Michael,
"data" notifications correspond to the V2/MP "historical" message type:
* https://docs.openvehicles.com/en/latest/protocol_v2/messages.html#historical-data-update-message-0x48-h
So a record type of "*-LOG-Poll" would be OK, but I suggest using
"*-LOG-PollStats" to be more precise.
The record ID needs to be an integer, and the default V2 server database
defines this to be a 32 bit signed integer. Note that sending a new
record won't overwrite an existing one with the same ID, as the
timestamp is part of the primary key. I suggest using your report line
number.
You can provide a header as line 0 then, or you can leave adding a
header to the download tool (as do all the other data records up to
now). If you use my server, you can download all data from the car UI,
if you use another public server, you can still use my download tool via
this page:
* https://dexters-web.de/downloadtool?lang=EN
Download tools other than the ones I provide in my web UI are the
scripts in the server repository's client directory:
* https://github.com/openvehicles/Open-Vehicle-Server/tree/master/clients
The most simple form is shown by the "serverlog.sh" script, for adding
headers see e.g. "rt_fetchlogs.sh". I normally let my server send me the
logs by mail on a daily base, these include all historical data files
with headers added.
Assuming record type "*-LOG-PollStats", I've just added auto headers to
my tool based on your template as follows:
* type,count_hz,avg_util_pm,peak_util_pm,avg_time_ms,peak_time_ms
(keeping the header style consistent with the other logs)
So you can now simply send the data rows, the tool will prepend the
header once on each download.
Am 19.06.24 um 11:10 schrieb Michael Geddes:
> Sure, I can do that.
> I did it this way because it was easier and could mostly do it in one
> message. As soon as I added spaces for alignment it pushed the message
> over 2 notifications. Also, I wasn't sure about making a new Data type
> and how that worked.
> I'm assuming something like: *-LOG-Poll would work (unless you want
> to suggest something else) The next 2 cols seem to be ID and lifetime.
> What do I use as an ID? Can it be an alpha string or does it have to
> be a number? (LIke using the first column descriptor). I'm not sure
> how the ID column is treated. I _could_ just send a line number for
> the dump group I guess?
> These are the columns I have. I can force the two cols to be always
> permille.
> "Type","Count (hz)","Avg utlization (permille)","Peak utlization
> (permille)", "Avg Time (ms)","Peak Time (ms)"
> Type is the only alpha column.. but if I can use that for the ID I
> guess that would be better?
> How would I provide a header if I wanted to? Is there some indicator
> saying it's a header line? I'm not sure I want to - just asking.
> //.ichael
> On Wed, 19 June 2024, 00:11 Michael Balzer via OvmsDev,
> <ovmsdev at lists.openvehicles.com> wrote:
> Michael,
> I've received the new drive report notifications now; these need
> to be changed: please do not use text notifications to transport
> CSV data. That's what "data" notifications are meant for, which
> are stored in their raw form on the server for later retrieval.
> See e.g. the vehicle trip & grid logs for reference on how to
> build the messages, or have a look at the specific Twizy and
> UpMiiGo data messages.
> Data notifications also are designed to transport one row at a
> time, so you normally don't run into buffer size issues. A header
> can be supplied as a row, but you normally add one when
> downloading the data from the server, so tools don't need to
> filter these out. I provide headers automatically on my server for
> known message types, just send me your template and I'll include that.
> Apart from that, the timing statistics now seem to work pretty
> well, providing valuable insights.
> Am 14.06.24 um 08:59 schrieb Michael Geddes:
>> Thankyou.
>> I was more worried that we might be waiting on each other.
>> I don't think I have quite the correct able to test on my friends
>> Leaf properly, or does it use the standard cable?
>> Anyway, let me know what I can do to.
>> //.ichael
>> On Fri, 14 Jun 2024 at 14:46, Michael Balzer via OvmsDev
>> Sorry, I know I'm behind with PRs.
>> I'll try to find some time this weekend.
>> Am 14.06.24 um 08:31 schrieb Michael Geddes via OvmsDev:
>>> Was this all good? I want to make sure I get to the bottom
>>> of this whole issue asap!
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/1018
>>> Was there something else you needed me to work on to make
>>> sure this all works for all supported cars?
