Fri May 3 20:28:43 HKT 2024
The Twizy feedback looks better, 3.3.004-74-gbd4e7196 seems to be fully
functional again.
Am 03.05.24 um 13:35 schrieb Michael Geddes via OvmsDev:
> Thanks that is definitely weird. Will check it out in detail tomorrow.
> On Fri, 3 May 2024, 19:10 Derek Caudwell via OvmsDev,
> <ovmsdev at lists.openvehicles.com> wrote:
> Hi Michael,
> When running firmware 3.3.004-74-gbd4e7196 on my Nissan Leaf I
> suspect (but can't be 100% sure as it's only been 24h without
> fault) the new poller caused the car to throw the attached faults
> from overloading the can bus whilst driving. The fault was
> sufficient to send the car into limp mode and could not be driven
> until cleared with LeafSpy. Ovms should not be polling in the
> driving state, so I'm not sure why the poller is overflowing.
> The ovms log repeats this overflow in rapid succession right
> before the failure occurred. I have since reverted to an earlier
> version and it might be advisable for other Leaf owners to do so
> until the new poller is fully operational.
> 2024-05-02 12:22:28.316 NZST I (36847486) vehicle-poll:
> Poller[Frame]: Task Queue Overflow
> 2024-05-02 12:22:28.326 NZST I (36847496) vehicle-poll:
> 2024-05-02 12:22:28.336 NZST I (36847506) vehicle-poll:
> 2024-05-02 12:22:28.346 NZST I (36847516) vehicle-poll:
> 2024-05-02 12:22:28.356 NZST I (36847526) vehicle-poll:
> On Fri, 3 May 2024 at 05:40, Michael Balzer via OvmsDev
> A task may delete itself by calling vTaskDelete(NULL) as the
> final statement, and that's normally a better way to shutdown
> a task, if you can signal the task it should terminate.
> Deleting a task from outside may always result in resources
> taken by the task not being freed, as the task gets terminated
> wherever it just is.
> As the vehicle task also needs to access vehicle data memory,
> vehicle destruction should not begin until the task has
> finished, otherwise a task job already running while the
> vehicle destruction takes place may run into an illegal memory
> access (access after free). Keep in mind, destructors are
> executed bottom up, so waiting for the task shutdown within
> the destructor won't help.
> Also, I think "MyCan.DeregisterCallback(TAG)" in
> ShuttingDown() is now obsolete.
> Am 02.05.24 um 15:23 schrieb Michael Geddes:
>> Thanks.
>> On that race condition... do you think we are better to just
>> delete the task or I saw one recommendation that
>> We can delete it outside the while loop in the task itself!
>> //.ichael
>> On Tue, 30 Apr 2024, 17:46 Michael Balzer via OvmsDev,
>> OK, understood & merged, thanks for the quick fix/workaround.
>> I'll ask the Twizy driver to test this.
>> PS: side note: there's a shutdown race condition arising
>> from `while (!m_is_shutdown)` in the new
>> `OvmsVehicle::VehicleTask()`: if the task receives a
>> message while m_is_shutdown already has been set, it will
>> exit the loop and return from the task function, which
>> isn't allowed. I think FreeRTOS will abort in that case.
>> Am 30.04.24 um 08:55 schrieb Michael Geddes:
>>> No it will start the poll thread of the poller fine for
>>> those that don't use it. That's the last commit.... so
>>> that should be covered. When the callback is registered
>>> the thread is force started.
>>> This is not to say that what you are suggesting isn't a
>>> better way forward... just that it should work.
>>> On Tue, 30 Apr 2024, 14:51 Michael Balzer via OvmsDev,
>>> Michael,
>>> (taking this back to the list, as other developers
>>> may have helpful ideas or suggestions)
>>> from a first check, your new patch (PR #1008) won't
>>> help for vehicles that don't use the poller, like
>>> the generic DBC vehicle or the Fiat 500 (plus
>>> possibly non-public third party vehicles). As the
>>> poller is normally compiled in, these would need a
>>> run time switch to re-enable the vehicle task, or
>>> more suitably default into that configuration and
>>> switch to the poller task only when the poller gets
>>> initialized.
>>> How about moving the task back into the vehicle
>>> class, but keeping your task message extensions
>>> while doing so, and adding a way for the poller to
>>> hook into the task? The dedicated vehicle task is an
>>> essential part of the vehicle framework, but I do
>>> remember some occasions where a general way to pass
>>> custom messages to the vehicle task would have been
>>> helpful to use the task for more than CAN processing.
