Fri May 3 19:35:33 HKT 2024
Thanks that is definitely weird.  Will check it out in detail tomorrow.
On Fri, 3 May 2024, 19:10 Derek Caudwell via OvmsDev, <
> Hi Michael,
> When running firmware  3.3.004-74-gbd4e7196 on my Nissan Leaf I suspect
> (but can't be 100% sure as it's only been 24h without fault) the new poller
> caused the car to throw the attached faults from overloading the can bus
> whilst driving. The fault was sufficient to send the car into limp mode and
> could not be driven until cleared with LeafSpy. Ovms should not be polling
> in the driving state, so I'm not sure why the poller is overflowing.
> The ovms log repeats this overflow in rapid succession right before the
> failure occurred. I have since reverted to an earlier version and it might
> be advisable for other Leaf owners to do so until the new poller is fully
> operational.
> 2024-05-02 12:22:28.316 NZST I (36847486) vehicle-poll: Poller[Frame]:
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> 2024-05-02 12:22:28.326 NZST I (36847496) vehicle-poll: Poller[Frame]:
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> 2024-05-02 12:22:28.336 NZST I (36847506) vehicle-poll: Poller[Frame]:
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> 2024-05-02 12:22:28.346 NZST I (36847516) vehicle-poll: Poller[Frame]:
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> 2024-05-02 12:22:28.356 NZST I (36847526) vehicle-poll: Poller[Frame]:
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> On Fri, 3 May 2024 at 05:40, Michael Balzer via OvmsDev <
>> A task may delete itself by calling vTaskDelete(NULL) as the final
>> statement, and that's normally a better way to shutdown a task, if you can
>> signal the task it should terminate. Deleting a task from outside may
>> always result in resources taken by the task not being freed, as the task
>> gets terminated wherever it just is.
>> As the vehicle task also needs to access vehicle data memory, vehicle
>> destruction should not begin until the task has finished, otherwise a task
>> job already running while the vehicle destruction takes place may run into
>> an illegal memory access (access after free). Keep in mind, destructors are
>> executed bottom up, so waiting for the task shutdown within the destructor
>> won't help.
>> Also, I think "MyCan.DeregisterCallback(TAG)" in ShuttingDown() is now
>> obsolete.
>> Am 02.05.24 um 15:23 schrieb Michael Geddes:
>> Thanks.
>> On that race condition... do you think we are better to just delete the
>> task  or I saw one recommendation that
>> We can delete it outside the while loop in the task itself!
>> //.ichael
>> On Tue, 30 Apr 2024, 17:46 Michael Balzer via OvmsDev, <
>>> OK, understood & merged, thanks for the quick fix/workaround.
>>> I'll ask the Twizy driver to test this.
>>> PS: side note: there's a shutdown race condition arising from `while
>>> (!m_is_shutdown)` in the new `OvmsVehicle::VehicleTask()`: if the task
>>> receives a message while m_is_shutdown already has been set, it will exit
>>> the loop and return from the task function, which isn't allowed. I think
>>> FreeRTOS will abort in that case.
>>> Am 30.04.24 um 08:55 schrieb Michael Geddes:
>>> No it will start the poll thread of the poller fine for those that don't
>>> use it.  That's the last commit.... so that should be covered. When the
>>> callback is registered the thread is force started.
>>> This is not to say that what you are suggesting isn't a better way
>>> forward... just that it should work.
>>> On Tue, 30 Apr 2024, 14:51 Michael Balzer via OvmsDev, <
>>>> Michael,
>>>> (taking this back to the list, as other developers may have helpful
>>>> ideas or suggestions)
>>>> from a first check, your new patch (PR #1008) won't help for vehicles
>>>> that don't use the poller, like the generic DBC vehicle or the Fiat 500
>>>> (plus possibly non-public third party vehicles). As the poller is normally
>>>> compiled in, these would need a run time switch to re-enable the vehicle
>>>> task, or more suitably default into that configuration and switch to the
>>>> poller task only when the poller gets initialized.
>>>> How about moving the task back into the vehicle class, but keeping your
>>>> task message extensions while doing so, and adding a way for the poller to
>>>> hook into the task? The dedicated vehicle task is an essential part of the
>>>> vehicle framework, but I do remember some occasions where a general way to
>>>> pass custom messages to the vehicle task would have been helpful to use the
>>>> task for more than CAN processing.
>>>> If the poller shall become avaible as a separate service that can be
>>>> used without any vehicle instance (currently not a defined use case), the
>>>> construct of a CAN processor task that can be extended for custom messages
>>>> (or a message processor task that can subscribe to CAN frames) could be
>>>> factored out into a dedicated class or template. The poller could then
>>>> create his own instance of that class, if it cannot hook into an existing
>>>> one.
