Michael Geddes
Wed Jun 19 17:10:38 HKT 2024
Sure, I can do that.
I did it this way because it was easier and could mostly do it in one
message. As soon as I added spaces for alignment it pushed the message over
2 notifications. Also, I wasn't sure about making a new Data type and how
that worked.
I'm assuming something like: *-LOG-Poll would work (unless you want to
suggest something else) The next 2 cols seem to be ID and lifetime.
What do I use as an ID? Can it be an alpha string or does it have to be a
number? (LIke using the first column descriptor). I'm not sure
how the ID column is treated. I _could_ just send a line number for the
dump group I guess?
These are the columns I have. I can force the two cols to be always
permille.
"Type","Count (hz)","Avg utlization (permille)","Peak utlization
(permille)", "Avg Time (ms)","Peak Time (ms)"
Type is the only alpha column.. but if I can use that for the ID I guess
that would be better?
How would I provide a header if I wanted to? Is there some indicator
saying it's a header line? I'm not sure I want to - just asking.
//.ichael
On Wed, 19 June 2024, 00:11 Michael Balzer via OvmsDev, <
> Michael,
> I've received the new drive report notifications now; these need to be
> changed: please do not use text notifications to transport CSV data. That's
> what "data" notifications are meant for, which are stored in their raw form
> on the server for later retrieval. See e.g. the vehicle trip & grid logs
> for reference on how to build the messages, or have a look at the specific
> Twizy and UpMiiGo data messages.
> Data notifications also are designed to transport one row at a time, so
> you normally don't run into buffer size issues. A header can be supplied as
> a row, but you normally add one when downloading the data from the server,
> so tools don't need to filter these out. I provide headers automatically on
> my server for known message types, just send me your template and I'll
> include that.
> Apart from that, the timing statistics now seem to work pretty well,
> providing valuable insights.
> Am 14.06.24 um 08:59 schrieb Michael Geddes:
> Thankyou.
> I was more worried that we might be waiting on each other.
> I don't think I have quite the correct able to test on my friends Leaf
> properly, or does it use the standard cable?
> Anyway, let me know what I can do to.
> //.ichael
> On Fri, 14 Jun 2024 at 14:46, Michael Balzer via OvmsDev <
>> Sorry, I know I'm behind with PRs.
>> I'll try to find some time this weekend.
>> Am 14.06.24 um 08:31 schrieb Michael Geddes via OvmsDev:
>> Was this all good? I want to make sure I get to the bottom of this whole
>> issue asap!
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/1018
>> Was there something else you needed me to work on to make sure this all
>> works for all supported cars?
>> //.ichael
>> On Sun, 26 May 2024 at 21:15, Michael Balzer via OvmsDev <
>>> OK, I see now why it wouldn't send the notification: the V2 & V3 server
>>> register for notifications up to COMMAND_RESULT_NORMAL = 1024 characters.
>>> The report quickly becomes larger than 1024 characters, so the
>>> notifications no longer get sent via the server connectors.
>>> You need to either reduce the size, split the report, or use data
>>> notifications instead.
>>> On the reset value init: for my float targeting smoothing helper class
>>> for the UpMiiGo, I implemented a gradual ramp up from 1 to the requested
>>> sample size. You can do something similar also with powers of 2. IOW, yes,
>>> initialization from the first values received is perfectly OK.
>>> Am 26.05.24 um 14:35 schrieb Michael Geddes:
>>> It _*should*_ already be sending a report on charge stop.
>>> MyEvents.RegisterEvent(TAG, "vehicle.charge.stop",
>>> std::bind(&OvmsPollers::VehicleChargeStop, this, _1, _2));
>>> Reset on charge start/vehicle on is a good idea.
>>> A question – would it be silly if the first value after a reset, rather
>>> than using 0 average to start with, if the average got set to the initial
>>> value? I’m in 2 minds about it. It would make the average more useful
>>> quicker.
>>> //.ichael
>>> On Sun, 26 May 2024, 19:39 Michael Balzer via OvmsDev, <
>>> As the averages quickly decline when idle, an automatic report should
>>> probably also be sent on charge stop.
>>> Also, I think you should automatically reset the timer statistics on
>>> drive & charge start.
