[Ovmsdev] V2 server not starting
Derek Caudwell d.caudwell at gmail.com
Sat Mar 23 02:54:53 HKT 2024
Hi all,
My ovms unit is regularly disconnecting from the V2 server with the message:
State: Waiting for network connectivity Server is ready to start
I'm on 3.3.003-696-g562479ea, I suspect it is happening when I either leave
home or return (simple script turns on/off modem to use wifi). The V3
server does not have the same issue. Any ideas on debugging appreciated, as
the network/wifi connection is up and stable?
Also I finally got to the bottom of my issue with the 7600 modem, the
daughter board's RX pin was not long enough causing intermittent connection
to the main board.
Cheers Derek
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240323/3fe1435f/attachment.htm>
