[Ovmsdev] V2 server not starting
Mon Mar 25 10:42:24 HKT 2024
Derek,
The message ‘waiting or network connectivity’ means there is no internet link (either wifi or modem), so the v2 server won’t start.
When you switch from wifi to modem (or vice-versa), all listening services and active connections will be reset. If there is a gap between leaving wifi and reaching modem coverage, listening services will be interrupted for that time.
You can see current status with ’network status’.
> On 23 Mar 2024, at 2:54 AM, Derek Caudwell <d.caudwell at gmail.com> wrote:
> Hi all,
> My ovms unit is regularly disconnecting from the V2 server with the message:
> State: Waiting for network connectivity Server is ready to start
> I'm on 3.3.003-696-g562479ea, I suspect it is happening when I either leave home or return (simple script turns on/off modem to use wifi). The V3 server does not have the same issue. Any ideas on debugging appreciated, as the network/wifi connection is up and stable?
> Also I finally got to the bottom of my issue with the 7600 modem, the daughter board's RX pin was not long enough causing intermittent connection to the main board.
> Cheers Derek
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240325/cb6b662f/attachment.htm>
