[Ovmsdev] UI redesign in Android App - Needs beta testing
Michael Geddes
Tue Dec 31 19:29:16 HKT 2024
The 12v works fine.
This is the othe one which I don't think is available.
On Tue, 31 Dec 2024, 19:27 Developer From Jokela, <
info at developerfromjokela.com> wrote:
> Not sure about that error. I didn't change that view from old UI, just
> moved it to new UI. Maybe it's just not supported?
> On 31. Dec 2024, at 13.13, Michael Geddes <frog at bunyip.wheelycreek.net>
> wrote:
> That makes sense. It's was fine at topping off level.
> Also this is a bit of a weird error here:
> <1000012023.jpg>
> Ir might be no data?
> On Tue, 31 Dec 2024, 18:50 Developer From Jokela via OvmsDev, <
> ovmsdev at lists.openvehicles.com> wrote:
>> Seems like there was an issue with showing charging time estimations.
>> Patched out in latest commit.
>> Developer From Jokela <info at developerfromjokela.com> kirjoitti
>> 31.12.2024 kello 11.49:
>> Hmm, strange. Could you possibly get a stack trace? If it’s too hard,
>> let’s hope I will find it in my own testing :)
>> - DFJ
>> Michael Geddes <frog at bunyip.wheelycreek.net> kirjoitti 31.12.2024 kello
>> 4.35:
>> Font size looks all fixed, thanks.
>> For some reason when I click on the widget it opens the old look ovms
>> still... is the old look still hidden somewhere?
>> Also if I start charging my car (not through the app), then whenever I
>> switch to or open the app, the app crashes.
>> I'm just doing ac charging from a wallbox.
>> //.ichael.
>> On Tue, 31 Dec 2024, 06:48 Developer From Jokela via OvmsDev, <
>>> Hi.
>>> New update is released at
>>> https://github.com/openvehicles/Open-Vehicle-Android/tree/test-dfj-ui/latest
>>> Brief:
>>> - Quick actions customisable
>>> - Twizy UI fixes
>>> - Font size related issues should be gone (hopefully ;D)
>>> - DFJ
>>> van der Meijden, Chris <chris at arachnon.de> kirjoitti 30.12.2024 kello
>>> 13.12:
>>> I like the design of the Mercedes Ne app. Don't need a one to one copy,
>>> but it has a good mixture between info and links, I think.
>>> Am 30. Dezember 2024 11:29:37 MEZ schrieb Developer From Jokela <
>>> info at developerfromjokela.com>:
>>>> Hi.
>>>> What info would you like to be shown on main screen?
>>>> On 30. Dec 2024, at 11.16, Chris van der Meijden <chris at arachnon.de>
>>>> wrote:
>>>> Also many thanks for the effort. The new design is not my cup of tea,
>>>> but that is question of personal liking I suppose. For me the menu is far
>>>> to present, whereas the information of the vehicle seems barely visible.
>>>> For the e-Up the climate control throws an error. "Fehler bei der
>>>> Kommandoausführung".
>>>> Kind regards
>>>> Chris
>>>> Am Montag, dem 30.12.2024 um 15:20 +0800 schrieb Michael Geddes via
>>>> OvmsDev:
>>>> Thanks for the update. In general I like the new design.
>>>> I've attached a screen shot. The list box items need to resize for
>>>> larger fonts to stop them being all cut off.
>>>> Also where does the "Unknown Vehicle model" come from?
>>>> <1000012000.jpg>
>>>> I have a slightly larger font setting:
>>>> <1000012001.jpg>
>>>> Also here:
>>>> <1000012002.jpg>
>>>> ..where the labels are overlapping due to the font size.
>>>> And the ... here:
>>>> <1000012003.jpg>
>>>> I'm also getting a crash when opening the settings on the map. (App
>>>> disappears. First time it prompted to clear cache which I did)
>>>> Is there a new widget? If I click on the widget I see the old UI.
>>>> //.ichael
>>>> On Mon, 30 Dec 2024, 07:28 Developer From Jokela via OvmsDev, <
>>>> Hi Android users.
>>>> I’ve recently redesigned UI for Android and it would need some testing.
>>>> Here is the latest build available for UI redesign:
>>>> Please report any issues, improvement suggestions, etc.
>>>> Thank you!
>>>> Br, DFJ
>>>> OvmsDev mailing list
>>>> <Screenshot_20241230-115518_Mercedes-Benz_1.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241231/dfe27e59/attachment-0001.htm>
