[Ovmsdev] Firmware release 3.3.004
Mon Mar 25 09:22:07 HKT 2024
I’ve done the same. 3.3.004 is now in EAP.
A huge thanks to everyone involved in this.
> On 23 Mar 2024, at 5:28 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Everyone,
> I've just tagged version 3.3.004 and released the build to EAP on ovms.dexters-web.de -- Mark, please follow up. As usual, we will release this to MAIN in about a week.
> This release has been long overdue, it includes numerous new features, new vehicles and of course lots of bug fixes.
> A huge thank you to everyone involved in this collaborative effort!
> Changes since 3.3.003:
> - MG EV Added support for MG5 (2020 - 2023) Short Range
> - MG EV Added support for MG ZS EV (2023 - ) and MG5 (2020 - 2023) Long Range
> - OVMS Server v3 metrics filtering
>   New configs:
>     [server.v3] metrics.include         -- Comma-separated list of metric names (with possible wildcard) matching metrics to send
>     [server.v3] metrics.exclude         -- Comma-separated list of metric names (with possible wildcard) matching metrics to not send
> - Renault Zoe Phase 2: Initial support
> - Improved output of bms shell command for narrow windows.
>   New commands:
>     bms volt                            -- Output only voltage info if available
>     bms temp                            -- Output only temperature info if available
> - Hyundai Ioniq 5: Initial support
> - Support for specifying units in scripts
>   New commands:
>     metrics units                       -- Display available unit identifiers
>     metrics get                         -- Get at a particular metric value (with a specified unit)
>   Extended commands:
>     metrics set                         -- Support setting with a specified unit
>   Extend functions
>     OvmsMetrics.Value                   -- Optionally specify a unit (and make 'decode' work) and to get values with units.
>     OvmsMetrics.GetValues               -- Optionally specify a unit to get values with units.
>     OvmsMetrics.AsFloat                 -- Optionally specify a unit
>   New DukTape function
>     OvmsMetrics.HasValue                -- Returns true if the metric has a valid value.
> - Added power consumptions units:  kWhP100K,KPkWh,MPkWh
> - Consolidate custom trip power consumption metrics to single value (kWhP100K)
>   in Kia Niro and Kia Soul
> - VFS: sorted directory listings & recursive directory listings
>   New commands:
>     vfs rls <path>                      -- List <path> and all subdirectory contents
> - Vehicle: emit standard events on charge/generator connection type changes
>   New events:
>     vehicle.charge.type                 -- Vehicle charge connection type has changed (e.g. ccs/type2/…)
>     vehicle.gen.type                    -- Vehicle generator connection type has changed
> - CAN logging: add possibility to log events (name) and metrics (JSON object with name, value, unit)
>   New configs:
>     [can] log.events_filters            -- comma-separated list of filters (with possible wildcard) matching an event name
>     [can] log.metrics_filters           -- comma-separated list of filters (with possible wildcard) matching a metric name
> - Add units Bar, Permille
> - Add user configuration for groups of metrics
>   Adds the 'ToUser' unit that converts to the user specified unit.
>   Add -u to 'metrics list' to view metrics as  user units.
> - Add completion for metrics set/get as well as units
> - Mini Cooper SE: Initial support
> - Hyundai Ioniq vFL: trip metrics, range estimations, TPMS, web configuration,
>     charge type detection, charge speed & time estimation
>   New configs:
>     [xhi] ctp.maxpower                -- Default charge power limit [kW] for charge time estimations, default 0 = unlimited
>     [xhi] ctp.soclimit                -- SOC level [%] for secondary charge time estimation (sufficient SOC), default 80
>     [xhi] notify.charge.delay.ccs     -- Wait time [sec] for DC charge power to ramp up before sending the notification, default 15
>     [xhi] notify.charge.delay.type2   -- … same for AC charging, default 3
>     [xhi] range.ideal                 -- ideal new car range [km], default 200
>     [xhi] range.user                  -- typical current user range [km], default 200
>     [xhi] range.smoothing             -- Number of SOC samples, default 10 = ~ 5% SOC
>     [xhi] tpms.pressure.warn              -- default 230 [kPa]
>     [xhi] tpms.pressure.alert         -- default 220 [kPa]
>     [xhi] tpms.temp.warn              -- default 90 [°C]
>     [xhi] tpms.temp.alert             -- default 100 [°C]
>   New metrics:
>     xhi.b.range.user                  -- actual current user range [km]
>     xhi.e.state                       -- General/ignition state flags
> - Module: support deep sleep schedules
>   New commands:
>     module sleep                      -- Shutdown all components and enter deep sleep for a time span or until a specific time.