>>> If the poller shall become avaible as a separate
>>> service that can be used without any vehicle
>>> instance (currently not a defined use case), the
>>> construct of a CAN processor task that can be
>>> extended for custom messages (or a message processor
>>> task that can subscribe to CAN frames) could be
>>> factored out into a dedicated class or template. The
>>> poller could then create his own instance of that
>>> class, if it cannot hook into an existing one.
>>> Btw, in case you're not aware of this, FreeRTOS also
>>> provides queue sets
>>> (https://www.freertos.org/RTOS-queue-sets.html). We
>>> haven't used them in the OVMS yet, but they could be
>>> useful, especially if message unions become large or
>>> tasks shall be able to dynamically subscribe to
>>> different message sources.
>>> Am 30.04.24 um 01:20 schrieb Michael Geddes:
>>>> It might be worth reverting, but, I've got a patch
>>>> suggestion that I'll push up which will let me know
>>>> if I understand everything and which might provide
>>>> a solution.
>>>> If this isn't going to work then revert. (P/R coming)
>>>> While the poller was still a part of the vehicle
>>>> class it was probably still all ok. The poller had
>>>> taken over what I assume you are talking about as
>>>> the vehicle task. A call-back fromthe poller was
>>>> calling IncomingPollRxFrame which was then coming
>>>> from the (now) poller task (is that correct?)
>>>> While we have OVMS_COMP_POLLER config defined, we
>>>> could just use the poller task to provide the
>>>> IncomingPollRxFrame call-back from the poller (was
>>>> vehicle?) task.
>>>> The problem is when OVMS_COMP_POLLER is undefined,
>>>> we need an alternate (maybe we could use the
>>>> 'Event' loop then) which is when I hacked that bad
>>>> solution.
>>>> //.ichael
>>>> I was thinking though that because everything is
>>>> being queued we could divert some calls into the car
>>>> On Mon, 29 Apr 2024, 18:58 Michael Balzer,
>>>> <dexter at expeedo.de> wrote:
>>>> Michael,
>>>> I've found a severe design flaw with your
>>>> poller change. Sorry, I should have seen that
>>>> before, and shouldn't have merged this.
>>>> You have moved the standard CAN frame
>>>> processing from the vehicle task into the CAN
>>>> task by changing the vehicle from a CAN
>>>> listener to a CAN callback processor. That will
>>>> break all kind of things, vehicles like the
>>>> Twizy, Smart and many others rely on frame
>>>> processing being done in the dedicated vehicle
>>>> task.
>>>> This especially induces issues regarding CAN
>>>> processing capacity, as the vehicles rely on
>>>> having a separate context and not needing to
>>>> decouple complex processing of incoming frames.
>>>> So this will degrade the CAN processing
>>>> performance seriously in many cases, where
>>>> additional steps involving file or network I/O
>>>> need to be done.
>>>> So this needs to be changed back.
>>>> I assumed you introduced a new dedicated poller
>>>> task but kept the vehicle task intact. From
>>>> your naming (OvmsVehicle::IncomingPollRxFrame),
>>>> it seems you misinterpreted the vehicle task's
>>>> purpose as only being used for polling.
>>>> I assume this isn't a small change…? If so we
>>>> should revert the poller merge, to avoid having
>>>> a defunctional edge build state until the fix.
>>>> Secondly: logging is generally expensive
>>>> regardless of the log level control and log
>>>> channels enabled. Any log message needs to be
>>>> queued to the log system, so involves a lock
>>>> and a potential wait state (for the queue) &
>>>> resulting context switch (= minimum delay of 10
>>>> ms). Therefore, logging must be avoided as far
>>>> as possible in any time critical context, and
>>>> is forbidden under some circumstances, e.g. in
>>>> a timer callback (see FreeRTOS docs on this).
>>>> The log system load multiplies with connected
>>>> web clients or enabled file logging and enabled
>>>> debug / verbose level logging -- that quickly
>>>> becomes too much, usually triggering the task
>>>> watchdog.
>>>> Your logging of nearly all bus events passing
>>>> to/from the poller (especially the log entry in
>>>> Queue_PollerFrame) becomes an issue on any
>>>> vehicle that has high frequency running process
>>>> data frames on the bus, like the Twizy or
>>>> Smart. As a counter measure, I've just added a
>>>> runtime control for all the poller's verbose
>>>> logging (by default now off), and changed some
>>>> debug level logs to verbose. Not sure if I've
>>>> catched all that may need to be silenced by
>>>> default. Please check all your log calls and
>>>> place them under the new "trace" control flag
>>>> wherever appropriate.
>>>> This won't help avoiding issues with process
>>>> data frame buses though.