>>> First stats from charging my UpMiiGo:
>>> Type | count | Utlztn | Time
>>> | per s | [‰] | [ms]
>>> Poll:PRI Avg| 1.00| 0.723| 0.716
>>> Peak| | 1.282| 3.822
>>> Poll:SRX Avg| 7.72| 1.246| 0.184
>>> Peak| | 3.128| 1.058
>>> RxCan1[7ae] Avg| 2.48| 0.915| 0.362
>>> Peak| | 1.217| 1.661
>>> RxCan1[7cf] Avg| 4.76| 1.928| 0.397
>>> Peak| | 2.317| 2.687
>>> RxCan1[7ed] Avg| 3.38| 1.251| 0.327
>>> Peak| | 8.154| 12.273
>>> RxCan1[7ee] Avg| 0.21| 0.066| 0.297
>>> Peak| | 0.225| 1.690
>>> TxCan1[744] Avg| 1.49| 0.022| 0.011
>>> Peak| | 0.032| 0.095
>>> TxCan1[765] Avg| 3.89| 0.134| 0.027
>>> Peak| | 0.155| 0.113
>>> TxCan1[7e5] Avg| 2.32| 0.038| 0.013
>>> Peak| | 0.295| 0.084
>>> TxCan1[7e6] Avg| 1 0.21| 0.002| 0.008
>>> Peak| | 0.010| 0.041
>>> Cmd:State Avg| 0.00| 0.000| 0.007
>>> Peak| | 0.005| 0.072
>>> Total Avg| 27.46| 6.324| 2.349
>>> Overall healthy I'd say, but let's see how it compares.
>>> 7ed is the BMS, the peak time is probably related to the extended cell
>>> data logging -- I've enabled log intervals for both cell voltages &
>>> temperatures.
>>> Am 26.05.24 um 08:42 schrieb Michael Balzer via OvmsDev:
>>> The notification works on my devices, it only has a garbled per mille
>>> character -- see attached screenshot. The same applies to the mail version:
>>> Poller timing is: on
>>> | per s | [‰] | [ms]
>>> Poll:PRI Avg| 0.25| 0.119| 0.382
>>> Peak| | 0.513| 0.678
>>> RxCan1[597] Avg| 0.01| 0.004| 0.021
>>> Peak| | 0.000| 0.338
>>> RxCan1[59b] Avg| 0.01| 0.011| 0.053
>>> Peak| | 0.000| 0.848
>>> Cmd:State Avg| 0.01| 0.002| 0.012
>>> Peak| | 0.000| 0.120
>>> Total Avg| 0.28| 0.135| 0.468
>>> The encoding is a general issue. The character encoding for text
>>> messages via V2/MP is quite old & clumsy, it's got an issue with the degree
>>> celcius character as well. We previously tried to keep all text messages
>>> within the SMS safe character set (which e.g. lead to writing just "C"
>>> instead of "°C"). I'd say we should head towards UTF-8 now. If we ever
>>> refit SMS support, we can recode on the fly.
>>> Regarding not seeing the notification on your phone:
>>> a) Check your notification subtype/channel filters on the module. See
>>> https://docs.openvehicles.com/en/latest/userguide/notifications.html#suppress-notifications
>>> b) Check your notification vehicle filters on the phone (menu on
>>> notification tab): if you enabled the vehicle filter, it will add the
>>> messages of not currently selected vehicles to the list only, but not raise
>>> a system notification. (Applies to the Android App, no idea about the iOS
>>> version)
>>> Am 26.05.24 um 06:32 schrieb Michael Geddes:
>>> Hi,
>>> I'm trying to finalise this now .. and one last thing is that I don't
>>> get the report coming to my mobile. I'm using the command:
>>> MyNotify.NotifyString("info", "poller.report", buf.c_str());
>>> Where the buffer string is just the same as the report output. Should I
>>> be using some other format or command?
>>> I get "alert" types (like the ioniq5 door-open alert) fine to my mobile.
>>> Michael.
>>> On Sun, 19 May 2024, 12:51 Michael Balzer via OvmsDev, <
>>> A builtin web UI for this seems a bit over the top. Builtin web config
>>> pages should focus on user features, this is clearly a feature only needed
>>> during/for the development/extension of a vehicle adapter. Development
>>> features in the web UI are confusing for end users.
