[Ovmsdev] Messages stopped being received on phone
Fri Jan 26 13:10:51 HKT 2024
I’m talking about the server key. Need Michael B to check.
> On 26 Jan 2024, at 12:47 PM, Greg D. <gregd2350 at gmail.com> wrote:
> No (assuming I'm looking in the right place...  App Options screen?  It's oaA6...Nrhy
> I'm guessing a revoke and renew is all I need to do, yes?
> Greg
> Mark Webb-Johnson wrote:
>> I’m seeing a lot of:
>> INVALID_KEY
>> messages from PushGCM on the server.
>> @Michael the API key I have is AIz…yew - is that the same as yours?
>>> On 26 Jan 2024, at 12:30 PM, Michael Geddes <frog at bunyip.wheelycreek.net> <mailto:frog at bunyip.wheelycreek.net> wrote:
>>> Hmm.  Im using that server and I Just started charging again and no message.
>>> On Fri, 26 Jan 2024, 12:25 Mark Webb-Johnson, <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>>> Not sure which server you guys are using.
>>>> Note: In case it is a problem with the api.openvehicles.com <http://api.openvehicles.com/> server, I have pro-actively restarted it.
>>>> Regards, Mark
>>>>> On 26 Jan 2024, at 10:49 AM, Derek Caudwell <d.caudwell at gmail.com <mailto:d.caudwell at gmail.com>> wrote:
>>>>> Hi Michael, Greg
>>>>> Fyi, it looks like my messages also stopped on the 8 Jan GMT, I'm on Android 12 OVMS app version 4.1.2.
>>>>> On Fri, 26 Jan 2024 at 14:35, <ovmsdev-request at lists.openvehicles.com <mailto:ovmsdev-request at lists.openvehicles.com>> wrote:
>>>>>> Send OvmsDev mailing list submissions to
>>>>>>         ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>
>>>>>> To subscribe or unsubscribe via the World Wide Web, visit
>>>>>>         http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>> or, via email, send a message with subject or body 'help' to
>>>>>> You can reach the person managing the list at
>>>>>>         ovmsdev-owner at lists.openvehicles.com <mailto:ovmsdev-owner at lists.openvehicles.com>
>>>>>> When replying, please edit your Subject line so it is more specific
>>>>>> than "Re: Contents of OvmsDev digest..."
>>>>>> Today's Topics:
>>>>>>    1. Re: Messages stopped being received on phone (Michael Balzer)
>>>>>>    2. Re: Working on ESP-IDF5 + Have a question about ovms_module
>>>>>>       'Name' (Michael Geddes)
>>>>>>    3. Re: Working on ESP-IDF5 + Have a question about ovms_module
>>>>>>       'Name' (Mark Webb-Johnson)
>>>>>> Message: 1
>>>>>> Date: Thu, 25 Jan 2024 19:55:40 +0100
>>>>>> From: Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>>
>>>>>> To: ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>
>>>>>> Subject: Re: [Ovmsdev] Messages stopped being received on phone
>>>>>> Message-ID: <93610d48-1492-4ca8-b3ff-1adee6c75ee0 at expeedo.de <mailto:93610d48-1492-4ca8-b3ff-1adee6c75ee0 at expeedo.de>>
>>>>>> Content-Type: text/plain; charset="utf-8"; Format="flowed"
>>>>>> Greg,
>>>>>> 8th of January matches our preparation steps for the Firebase messaging
>>>>>> migration.
>>>>>> But that to my knowledge didn't involve any change to the server yet,
>>>>>> and should only have added the Firebase instance to the Google cloud
>>>>>> account without disabling the old GCM.
>>>>>> Also? if it was an issue of the server / Google cloud, there certainly
>>>>>> would be other users affected.
>>>>>> I assume you didn't install the beta test App build yet? That could be
>>>>>> worth a try. The new build works with both the old & new server API.
>>>>>> Google wrote the old Android APIs would continue to work until June, but
>>>>>> maybe that was too optimistic?