>>>> Shall I revert the poller merge for now?
>>>> Regards,
>>>> Michael
>>>> Am 29.04.24 um 06:18 schrieb Michael Geddes:
>>>>> Btw I included the log changes in the p/r
>>>>> which is a few small commits for the poller.
>>>>> On Mon, 29 Apr 2024, 07:20 Michael Geddes,
>>>>> <frog at bunyip.wheelycreek.net> wrote:
>>>>> Hey Michael,
>>>>> I've got to work now (it's Monday), but I
>>>>> suspect those 'giving up' are from
>>>>> unsolicited messages on the bus.
>>>>> I can re-order things so that the message
>>>>> will likely be 'dropped (no poll entry)'
>>>>> rather than the time-out message.
>>>>> And make it a verbose log.
>>>>> //.ichael
>>>>> On Mon, 29 Apr 2024 at 00:25, Michael
>>>>> Balzer <dexter at expeedo.de> wrote:
>>>>> Michael,
>>>>> forwarding the Twizy logs to you
>>>>> directly, as they contain the user
>>>>> location.
>>>>> He has just verified it's the new
>>>>> version, he says the module stops
>>>>> responding as soon as he turns on the
>>>>> Twizy.
>>>>> His description of his actions is a
>>>>> bit ambiguous, and it seems he didn't
>>>>> enable logging to the file persistently.
>>>>> According to the server, these were
>>>>> the version boot times:
>>>>> 2024-04-28 15:30:56 0
>>>>> 3.3.004-32-g125e0841/ota_0/edge (build
>>>>> idf v3.3.4-849-g6e214dc335 Apr 26 2024
>>>>> 19:16:50)
>>>>> 2024-04-28 16:21:08 0
>>>>> 19:16:50)
>>>>> 2024-04-28 16:38:33 0
>>>>> 3.3.004-63-gf3595561/ota_1/edge (build
>>>>> idf v3.3.4-849-g6e214dc335 Apr 27 2024
>>>>> 07:44:50)
>>>>> 2024-04-28 16:40:57 0
>>>>> 07:44:50)
>>>>> 2024-04-28 16:43:14 0
>>>>> 07:44:50)
>>>>> 2024-04-28 16:46:39 0
>>>>> 07:44:50)
>>>>> 2024-04-28 16:54:44 0
>>>>> 19:16:50)
>>>>> Attached is also his crash debug log
>>>>> -- a2ll doesn't tell much about what
>>>>> happened, but maybe you get an idea
>>>>> from this.
>>>>> After the boot at 16:46, there are
>>>>> immediately lots of these messages:
>>>>> 2024-04-28 16:46:33.792 CEST D (39042)
>>>>> vehicle-poll: Poller: Queue PollerFrame()
>>>>> vehicle-poll: [1]Poller: Incoming -
>>>>> giving up
>>>>> Regards,
>>>>> Michael
>>>>> Am 28.04.24 um 16:44 schrieb Michael
>>>>> Geddes:
>>>>>> Ah. OK.
>>>>>> I could try to fix the vin thing
>>>>>> using the new way of doing it and get
>>>>>> rid of a semaphore?
>>>>>> It would at least identify the
>>>>>> problem possibly?
>>>>>> Michael
>>>>>> On Sun, 28 Apr 2024, 22:32 Michael
>>>>>> Balzer via OvmsDev,
>>>>>> Not sure if that's the problem,
>>>>>> but I've found a different
>>>>>> behaviour with the new
>>>>>> PollSetState() implementation.
>>>>>> The old version only did anything
>>>>>> if the new state actually was
>>>>>> different from the previous one.
>>>>>> The Twizy relies on this
>>>>>> behaviour, calling PollSetState()
>>>>>> from the per second ticker (see
>>>>>> OvmsVehicleRenaultTwizy::ObdTicker1).
>>>>>> The new implementation apparently
>>>>>> always sends the PollState
>>>>>> command to the task, and that in
>>>>>> turn always at least locks the
>>>>>> poller mutex. Not sure if/how
>>>>>> that could cause the observed
>>>>>> issues, but it definitely adds
>>>>>> quite some (unnecessary?)
>>>>>> lock/unlock operations.
>>>>>> Am 28.04.24 um 16:05 schrieb
>>>>>> Michael Balzer via OvmsDev:
>>>>>>> The Twizy uses the poller to
>>>>>>> query the VIN (once) and DTCs
>>>>>>> (every 10 seconds while
>>>>>>> driving), see rt_obd2.cpp.
