[Ovmsdev] Strange issues with Car GPS accuracy.
Michael Geddes
Sat May 27 16:07:35 HKT 2023
Latest: I changed the startup vehicle to None and turned off the mobile.
Still getting drifting vehicle GPS until I unplug the OVMS. Hardware
issue? Does anybody have any clues?
On Sun, 21 May 2023, 11:41 am Michael Geddes, <frog at bunyip.wheelycreek.net>
wrote:
> Hi all,
> I'm having a bunch of weird things going on which seem correlated to
> having the OVMS running. I'm not convinced of causation yet.
> My car's Nav system is drifting out majorly (like by >100m) and then seems
> to stay out. This causes major distractions as the nav system keeps giving
> me warnings about going down one-way roads and it makes the navigation
> 'interesting' to use.
> I also noticed that Android Auto location was frozen in one place, so I
> assumed this was coming from the car - or meant to be anyway. I reduced
> the polling rate (new work I'm doing) slightly and this freezing no longer
> happens. (To 3 speed queries per second). But the drifting out on the
> Navigation still happens... but then not on AA!? Very very weird.
> If I unplug the OVMS from the OBD port (as I'm driving) it seems to (but
> not immediately - after a minute or so) correct itself. It's hard to
> confirm this is directly resulting .. but it seems to be?
> I turned off my ECU2OBD which should mean that it is resorting to 1 per
> second POLL with a low throttle value. I'll run with some logs to make
> sure this is what is happening.. but it still seems that this hasn't
> stopped this issue from happening.
> I've tried turning the GSM power off. No result.
> Another note: I seem to have stopped getting anything near regular updates
> from the OVMS GPS. Every now and again it gets a successful change come
> through. Still working on diagnosing that.. maybe it's related?
> Any thoughts / help would be useful.
> //.ichael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230527/bdd1ef6b/attachment.htm>
