[Ovmsdev] OBD poller module shell proposal
Michael Geddes
Sat Apr 27 09:10:20 HKT 2024
Ah. You did merge those in.
I'll rebase and out up a request.
On Sat, 27 Apr 2024, 09:04 Michael Geddes, <frog at bunyip.wheelycreek.net>
wrote:
> That's great news, and I can certainly do this. My only concern is that
> this branch as a whole contains a whole bunch of smaller pieces scattered
> through it.
> I have raised a number of pull requests over the last week that
> incorporate various of the things I have added...
> but if you are sure, I can certainly raise it as a single p/r with the
> branch as-is.
> If you accepted those recent p/r I would then rebase that whole branch
> before doing the new p/r. But the result would be the same.
> Just depends on how you want to track it. Again, I'll follow your lead.
> //.ichael
> On Sat, 27 Apr 2024 at 00:59, Michael Balzer via OvmsDev <
> ovmsdev at lists.openvehicles.com> wrote:
>> Michael,
>> I've been using the new poller for two weeks now without issues. VWTP
>> also works flawlessly.
>> I'd say we merge this now, so more tests can be done on a wider variety
>> of vehicles.
>> Can you please update your pull request?
>> Am 09.04.24 um 04:35 schrieb frog at bunyip.wheelycreek.net:
>> Thanks Michael,
>> I’ve fixed the register/deregister and also fixed a few issues /
>> dependencies for compiling when OVMS_COMP_POLLER is not selected.
>> //.ichael
>> *From:* OvmsDev <ovmsdev-bounces at lists.openvehicles.com>
>> <ovmsdev-bounces at lists.openvehicles.com> *On Behalf Of *Michael Balzer
>> *Sent:* Sunday, April 7, 2024 4:44 PM
>> *To:* ovmsdev at lists.openvehicles.com
>> *Subject:* Re: [Ovmsdev] OBD poller module shell proposal
>> Michael,
>> I think this…
>> https://github.com/frogonwheels/Open-Vehicle-Monitoring-System-3/blob/new-poller/vehicle/OVMS.V3/components/vehicle/vehicle.cpp#L358
>> MyPollers.*RegisterRunFinished*(TAG,
>> std::bind(&OvmsVehicle::PollerStateTickerNotify, this, _1, _2));
>> …should be a call to MyPollers.RegisterPollStateTicker() instead, and
>> OvmsVehicle::ShuttingDown() is missing a call to
>> DeregisterPollStateTicker().
>> Am 31.03.24 um 01:44 schrieb Michael Geddes:
>> I have pushed up changes for PR#966 as well as to the 'new-poller' branch
>> that handle the PollerStateTicker()
>> //.ichael
>> On Sat, 30 Mar 2024 at 08:39, Michael Geddes <frog at bunyip.wheelycreek.net>
>> wrote:
>> Thanks so much for giving this a good run.
>> I totally missed that about the purpose of PollerStateTicker() damn.
>> I think I can call this on primary ticks only from PollerSend() itself
>> outside of the mutex. That would work - I'll get onto that.
>> In the original PR# 966 PollerSend() is an OvmsVehicle() member and as
>> such this is a no-brainer.
>> That would mean it will get called from the Rx/Poller task rather than
>> the schedule (ticker1) task which is not necessarily a bad thing... but
>> different.
>> I believe that for the Poller implementation though, this will need to be
>> an event similar to PollRunFinished() - which kind of has similar usage
>> but occurs between (effectively) poller ticks (ie when all the
>> entries in the list have been dealt with) rather than what will be at the
>> beginning of each Primary tick.
>> Unless you have an objection - I'll pass in (canbus* bus) to this -
>> //.ichael
>> On Fri, 29 Mar 2024 at 21:51, Michael Balzer <dexter at expeedo.de> wrote:
>> Michael,
>> first feedback: testing this revealed some strange issues with vehicle
>> state changes apparently not being detected or reacted to properly.
>> A quick first check shows you have changed the way, the
>> PollerStateTicker() hook works: it's now called independently from / as of
>> the component ticker.1 registration sequence after the poller's primary
>> send, rather than before.
>> The callback was explicitly meant to provide a means to change the poller
>> state just before the next poll would take place:
>> * PollerStateTicker: check for state changes (stub, override with
>> vehicle implementation)
>> * This is called by VehicleTicker1() just before the next PollerSend().
>> * Implement your poller state transition logic in this method, so the
>> changes
>> * will get applied immediately.
>> This change is already present in PR #966, so I'll delay merging that.
>> Apart from that, the new poller seems to work normally, i.e. the polling
>> scheme works and results are coming in, at least regarding ISOTP. I haven't
>> tested VWTP yet.
>> Am 26.03.24 um 08:46 schrieb Michael Geddes:
>> Yeah wow. So close and yet so far.
>> Fix pushed.