>>>>>>> It also has its own version of
>>>>>>> the OBD single request
>>>>>>> (OvmsVehicleRenaultTwizy::ObdRequest),
>>>>>>> which was the precursor for the
>>>>>>> generalized version. This is
>>>>>>> used by custom/user Twizy
>>>>>>> plugins and scripts to access
>>>>>>> ECU internals.
>>>>>>> The Twizy doesn't use
>>>>>>> IncomingPollRxFrame, but the
>>>>>>> Twizy's IncomingPollReply
>>>>>>> handler will log any poll
>>>>>>> responses it doesn't know about,
>>>>>>> so that could lead to a lot of
>>>>>>> log output if something goes
>>>>>>> wrong there.
>>>>>>>> AFAICT the twizzy doesn't use
>>>>>>>> the poller list at all. So is
>>>>>>>> it missing a call-back or
>>>>>>>> something??
>>>>>>>> I can see a potential problem
>>>>>>>> with IncomingPollRxFrame being
>>>>>>>> called twice as much as it
>>>>>>>> should be but only when there
>>>>>>>> is a poll list. Maybe
>>>>>>>> commenting out this would do
>>>>>>>> it. (I can find another away
>>>>>>>> to get this called on the
>>>>>>>> thread I want). This might be
>>>>>>>> the problem with the smarted
>>>>>>>> void
>>>>>>>> OvmsVehicle::OvmsVehicleSignal::IncomingPollRxFrame(canbus*
>>>>>>>> bus, CAN_frame_t *frame, bool
>>>>>>>> success)
>>>>>>>> //if (Ready())
>>>>>>>> m_parent->IncomingPollRxFrame(frame,
>>>>>>>> success);
>>>>>>>> On Sun, 28 Apr 2024 at 21:10,
>>>>>>>> wrote:
>>>>>>>> There may also be an issue
>>>>>>>> with the Renault Twizy,
>>>>>>>> I've received a report of a
>>>>>>>> user who is using the edge
>>>>>>>> builds, that the latest
>>>>>>>> build wouldn't work.
>>>>>>>> He reports all kinds of
>>>>>>>> errors and warnings
>>>>>>>> signaled by the car during
>>>>>>>> driving, and switching back
>>>>>>>> to the previous build fixed
>>>>>>>> the issues.
>>>>>>>> I've asked him to provide a
>>>>>>>> debug log excerpt if possible.
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 28.04.24 um 14:29
>>>>>>>> OvmsDev:
>>>>>>>>> OK. That's bad.
>>>>>>>>> Does the reading work in
>>>>>>>>> general?
>>>>>>>>> Is it just the writing
>>>>>>>>> commands?
>>>>>>>>> Raise a ticket on github
>>>>>>>>> and tag me in and we can
>>>>>>>>> address it that way.
>>>>>>>>> Michael
>>>>>>>>> On Sun, 28 Apr 2024, 19:49
>>>>>>>>> Thomas Heuer via OvmsDev,
>>>>>>>>> wrote:
>>>>>>>>> Hi,
>>>>>>>>> The new poller code
>>>>>>>>> doesn't seem to work
>>>>>>>>> properly with the smarted.
>>>>>>>>> D (218831)
>>>>>>>>> vehicle-poll:
>>>>>>>>> [1]PollerNextTick(PRI):
>>>>>>>>> cycle complete for
>>>>>>>>> ticker=215
>>>>>>>>> V (218831)
>>>>>>>>> vehicle-poll: Standard
>>>>>>>>> Poll Series: List reset
>>>>>>>>> D (218831)
>>>>>>>>> vehicle-poll:
>>>>>>>>> PollSeriesList::NextPollEntry[!v.standard]:
>>>>>>>>> ReachedEnd
>>>>>>>>> V (218831)
>>>>>>>>> vehicle-poll:
>>>>>>>>> [1]PollerSend: Poller
>>>>>>>>> Reached End
>>>>>>>>> D (219691)
>>>>>>>>> Queue PollerFrame()
>>>>>>>>> D (219691)
>>>>>>>>> Queue PollerFrame()
>>>>>>>>> V (219691)
>>>>>>>>> vehicle-poll: Pollers:
>>>>>>>>> FrameRx(bus=2)
>>>>>>>>> D (219691)
>>>>>>>>> Queue PollerFrame()
>>>>>>>>> V (219691)
>>>>>>>>> FrameRx(bus=2)