>>>> Btw, in case you're not aware of this, FreeRTOS also provides queue
>>>> sets (https://www.freertos.org/RTOS-queue-sets.html). We haven't used
>>>> them in the OVMS yet, but they could be useful, especially if message
>>>> unions become large or tasks shall be able to dynamically subscribe to
>>>> different message sources.
>>>> Regards,
>>>> Michael
>>>> Am 30.04.24 um 01:20 schrieb Michael Geddes:
>>>> It might be worth reverting, but, I've got a patch suggestion that I'll
>>>> push up which will let me know if I understand everything and which might
>>>> provide a solution.
>>>> If this isn't going to work then revert. (P/R coming)
>>>> While the poller was still a part of the vehicle class it was probably
>>>> still all ok.   The poller had taken over what I assume you are talking
>>>> about as the vehicle task.  A call-back fromthe poller was calling
>>>> IncomingPollRxFrame which was then coming from the (now) poller task (is
>>>> that correct?)
>>>> While we have OVMS_COMP_POLLER config defined, we could just use the
>>>> poller task to provide the IncomingPollRxFrame call-back from the poller
>>>> (was vehicle?) task.
>>>> The problem is when OVMS_COMP_POLLER is undefined, we need an alternate
>>>> (maybe we could use the 'Event' loop then) which is when I hacked that bad
>>>> solution.
>>>> //.ichael
>>>> I was thinking though that because everything is being queued we could
>>>> divert some calls into the car
>>>> On Mon, 29 Apr 2024, 18:58 Michael Balzer, <dexter at expeedo.de> wrote:
>>>>> Michael,
>>>>> I've found a severe design flaw with your poller change. Sorry, I
>>>>> should have seen that before, and shouldn't have merged this.
>>>>> You have moved the standard CAN frame processing from the vehicle task
>>>>> into the CAN task by changing the vehicle from a CAN listener to a CAN
>>>>> callback processor. That will break all kind of things, vehicles like the
>>>>> Twizy, Smart and many others rely on frame processing being done in the
>>>>> dedicated vehicle task.
>>>>> This especially induces issues regarding CAN processing capacity, as
>>>>> the vehicles rely on having a separate context and not needing to decouple
>>>>> complex processing of incoming frames. So this will degrade the CAN
>>>>> processing performance seriously in many cases, where additional steps
>>>>> involving file or network I/O need to be done.
>>>>> So this needs to be changed back.
>>>>> I assumed you introduced a new dedicated poller task but kept the
>>>>> vehicle task intact. From your naming (OvmsVehicle::IncomingPollRxFrame),
>>>>> it seems you misinterpreted the vehicle task's purpose as only being used
>>>>> for polling.
>>>>> I assume this isn't a small change…? If so we should revert the poller
>>>>> merge, to avoid having a defunctional edge build state until the fix.
>>>>> Secondly: logging is generally expensive regardless of the log level
>>>>> control and log channels enabled. Any log message needs to be queued to the
>>>>> log system, so involves a lock and a potential wait state (for the queue) &
>>>>> resulting context switch (= minimum delay of 10 ms). Therefore, logging
>>>>> must be avoided as far as possible in any time critical context, and is
>>>>> forbidden under some circumstances, e.g. in a timer callback (see FreeRTOS
>>>>> docs on this). The log system load multiplies with connected web clients or
>>>>> enabled file logging and enabled debug / verbose level logging -- that
>>>>> quickly becomes too much, usually triggering the task watchdog.
>>>>> Your logging of nearly all bus events passing to/from the poller
>>>>> (especially the log entry in Queue_PollerFrame) becomes an issue on any
>>>>> vehicle that has high frequency running process data frames on the bus,
>>>>> like the Twizy or Smart. As a counter measure, I've just added a runtime
>>>>> control for all the poller's verbose logging (by default now off), and
>>>>> changed some debug level logs to verbose. Not sure if I've catched all that
>>>>> may need to be silenced by default. Please check all your log calls and
>>>>> place them under the new "trace" control flag wherever appropriate.
>>>>> This won't help avoiding issues with process data frame buses though.
>>>>> Shall I revert the poller merge for now?
>>>>> Regards,
>>>>> Michael
>>>>> Am 29.04.24 um 06:18 schrieb Michael Geddes:
>>>>> Btw I included the log changes in the p/r which is a few small commits
>>>>> for the poller.
>>>>> On Mon, 29 Apr 2024, 07:20 Michael Geddes, <
>>>>> frog at bunyip.wheelycreek.net> wrote:
>>>>>> Hey Michael,
>>>>>> I've got to work now (it's Monday), but I suspect those 'giving up'
>>>>>> are from unsolicited messages on the bus.