>> On Sat, 23 Mar 2024 at 21:58, Michael Balzer <dexter at expeedo.de> wrote:
>> Michael,
>> looking forward to test this, but trying to run your branch with the VW
>> e-Up leads to an early crash boot loop.
>> Apparently `OvmsPollers::PollSetPidList()` doesn't check for a NULL plist:
>> 0x40195b6f is in OvmsPollers::PollSetPidList(canbus*,
>> OvmsPoller::poll_pid_t const*, OvmsPoller::VehicleSignal*)
>> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/poller/src/vehicle_poller.cpp:1201).
>> 1196 bool hasbus[1+VEHICLE_MAXBUSSES];
>> 1197 for (int i = 0 ; i <= VEHICLE_MAXBUSSES; ++i)
>> 1198 hasbus[i] = false;
>> 1199
>> 1200 // Check for an Empty list.
>> *1201 if (plist->txmoduleid == 0)*
>> 1202 {
>> 1203 plist = nullptr;
>> 1204 ESP_LOGD(TAG, "PollSetPidList - Setting Empty List");
>> 1205 }
>> 0x401a2675 is in OvmsVehicle::PollSetPidList(canbus*,
>> OvmsPoller::poll_pid_t const*)
>> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/vehicle/vehicle.cpp:2278).
>> 2273 return m_pollsignal;
>> 2274 }
>> 2275 void OvmsVehicle::PollSetPidList(canbus* bus, const
>> OvmsPoller::poll_pid_t* plist)
>> 2276 {
>> 2277 m_poll_bus_default = bus;
>> 2278 MyPollers.PollSetPidList(bus, plist, GetPollerSignal());
>> 2279 }
>> 2280 #endif
>> 2281
>> 2282 /**
>> 0x4023209e is in OvmsVehicleVWeUp::OBDInit()
>> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/vehicle_vweup/src/vweup_obd.cpp:233).
>> 228 obd_state_t previous_state = m_obd_state;
>> 229 m_obd_state = OBDS_Config;
>> 230
>> 231 if (previous_state != OBDS_Pause)
>> 232 {
>> *233 PollSetPidList(m_can1, NULL);*
>> 234 PollSetThrottling(0);
>> 235 PollSetResponseSeparationTime(1);
>> 236
>> 237 if (StandardMetrics.ms_v_charge_inprogress->AsBool())
>> Am 21.03.24 um 10:17 schrieb Michael Geddes:
>> I've pushed up my working tree here:
>> https://github.com/frogonwheels/Open-Vehicle-Monitoring-System-3/tree/new-poller
>> partly for feedback, and partly because I wanted it backed up!
>> This incorporates about 10 pull/requests worth of work which is why I
>> didn't even add it as a draft, so I see this as taking some number of
>> months to push up.
>> Of interest is really the final components/poller/src/vehicle_poller*
>> files and how that has all come together.. I've added some preliminary
>> documentation for that which I'm quite happy to accept any critiques or
>> requests for specific information!
>> The Duktape metrics 'stale, age' methods are probably ready for a p/r
>> as-is.
>> //.ichael
>> On Sun, 17 Mar 2024 at 16:58, Michael Geddes <frog at bunyip.wheelycreek.net>
>> wrote:
>> Thanks Michael,
>> I'll definitely add the config - pretty much sorted out the singleton
>> (except for the change of directory). Just wondering if I should rebase
>> this change down earlier or just keep it as the 'last change' that is
>> making the final break. It might be a better transition that way?
>> Anyway have a look at this little class below; we have a bunch of
>> different implementations for an event register and came up with the
>> OvmsCallBackRegister below.
>> In my example the event notification looks like this:
>> void PollRunFinished(canbus *bus)
>> m_runfinished_callback.Call(
>> [bus](const std::string &name, const PollCallback &cb)
>> cb(bus, nullptr);
>> I could possibly but it in main/ovms_utils.h ?? It could also use a
>> std:map to implement it, though I think we save space this way and tbh the
>> use case wouldn't be doing a lot of Register and Unregister which would be
>> the slowest operations... I've made it not shrink the list size .... but
>> again, not that important in the context.
>> Thoughts?
>> //.ichael
>> --------------8< -----------------------------------
>> /* Call-back register.
>> * The list does not shrink which is fine for this use-case.
>> * Can be made inexpensively threadsafe/re-entrant safe.