>>> If persistent enabling/disabling is done by a simple config command
>>> (e.g. "config set can poller.trace on"), that's also doable by users.
>>> Am 19.05.24 um 02:06 schrieb Michael Geddes:
>>> I was so focused on how I calculated the value that I totally
>>> missed that ‰ would be a better description. I could also use the system
>>> 'Ratio' unit... so % or ‰.
>>> I'll make space to put 'Avg' on the row. Was trying to limit the width
>>> for output on a mobile. I agree it would make it easier to understand.
>>> Totals also makes sense.
>>> Should I make this a configuration that can be set on the web-page?
>>> I'd probably use a configuration change notification so that the very bit
>>> setting is sync'd with the 'configuration' value.
>>> //.ichael
>>> On Sat, 18 May 2024, 14:05 Michael Balzer, <dexter at expeedo.de> wrote:
>>> I'm not sure whether the 'max' should be the maximum of the smoothed
>>> value.. or the maximum of the raw value.
>>> It should normally be the maximum of the raw value I think, the maximum
>>> of the smoothed value cannot tell about how bad the processing of an ID can
>>> become.
>>> The naming in the table is a bit confusing I think. (besides: I've never
>>> seen "ave" as the abbreviation for average)
>>> If I understand you correctly, "time ms per s" is the time share in per
>>> mille, so something in that direction would be more clear, and "length ms"
>>> would then be "time [ms]".
>>> The totals for all averages in the table foot would also be nice.
>>> Maybe "Ave" (or avg?) also should be placed on the left, as the "peak"
>>> label now suggests being the peak of the average.
>>> Btw, keep in mind, not all "edge" users / testers are developers (e.g.
>>> the Twizy driver I'm in contact with), collecting stats feedback for
>>> vehicles from testers should be straight forward. Maybe add a data/history
>>> record, sent automatically on every drive/charge stop when the poller
>>> tracing is on?
>>> Am 18.05.24 um 02:28 schrieb Michael Geddes:
>>> You did say max/pead value. I also halved the N for both.
>>> This is currently the raw-value maximum.
>>> The problem is that the middle column is the maximum of the {{sum over
>>> 10s} / (10*1000,000)
>>> I could easily change the 'period' to 1s and see how that goes.. was
>>> just trying to reduce the larger calculations.
>>> Usage: poller [pause|resume|status|times|trace]
>>> OVMS# poller time status
>>> Type | Count | Ave time | Ave length
>>> | per s | ms per s | ms
>>> Poll:PRI | 1.00| 0.559| 0.543
>>> peak | | 0.663| 1.528
>>> Poll:SRX | 0.08| 0.009| 0.038
>>> peak | | 0.068| 0.146
>>> CAN1 RX[778] | 0.11| 0.061| 0.280
>>> peak | | 0.458| 1.046
>>> CAN1 RX[7a8] | 0.04| 0.024| 0.124
>>> peak | | 0.160| 0.615
>>> CAN1 TX[770] | 0.05| 0.004| 0.016
>>> peak | | 0.022| 0.102
>>> CAN1 TX[7a0] | 0.02| 0.002| 0.011
>>> peak | | 0.010| 0.098
>>> CAN1 TX[7b3] | 0.01| 0.001| 0.006
>>> peak | | 0.000| 0.099
>>> CAN1 TX[7e2] | 0.02| 0.002| 0.011
>>> peak | | 0.010| 0.099
>>> CAN1 TX[7e4] | 0.08| 0.008| 0.048
>>> peak | | 0.049| 0.107
>>> Cmd:State | 0.00| 0.000| 0.005
>>> peak | | 0.000| 0.094
>>> On Fri, 17 May 2024 at 15:26, Michael Geddes <
>>> frog at bunyip.wheelycreek.net> wrote:
>>> This is what I have now.
>>> The one on the end is the one MIchael B was after using an N of 32. (up
>>> for discussion).
>>> The middle is the time spent in that even t per second. It accumulates
>>> times (in microseconds), and then every 10s it stores it as smoothed (N=16)
>>> value.
