[Ovmsdev] Uart errors accessing SD Card
Wed Jul 10 02:31:41 HKT 2024
Maybe the card is only labeled as 25.000 … like those chinese 9.900 mAh
18650 cells ;-)
Regarding the completion buffer, have a look at the completion of
"metrics set" -- if there are too many, it ends the list with an ellipsis.
Am 09.07.24 um 16:52 schrieb Michael Geddes via OvmsDev:
> It's a 25000kHz sd card.
> config set sdcard maxfreq.khz 15000
> did the trick. Setting it to 20000 was still giving grief.
> On Tue, 9 Jul 2024 at 08:37, Michael Geddes
> <frog at bunyip.wheelycreek.net> wrote:
>     Since forever I've been getting uart errors (4) - which seems to
>     be an ERROR
>     *E (56071827) uart_events: uart event type: 4*
>     It seems it gets easily overwhelmed.
>     For example while doing (From the web i/f) 'vfs ls /sd'  is fine
>     (there are only 15 entries there) .. the command:
>     *vfs ls /sd/log*
>     causes a whole bunch of the above uart errors (l50 or so)
>     interrupted by the output of the command results (50 or so
>     files).  I'm not sure  whether it lists all of them.. but probably?
>     I was implementing file completion in 'vfs' command.. and it works
>     except for when trying to complete in that directory.  I suspect
>     that it's overwhelming the limited spaces in the complete buffer..
>     but also the messages queue is getting swamped by all the
>     uart_event errors.
>     Thoughts?
>     //.ichael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240709/d12cd76a/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240709/d12cd76a/attachment.sig>