>>>>>> I can re-order things so that the message will likely be  'dropped
>>>>>> (no poll entry)' rather than the time-out message.
>>>>>> And make it a verbose log.
>>>>>> //.ichael
>>>>>> On Mon, 29 Apr 2024 at 00:25, Michael Balzer <dexter at expeedo.de>
>>>>>> wrote:
>>>>>>> Michael,
>>>>>>> forwarding the Twizy logs to you directly, as they contain the user
>>>>>>> location.
>>>>>>> He has just verified it's the new version, he says the module stops
>>>>>>> responding as soon as he turns on the Twizy.
>>>>>>> His description of his actions is a bit ambiguous, and it seems he
>>>>>>> didn't enable logging to the file persistently.
>>>>>>> According to the server, these were the version boot times:
>>>>>>> 2024-04-28 15:30:56    0    3.3.004-32-g125e0841/ota_0/edge (build
>>>>>>> idf v3.3.4-849-g6e214dc335 Apr 26 2024 19:16:50)
>>>>>>> 2024-04-28 16:21:08    0    3.3.004-32-g125e0841/ota_0/edge (build
>>>>>>> 2024-04-28 16:38:33    0    3.3.004-63-gf3595561/ota_1/edge (build
>>>>>>> idf v3.3.4-849-g6e214dc335 Apr 27 2024 07:44:50)
>>>>>>> 2024-04-28 16:40:57    0    3.3.004-63-gf3595561/ota_1/edge (build
>>>>>>> 2024-04-28 16:43:14    0    3.3.004-63-gf3595561/ota_1/edge (build
>>>>>>> 2024-04-28 16:46:39    0    3.3.004-63-gf3595561/ota_1/edge (build
>>>>>>> 2024-04-28 16:54:44    0    3.3.004-32-g125e0841/ota_0/edge (build
>>>>>>> Attached is also his crash debug log -- a2ll doesn't tell much about
>>>>>>> what happened, but maybe you get an idea from this.
>>>>>>> After the boot at 16:46, there are immediately lots of these
>>>>>>> messages:
>>>>>>> 2024-04-28 16:46:33.792 CEST D (39042) vehicle-poll: Poller: Queue
>>>>>>> PollerFrame()
>>>>>>> 2024-04-28 16:46:33.792 CEST D (39042) vehicle-poll: [1]Poller:
>>>>>>> Incoming - giving up
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 28.04.24 um 16:44 schrieb Michael Geddes:
>>>>>>> Ah. OK.
>>>>>>> I could try to fix the vin thing using the new way of doing it and
>>>>>>> get rid of a semaphore?
>>>>>>> It would at least identify the problem possibly?
>>>>>>> Michael
>>>>>>> On Sun, 28 Apr 2024, 22:32 Michael Balzer via OvmsDev, <
>>>>>>>> Not sure if that's the problem, but I've found a different
>>>>>>>> behaviour with the new PollSetState() implementation.
>>>>>>>> The old version only did anything if the new state actually was
>>>>>>>> different from the previous one. The Twizy relies on this behaviour,
>>>>>>>> calling PollSetState() from the per second ticker (see
>>>>>>>> OvmsVehicleRenaultTwizy::ObdTicker1).
>>>>>>>> The new implementation apparently always sends the PollState
>>>>>>>> command to the task, and that in turn always at least locks the poller
>>>>>>>> mutex. Not sure if/how that could cause the observed issues, but it
>>>>>>>> definitely adds quite some (unnecessary?) lock/unlock operations.
>>>>>>>> Am 28.04.24 um 16:05 schrieb Michael Balzer via OvmsDev:
>>>>>>>> The Twizy uses the poller to query the VIN (once) and DTCs (every
>>>>>>>> 10 seconds while driving), see rt_obd2.cpp.
>>>>>>>> It also has its own version of the OBD single request
>>>>>>>> (OvmsVehicleRenaultTwizy::ObdRequest), which was the precursor for the
>>>>>>>> generalized version. This is used by custom/user Twizy plugins and scripts
>>>>>>>> to access ECU internals.
>>>>>>>> The Twizy doesn't use IncomingPollRxFrame, but the Twizy's
>>>>>>>> IncomingPollReply handler will log any poll responses it doesn't know
>>>>>>>> about, so that could lead to a lot of log output if something goes wrong
>>>>>>>> there.
>>>>>>>> Am 28.04.24 um 15:49 schrieb Michael Geddes via OvmsDev:
>>>>>>>> AFAICT the twizzy doesn't use the poller list at all.  So is it
>>>>>>>> missing a call-back or something??
