version
>> only did
>> anything
>> if the
>> new state
>> actually
>> was
>> different
>> from the
>> previous
>> one. The
>> Twizy
>> relies on
>> this
>> behaviour,
>> calling
>> PollSetState()
>> from the
>> per
>> second
>> ticker
>> (see
>> OvmsVehicleRenaultTwizy::ObdTicker1).
>> The new
>> implementation
>> apparently
>> always
>> sends the
>> PollState
>> command
>> to the
>> task, and
>> that in
>> turn
>> always at
>> least
>> locks the
>> poller
>> mutex.
>> Not sure
>> if/how
>> that
>> could
>> cause the
>> observed
>> issues,
>> but it
>> definitely
>> adds
>> quite
>> some
>> (unnecessary?)
>> lock/unlock
>> operations.
>> Am
>> 28.04.24
>> um 16:05
>> schrieb
>> Balzer
>> via OvmsDev:
>> The
>> Twizy
>> uses
>> the
>> poller
>> to
>> query
>> the
>> VIN
>> (once)
>> and
>> DTCs
>> (every
>> 10
>> seconds
>> while
>> driving),
>> see
>> rt_obd2.cpp.
>> It
>> also
>> has
>> its
>> own
>> version
>> of
>> the
>> OBD
>> single
>> request
>> (OvmsVehicleRenaultTwizy::ObdRequest),
>> which
>> was
>> the
>> precursor
>> for
>> the
>> generalized
>> version.
>> This
>> is
>> used
>> by
>> custom/user
>> Twizy
>> plugins
>> and
>> scripts
>> to
>> access
>> ECU
>> internals.
>> The
>> Twizy
>> doesn't
>> use
>> IncomingPollRxFrame,
>> but
>> the
>> Twizy's
>> IncomingPollReply
>> handler
>> will
>> log
>> any
>> poll
>> responses
>> it
>> doesn't
>> know
>> about,
>> so
>> that
>> could
>> lead
>> to a
>> lot
>> of
>> log
>> output
>> if
>> something
>> goes
>> wrong
>> there.
>> Am
>> 28.04.24
>> um
>> 15:49
>> schrieb
>> Geddes
>> via
>> OvmsDev:
>> AFAICT
>> the
>> twizzy
>> doesn't
>> use
>> the
>> poller
>> list
>> at
>> all.
>> So
>> is
>> it
>> missing
>> a
>> call-back
>> or
>> something??
>> I
>> can
>> see
>> a
>> potential
>> problem
>> with
>> IncomingPollRxFrame
>> being
>> called
>> twice
>> as
>> much
>> as
>> it
>> should
>> be
>> but
>> only
>> when
>> there
>> is
>> a
>> poll
>> list.
>> Maybe
>> commenting
>> out
>> this
>> would
>> do
>> it.
>> (I
>> can
>> find
>> another
>> away
>> to
>> get
>> this
>> called
>> on
>> the
>> thread
>> I
>> want).
>> This
>> might
>> be
>> the
>> problem
>> with
>> the
>> smarted
>> void
>> OvmsVehicle::OvmsVehicleSignal::IncomingPollRxFrame(canbus*
>> bus,
>> CAN_frame_t
>> *frame,
>> bool
>> success)
>> //if
>> (Ready())
>> m_parent->IncomingPollRxFrame(frame,
>> success);
>> On
>> Sun,
>> 28
>> Apr
>> 2024
>> at
>> 21:10,
>> Balzer
>> via
>> OvmsDev
>> wrote:
>> There
>> may
>> also
>> be
>> an
>> issue
>> with
>> the
>> Renault
>> Twizy,
>> I've
>> received
>> a
>> report
>> of
>> a
>> user
>> who
>> is
>> using
>> the
>> edge
>> builds,
>> that
>> the
>> latest
>> build
>> wouldn't
>> work.
>> He
>> reports
>> all
>> kinds
>> of
>> errors
>> and
>> warnings
>> signaled
>> by
>> the
>> car
>> during
>> driving,
>> and
>> switching
>> back
>> to
>> the
>> previous
>> build
>> fixed
>> the
>> issues.
>> I've
>> asked
>> him
>> to
>> provide
>> a
>> debug
>> log
>> excerpt
>> if
>> possible.
>> Am
>> 28.04.24
>> um
>> 14:29
>> schrieb
>> Geddes
>> via
>> OvmsDev:
>> OK.
>> That's
>> bad.
>> Does
>> the
>> reading
>> work
>> in
>> general?
>> Is
>> it
>> just
>> the
>> writing
>> commands?
>> Raise
>> a
>> ticket
>> on
>> github
>> and
>> tag
>> me
>> in
>> and
>> we
>> can
>> address
>> it
>> that
>> way.
>> On
>> Sun,
>> 28
>> Apr
>> 2024,
>> 19:49
>> Thomas
>> Heuer
>> via
>> OvmsDev,
>> wrote:
>> Hi,
>> The
>> new
>> poller
>> code
>> doesn't
>> seem
>> to
>> work
>> properly
>> with
>> the
>> smarted.
>> D
>> (218831)
>> vehicle-poll:
>> [1]PollerNextTick(PRI):
>> cycle
>> complete
>> for
>> ticker=215
>> V
>> (218831)
>> vehicle-poll:
>> Standard
>> Poll
>> Series:
>> List
>> reset
>> D
>> (218831)
>> vehicle-poll:
>> PollSeriesList::NextPollEntry[!v.standard]:
>> ReachedEnd
>> V
>> (218831)
>> vehicle-poll:
>> [1]PollerSend:
>> Poller
>> Reached
>> End
>> D
>> (219691)
>> vehicle-poll:
>> Poller:
>> Queue
>> PollerFrame()
>> D
>> (219691)
>> vehicle-poll:
>> Poller:
>> Queue
>> PollerFrame()
>> V
>> (219691)
>> vehicle-poll:
>> Pollers:
>> FrameRx(bus=2)
>> D
>> (219691)
>> vehicle-poll:
>> Poller:
>> Queue
>> PollerFrame()
>> V
>> (219691)
>> vehicle-poll:
>> Pollers:
>> FrameRx(bus=2)
>> V
>> (219691)
>> vehicle-poll:
>> Pollers:
>> FrameRx(bus=2)
>> D
>> (219691)
>> vehicle-poll:
>> Poller:
>> Queue
>> PollerFrame()
>> *OVMS#*unlock
>> 22
>> Vehicle
>> unlocked
>> V
>> (219691)
>> vehicle-poll:
>> Pollers:
>> FrameRx(bus=2)
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240506/ff6a7098/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240506/ff6a7098/attachment-0001.sig>
