[Ovmsdev] Uart errors accessing SD Card
Michael Geddes
Tue Jul 9 22:52:18 HKT 2024
It's a 25000kHz sd card.
config set sdcard maxfreq.khz 15000
did the trick. Setting it to 20000 was still giving grief.
On Tue, 9 Jul 2024 at 08:37, Michael Geddes <frog at bunyip.wheelycreek.net>
wrote:
> Since forever I've been getting uart errors (4) - which seems to be an
> ERROR
> *E (56071827) uart_events: uart event type: 4*
> It seems it gets easily overwhelmed.
> For example while doing (From the web i/f) 'vfs ls /sd' is fine (there
> are only 15 entries there) .. the command:
> *vfs ls /sd/log*
> causes a whole bunch of the above uart errors (l50 or so) interrupted by
> the output of the command results (50 or so files). I'm not sure whether
> it lists all of them.. but probably?
> I was implementing file completion in 'vfs' command.. and it works except
> for when trying to complete in that directory. I suspect that it's
> overwhelming the limited spaces in the complete buffer.. but also the
> messages queue is getting swamped by all the uart_event errors.
> Thoughts?
> //.ichael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240709/8a299f75/attachment.htm>
