[Ovmsdev] Use of ovms_netlib component ?
Mon May 29 16:13:32 HKT 2023
Yes, that's the component. See my post on the OTA HTTPS issue for more
links:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/858#issuecomment-1483760647
Am 27.05.23 um 22:18 schrieb Ludovic LANGE:
> Hi Mark,
> Thanks for the info.
> It's not in the way, no issue with it. Is it this component that have
> been used in the past for OTA (in order to add https support) and that
> we had to revert because of this issue with SSH ?
> As I am in the process of porting our mongoose from 6.11 to 7.10 (*) I
> had to prioritize the modules, and this one was puzzling me as not
> used (yet!) by anything else.
> And by the way... I'll certainly be able to use some help with this
> port : while everything compiles and runs fine, unfortunately the most
> important component (to me...) - ssh - is crashing at boot.
> I'm finalizing the working branch then I'll write a more complete
> "call for help" about it.
> (*) Not that I wanted to upgrade every component of OVMS, but
> unfortunately in the ESP-IDF 5.x port I could not make the TLS part of
> mongoose 6.12 work with neither wolfssl nor mbedtls. In particular,
> serverv2 is not working, which is a no-go. So I took the opportunity
> to upgrade mongoose - which make serverv2 work again.
> Le 27/05/2023 à 10:44, Mark Webb-Johnson a écrit :
>> The OVMS_netlib component is mine. It is a work in progress, trying
>> to build a C++ framework around mongoose. But not very successful so
>> far. In particular, I tried to build a blocking version of HTTP
>> (built on async mongoose), but that failed miserably when run from
>> already running mongoose components like ssh.
>> It is not used by anything at the moment (that I am aware of). If it
>> is getting in the way, we can move it off to a branch.
>>> On 26 May 2023, at 2:14 PM, Ludovic LANGE <ll-ovmsdev at lange.nom.fr>
>>> wrote:
>>> Dear all,
>>> While doing network-related things (/mainly trying to upgrade our
>>> Mongoose from 6.11 to 7.10 - more on that in a later mail/) I've
>>> seen this module (components/ovms_netlib).
>>> I can't easily figure how, and where it is used.
>>> Can someone please enlighten me ?
>>> Thanks in advance.
>>> Brest regards,
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230529/c472335a/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230529/c472335a/attachment-0001.sig>