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 25.01.24 um 00:22 schrieb Greg D.:
>>>>>> > Hi folks,
>>>>>> > I recently noticed that Alerts (Messages) have stopped coming to my
>>>>>> > phone.? The last one was on 8-January '24.? The car is still operating
>>>>>> > / charging normally, and has been driven since then. The Battery, Car,
>>>>>> > and Location screens are up to date and live. The OVMS module is
>>>>>> > connected to the home Wi-Fi, as normal, and I can access it through
>>>>>> > the internal web server (dashboard, status, etc.).? But the phone
>>>>>> > app's Messages page stops at 8-January.
>>>>>> > I've not messed with the module in a long time.? Last boot, in fact,
>>>>>> > was a crash back in July 2023, from which it recovered normally. (So
>>>>>> > lovely seeing an uptime in excess of 17 million seconds.)
>>>>>> > So, what happened back on 8-January?? The only thing I can think of
>>>>>> > was that Android is being more aggressive about shutting down
>>>>>> > background processing (in the name of increased battery life), but
>>>>>> > leaving the app running in foreground and triggering an event still
>>>>>> > wasn't seen on the phone.? I can see them on the Web's Dashboard, so
>>>>>> > the events are being generated and processed otherwise normally.
>>>>>> > The phone is a Pixel 7a, Android 14.? OVMS firmware is
>>>>>> > 3.3.003/ota_1/eap (build idf v3.3.4-848-g1ff5e24b1 Sep 1 2022 08:40:30).
>>>>>> > Any ideas?
>>>>>> > Thanks,
>>>>>> > Greg
>>>>>> > _______________________________________________
>>>>>> > OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
>>>>>> -------------- next part --------------
>>>>>> A non-text attachment was scrubbed...
>>>>>> Type: application/pgp-signature
>>>>>> Desc: OpenPGP digital signature
>>>>>> URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240125/7996b03f/attachment-0001.sig>
>>>>>> Message: 2
>>>>>> Date: Fri, 26 Jan 2024 09:23:42 +0800
>>>>>> From: Michael Geddes <frog at bunyip.wheelycreek.net <mailto:frog at bunyip.wheelycreek.net>>
>>>>>> To: OVMS Developers <ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>>
>>>>>> Cc: "casner at acm.org <mailto:casner at acm.org>" <casner at acm.org <mailto:casner at acm.org>>
>>>>>> Subject: Re: [Ovmsdev] Working on ESP-IDF5 + Have a question about
>>>>>>         ovms_module 'Name'
>>>>>> Message-ID:
>>>>>>         <CAH0p7u+KC5Nh1+dds4ib3srAnVzMsNP3Lg7JVdrOF1YYpopy4w at mail.gmail.com <mailto:CAH0p7u%2BKC5Nh1%2Bdds4ib3srAnVzMsNP3Lg7JVdrOF1YYpopy4w at mail.gmail.com>>
>>>>>> Thanks Michael,
>>>>>> I hadn't considered there would be an essay in the commit, thanks for that
>>>>>> - though it doesn't shed a lot of light on the situation
>>>>>> There seems to be 2 places that mark a Name using the high bit, and only
>>>>>> one place that kinda-sorta reads it.
>>>>>> The Name is 'marked' during populate() which seems to be to mark each name
>>>>>> with a '*' and the high-bit, before going through and getting the current
>>>>>> names for the processes - adding new ones and replacing the old ones
>>>>>> without '*' and high-bit mark.  So items which are double marked are
>>>>>> effectively stale/historic.
>>>>>> It is also 'marked' during the find call .. which basically marks the
>>>>>> 'found' name if it was not found and then constructed.  The does not appear
>>>>>> to be any purpose to this that I can ascertain.
>>>>>> The one place (afaict) it reads the value is in zero() below - the problem
>>>>>> is that it looks at the entire top uint32 rather than just that high
>>>>>> byte!!   It's hard to work out whether this is just a long-standing bug or
>>>>>> whether it is weeding out names > 12 characters as well from being removed.
>>>>>> So this seems to remove an item from the map, but only if it isn't marked
>>>>>> (or long) ie if it isn't stale - or been 'seen' I guess?