>>>>>>>> I can see a potential problem with IncomingPollRxFrame being called
>>>>>>>> twice as much as it should be but only when there is a poll list.  Maybe
>>>>>>>> commenting out this would do it.  (I can find another away to get this
>>>>>>>> called on the thread I want).  This might be the problem with the smarted
>>>>>>>> void OvmsVehicle::OvmsVehicleSignal::IncomingPollRxFrame(canbus*
>>>>>>>> bus, CAN_frame_t *frame, bool success)
>>>>>>>>   //if (Ready())
>>>>>>>>   //  m_parent->IncomingPollRxFrame(frame, success);
>>>>>>>> On Sun, 28 Apr 2024 at 21:10, Michael Balzer via OvmsDev <
>>>>>>>>> There may also be an issue with the Renault Twizy, I've received a
>>>>>>>>> report of a user who is using the edge builds, that the latest build
>>>>>>>>> wouldn't work.
>>>>>>>>> He reports all kinds of errors and warnings signaled by the car
>>>>>>>>> during driving, and switching back to the previous build fixed the issues.
>>>>>>>>> I've asked him to provide a debug log excerpt if possible.
>>>>>>>>> Regards,
>>>>>>>>> Michael
>>>>>>>>> Am 28.04.24 um 14:29 schrieb Michael Geddes via OvmsDev:
>>>>>>>>> OK. That's bad.
>>>>>>>>> Does the reading work in general?
>>>>>>>>> Is it just the writing commands?
>>>>>>>>> Raise a ticket on github and tag me in and we can address it that
>>>>>>>>> way.
>>>>>>>>> Michael
>>>>>>>>> On Sun, 28 Apr 2024, 19:49 Thomas Heuer via OvmsDev, <
>>>>>>>>>> Hi,
>>>>>>>>>> The new poller code doesn't seem to work properly with the
>>>>>>>>>> smarted.
>>>>>>>>>> D (218831) vehicle-poll: [1]PollerNextTick(PRI): cycle complete
>>>>>>>>>> for ticker=215
>>>>>>>>>> V (218831) vehicle-poll: Standard Poll Series: List reset
>>>>>>>>>> PollSeriesList::NextPollEntry[!v.standard]: ReachedEnd
>>>>>>>>>> V (218831) vehicle-poll: [1]PollerSend: Poller Reached End
>>>>>>>>>> D (219691) vehicle-poll: Poller: Queue PollerFrame()
>>>>>>>>>> V (219691) vehicle-poll: Pollers: FrameRx(bus=2)
>>>>>>>>>> *OVMS#* unlock 22
>>>>>>>>>> Vehicle unlocked
>>>>>>>>>> D (219701) vehicle-poll: Poller: Queue PollerFrame()
>>>>>>>>>> V (219701) vehicle-poll: Pollers: FrameRx(bus=2)
>>>>>>>>>> *Von:* OvmsDev <ovmsdev-bounces at lists.openvehicles.com> *Im
>>>>>>>>>> Auftrag von *Michael Geddes via OvmsDev
>>>>>>>>>> *Gesendet:* Sonntag, 28. April 2024 12:27
>>>>>>>>>> *An:* OVMS Developers <ovmsdev at lists.openvehicles.com>
>>>>>>>>>> *Cc:* Michael Geddes <frog at bunyip.wheelycreek.net>
>>>>>>>>>> *Betreff:* [Ovmsdev] OVMS Poller module/singleton
>>>>>>>>>> Hey all,
>>>>>>>>>> The poller singleton code that I've been working on for over a
>>>>>>>>>> year now is merged in. (Thanks Michael for expediting the final step).
>>>>>>>>>> This includes separate multi-frame states per bus and multiple
>>>>>>>>>> poll lists as well as non-blocking one off queries. As well as more
>>>>>>>>>> 'states'.
>>>>>>>>>> I have included some programming documentation in the change but
>>>>>>>>>> am happy to supply more if needed.
>>>>>>>>>> The ioniq 5 code has some examples of how it can be used. Some
>>>>>>>>>> examples are:
>>>>>>>>>> * grabbing the vin as a one shot without blocking
>>>>>>>>>> * having a short list of queries that are polled quickly for
>>>>>>>>>> obd2ecu (this also demonstrates using a shorter frame break value and then
>>>>>>>>>> a break after successful a response)
>>>>>>>>>> Have a play please!
>>>>>>>>>> Also interested in hearing what user tools might be worth looking
>>>>>>>>>> at next for the poller object.
>>>>>>>>>> //.ichael G.
>>>>>>>>>> _______________________________________________
>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240503/bc2803fd/attachment-0001.htm>
