[Ovmsdev] Can't compile due to wolfssh
    Chris van der Meijden
    chris at arachnon.de
    Sun May 14 01:59:08 HKT 2023
Could you please explain in detail what I need to do?
I tried to pull the code completely fresh from master. That does not
work.
What if a new user tries to compile from scratch? Will they run into
the same issues?
Am Samstag, dem 13.05.2023 um 19:32 +0200 schrieb Ludovic LANGE:
> Hi Chris,
> Yes we unfortunately had an issue where we merged, then reverted a
> patch.
> It seems that unfortunately it didn't work for you. Could you try to
> fetch, then reset your git repo to HEAD, it seems you did not fetch
> the "revert" patches ?
> Let us know.
> Le 13/05/2023 à 19:08, Chris van der Meijden a écrit :
> Today I pulled the newest version. During the pull my Wolfssh
> directory was deleted. I then renewed all the submodules and I got
> the newest Wolfssh.
> But now the verion 3.3.003-467-ge7f41bd8-dirty won't compile (why is
> it "dirty" anyways, I didn't change the code ...).
> First I get
> CXX build/console_ssh/src/console_ssh.o
> /home/chris/OVMS/Open-Vehicle-Monitoring-System-
> 3/vehicle/OVMS.V3/components/console_ssh/src/console_ssh.cpp: In
> function 'void wolfssh_logger(wolfSSH_LogLevel, const char*)':
> 3/vehicle/OVMS.V3/components/console_ssh/src/console_ssh.cpp:1176:10:
> error: enumeration value 'WS_LOG_CERTMAN' not handled in switch [-
> Werror=switch]
> switch (level)
> Then I add case WS_LOG_CERTMAN: on line 1178:
> static void wolfssh_logger(enum wolfSSH_LogLevel level, const char*
> const msg)
> switch (level)
> But the I run into this error:
> 3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c: In
> function 'IdentifyKey':
> 3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:883:9:
> warning: unused variable 'dynType' [-Wunused-variable]
> int dynType = isPrivate ? DYNTYPE_PRIVKEY : DYNTYPE_PUBKEY;
> function 'DoKexDhReply':
> 3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:3947:17:
> error: implicit declaration of function 'PRIVATE_KEY_UNLOCK' [-
> Werror=implicit-function-declaration]
> PRIVATE_KEY_UNLOCK();
> 3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:3952:17:
> error: implicit declaration of function 'PRIVATE_KEY_LOCK' [-
> PRIVATE_KEY_LOCK();
> Any ideas?
> Regards Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230513/a772b77d/attachment.htm>
