[Ovmsdev] Ioniq 28kwh / ovms problems
    Chris van der Meijden
    chris at arachnon.de
    Mon Dec 30 17:25:42 HKT 2024
I have the same problem here with OVMS not booting after updating the
firmware. I also need to unplug to get it starting again.
I compile the firmware by myself, upload it to my server and update via
the http link to my server in the ovms web interface.
Kind Regards
Chris
Am Montag, dem 30.12.2024 um 10:17 +0100 schrieb Tamás Kovács via
OvmsDev:
> Now, during the holidays, I had some time to start solving my problem
> with the OVMS development environment again, since the basic ESP 3 is
> EOL, so it doesn't work, but luckily I managed to find a solution.
> (https://github.com/espressif/esp-idf/issues/14809))
> The car with the OVMS is an ioniq 28kwh
> I noticed that the car's 12V battery was very low. the last time I
> went, the ovms froze while charging, it read 78% all the time, and I
> already drove 100 km with it. I didn't bother with it, but I noticed
> that the 12V battery was not charged, then I looked at it and there
> were no can messages. I restarted it and then the dive started again.
> My other problem is that no matter how many times I try to put
> another firmware on it via Wi-Fi, it won't start, I have to unplug it
> and plug it back in.
> Could you give me some advice on where I should go in
> troubleshooting?
> Üdvözlettel:
> Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241230/9937223b/attachment.htm>