>>> The Count is similar (except that we store a value of '100' as 1 event
>>> so it can be still integers and has 2 decimal places).
>>> Every received poll does a 64bit difference to 32bit (for the elapsed
>>> time) and 64bit comparison (for end-of-period).
>>> It also does 1x 32bit smoothing and 2x 32bit adds.
>>> Then at the end of a 10s period, it will do a 64bit add to get the next
>>> end-of-period value, as well as the 2x 32bit smoothing calcs.
>>> This is from the Ioniq 5 so not any big values yet. You can certainly
>>> see how insignificant the TX callbacks are.
>>> I'll leave it on for when the car is moving and gets some faster polling.
>>> OVMS# poll time status
>>> Type | Count | Ave time | Ave Length
>>> Poll:PRI | 1.00| 0.540| 0.539
>>> Poll:SRX | 0.03| 0.004| 0.017
>>> CAN1 RX[778] | 0.06| 0.042| 0.175
>>> CAN1 TX[770] | 0.04| 0.002| 0.008
>>> Cmd:State | 0.01| 0.001| 0.005
>>> ----------------------8<--------------------------------
>>> Nice smoothing class (forces N as a power of 2):
>>> constexpr unsigned floorlog2(unsigned x)
>>> return x == 1 ? 0 : 1+floorlog2(x >> 1);
>>> /* Maintain a smoothed average using shifts for division.
>>> * T should be an integer type
>>> * N needs to be a power of 2
>>> template <typename T, unsigned N>
>>> class average_util_t
>>> private:
>>> T m_ave;
>>> public:
>>> average_util_t() : m_ave(0) {}
>>> static const uint8_t _BITS = floorlog2(N);
>>> void add( T val)
>>> static_assert(N == (1 << _BITS), "N must be a power of 2");
>>> m_ave = (((N-1) * m_ave) + val) >> _BITS;
>>> T get() { return m_ave; }
>>> operator T() { return m_ave; }
>>> On Thu, 16 May 2024 at 10:29, Michael Geddes <
>>> Thanks Michael,
>>> My calculations give me ((2^32)-1) / (1000*1000*3600) = only 1.2 hours
>>> of processing time in 32bit. The initial subtraction is 64bit anyway and I
>>> can't see a further 64bit addition being a problem. I have the calculations
>>> being performed in doubles at print-out where performance is not really an
>>> issue anyway. (Though apparently doing 64 bit division is worse than
>>> floating point).
>>> In addition
>>> * I currently have this being able to be turned on and off and reset
>>> manually (only do it when required).
>>> * For the lower volume commands, the smoothed average is not going to
>>> be useful - the count is more interesting for different reasons.
>>> * The total time is quite useful. Ie a high average time doesn't matter
>>> if the count is low. The things that are affecting performance are stuff
>>> with high total time. Stuff which is happening 100 times a second needs to
>>> be a much lower average than once a second.
>>> * A measure like 'time per minute/second' and possibly count per
>>> minute/seconds as a smoothed average would potentially be more useful. (or
>>> in addition?)
>>> I think we could do _that_ in a reasonably efficient manner using a 64
>>> bit 'last measured time', a 32 bit accumulated value and the stored 32 bit
>>> rolling average.
>>> It would boils down to some iterative (integer) sums and multiplications
>>> plus a divide by n ^ (time periods passed) - which is a shift - and which
>>> can be optimised to '0' if 'time-periods-passed' is more than
>>> 32/(bits-per-n) - effectively limiting the number of iterations.
>>> The one issue I can see is that we need to calculate 'number of
>>> time-periods passed' which is a 64 bit subtraction followed by a 32 bit
>>> division (not optimisable to a simple shift).
>>> * I'm also happy to keep a rolling (32bit) average time.
>>> Even if you assume averages in the 100ms, 32bit is going to happily
>>> support an N of 64 or even 128.
>>> Am I right in thinking that the choice of N is highly dependent on
>>> frequency. For things happening 100 times per second, you might want an N
>>> like 128.. where things happening once per
>>> second, you might want an N of 4 or 8. The other things we keep
>>> track of in this manner we have a better idea of the frequency of the thing.
