[Ovmsdev] UI redesign in Android App - Needs beta testing
Tue Dec 31 20:07:22 HKT 2024
The "Battery history" chart is a Twizy specific feature, it's a battery
cell state chart like the battery monitor in the web UI.
It's currently bound to the wrong button though: the button "Energy
statistics" should open another Twizy specific chart displaying power
levels & energy usage over time. That chart doesn't seem to be available
now… and currently the App immediately crashes after selecting a Twizy
profile. And keeps crashing, see below.
With actual data, the charts look like the example screen shots 2 & 3:
https://dexters-web.de/faq#waskann
Both charts could get supported generally, with some modifications. They
currently need the Twizy specific historical data records (RT-BAT-P,
RT-BAT-C, RT-PWR-Stats). The main issue is finding a suitable
generalization for these.
Twizy crash log excerpt:
2024-12-31 13:04:01.702 25409-25409 ApiWidget
com.openvehicles.OVMS V onReceive: ApiEvent LoginComplete
com.openvehicles.OVMS V updateAllWidgets: 1 instances
2024-12-31 13:04:01.956 25409-25409 AndroidRuntime
com.openvehicles.OVMS D Shutting down VM
2024-12-31 13:04:01.957 25409-25409 AndroidRuntime
com.openvehicles.OVMS E FATAL EXCEPTION: main
Process: com.openvehicles.OVMS, PID: 25409
java.util.UnknownFormatConversionException: Conversion = 'End of String'
at java.util.Formatter$FormatSpecifierParser.peek(Formatter.java:2647)
at java.util.Formatter$FormatSpecifierParser.<init>(Formatter.java:2608)
at java.util.Formatter.parse(Formatter.java:2563)
at java.util.Formatter.format(Formatter.java:2510)
at java.util.Formatter.format(Formatter.java:2464)
at java.lang.String.format(String.java:3603)
at
com.openvehicles.OVMS.ui2.pages.HomeFragment.initialiseTabs(HomeFragment.kt:1081)
at com.openvehicles.OVMS.ui2.pages.HomeFragment.update(HomeFragment.kt:1143)
at
com.openvehicles.OVMS.api.ApiObservable.notifyOneUpdate(ApiObservable.kt:73)
at
com.openvehicles.OVMS.api.ApiObservable.access$notifyOneUpdate(ApiObservable.kt:8)
at
com.openvehicles.OVMS.api.ApiObservable$NotifyOneHandler.handleMessage(ApiObservable.kt:91)
at android.os.Handler.dispatchMessage(Handler.java:106)
at android.os.Looper.loopOnce(Looper.java:201)
at android.os.Looper.loop(Looper.java:288)
at android.app.ActivityThread.main(ActivityThread.java:7924)
at java.lang.reflect.Method.invoke(Native Method)
at
com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:548)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:936)
Am 31.12.24 um 12:29 schrieb Michael Geddes via OvmsDev:
> The 12v works fine.
> This is the othe one which I don't think is available.
> On Tue, 31 Dec 2024, 19:27 Developer From Jokela,
> <info at developerfromjokela.com> wrote:
> Not sure about that error. I didn't change that view from old UI,
> just moved it to new UI. Maybe it's just not supported?
>> On 31. Dec 2024, at 13.13, Michael Geddes
>> <frog at bunyip.wheelycreek.net> wrote:
>> That makes sense. It's was fine at topping off level.
>> Also this is a bit of a weird error here:
>> <1000012023.jpg>
>> Ir might be no data?
>> On Tue, 31 Dec 2024, 18:50 Developer From Jokela via OvmsDev,
>> <ovmsdev at lists.openvehicles.com> wrote:
>> Seems like there was an issue with showing charging time
>> estimations. Patched out in latest commit.
