[Ovmsdev] Implementing time printing/parsing and 32bit time_t values!
Sun Nov 5 15:17:06 HKT 2023
I've added a p/r that implements a 'date+time' metric
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/946
I've also added a comment that reads as follows:
One discovery I made while implementing this was that time_t is a 32bit
number. It seems when we move to the 5.0+ framework this will be fixed in
the esp32 libraries, but we will still need to implement a separate metric
class for 64 bit time_t values. I'm thinking that an easy way to do it,
since the underlying persist mechanism is 32bit, would be to have "_high"
suffix a store the high bit as a "separate" metric. Should I do it with
this patchset? I can implement the separate metric class and put in #ifdefs
for when the time_t value is 64bit.
Thoughts on this??   It also highlights the importance of pushing forwards
with the new frameworks and filling in the gaps for that.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20231105/9cd3b97a/attachment.htm>
