[Ovmsdev] Messages stopped being received on phone
Fri Jan 26 19:05:27 HKT 2024
Greg, Frog?,
Can you try again? I tried switching to another key.
But just guessing at this point, because the google APIs are voodoo and are seemingly deprecated once a year.
> On 26 Jan 2024, at 1:10 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> I’m talking about the server key. Need Michael B to check.
>> On 26 Jan 2024, at 12:47 PM, Greg D. <gregd2350 at gmail.com> wrote:
>> No (assuming I'm looking in the right place...  App Options screen?  It's oaA6...Nrhy
>> I'm guessing a revoke and renew is all I need to do, yes?
>> Greg
>> Mark Webb-Johnson wrote:
>>> I’m seeing a lot of:
>>> INVALID_KEY
>>> messages from PushGCM on the server.
>>> @Michael the API key I have is AIz…yew - is that the same as yours?
>>>> On 26 Jan 2024, at 12:30 PM, Michael Geddes <frog at bunyip.wheelycreek.net> <mailto:frog at bunyip.wheelycreek.net> wrote:
>>>> Hmm.  Im using that server and I Just started charging again and no message.
>>>> Michael
>>>> On Fri, 26 Jan 2024, 12:25 Mark Webb-Johnson, <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>>>> Not sure which server you guys are using.
>>>>> Note: In case it is a problem with the api.openvehicles.com <http://api.openvehicles.com/> server, I have pro-actively restarted it.
>>>>> Regards, Mark
>>>>>> On 26 Jan 2024, at 10:49 AM, Derek Caudwell <d.caudwell at gmail.com <mailto:d.caudwell at gmail.com>> wrote:
>>>>>> Hi Michael, Greg
>>>>>> Fyi, it looks like my messages also stopped on the 8 Jan GMT, I'm on Android 12 OVMS app version 4.1.2.
>>>>>> On Fri, 26 Jan 2024 at 14:35, <ovmsdev-request at lists.openvehicles.com <mailto:ovmsdev-request at lists.openvehicles.com>> wrote:
>>>>>>> Send OvmsDev mailing list submissions to
>>>>>>>         ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>
>>>>>>> To subscribe or unsubscribe via the World Wide Web, visit
>>>>>>>         http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>> or, via email, send a message with subject or body 'help' to
>>>>>>> You can reach the person managing the list at
>>>>>>>         ovmsdev-owner at lists.openvehicles.com <mailto:ovmsdev-owner at lists.openvehicles.com>
>>>>>>> When replying, please edit your Subject line so it is more specific
>>>>>>> than "Re: Contents of OvmsDev digest..."
>>>>>>> Today's Topics:
>>>>>>>    1. Re: Messages stopped being received on phone (Michael Balzer)
>>>>>>>    2. Re: Working on ESP-IDF5 + Have a question about ovms_module
>>>>>>>       'Name' (Michael Geddes)
>>>>>>>    3. Re: Working on ESP-IDF5 + Have a question about ovms_module
>>>>>>>       'Name' (Mark Webb-Johnson)
>>>>>>> Message: 1
>>>>>>> Date: Thu, 25 Jan 2024 19:55:40 +0100
>>>>>>> From: Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>>
>>>>>>> To: ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>
>>>>>>> Subject: Re: [Ovmsdev] Messages stopped being received on phone
>>>>>>> Message-ID: <93610d48-1492-4ca8-b3ff-1adee6c75ee0 at expeedo.de <mailto:93610d48-1492-4ca8-b3ff-1adee6c75ee0 at expeedo.de>>
>>>>>>> Content-Type: text/plain; charset="utf-8"; Format="flowed"
>>>>>>> Greg,
>>>>>>> 8th of January matches our preparation steps for the Firebase messaging
>>>>>>> migration.
>>>>>>> But that to my knowledge didn't involve any change to the server yet,
>>>>>>> and should only have added the Firebase instance to the Google cloud
>>>>>>> account without disabling the old GCM.
>>>>>>> Also? if it was an issue of the server / Google cloud, there certainly
>>>>>>> would be other users affected.
>>>>>>> I assume you didn't install the beta test App build yet? That could be
>>>>>>> worth a try. The new build works with both the old & new server API.
>>>>>>> Google wrote the old Android APIs would continue to work until June, but
>>>>>>> maybe that was too optimistic?
