[Ovmsdev] Firmware release 3.3.004
Sat Mar 23 17:28:48 HKT 2024
Everyone,
I've just tagged version 3.3.004 and released the build to EAP on
ovms.dexters-web.de -- Mark, please follow up. As usual, we will release
this to MAIN in about a week.
This release has been long overdue, it includes numerous new features,
new vehicles and of course lots of bug fixes.
A huge thank you to everyone involved in this collaborative effort!
Changes since 3.3.003:
- MG EV Added support for MG5 (2020 - 2023) Short Range
- MG EV Added support for MG ZS EV (2023 - ) and MG5 (2020 - 2023) Long
Range
- OVMS Server v3 metrics filtering
New configs:
[server.v3] metrics.include -- Comma-separated list of
metric names (with possible wildcard) matching metrics to send
[server.v3] metrics.exclude -- Comma-separated list of
metric names (with possible wildcard) matching metrics to not send
- Renault Zoe Phase 2: Initial support
- Improved output of bms shell command for narrow windows.
New commands:
bms volt -- Output only voltage info if
available
bms temp -- Output only temperature info
if available
- Hyundai Ioniq 5: Initial support
- Support for specifying units in scripts
New commands:
metrics units -- Display available unit
identifiers
metrics get -- Get at a particular metric
value (with a specified unit)
Extended commands:
metrics set -- Support setting with a
specified unit
Extend functions
OvmsMetrics.Value -- Optionally specify a unit
(and make 'decode' work) and to get values with units.
OvmsMetrics.GetValues -- Optionally specify a unit to
OvmsMetrics.AsFloat -- Optionally specify a unit
New DukTape function
OvmsMetrics.HasValue -- Returns true if the metric
has a valid value.
- Added power consumptions units: kWhP100K,KPkWh,MPkWh
- Consolidate custom trip power consumption metrics to single value
(kWhP100K)
in Kia Niro and Kia Soul
- VFS: sorted directory listings & recursive directory listings
New commands:
vfs rls <path> -- List <path> and all
subdirectory contents
- Vehicle: emit standard events on charge/generator connection type changes
New events:
vehicle.charge.type -- Vehicle charge connection
type has changed (e.g. ccs/type2/…)
vehicle.gen.type -- Vehicle generator connection
type has changed
- CAN logging: add possibility to log events (name) and metrics (JSON
object with name, value, unit)
New configs:
[can] log.events_filters -- comma-separated list of
filters (with possible wildcard) matching an event name
[can] log.metrics_filters -- comma-separated list of
filters (with possible wildcard) matching a metric name
- Add units Bar, Permille
- Add user configuration for groups of metrics
Adds the 'ToUser' unit that converts to the user specified unit.
Add -u to 'metrics list' to view metrics as user units.
- Add completion for metrics set/get as well as units
- Mini Cooper SE: Initial support
- Hyundai Ioniq vFL: trip metrics, range estimations, TPMS, web
configuration,
charge type detection, charge speed & time estimation
New configs:
[xhi] ctp.maxpower -- Default charge power limit
[kW] for charge time estimations, default 0 = unlimited
[xhi] ctp.soclimit -- SOC level [%] for secondary
charge time estimation (sufficient SOC), default 80
[xhi] notify.charge.delay.ccs -- Wait time [sec] for DC charge
power to ramp up before sending the notification, default 15
[xhi] notify.charge.delay.type2 -- … same for AC charging, default 3
[xhi] range.ideal -- ideal new car range [km],
default 200
[xhi] range.user -- typical current user range
[km], default 200
[xhi] range.smoothing -- Number of SOC samples, default
10 = ~ 5% SOC
[xhi] tpms.pressure.warn -- default 230 [kPa]
[xhi] tpms.pressure.alert -- default 220 [kPa]
[xhi] tpms.temp.warn -- default 90 [°C]
[xhi] tpms.temp.alert -- default 100 [°C]
New metrics:
xhi.b.range.user -- actual current user range [km]
xhi.e.state -- General/ignition state flags
- Module: support deep sleep schedules
New commands:
module sleep -- Shutdown all components and
enter deep sleep for a time span or until a specific time.
- Add support for user-configured metrics in the web interface and plugins:
Adds an extra 'units' stream from the websocket containing sub-streams:
- metrics (for the current user unit/label for each metric)
(subscribe to units/metrics)
- prefs (for any user preferences for unit groups/types)
(subscribe to units/prefs)
Adds proxy arrays metrics_user[] , metrics_label[] available to
plugin pages.
Adds various browser javascript functions and methods for plugins
related
to displaying user configurations Auto-converts metric display to user
units in plugins that use attributes
- Cellular: add GPS/GNSS state control commands (for power management)
New commands:
cellular gps [status] -- output current modem GPS/GNSS
subsystem status
cellular gps start -- start modem GPS/GNSS subsystem
cellular gps stop -- stop modem GPS/GNSS subsystem
- CAN framework: add bus reset command
New commands:
can [can1…4] reset -- reset the CAN interface
- Vehicle: add support for custom command handlers, see…
https://docs.openvehicles.com/en/latest/userguide/scripting.html#ovmsvehicle-command-plugins
- Renault Twizy: read battery energy available from BMS (thanks to
Martin Bitz)
New metrics:
xrt.b.energy.avail -- Current battery energy
available [kWh] (aged)
xrt.b.energy.full -- Maximum battery energy
capacity [kWh] (aged, needs full charge)
- Add button on web file editor to reload obd2ECU (when obd2ECU is enabled).
- Vehicle: add support for a geofence for valet mode similar to
parking/flatbed warnings.
New Configs:
[vehicle] valet.alarmdistance -- How far away from the original
position before raising an alert (in metres)
[vehicle] valet.alarminterval -- How often the alarm can be
raised in minumtes
- Add metric and events related to obd2ecu process:
New metric:
m.obdc2ecu.on -- Is the OBD2ECU process
currently on.
New events:
obd2ecu.start -- Called after the OBD2ECU
process is started.
obd2ecu.stop -- Called before the OBD2ECU
process is stopped.
- Web UI: Add configuration for Valet and Flatbed geofence to the
Locations config page.
- Network: New 'network ping' command to ping (ICMP) hostname or IP
address. (ESP-IDFv4+ only / needs to be enabled in menuconfig -
Developer Options)
- Vehicle: add automatic module shutdown/reboot based on 12V battery
voltage level
New configs:
[vehicle] 12v.shutdown -- Shutdown voltage level
(default: disabled)
[vehicle] 12v.wakeup -- Reboot minimum voltage level
after shutdown (default: any)
[vehicle] 12v.wakeup_interval -- Reboot test interval in
seconds (default: 60)
New events:
vehicle.alert.12v.shutdown -- 12V shutdown threshold
reached, entering deep sleep
- BYD Atto 3 initial support
- Vehicle: add 12V shutdown delay & notification
New configs:
[vehicle] 12v.shutdown_delay -- Shutdown delay in minutes
(default: 2)
New events:
vehicle.alert.12v.low -- 12V shutdown voltage level
detected
vehicle.alert.12v.operational -- 12V recovered above shutdown level
New notifications:
[alert] batt.12v.shutdown -- Alert about imminent 12V shutdown
- VFS toolkit: add recursive options to mkdir (-p) & rmdir (-r) commands
- Renault-Zoe-Ph1: add Cabin Pre-heat/cool Control
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240323/da78b35c/attachment.sig>