>>> //.ichael
>>> On Sun, 26 May 2024 at 21:15, Michael Balzer via OvmsDev
>>> OK, I see now why it wouldn't send the notification: the
>>> V2 & V3 server register for notifications up to
>>> COMMAND_RESULT_NORMAL = 1024 characters.
>>> The report quickly becomes larger than 1024 characters,
>>> so the notifications no longer get sent via the server
>>> connectors.
>>> You need to either reduce the size, split the report, or
>>> use data notifications instead.
>>> On the reset value init: for my float targeting
>>> smoothing helper class for the UpMiiGo, I implemented a
>>> gradual ramp up from 1 to the requested sample size. You
>>> can do something similar also with powers of 2. IOW,
>>> yes, initialization from the first values received is
>>> perfectly OK.
>>> Am 26.05.24 um 14:35 schrieb Michael Geddes:
>>>> It _/should/_ already be sending a report on charge stop.
>>>> MyEvents.RegisterEvent(TAG, "vehicle.charge.stop",
>>>> std::bind(&OvmsPollers::VehicleChargeStop, this, _1, _2));
>>>> Reset on charge start/vehicle on is a good idea.
>>>> A question – would it be silly if the first value after
>>>> a reset, rather than using 0 average to start with, if
>>>> the average got set to the initial value? I’m in 2
>>>> minds about it. It would make the average more useful
>>>> quicker.
>>>> //.ichael
>>>> On Sun, 26 May 2024, 19:39 Michael Balzer via OvmsDev,
>>>> As the averages quickly decline when idle, an
>>>> automatic report should probably also be sent on
>>>> charge stop.
>>>> Also, I think you should automatically reset the
>>>> timer statistics on drive & charge start.
>>>> First stats from charging my UpMiiGo:
>>>> Type | count | Utlztn | Time
>>>> | per s | [‰] | [ms]
>>>> Poll:PRI Avg| 1.00| 0.723| 0.716
>>>> Peak| | 1.282| 3.822
>>>> Poll:SRX Avg| 7.72| 1.246| 0.184
>>>> Peak| | 3.128| 1.058
>>>> RxCan1[7ae] Avg| 2.48| 0.915| 0.362
>>>> Peak| | 1.217| 1.661
>>>> RxCan1[7cf] Avg| 4.76| 1.928| 0.397
>>>> Peak| | 2.317| 2.687
>>>> RxCan1[7ed] Avg| 3.38| 1.251| 0.327
>>>> Peak| | 8.154| 12.273
>>>> RxCan1[7ee] Avg| 0.21| 0.066| 0.297
>>>> Peak| | 0.225| 1.690
>>>> TxCan1[744] Avg| 1.49| 0.022| 0.011
>>>> Peak| | 0.032| 0.095
>>>> TxCan1[765] Avg| 3.89| 0.134| 0.027
>>>> Peak| | 0.155| 0.113
>>>> TxCan1[7e5] Avg| 2.32| 0.038| 0.013
>>>> Peak| | 0.295| 0.084
>>>> TxCan1[7e6] Avg| 1 0.21| 0.002| 0.008
>>>> Peak| | 0.010| 0.041
>>>> Cmd:State Avg| 0.00| 0.000| 0.007
>>>> Peak| | 0.005| 0.072
>>>> Total Avg| 27.46| 6.324| 2.349
>>>> Overall healthy I'd say, but let's see how it compares.
>>>> 7ed is the BMS, the peak time is probably related
>>>> to the extended cell data logging -- I've enabled
>>>> log intervals for both cell voltages & temperatures.