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 25.01.24 um 00:22 schrieb Greg D.:
>>>>>>> > Hi folks,
>>>>>>> > I recently noticed that Alerts (Messages) have stopped coming to my
>>>>>>> > phone.? The last one was on 8-January '24.? The car is still operating
>>>>>>> > / charging normally, and has been driven since then. The Battery, Car,
>>>>>>> > and Location screens are up to date and live. The OVMS module is
>>>>>>> > connected to the home Wi-Fi, as normal, and I can access it through
>>>>>>> > the internal web server (dashboard, status, etc.).? But the phone
>>>>>>> > app's Messages page stops at 8-January.
>>>>>>> > I've not messed with the module in a long time.? Last boot, in fact,
>>>>>>> > was a crash back in July 2023, from which it recovered normally. (So
>>>>>>> > lovely seeing an uptime in excess of 17 million seconds.)
>>>>>>> > So, what happened back on 8-January?? The only thing I can think of
>>>>>>> > was that Android is being more aggressive about shutting down
>>>>>>> > background processing (in the name of increased battery life), but
>>>>>>> > leaving the app running in foreground and triggering an event still
>>>>>>> > wasn't seen on the phone.? I can see them on the Web's Dashboard, so
>>>>>>> > the events are being generated and processed otherwise normally.
>>>>>>> > The phone is a Pixel 7a, Android 14.? OVMS firmware is
>>>>>>> > 3.3.003/ota_1/eap (build idf v3.3.4-848-g1ff5e24b1 Sep 1 2022 08:40:30).
>>>>>>> > Any ideas?
>>>>>>> > Thanks,
>>>>>>> > Greg
>>>>>>> > _______________________________________________
>>>>>>> > OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
>>>>>>> -------------- next part --------------
>>>>>>> A non-text attachment was scrubbed...
>>>>>>> Type: application/pgp-signature
>>>>>>> Desc: OpenPGP digital signature
>>>>>>> URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240125/7996b03f/attachment-0001.sig>
>>>>>>> Message: 2
>>>>>>> Date: Fri, 26 Jan 2024 09:23:42 +0800
>>>>>>> From: Michael Geddes <frog at bunyip.wheelycreek.net <mailto:frog at bunyip.wheelycreek.net>>
>>>>>>> To: OVMS Developers <ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>>
>>>>>>> Cc: "casner at acm.org <mailto:casner at acm.org>" <casner at acm.org <mailto:casner at acm.org>>
>>>>>>> Subject: Re: [Ovmsdev] Working on ESP-IDF5 + Have a question about
>>>>>>>         ovms_module 'Name'
>>>>>>> Message-ID:
>>>>>>>         <CAH0p7u+KC5Nh1+dds4ib3srAnVzMsNP3Lg7JVdrOF1YYpopy4w at mail.gmail.com <mailto:CAH0p7u%2BKC5Nh1%2Bdds4ib3srAnVzMsNP3Lg7JVdrOF1YYpopy4w at mail.gmail.com>>
>>>>>>> Thanks Michael,
>>>>>>> I hadn't considered there would be an essay in the commit, thanks for that
>>>>>>> - though it doesn't shed a lot of light on the situation
>>>>>>> There seems to be 2 places that mark a Name using the high bit, and only
>>>>>>> one place that kinda-sorta reads it.
>>>>>>> The Name is 'marked' during populate() which seems to be to mark each name
>>>>>>> with a '*' and the high-bit, before going through and getting the current
>>>>>>> names for the processes - adding new ones and replacing the old ones
>>>>>>> without '*' and high-bit mark.  So items which are double marked are
>>>>>>> effectively stale/historic.
>>>>>>> It is also 'marked' during the find call .. which basically marks the
>>>>>>> 'found' name if it was not found and then constructed.  The does not appear
>>>>>>> to be any purpose to this that I can ascertain.
>>>>>>> The one place (afaict) it reads the value is in zero() below - the problem
>>>>>>> is that it looks at the entire top uint32 rather than just that high
>>>>>>> byte!!   It's hard to work out whether this is just a long-standing bug or
>>>>>>> whether it is weeding out names > 12 characters as well from being removed.
>>>>>>> So this seems to remove an item from the map, but only if it isn't marked
>>>>>>> (or long) ie if it isn't stale - or been 'seen' I guess?
