[Ovmsdev] Upgrading Mongoose ?
Michael Geddes
Fri Apr 26 19:17:00 HKT 2024
Thanks MIchael, that helps.
Any thoughts on moving to wolfmqqt with alias support?
//.ichael
On Tue, 13 Feb 2024 at 04:45, Michael Balzer <dexter at expeedo.de> wrote:
> Michael,
> I think you'll find all our PRs/commits to Mongoose here:
> https://github.com/cesanta/mongoose/pull/894
> I have no idea which have finally been merged or reimplemented by them,
> they more or less ignored us until their code base was too far off.
> Am 11.02.24 um 09:58 schrieb Michael Geddes:
> > I've been looking at the work of Ludovic in updating OVMS to the new
> > framework. I've even put up a few pull-requests where this work has
> > uncovered bugs due to improvements in the compiler.
> > Ludovic did a great job in also updating the Mongoose library. For
> > those unaware, the big issue is that there was a massive reworking of
> > the library just after the point where ovms forked the library. I
> > suspect some/many? of the changes that were made in our fork are no
> > longer required.
> > There was a lot done in moving some of the work that had to be done in
> > the callers (ovms) code into the mongoose code which is great - and
> > Ludovic has done that conversion - there are just a few more things
> > that needed to be done on top of that.
> > One of the things they did was remove mg_locals.h which allowed us to
> > configure mongoose from our own custom include.
> > The other really annoying thing they did was to remove the use of
> > MG_ALLOC, MG_CALLOC in place of malloc( calloc( etc. The problem with
> > this is for freertos they define
> > #define calloc(a, b) mg_calloc(a, b)
> > #define free(a) vPortFree(a)
> > #define malloc(a) pvPortMalloc(a)
> > without any further condition. Tihs means we don't have a way of
> > defining these to our own versions which is what we originally did...
> > well not without forking the mongoose (which maybe we do anyway).
> > It also means that any of our files that include mongoose.h will have
> > these redefined away from our own versions of these. Fortunately it
> > seems we don't use those much.
> > I also noticed that even the latest Mongoose MQTT doesn't appear to
> > support aliases (and therefore optimising the amount of data used by a
> > v3 server).. but it appears that wolfmqtt does - so should we be using
> > that instead as a mqtt client??
> > Does anybody else have some further input on this??
> > OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240426/1e89800d/attachment.htm>