>>>>>>>>> V (219691)
>>>>>>>>> FrameRx(bus=2)
>>>>>>>>> D (219691)
>>>>>>>>> Queue PollerFrame()
>>>>>>>>> *OVMS#*unlock 22
>>>>>>>>> Vehicle unlocked
>>>>>>>>> V (219691)
>>>>>>>>> FrameRx(bus=2)
>>>>>>>>> D (219691)
>>>>>>>>> Queue PollerFrame()
>>>>>>>>> V (219691)
>>>>>>>>> FrameRx(bus=2)
>>>>>>>>> D (219701)
>>>>>>>>> Queue PollerFrame()
>>>>>>>>> V (219701)
>>>>>>>>> FrameRx(bus=2)
>>>>>>>>> D (219701)
>>>>>>>>> Queue PollerFrame()
>>>>>>>>> V (219701)
>>>>>>>>> FrameRx(bus=2)
>>>>>>>>> D (219701)
>>>>>>>>> Queue PollerFrame()
>>>>>>>>> V (219701)
>>>>>>>>> FrameRx(bus=2)
>>>>>>>>> D (219701)
>>>>>>>>> Queue PollerFrame()
>>>>>>>>> V (219701)
>>>>>>>>> FrameRx(bus=2)
>>>>>>>>> D (219701)
>>>>>>>>> Queue PollerFrame()
>>>>>>>>> V (219701)
>>>>>>>>> FrameRx(bus=2)
>>>>>>>>> D (219701)
>>>>>>>>> Queue PollerFrame()
>>>>>>>>> V (219701)
>>>>>>>>> FrameRx(bus=2)
>>>>>>>>> D (219701)
>>>>>>>>> Queue PollerFrame()
>>>>>>>>> V (219701)
>>>>>>>>> FrameRx(bus=2)
>>>>>>>>> D (219701)
>>>>>>>>> Queue PollerFrame()
>>>>>>>>> V (219701)
>>>>>>>>> FrameRx(bus=2)
>>>>>>>>> D (219701)
>>>>>>>>> Queue PollerFrame()
>>>>>>>>> V (219701)
>>>>>>>>> FrameRx(bus=2)
>>>>>>>>> D (219701)
>>>>>>>>> Queue PollerFrame()
>>>>>>>>> V (219701)
>>>>>>>>> FrameRx(bus=2)
>>>>>>>>> D (219701)
>>>>>>>>> Queue PollerFrame()
>>>>>>>>> *Von:*OvmsDev
>>>>>>>>> <ovmsdev-bounces at lists.openvehicles.com>
>>>>>>>>> *Im Auftrag von
>>>>>>>>> *Michael Geddes via
>>>>>>>>> OvmsDev
>>>>>>>>> *Gesendet:* Sonntag,
>>>>>>>>> 28. April 2024 12:27
>>>>>>>>> *An:* OVMS Developers
>>>>>>>>> *Cc:* Michael Geddes
>>>>>>>>> *Betreff:* [Ovmsdev]
>>>>>>>>> OVMS Poller
>>>>>>>>> module/singleton
>>>>>>>>> Hey all,
>>>>>>>>> The poller singleton
>>>>>>>>> code that I've been
>>>>>>>>> working on for over a
>>>>>>>>> year now is merged in.
>>>>>>>>> (Thanks Michael for
>>>>>>>>> expediting the final
>>>>>>>>> step).
>>>>>>>>> This includes separate
>>>>>>>>> multi-frame states per
>>>>>>>>> bus and multiple poll
>>>>>>>>> lists as well as
>>>>>>>>> non-blocking one off
>>>>>>>>> queries. As well as
>>>>>>>>> more 'states'.
>>>>>>>>> I have included some
>>>>>>>>> programming
>>>>>>>>> documentation in the
>>>>>>>>> change but am happy to
>>>>>>>>> supply more if needed.
>>>>>>>>> The ioniq 5 code has
>>>>>>>>> some examples of how
>>>>>>>>> it can be used. Some
>>>>>>>>> examples are:
>>>>>>>>> * grabbing the vin as
>>>>>>>>> a one shot without
>>>>>>>>> blocking
>>>>>>>>> * having a short list
>>>>>>>>> of queries that are
>>>>>>>>> polled quickly for
>>>>>>>>> obd2ecu (this also
>>>>>>>>> demonstrates using a
>>>>>>>>> shorter frame break
>>>>>>>>> value and then a break
>>>>>>>>> after successful a
>>>>>>>>> response)
>>>>>>>>> Have a play please!
>>>>>>>>> Also interested in
>>>>>>>>> hearing what user
>>>>>>>>> tools might be worth
>>>>>>>>> looking at next for
>>>>>>>>> the poller object.
>>>>>>>>> //.ichael G.
>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240503/3564adc2/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240503/3564adc2/attachment-0001.sig>