>>>>>>     bool zero(TaskHandle_t taskid)
>>>>>>       for (int i = 0; i < count; ++i)
>>>>>>         if (map[i].id == taskid)
>>>>>> *          if (map[i].name.words[NAMELEN/4-1] > 0)*
>>>>>>             return false;
>>>>>>           for (++i ; i < count; ++i)
>>>>>>             map[i-1] = map[i];
>>>>>>           --count;
>>>>>>           return true;
>>>>>>       return false;
>>>>>> Does this help? Any thoughts on what this was meant to do ? I've CCd
>>>>>> Stephen with a hope he might chip in?
>>>>>> On Wed, 24 Jan 2024 at 15:09, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>> > Michael,
>>>>>> > Am 21.01.24 um 02:54 schrieb Michael Geddes:
>>>>>> > Hey, In working trying to get ESP-IDF 5+ Working, I came across the
>>>>>> > following fun thing that I'm trying to work out what is going on!!
>>>>>> > This is from main/ovms_module.cpp
>>>>>> > I'm not sure why we don't just go through all the words and compare - why
>>>>>> > the masked compare for the last entry! And why that value?? It might make
>>>>>> > sense if you masked out the final byte ... I'm just struggling to
>>>>>> > understand.
>>>>>> > From the further accesses to the last word/byte in TaskMap, I'd guess
>>>>>> > Steve intended using the sign bit on the last byte as some special
>>>>>> > indicator, but it's not clear to me for what purpose. It also doesn't seem
>>>>>> > to be relevant anymore.
>>>>>> > Steve's commit message is verbose
>>>>>> > (30d0a403a380e797f9b222b01dab8da791ab388c), and maybe you can find some
>>>>>> > more explanation in the list archives.
>>>>>> > Regards,
>>>>>> > Michael
>>>>>> > Why am I looking at it?? Well there's a new warning about copy
>>>>>> > constructors.. and then I ran into a problem where 'Name' is sometimes in
>>>>>> > memory that can only be accessed 32bit int aligned (which is why the
>>>>>> > strange implementation in the first place - I get that).
>>>>>> > Can anybody shed any light on this?
>>>>>> > class Name
>>>>>> >    inline bool operator==(const Name& a) const
>>>>>> >       for (int i = 0; i < NAMELEN/4 - 1; ++i)
>>>>>> >         if (a.words[i] != words[i]) return false;
>>>>>> >       i*f (a.words[NAMELEN/4-1] != (words[NAMELEN/4-1] &  0x7FFFFFFF))
>>>>>> > return false;*
>>>>>> >       return true;
>>>>>> > OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp:// <mailto:listOvmsDev at lists.openvehicles.comhttp://>lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
>>>>>> An HTML attachment was scrubbed...
>>>>>> URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240126/5ca8f078/attachment-0001.htm>
>>>>>> Message: 3
>>>>>> Date: Fri, 26 Jan 2024 09:34:09 +0800
>>>>>> From: Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>
>>>>>>         ovms_module 'Name'
>>>>>> Message-ID: <E6A7C991-83E1-40E2-9CD1-19C827EA865F at webb-johnson.net <mailto:E6A7C991-83E1-40E2-9CD1-19C827EA865F at webb-johnson.net>>
>>>>>> Michael,
>>>>>> Unfortunately, Steve passed away in 2022 so is unlikely to reply :-(
>>>>>> He did work on some of the lower level and more complex parts of OVMS, as well as the command processing framework, and is sorely missed.
>>>>>> I can?t help much with the code you are working on, other than to ask if this functionality is still required in the v5 IDF framework? A lot of stuff we did back then was to address inadequacies in the very new early buggy frameworks coming out of Espressif for the just released ESP-32.
>>>>>> Regards, Mark.
>>>>>> An embedded message was scrubbed...
>>>>>> Subject: Passing of Steve Casner
>>>>>> Date: Fri, 8 Jul 2022 08:19:25 +0800
>>>>>> URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240126/251d3df8/attachment.eml>
>>>>>> > On 26 Jan 2024, at 9:23 AM, Michael Geddes <frog at bunyip.wheelycreek.net <mailto:frog at bunyip.wheelycreek.net>> wrote:
>>>>>> > Does this help? Any thoughts on what this was meant to do ? I've CCd Stephen with a hope he might chip in?
>>>>>> Subject: Digest Footer
>>>>>> End of OvmsDev Digest, Vol 144, Issue 8
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240126/16e650cd/attachment-0001.htm>