>>>> Regards,
>>>> Michael
>>>> Am 26.05.24 um 08:42 schrieb Michael Balzer via
>>>> OvmsDev:
>>>> The notification works on my devices, it only
>>>> has a garbled per mille character -- see
>>>> attached screenshot. The same applies to the
>>>> mail version:
>>>> Poller timing is: on
>>>> | per s | [‰] | [ms]
>>>> Poll:PRI Avg| 0.25| 0.119| 0.382
>>>> Peak| | 0.513| 0.678
>>>> RxCan1[597] Avg| 0.01| 0.004| 0.021
>>>> Peak| | 0.000| 0.338
>>>> RxCan1[59b] Avg| 0.01| 0.011| 0.053
>>>> Peak| | 0.000| 0.848
>>>> Cmd:State Avg| 0.01| 0.002| 0.012
>>>> Peak| | 0.000| 0.120
>>>> Total Avg| 0.28| 0.135| 0.468
>>>> The encoding is a general issue. The character
>>>> encoding for text messages via V2/MP is quite
>>>> old & clumsy, it's got an issue with the degree
>>>> celcius character as well. We previously tried
>>>> to keep all text messages within the SMS safe
>>>> character set (which e.g. lead to writing just
>>>> "C" instead of "°C"). I'd say we should head
>>>> towards UTF-8 now. If we ever refit SMS
>>>> support, we can recode on the fly.
>>>> Regarding not seeing the notification on your
>>>> phone:
>>>> a) Check your notification subtype/channel
>>>> filters on the module. See
>>>> https://docs.openvehicles.com/en/latest/userguide/notifications.html#suppress-notifications
>>>> b) Check your notification vehicle filters on
>>>> the phone (menu on notification tab): if you
>>>> enabled the vehicle filter, it will add the
>>>> messages of not currently selected vehicles to
>>>> the list only, but not raise a system
>>>> notification. (Applies to the Android App, no
>>>> idea about the iOS version)
>>>> Regards,
>>>> Michael
>>>> Am 26.05.24 um 06:32 schrieb Michael Geddes:
>>>> Hi,
>>>> I'm trying to finalise this now .. and one
>>>> last thing is that I don't get the report
>>>> coming to my mobile. I'm using the command:
>>>> MyNotify.NotifyString("info",
>>>> "poller.report", buf.c_str());
>>>> Where the buffer string is just the same as
>>>> the report output. Should I be using some
>>>> other format or command?
>>>> I get "alert" types (like the ioniq5
>>>> door-open alert) fine to my mobile.
>>>> Michael.
>>>> On Sun, 19 May 2024, 12:51 Michael Balzer
>>>> via OvmsDev,
>>>> A builtin web UI for this seems a bit
>>>> over the top. Builtin web config pages
>>>> should focus on user features, this is
>>>> clearly a feature only needed
>>>> during/for the development/extension of
>>>> a vehicle adapter. Development features
>>>> in the web UI are confusing for end users.
>>>> If persistent enabling/disabling is
>>>> done by a simple config command (e.g.
>>>> "config set can poller.trace on"),
>>>> that's also doable by users.
>>>> Regards,
>>>> Michael
>>>> Am 19.05.24 um 02:06 schrieb Michael
>>>> Geddes:
>>>> I was so focused on how I
>>>> calculated the value that I totally
>>>> missed that ‰ would be a better
>>>> description. I could also use the
>>>> system 'Ratio' unit... so % or ‰.
>>>> I'll make space to put 'Avg' on the
>>>> row. Was trying to limit the width
>>>> for output on a mobile. I agree it
>>>> would make it easier to understand.
>>>> Totals also makes sense.
>>>> Should I make this a configuration
>>>> that can be set on the web-page?
>>>> I'd probably use a configuration
>>>> change notification so that the
>>>> very bit setting is sync'd with the
>>>> 'configuration' value.
>>>> //.ichael
>>>> On Sat, 18 May 2024, 14:05 Michael
>>>> Balzer, <dexter at expeedo.de> wrote:
>>>> I'm not sure whether the
>>>> 'max' should be the maximum
>>>> of the smoothed value.. or
>>>> the maximum of the raw value.
>>>> It should normally be the
>>>> maximum of the raw value I
>>>> think, the maximum of the
>>>> smoothed value cannot tell
>>>> about how bad the processing of
>>>> an ID can become.
>>>> The naming in the table is a
>>>> bit confusing I think.
>>>> (besides: I've never seen "ave"
>>>> as the abbreviation for average)
>>>> If I understand you correctly,
>>>> "time ms per s" is the time
>>>> share in per mille, so
>>>> something in that direction
>>>> would be more clear, and
>>>> "length ms" would then be "time
>>>> [ms]".
