[Ovmsdev] Ioniq 28kwh / ovms problems
    Tamás Kovács
    kommykt at gmail.com
    Mon Dec 30 23:32:19 HKT 2024
Now i create a factory reset from the webUI shell with the following
command: factory reset -noconfirm
But after this the OVMS not boot i wait 10 mins. Reconnect and working.
Now if i access the sd card with the following command: vfs ls /sd
i get many error: E (1030196) uart_events: uart event type: Frame Err
but read the card, tomorrow remove the ovms from the car and add usb cable
to access it and reformat the sd card i think. After restart the procedure
from factory
Michael Balzer via OvmsDev <ovmsdev at lists.openvehicles.com> ezt írta
(időpont: 2024. dec. 30., H, 10:57):
> Last time I had a similar effect (needing to power off to reboot) was due
> to a subtle corruption of the /store partition. These still occur, and in
> my case I could even write data normally to /store.
> Doing a factory reset & restore of the last backup solved it for me.
> The tool that might help debug this is the USB console. It works already
> during the early boot phase, so will probably show some info on the cause
> of a failing boot.
> Unfortunately my trained reflex was simply doing the factory reset, before
> thinking about capturing logs on my unit.
> Am 30.12.24 um 10:47 schrieb Michael Geddes via OvmsDev:
> My gut feel on this is that it is to do with the shutdown procedures. (And
> possibly something I did).
> I'm wondering if Michael Balzer can shed any light on what might be going
> wrong or if he has some other tools that might help debug what is going on
> with that.
> //.ichael
> On Mon, 30 Dec 2024 at 17:25, Chris van der Meijden via OvmsDev <
> ovmsdev at lists.openvehicles.com> wrote:
>> I have the same problem here with OVMS not booting after updating the
>> firmware. I also need to unplug to get it starting again.
>> I compile the firmware by myself, upload it to my server and update via
>> the http link to my server in the ovms web interface.
>> Kind Regards
>> Chris
>> Am Montag, dem 30.12.2024 um 10:17 +0100 schrieb Tamás Kovács via OvmsDev:
>> Now, during the holidays, I had some time to start solving my problem
>> with the OVMS development environment again, since the basic ESP 3 is EOL,
>> so it doesn't work, but luckily I managed to find a solution. (
>> https://github.com/espressif/esp-idf/issues/14809))
>> The car with the OVMS is an ioniq 28kwh
>> I noticed that the car's 12V battery was very low. the last time I went,
>> the ovms froze while charging, it read 78% all the time, and I already
>> drove 100 km with it. I didn't bother with it, but I noticed that the 12V
>> battery was not charged, then I looked at it and there were no can
>> messages. I restarted it and then the dive started again.
>> My other problem is that no matter how many times I try to put another
>> firmware on it via Wi-Fi, it won't start, I have to unplug it and plug it
>> back in.
>> Could you give me some advice on where I should go in troubleshooting?
>> Üdvözlettel:
>> Kovács Tamás
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
> Fon 02330 9104094 * Handy 0176 20698926
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241230/fb17f517/attachment.htm>
