[Ovmsdev] Can't compile due to wolfssh
Ludovic LANGE ll-ovmsdev at lange.nom.fr
Sun May 14 01:32:11 HKT 2023
Hi Chris,
Yes we unfortunately had an issue where we merged, then reverted a patch.
It seems that unfortunately it didn't work for you. Could you try to
fetch, then reset your git repo to HEAD, it seems you did not fetch the
"revert" patches ?
Let us know.
Le 13/05/2023 à 19:08, Chris van der Meijden a écrit :
> Today I pulled the newest version. During the pull my Wolfssh
> directory was deleted. I then renewed all the submodules and I got the
> newest Wolfssh.
> But now the verion 3.3.003-467-ge7f41bd8-dirty won't compile (why is
> it "dirty" anyways, I didn't change the code ...).
> First I get
> CXX build/console_ssh/src/console_ssh.o
> /home/chris/OVMS/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/console_ssh/src/console_ssh.cpp:
> In function 'void wolfssh_logger(wolfSSH_LogLevel, const char*)':
> /home/chris/OVMS/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/console_ssh/src/console_ssh.cpp:1176:10:
> error: enumeration value 'WS_LOG_CERTMAN' not handled in switch
> [-Werror=switch]
> switch (level)
> Then I add case WS_LOG_CERTMAN: on line 1178:
> static void wolfssh_logger(enum wolfSSH_LogLevel level, const char*
> const msg)
> switch (level)
> But the I run into this error:
> /home/chris/OVMS/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:
> In function 'IdentifyKey':
> /home/chris/OVMS/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:883:9:
> warning: unused variable 'dynType' [-Wunused-variable]
> int dynType = isPrivate ? DYNTYPE_PRIVKEY : DYNTYPE_PUBKEY;
> In function 'DoKexDhReply':
> /home/chris/OVMS/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:3947:17:
> error: implicit declaration of function 'PRIVATE_KEY_UNLOCK'
> [-Werror=implicit-function-declaration]
> PRIVATE_KEY_UNLOCK();
> /home/chris/OVMS/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:3952:17:
> error: implicit declaration of function 'PRIVATE_KEY_LOCK'
> PRIVATE_KEY_LOCK();
> Any ideas?
> Regards Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230513/71754c16/attachment-0001.htm>