>>>> The totals for all averages in
>>>> the table foot would also be nice.
>>>> Maybe "Ave" (or avg?) also
>>>> should be placed on the left,
>>>> as the "peak" label now
>>>> suggests being the peak of the
>>>> average.
>>>> Btw, keep in mind, not all
>>>> "edge" users / testers are
>>>> developers (e.g. the Twizy
>>>> driver I'm in contact with),
>>>> collecting stats feedback for
>>>> vehicles from testers should be
>>>> straight forward. Maybe add a
>>>> data/history record, sent
>>>> automatically on every
>>>> drive/charge stop when the
>>>> poller tracing is on?
>>>> Regards,
>>>> Michael
>>>> Am 18.05.24 um 02:28 schrieb
>>>> Michael Geddes:
>>>> You did say max/pead
>>>> value. I also halved the N
>>>> for both.
>>>> This is currently the
>>>> raw-value maximum.
>>>> The problem is that the
>>>> middle column is the
>>>> maximum of the {{sum over
>>>> 10s} / (10*1000,000)
>>>> I could easily change the
>>>> 'period' to 1s and see how
>>>> that goes.. was just trying
>>>> to reduce the larger
>>>> calculations.
>>>> Usage: poller
>>>> [pause|resume|status|times|trace]
>>>> OVMS# poller time status
>>>> Type | Count |
>>>> Ave time | Ave length
>>>> | per s |
>>>> ms per s | ms
>>>> Poll:PRI | 1.00|
>>>> 0.559| 0.543
>>>> peak | |
>>>> 0.663| 1.528
>>>> Poll:SRX | 0.08|
>>>> 0.009| 0.038
>>>> peak | |
>>>> 0.068| 0.146
>>>> CAN1 RX[778] | 0.11|
>>>> 0.061| 0.280
>>>> peak | |
>>>> 0.458| 1.046
>>>> CAN1 RX[7a8] | 0.04|
>>>> 0.024| 0.124
>>>> peak | |
>>>> 0.160| 0.615
>>>> CAN1 TX[770] | 0.05|
>>>> 0.004| 0.016
>>>> peak | |
>>>> 0.022| 0.102
>>>> CAN1 TX[7a0] | 0.02|
>>>> 0.002| 0.011
>>>> peak | |
>>>> 0.010| 0.098
>>>> CAN1 TX[7b3] | 0.01|
>>>> 0.001| 0.006
>>>> peak | |
>>>> 0.000| 0.099
>>>> CAN1 TX[7e2] | 0.02|
>>>> 0.002| 0.011
>>>> peak | |
>>>> 0.010| 0.099
>>>> CAN1 TX[7e4] | 0.08|
>>>> 0.008| 0.048
>>>> peak | |
>>>> 0.049| 0.107
>>>> Cmd:State | 0.00|
>>>> 0.000| 0.005
>>>> peak | |
>>>> 0.000| 0.094
>>>> On Fri, 17 May 2024 at
>>>> 15:26, Michael Geddes
>>>> <frog at bunyip.wheelycreek.net>
>>>> wrote:
>>>> This is what I have now.
>>>> The one on the end is
>>>> the one MIchael B
>>>> was after using an N of
>>>> 32. (up for discussion).
>>>> The middle is the time
>>>> spent in that even t
>>>> per second. It
>>>> accumulates times (in
>>>> microseconds), and then
>>>> every 10s it stores it
>>>> as smoothed (N=16) value.
>>>> The Count is similar
>>>> (except that we store a
>>>> value of '100' as 1
>>>> event so it can be
>>>> still integers and has
>>>> 2 decimal places).
>>>> Every received poll
>>>> does a 64bit difference
>>>> to 32bit (for the
>>>> elapsed time) and 64bit
>>>> comparison (for
>>>> end-of-period).
>>>> It also does 1x 32bit
>>>> smoothing and 2x 32bit
>>>> adds.
>>>> Then at the end of a
>>>> 10s period, it will do
>>>> a 64bit add to get the
>>>> next end-of-period
>>>> value, as well as the
>>>> 2x 32bit smoothing calcs.