>>> Developer From Jokela <info at developerfromjokela.com>
>>> kirjoitti 31.12.2024 kello 11.49:
>>> Hmm, strange. Could you possibly get a stack trace? If it’s
>>> too hard, let’s hope I will find it in my own testing :)
>>> - DFJ
>>>> Michael Geddes <frog at bunyip.wheelycreek.net> kirjoitti
>>>> 31.12.2024 kello 4.35:
>>>> Font size looks all fixed, thanks.
>>>> For some reason when I click on the widget it opens the old
>>>> look ovms still... is the old look still hidden somewhere?
>>>> Also if I start charging my car (not through the app),
>>>> then whenever I switch to or open the app, the app crashes.
>>>> I'm just doing ac charging from a wallbox.
>>>> //.ichael.
>>>> On Tue, 31 Dec 2024, 06:48 Developer From Jokela via
>>>> OvmsDev, <ovmsdev at lists.openvehicles.com> wrote:
>>>> Hi.
>>>> New update is released at
>>>> https://github.com/openvehicles/Open-Vehicle-Android/tree/test-dfj-ui/latest.
>>>> Brief:
>>>> - Quick actions customisable
>>>> - Twizy UI fixes
>>>> - Font size related issues should be gone (hopefully ;D)
>>>> - DFJ
>>>>> van der Meijden, Chris <chris at arachnon.de> kirjoitti
>>>>> 30.12.2024 kello 13.12:
>>>>> I like the design of the Mercedes Ne app. Don't need a
>>>>> one to one copy, but it has a good mixture between
>>>>> info and links, I think.
>>>>> Am 30. Dezember 2024 11:29:37 MEZ schrieb Developer
>>>>> From Jokela <info at developerfromjokela.com>:
>>>>> Hi.
>>>>> What info would you like to be shown on main screen?
>>>>>> On 30. Dec 2024, at 11.16, Chris van der Meijden
>>>>>> <chris at arachnon.de> wrote:
>>>>>> Also many thanks for the effort. The new design
>>>>>> is not my cup of tea, but that is question of
>>>>>> personal liking I suppose. For me the menu is far
>>>>>> to present, whereas the information of the
>>>>>> vehicle seems barely visible.
>>>>>> For the e-Up the climate control throws an error.
>>>>>> "Fehler bei der Kommandoausführung".
>>>>>> Kind regards
>>>>>> Chris
>>>>>>> Thanks for the update. In general I like the new
>>>>>>> design.
>>>>>>> I've attached a screen shot. The list box items
>>>>>>> need to resize for larger fonts to stop them
>>>>>>> being all cut off.
>>>>>>> Also where does the "Unknown Vehicle model" come
>>>>>>> from?
>>>>>>> <1000012000.jpg>
>>>>>>> I have a slightly larger font setting:
>>>>>>> <1000012001.jpg>
>>>>>>> Also here:
>>>>>>> <1000012002.jpg>
>>>>>>> ..where the labels are overlapping due to the
>>>>>>> font size.
>>>>>>> And the ... here:
>>>>>>> <1000012003.jpg>
>>>>>>> I'm also getting a crash when opening the
>>>>>>> settings on the map. (App disappears. First time
>>>>>>> it prompted to clear cache which I did)
>>>>>>> Is there a new widget? If I click on the widget
>>>>>>> I see the old UI.
>>>>>>> //.ichael
>>>>>>> On Mon, 30 Dec 2024, 07:28 Developer From Jokela
>>>>>>> via OvmsDev, <ovmsdev at lists.openvehicles.com> wrote:
>>>>>>>> Hi Android users.
>>>>>>>> I’ve recently redesigned UI for Android and it
>>>>>>>> would need some testing.
>>>>>>>> Here is the latest build available for UI
>>>>>>>> redesign:
>>>>>>>> Please report any issues, improvement
>>>>>>>> suggestions, etc.
>>>>>>>> Thank you!
>>>>>>>> Br, DFJ
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>> <Screenshot_20241230-115518_Mercedes-Benz_1.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241231/b35a2ccd/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241231/b35a2ccd/attachment-0001.sig>