>>> How about we have (per record type):
>>> * total count (since last reset?) (32 bit)
>>> * smoothed average of time per instance (32 bit)
>>> * ?xx? total accumulated time since last reset (64bit) ?? <-- with the
>>> below stats this is much less useful
>>> * last-measured-time (64 bit)
>>> * accumulated count since last time-period (16bit - but maybe 32bit
>>> anyway for byte alignment?)
>>> * smoothed average of count per time-period (32bit)
>>> * accumulated time since last time-period (32bit)
>>> * smoothed average of time per time-period (32bit)
>>> It's possible to keep the
>>> Is this going to be too much per record type? The number of 'records'
>>> we are keeping is quite low (so 10 to 20 maybe) - so it's not a huge memory
>>> burden.
>>> Thoughts?
>>> //.ichael
>>> On Thu, 16 May 2024 at 03:09, Michael Balzer via OvmsDev <
>>> esp_timer_get_time() is the right choice for precision timing.
>>> I'd say uint32 is enough though, even if counting microseconds that can
>>> hold a total of more than 71 hours of actual processing time. uint64 has a
>>> significant performance penalty, although I don't recall the overhead for
>>> simple additions.
>>> Also & more important, the average wouldn't be my main focus, but the
>>> maximum processing time seen per ID, which seems to be missing in your
>>> draft.
>>> Second thought on the average… the exact overall average really has a
>>> minor meaning, I'd rather see the current average, adapting to the current
>>> mode of operation (drive/charge/…). I suggest feeding the measurements to a
>>> low pass filter to get the smoothed average of the last n measurements.
>>> Pattern:
>>> runavg = ((N-1) * runavg + newval) / N
>>> By using a low power of 2 for N (e.g. 8 or 16), you can replace the
>>> division by a simple bit shift, and have enough headroom to use 32 bit
>>> integers.
>>> Am 15.05.24 um 06:51 schrieb Michael Geddes via OvmsDev:
>>> Formatting aside, I have implemented what I think Michael B was
>>> suggesting. This is a sample run on the Ioniq 5 (which doesn't have
>>> unsolicited RX events).
>>> This uses the call esp_timer_get_time() got get a 64bit *microseconds*
>>> since started value - and works out the time to execute that way. It's
>>> looking at absolute time and not time in the Task - so other things going
>>> on at the same time in other tasks will have an effect. (The normal tick
>>> count doesn't have nearly enough resolution to be useful - any other ideas
>>> on measurement?) I've got total accumulated time displaying in seconds and
>>> the average in milliseconds currently - but I can change that easy enough.
>>> The cumulative time is stored as uint64_t which will be plenty, as 32bit
>>> wouldn't be nearly enough.
>>> OVMS# *poller time on*
>>> Poller timing is now on
>>> OVMS# *poller time status*
>>> Poll [PRI] : n=390 tot=0.2s ave=0.586ms
>>> Poll [SRX] : n=316 tot=0.1s ave=0.196ms
>>> CAN1 RX[0778] : n=382 tot=0.2s ave=0.615ms
>>> CAN1 RX[07a8] : n=48 tot=0.0s ave=0.510ms
>>> CAN1 RX[07bb] : n=162 tot=0.1s ave=0.519ms
>>> CAN1 RX[07ce] : n=33 tot=0.0s ave=0.469ms
>>> CAN1 RX[07ea] : n=408 tot=0.2s ave=0.467ms
>>> CAN1 RX[07ec] : n=486 tot=0.2s ave=0.477ms
>>> CAN3 RX[07df] : n=769 tot=0.2s ave=0.261ms
>>> CAN1 TX[0770] : n=191 tot=0.0s ave=0.054ms
>>> CAN1 TX[07a0] : n=16 tot=0.0s ave=0.047ms
>>> CAN1 TX[07b3] : n=31 tot=0.0s ave=0.069ms
>>> CAN1 TX[07c6] : n=11 tot=0.0s ave=0.044ms
>>> CAN1 TX[07e2] : n=82 tot=0.0s ave=0.067ms
>>> CAN1 TX[07e4] : n=54 tot=0.0s ave=0.044ms
>>> Set State :
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240619/3bc1b9db/attachment-0001.htm>