>>>> This is from the Ioniq
>>>> 5 so not any big values
>>>> yet. You can certainly
>>>> see how insignificant
>>>> the TX callbacks are.
>>>> I'll leave it on for
>>>> when the car is moving
>>>> and gets some faster
>>>> polling.
>>>> OVMS# poll time status
>>>> Type | Count
>>>> | Ave time | Ave Length
>>>> | per s
>>>> | ms per s | ms
>>>> Poll:PRI |
>>>> 1.00| 0.540| 0.539
>>>> Poll:SRX |
>>>> 0.03| 0.004| 0.017
>>>> CAN1 RX[778] |
>>>> 0.06| 0.042| 0.175
>>>> CAN1 TX[770] |
>>>> 0.04| 0.002| 0.008
>>>> Cmd:State |
>>>> 0.01| 0.001| 0.005
>>>> ----------------------8<--------------------------------
>>>> Nice smoothing class
>>>> (forces N as a power of 2):
>>>> constexpr unsigned
>>>> floorlog2(unsigned x)
>>>> return x == 1 ? 0 :
>>>> 1+floorlog2(x >> 1);
>>>> /* Maintain a
>>>> smoothed average using
>>>> shifts for division.
>>>> * T should be an
>>>> integer type
>>>> * N needs to be a
>>>> power of 2
>>>> template <typename T,
>>>> unsigned N>
>>>> class average_util_t
>>>> private:
>>>> T m_ave;
>>>> public:
>>>> average_util_t() :
>>>> m_ave(0) {}
>>>> static const
>>>> uint8_t _BITS =
>>>> floorlog2(N);
>>>> void add( T val)
>>>> static_assert(N == (1
>>>> << _BITS), "N must be a
>>>> power of 2");
>>>> m_ave = (((N-1)
>>>> * m_ave) + val) >> _BITS;
>>>> T get() { return
>>>> m_ave; }
>>>> operator T() {
>>>> return m_ave; }
>>>> On Thu, 16 May 2024 at
>>>> 10:29, Michael Geddes
>>>> wrote:
>>>> Thanks Michael,
>>>> My calculations
>>>> give me ((2^32)-1)
>>>> / (1000*1000*3600)
>>>> = only 1.2 hours of
>>>> processing time in
>>>> 32bit. The initial
>>>> subtraction is
>>>> 64bit anyway and I
>>>> can't see a
>>>> further 64bit
>>>> addition being a
>>>> problem. I have the
>>>> calculations being
>>>> performed in
>>>> doubles at
>>>> print-out where
>>>> performance is not
>>>> really an issue
>>>> anyway. (Though
>>>> apparently doing 64
>>>> bit division is
>>>> worse than floating
>>>> point).
>>>> In addition
>>>> * I currently have
>>>> this being able to
>>>> be turned on and
>>>> off and reset
>>>> manually (only do
>>>> it when required).
>>>> * For the lower
>>>> volume commands,
>>>> the smoothed
>>>> average is not
>>>> going to be useful
>>>> - the count is more
>>>> interesting for
>>>> different reasons.
>>>> * The total time is
>>>> quite useful. Ie a
>>>> high average time
>>>> doesn't matter if
>>>> the count is low.
>>>> The things that are
>>>> affecting
>>>> performance are
>>>> stuff with high
>>>> total time. Stuff
>>>> which is happening
>>>> 100 times a second
>>>> needs to be a much
>>>> lower average than
>>>> once a second.
>>>> * A measure like
>>>> 'time per
>>>> minute/second' and
>>>> possibly count per
>>>> minute/seconds as a
>>>> smoothed average
>>>> would potentially
>>>> be more useful. (or
>>>> in addition?)
>>>> I think we could do
>>>> _that_ in a
>>>> reasonably
>>>> efficient manner
>>>> using a 64 bit
>>>> 'last measured
>>>> time', a 32 bit
>>>> accumulated value
>>>> and the stored 32
>>>> bit rolling average.
>>>> It would boils down
>>>> to some iterative
>>>> (integer) sums and
>>>> multiplications
>>>> plus a divide by n
>>>> ^ (time periods
>>>> passed) - which is
>>>> a shift - and which
>>>> can be optimised to
>>>> '0' if
>>>> 'time-periods-passed'
>>>> is more than
>>>> 32/(bits-per-n) -
>>>> effectively
>>>> limiting the number
>>>> of iterations.