>>>>>>>     bool zero(TaskHandle_t taskid)
>>>>>>>       for (int i = 0; i < count; ++i)
>>>>>>>         if (map[i].id == taskid)
>>>>>>> *          if (map[i].name.words[NAMELEN/4-1] > 0)*
>>>>>>>             return false;
>>>>>>>           for (++i ; i < count; ++i)
>>>>>>>             map[i-1] = map[i];
>>>>>>>           --count;
>>>>>>>           return true;
>>>>>>>       return false;
>>>>>>> Does this help? Any thoughts on what this was meant to do ? I've CCd
>>>>>>> Stephen with a hope he might chip in?
>>>>>>> On Wed, 24 Jan 2024 at 15:09, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>>> > Michael,
>>>>>>> > Am 21.01.24 um 02:54 schrieb Michael Geddes:
>>>>>>> > Hey, In working trying to get ESP-IDF 5+ Working, I came across the
>>>>>>> > following fun thing that I'm trying to work out what is going on!!
>>>>>>> > This is from main/ovms_module.cpp
>>>>>>> > I'm not sure why we don't just go through all the words and compare - why
>>>>>>> > the masked compare for the last entry! And why that value?? It might make
>>>>>>> > sense if you masked out the final byte ... I'm just struggling to
>>>>>>> > understand.
>>>>>>> > From the further accesses to the last word/byte in TaskMap, I'd guess
>>>>>>> > Steve intended using the sign bit on the last byte as some special
>>>>>>> > indicator, but it's not clear to me for what purpose. It also doesn't seem
>>>>>>> > to be relevant anymore.
>>>>>>> > Steve's commit message is verbose
>>>>>>> > (30d0a403a380e797f9b222b01dab8da791ab388c), and maybe you can find some
>>>>>>> > more explanation in the list archives.
>>>>>>> > Regards,
>>>>>>> > Michael
>>>>>>> > Why am I looking at it?? Well there's a new warning about copy
>>>>>>> > constructors.. and then I ran into a problem where 'Name' is sometimes in
>>>>>>> > memory that can only be accessed 32bit int aligned (which is why the
>>>>>>> > strange implementation in the first place - I get that).
>>>>>>> > Can anybody shed any light on this?
>>>>>>> > class Name
>>>>>>> >    inline bool operator==(const Name& a) const
>>>>>>> >       for (int i = 0; i < NAMELEN/4 - 1; ++i)
>>>>>>> >         if (a.words[i] != words[i]) return false;
>>>>>>> >       i*f (a.words[NAMELEN/4-1] != (words[NAMELEN/4-1] &  0x7FFFFFFF))
>>>>>>> > return false;*
>>>>>>> >       return true;
>>>>>>> > OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp:// <mailto:listOvmsDev at lists.openvehicles.comhttp://>lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
>>>>>>> An HTML attachment was scrubbed...
>>>>>>> URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240126/5ca8f078/attachment-0001.htm>
>>>>>>> Message: 3
>>>>>>> Date: Fri, 26 Jan 2024 09:34:09 +0800
>>>>>>> From: Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>
>>>>>>>         ovms_module 'Name'
>>>>>>> Message-ID: <E6A7C991-83E1-40E2-9CD1-19C827EA865F at webb-johnson.net <mailto:E6A7C991-83E1-40E2-9CD1-19C827EA865F at webb-johnson.net>>
>>>>>>> Michael,
>>>>>>> Unfortunately, Steve passed away in 2022 so is unlikely to reply :-(
>>>>>>> He did work on some of the lower level and more complex parts of OVMS, as well as the command processing framework, and is sorely missed.
>>>>>>> I can?t help much with the code you are working on, other than to ask if this functionality is still required in the v5 IDF framework? A lot of stuff we did back then was to address inadequacies in the very new early buggy frameworks coming out of Espressif for the just released ESP-32.
>>>>>>> Regards, Mark.
>>>>>>> An embedded message was scrubbed...
>>>>>>> Subject: Passing of Steve Casner
>>>>>>> Date: Fri, 8 Jul 2022 08:19:25 +0800
>>>>>>> URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240126/251d3df8/attachment.eml>
>>>>>>> > On 26 Jan 2024, at 9:23 AM, Michael Geddes <frog at bunyip.wheelycreek.net <mailto:frog at bunyip.wheelycreek.net>> wrote:
>>>>>>> > Does this help? Any thoughts on what this was meant to do ? I've CCd Stephen with a hope he might chip in?
>>>>>>> Subject: Digest Footer
>>>>>>> End of OvmsDev Digest, Vol 144, Issue 8
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240126/c7fd5a5e/attachment-0001.htm>
