Sun Apr 28 22:44:51 HKT 2024
Ah. OK.
I could try to fix the vin thing using the new way of doing it and get rid
of a semaphore?
It would at least identify the problem possibly?
On Sun, 28 Apr 2024, 22:32 Michael Balzer via OvmsDev, <
> Not sure if that's the problem, but I've found a different behaviour with
> the new PollSetState() implementation.
> The old version only did anything if the new state actually was different
> from the previous one. The Twizy relies on this behaviour, calling
> PollSetState() from the per second ticker (see
> OvmsVehicleRenaultTwizy::ObdTicker1).
> The new implementation apparently always sends the PollState command to
> the task, and that in turn always at least locks the poller mutex. Not sure
> if/how that could cause the observed issues, but it definitely adds quite
> some (unnecessary?) lock/unlock operations.
> Am 28.04.24 um 16:05 schrieb Michael Balzer via OvmsDev:
> The Twizy uses the poller to query the VIN (once) and DTCs (every 10
> seconds while driving), see rt_obd2.cpp.
> It also has its own version of the OBD single request
> (OvmsVehicleRenaultTwizy::ObdRequest), which was the precursor for the
> generalized version. This is used by custom/user Twizy plugins and scripts
> to access ECU internals.
> The Twizy doesn't use IncomingPollRxFrame, but the Twizy's
> IncomingPollReply handler will log any poll responses it doesn't know
> about, so that could lead to a lot of log output if something goes wrong
> there.
> Am 28.04.24 um 15:49 schrieb Michael Geddes via OvmsDev:
> AFAICT the twizzy doesn't use the poller list at all.  So is it missing a
> call-back or something??
> I can see a potential problem with IncomingPollRxFrame being called twice
> as much as it should be but only when there is a poll list.  Maybe
> commenting out this would do it.  (I can find another away to get this
> called on the thread I want).  This might be the problem with the smarted
> void OvmsVehicle::OvmsVehicleSignal::IncomingPollRxFrame(canbus* bus,
> CAN_frame_t *frame, bool success)
>   //if (Ready())
>   //  m_parent->IncomingPollRxFrame(frame, success);
> On Sun, 28 Apr 2024 at 21:10, Michael Balzer via OvmsDev <
>> There may also be an issue with the Renault Twizy, I've received a report
>> of a user who is using the edge builds, that the latest build wouldn't work.
>> He reports all kinds of errors and warnings signaled by the car during
>> driving, and switching back to the previous build fixed the issues.
>> I've asked him to provide a debug log excerpt if possible.
>> Am 28.04.24 um 14:29 schrieb Michael Geddes via OvmsDev:
>> OK. That's bad.
>> Does the reading work in general?
>> Is it just the writing commands?
>> Raise a ticket on github and tag me in and we can address it that way.
>> On Sun, 28 Apr 2024, 19:49 Thomas Heuer via OvmsDev, <
>>> Hi,
>>> The new poller code doesn't seem to work properly with the smarted.
>>> D (218831) vehicle-poll: [1]PollerNextTick(PRI): cycle complete for
>>> ticker=215
>>> V (218831) vehicle-poll: Standard Poll Series: List reset
>>> D (218831) vehicle-poll: PollSeriesList::NextPollEntry[!v.standard]:
>>> ReachedEnd
>>> V (218831) vehicle-poll: [1]PollerSend: Poller Reached End
>>> D (219691) vehicle-poll: Poller: Queue PollerFrame()
>>> V (219691) vehicle-poll: Pollers: FrameRx(bus=2)
>>> *OVMS#* unlock 22
>>> Vehicle unlocked
>>> D (219701) vehicle-poll: Poller: Queue PollerFrame()
>>> V (219701) vehicle-poll: Pollers: FrameRx(bus=2)
>>> *Von:* OvmsDev <ovmsdev-bounces at lists.openvehicles.com> *Im Auftrag von
>>> *Michael Geddes via OvmsDev
>>> *Gesendet:* Sonntag, 28. April 2024 12:27
>>> *An:* OVMS Developers <ovmsdev at lists.openvehicles.com>
>>> *Cc:* Michael Geddes <frog at bunyip.wheelycreek.net>
>>> *Betreff:* [Ovmsdev] OVMS Poller module/singleton
>>> Hey all,
>>> The poller singleton code that I've been working on for over a year now
>>> is merged in. (Thanks Michael for expediting the final step).
>>> This includes separate multi-frame states per bus and multiple poll
>>> lists as well as non-blocking one off queries. As well as more 'states'.
>>> I have included some programming documentation in the change but am
>>> happy to supply more if needed.
>>> The ioniq 5 code has some examples of how it can be used. Some examples
>>> are:
>>> * grabbing the vin as a one shot without blocking
>>> * having a short list of queries that are polled quickly for obd2ecu
>>> (this also demonstrates using a shorter frame break value and then a break
>>> after successful a response)
>>> Have a play please!
>>> Also interested in hearing what user tools might be worth looking at
>>> next for the poller object.
>>> //.ichael G.
>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240428/0190140c/attachment-0001.htm>