>>>> The one issue I can
>>>> see is that we need
>>>> to calculate
>>>> 'number of
>>>> time-periods
>>>> passed' which is a
>>>> 64 bit subtraction
>>>> followed by a 32
>>>> bit division (not
>>>> optimisable to a
>>>> simple shift).
>>>> * I'm also happy to
>>>> keep a rolling
>>>> (32bit) average time.
>>>> Even if you
>>>> assume averages in
>>>> the 100ms, 32bit is
>>>> going to happily
>>>> support an N of 64
>>>> or even 128.
>>>> Am I right in
>>>> thinking that the
>>>> choice of N is
>>>> highly dependent on
>>>> frequency. For
>>>> things happening
>>>> 100 times per
>>>> second, you might
>>>> want an N like
>>>> 128.. where things
>>>> happening once per
>>>> second, you
>>>> might want an N of
>>>> 4 or 8. The other
>>>> things we keep
>>>> track of in this
>>>> manner we have a
>>>> better idea of the
>>>> frequency of the thing.
>>>> How about we have
>>>> (per record type):
>>>> * total count
>>>> (since last reset?)
>>>> (32 bit)
>>>> * smoothed
>>>> average of time per
>>>> instance (32 bit)
>>>> * ?xx? total
>>>> accumulated time
>>>> since last reset
>>>> (64bit) ?? <-- with
>>>> the below stats
>>>> this is much less
>>>> useful
>>>> last-measured-time
>>>> (64 bit)
>>>> * accumulated
>>>> count since last
>>>> time-period (16bit
>>>> - but maybe 32bit
>>>> anyway for byte
>>>> alignment?)
>>>> * smoothed
>>>> average of count
>>>> per time-period (32bit)
>>>> * accumulated
>>>> time since last
>>>> time-period (32bit)
>>>> * smoothed
>>>> average of time per
>>>> time-period (32bit)
>>>> It's possible to
>>>> keep the
>>>> Is this going to be
>>>> too much per record
>>>> type? The number
>>>> of 'records' we are
>>>> keeping is quite
>>>> low (so 10 to 20
>>>> maybe) - so it's
>>>> not a huge memory
>>>> burden.
>>>> Thoughts?
>>>> //.ichael
>>>> On Thu, 16 May 2024
>>>> at 03:09, Michael
>>>> Balzer via OvmsDev
>>>> wrote:
>>>> esp_timer_get_time()
>>>> is the right
>>>> choice for
>>>> precision timing.
>>>> I'd say uint32
>>>> is enough
>>>> though, even if
>>>> counting
>>>> microseconds
>>>> that can hold a
>>>> total of more
>>>> than 71 hours
>>>> of actual
>>>> processing
>>>> time. uint64
>>>> has a
>>>> significant
>>>> performance
>>>> penalty,
>>>> although I
>>>> don't recall
>>>> the overhead
>>>> for simple
>>>> additions.
>>>> Also & more
>>>> important, the
>>>> average
>>>> wouldn't be my
>>>> main focus, but
>>>> the maximum
>>>> processing time
>>>> seen per ID,
>>>> which seems to
>>>> be missing in
>>>> your draft.
>>>> Second thought
>>>> on the average…
>>>> the exact
>>>> overall average
>>>> really has a
>>>> minor meaning,
>>>> I'd rather see
>>>> the current
>>>> average,
>>>> adapting to the
>>>> current mode of
>>>> operation
>>>> (drive/charge/…).
>>>> I suggest
>>>> feeding the
>>>> measurements to
>>>> a low pass
>>>> filter to get
>>>> the smoothed
>>>> average of the
>>>> last n
>>>> measurements.
>>>> Pattern:
>>>> runavg = ((N-1)
>>>> * runavg +
>>>> newval) / N
>>>> By using a low
>>>> power of 2 for
>>>> N (e.g. 8 or
>>>> 16), you can
>>>> replace the
>>>> division by a
>>>> simple bit
>>>> shift, and have
>>>> enough headroom
>>>> to use 32 bit
>>>> integers.