> - Add support for user-configured metrics in the web interface and plugins:
>    Adds an extra 'units' stream from the websocket containing sub-streams:
>      - metrics (for the current user unit/label for each metric) (subscribe to units/metrics)
>      - prefs (for any user preferences for unit groups/types) (subscribe to units/prefs)
>    Adds proxy arrays metrics_user[] , metrics_label[] available to plugin pages.
>    Adds various browser javascript functions and methods for plugins related
>      to displaying user configurations Auto-converts metric display to user
>      units in plugins that use attributes
> - Cellular: add GPS/GNSS state control commands (for power management)
>   New commands:
>     cellular gps [status]             -- output current modem GPS/GNSS subsystem status
>     cellular gps start                -- start modem GPS/GNSS subsystem
>     cellular gps stop                 -- stop modem GPS/GNSS subsystem
> - CAN framework: add bus reset command
>   New commands:
>     can [can1…4] reset                -- reset the CAN interface
> - Vehicle: add support for custom command handlers, see…
> https://docs.openvehicles.com/en/latest/userguide/scripting.html#ovmsvehicle-command-plugins
> - Renault Twizy: read battery energy available from BMS (thanks to Martin Bitz)
>   New metrics:
>     xrt.b.energy.avail                -- Current battery energy available [kWh] (aged)
>     xrt.b.energy.full                 -- Maximum battery energy capacity [kWh] (aged, needs full charge)
> - Add button on web file editor to reload obd2ECU (when obd2ECU is enabled).
> - Vehicle: add support for a geofence for valet mode similar to parking/flatbed warnings.
>   New Configs:
>     [vehicle] valet.alarmdistance     -- How far away from the original position before raising an alert (in metres)
>     [vehicle] valet.alarminterval      -- How often the alarm can be raised in minumtes
> - Add metric and events related to obd2ecu process:
>   New metric:
>     m.obdc2ecu.on                     -- Is the OBD2ECU process currently on.
>   New events:
>     obd2ecu.start                     -- Called after the OBD2ECU process is started.
>     obd2ecu.stop                      -- Called before the OBD2ECU process is stopped.
> - Web UI: Add configuration for Valet and Flatbed geofence to the Locations config page.
> - Network: New 'network ping' command to ping (ICMP) hostname or IP address. (ESP-IDFv4+ only / needs to be enabled in menuconfig - Developer Options)
> - Vehicle: add automatic module shutdown/reboot based on 12V battery voltage level
>   New configs:
>     [vehicle] 12v.shutdown            -- Shutdown voltage level (default: disabled)
>     [vehicle] 12v.wakeup              -- Reboot minimum voltage level after shutdown (default: any)
>     [vehicle] 12v.wakeup_interval     -- Reboot test interval in seconds (default: 60)
>   New events:
>     vehicle.alert.12v.shutdown        -- 12V shutdown threshold reached, entering deep sleep
> - BYD Atto 3 initial support
> - Vehicle: add 12V shutdown delay & notification
>   New configs:
>     [vehicle] 12v.shutdown_delay      -- Shutdown delay in minutes (default: 2)
>   New events:
>     vehicle.alert.12v.low             -- 12V shutdown voltage level detected
>     vehicle.alert.12v.operational     -- 12V recovered above shutdown level
>   New notifications:
>     [alert] batt.12v.shutdown         -- Alert about imminent 12V shutdown
> - VFS toolkit: add recursive options to mkdir (-p) & rmdir (-r) commands
> - Renault-Zoe-Ph1: add Cabin Pre-heat/cool Control