>> template <typename FN>
>> class OvmsCallBackRegister
>> private:
>> class CallbackEntry
>> public:
>> CallbackEntry(const std::string &caller, FN callback)
>> m_name = caller;
>> m_callback = callback;
>> ~CallbackEntry() {}
>> public:
>> std::string m_name;
>> FN m_callback;
>> typedef std::forward_list<CallbackEntry> callbacklist_t;
>> callbacklist_t m_list;
>> public:
>> ~OvmsCallBackRegister()
>> void Register(const std::string &nametag, FN callback)
>> // Replace
>> for (auto it = m_list.begin(); it != m_list.end(); ++it)
>> if ((*it).m_name == nametag)
>> (*it).m_callback = callback;
>> return;
>> if (!callback)
>> return;
>> if (!(*it).m_callback)
>> CallbackEntry &entry = *it;
>> entry.m_name = nametag;
>> entry.m_callback = callback;
>> return;
>> m_list.push_front(CallbackEntry(nametag, callback));
>> void Deregister(const std::string &nametag)
>> Register(nametag, nullptr);
>> typedef std::function<void (const std::string &nametag, FN callback)>
>> visit_fn_t;
>> void Call(visit_fn_t visit)
>> const CallbackEntry &entry = *it;
>> if (entry.m_callback)
>> visit(entry.m_name, entry.m_callback);
>> On Thu, 14 Mar 2024 at 12:08, Mark Webb-Johnson <mark at webb-johnson.net>
>> wrote:
>> Michael,
>> I suggest that if it is a separate component then better to move it to
>> it’s own component directory (just as canopen is done).
>> For completeness, I suggest it would also be good to include
>> a CONFIG_OVMS_COMP_* sdkconfig (default: yes), and put that as a
>> requirement for your component (as well as for any vehicle doing polling, I
>> guess).
>> Regards, Mark
>> On 14 Mar 2024, at 11:01 AM, Michael Geddes <frog at bunyip.wheelycreek.net>
>> wrote:
>> Thanks Michael, Mark,
>> Sorry for not acknowledging earlier.. this feedback is great; I've just
>> been cogitating on the consequences.
>> I still have the Poller hanging onto the vehicle by a thread so I should
>> just cut the thread making the Poller a separate singleton (it's still
>> embedded in the vehicle class for now with a small interface joining them).
>> If I do, does it need to get moved to a new directory or can it stay in
>> the vehicle/ directory? The file vehicle_poller.cpp (and the _isotp and
>> vwtp parts to it) are still pretty much as they were with only a change in
>> class name..
>> I think I just need the poller to get its own values of m_can1 etc and
>> provide a different way of getting the feedback results.
>> I also need to make sure I'm not cutting off the 'vehicle' class' access
>> to non-solicited messages (ie stuff that is just on the bus).
>> //.ichael
>> On Mon, 11 Mar 2024 at 14:51, Michael Balzer <dexter at expeedo.de> wrote:
>> Actually, separating the poller from the vehicle was part of the plan of
>> reworking it into a job/worker architecture. I see no reason the
>> generalized poller would need to remain coupled to the vehicle.
>> That's why I placed the OBD single request command in the "obdii"
>> hierarchy (although a more proper naming would have been e.g. "isotp", but
>> changing the name or having both would confuse users -- and meanwhile the
>> poller also supports a non-ISO TP variant).
>> Am 11.03.24 um 00:51 schrieb Mark Webb-Johnson:
>> Michael,
>> It depends on whether the poller can *only* be used in the vehicle class
>> or if it is a framework all by itself (for example with commands to
>> manually poll specific PIDs, etc).
>> If *only* within vehicle framework, then putting it as a sub-command
>> under ‘vehicle’ seems sensible.
>> If more general purpose, then perhaps look at ‘copen’ (component/canopen)
>> as an example.
>> On 10 Mar 2024, at 7:25 AM, Michael Geddes <frog at bunyip.wheelycreek.net>
>> <frog at bunyip.wheelycreek.net> wrote:
>> Hi all,
>> I know some of this (especially for the status) functionality is
>> predicated on code that's not gone up yet - however this is allowing
>> 'pause' and 'resume' of the poller (which has been merged).
>> My question is not so much about the functionality and status
>> information, but about the location of the *poller* subcommand. (See
>> below).
>> Should 'vehicle' be exclusively for switching the vehicle type? Should
>> the 'poller' command be top-level? Under obdii?
>> Thoughts welcome.
>> If you do vehicle poller pause then the last line reads 'Vehicle OBD
>> Polling is paused'
>> -------8<----------------------------------------
>> *OVMS# vehicle ?*
>> Usage: vehicle [list|module|poller|status]
>> list Show list of available vehicle modules
>> module Set (or clear) vehicle module
>> poller OBD polling status
>> status Show vehicle module status
>> *OVMS# vehicle poller ?*
>> Usage: vehicle poller [pause|resume]
>> pause Pause OBD Polling
>> resume Resume OBD Polling
>> *OVMS# vehicle poller*
>> OBD Polling running on bus 1 with an active list
>> Time between polling ticks is 1000ms with 1 secondary sub-ticks
>> Last poll command received 1s (ticks) ago.
>> Vehicle OBD Polling is running.
>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240427/0733a165/attachment-0001.htm>