>>>> Regards,
>>>> Michael
>>>> Am 15.05.24 um
>>>> 06:51 schrieb
>>>> Michael Geddes
>>>> via OvmsDev:
>>>> Formatting
>>>> aside, I
>>>> have
>>>> implemented
>>>> what I
>>>> think
>>>> Michael B
>>>> was
>>>> suggesting.
>>>> This is a
>>>> sample run
>>>> on the
>>>> Ioniq 5
>>>> (which
>>>> doesn't
>>>> have
>>>> unsolicited RX
>>>> events).
>>>> This uses
>>>> the
>>>> call esp_timer_get_time()
>>>> got get a
>>>> 64bit
>>>> *microseconds*
>>>> since
>>>> started
>>>> value - and
>>>> works out
>>>> the time to
>>>> execute
>>>> that way.
>>>> It's
>>>> looking at
>>>> absolute
>>>> time and
>>>> not time in
>>>> the Task -
>>>> so other
>>>> things
>>>> going on at
>>>> the same
>>>> time in
>>>> other tasks
>>>> will have
>>>> an effect.
>>>> (The normal
>>>> tick count
>>>> doesn't
>>>> have nearly
>>>> enough
>>>> resolution
>>>> to be
>>>> useful -
>>>> any other
>>>> ideas on
>>>> measurement?)
>>>> I've got
>>>> total
>>>> accumulated
>>>> time
>>>> displaying
>>>> in seconds
>>>> and the
>>>> average in
>>>> milliseconds
>>>> currently -
>>>> but I can
>>>> change that
>>>> easy enough.
>>>> The
>>>> cumulative
>>>> time is
>>>> stored as
>>>> uint64_t
>>>> which will
>>>> be plenty,
>>>> as 32bit
>>>> wouldn't be
>>>> nearly enough.
>>>> OVMS#
>>>> *poller
>>>> time on*
>>>> Poller
>>>> timing is
>>>> now on
>>>> OVMS#
>>>> *poller
>>>> time status*
>>>> Poller
>>>> timing is: on
>>>> Poll [PRI]
>>>> n=390
>>>> tot=0.2s
>>>> ave=0.586ms
>>>> Poll [SRX]
>>>> n=316
>>>> tot=0.1s
>>>> ave=0.196ms
>>>> CAN1
>>>> RX[0778]
>>>> n=382
>>>> tot=0.2s
>>>> ave=0.615ms
>>>> CAN1
>>>> RX[07a8]
>>>> n=48
>>>> tot=0.0s
>>>> ave=0.510ms
>>>> CAN1
>>>> RX[07bb]
>>>> n=162
>>>> tot=0.1s
>>>> ave=0.519ms
>>>> CAN1
>>>> RX[07ce]
>>>> n=33
>>>> tot=0.0s
>>>> ave=0.469ms
>>>> CAN1
>>>> RX[07ea]
>>>> n=408
>>>> tot=0.2s
>>>> ave=0.467ms
>>>> CAN1
>>>> RX[07ec]
>>>> n=486
>>>> tot=0.2s
>>>> ave=0.477ms
>>>> CAN3
>>>> RX[07df]
>>>> n=769
>>>> tot=0.2s
>>>> ave=0.261ms
>>>> CAN1
>>>> TX[0770]
>>>> n=191
>>>> tot=0.0s
>>>> ave=0.054ms
>>>> CAN1
>>>> TX[07a0]
>>>> n=16
>>>> tot=0.0s
>>>> ave=0.047ms
>>>> CAN1
>>>> TX[07b3]
>>>> n=31
>>>> tot=0.0s
>>>> ave=0.069ms
>>>> CAN1
>>>> TX[07c6]
>>>> n=11
>>>> tot=0.0s
>>>> ave=0.044ms
>>>> CAN1
>>>> TX[07e2]
>>>> n=82
>>>> tot=0.0s
>>>> ave=0.067ms
>>>> CAN1
>>>> TX[07e4]
>>>> n=54
>>>> tot=0.0s
>>>> ave=0.044ms
>>>> Set State
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240621/c89b74e0/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240621/c89b74e0/attachment-0001.sig>
