[Ovmsdev] Toyota bZ4X and Subaru Solterra
Solterra solterra at kezarnet.com
Sun Jun 11 05:11:10 HKT 2023
I've decided on a structure, so I'll outline it here.
My major problem is that I don't know how different the vehicles are (I
just have the Subaru...). So, I created a Toyota e-TNGA class where most
of the functionality lives. I then created a wrapper for the Subaru (and
will do the same for bZ4X). The same code likely works for Lexus RZ450e
as well.
I guess when I (or someone else) finds a difference, at least there's a
home for the code.
Thanks for your advice.
On 2023-05-29 20:21, Michael Geddes wrote:
> Just FYI on the Ioniq5 I was able to see using the 'valid bits' which
> of the battery voltages were valid, therefore hopefully what the
> overall battery capacity is.  I have not got feedback on any different
> battery configs yet... You can have a look at what I've done there
> anyway.
> Sounds good anyway.
> On Tue, 30 May 2023, 3:29 am Solterra, <solterra at kezarnet.com> wrote:
> It's Toyota's e-TNGA platform. I know the CAN network is the same for
> Toyota bZ4X and Subaru Solterra, but I'm not sure about the bZ3 (China)
> and Lexus RZ... One complicating factor is there are two battery
> configurations for the bZ4X, one of which is shared with the Solterra.
> Probably a detail for down the road a bit. For now, I've just created a
> bZ4X vehicle module and am tinkering under that.
> On 2023-05-28 21:45, Mark Webb-Johnson wrote:
> Solterra,
> Michael's advice is good.
> If it is just two names for essentially the same vehicle, I think you
> can refer to vehicle_voltampera (which implemented the Chevy Volt and
> Open Ampera vehicle support). These were essentially the same vehicle
> platform, but with minor bodywork differences and labelling.
> If the two vehicles share the same platform (such as BMS, battery, etc)
> but are otherwise very different, then I suggest you implement a
> vehicle_<platform> for that platform, and derive two classes from that
> in the same /src/ directory (one for each vehicle type). That will
> allow you to put all common support code in the base platform, but have
> each vehicle type customisable (and individually selectable).
> Looking at images of the cars, it seems they are closest to the Volt
> Ampera situation. Perhaps BZSS?
> On 28 May 2023, at 8:23 AM, Michael Geddes
> <frog at bunyip.wheelycreek.net> wrote:
> Hey Solterra,
> I couldn't say definitively but imho there are various options
> depending on HOW different.
> 1) They are exactly the same - or differences can be distinguished from
> responses: Register the name with both in it. Done. (This has happened
> with some older Kia + Hyundai even)
> 2)  They are mostly the same.  You could probably keep the one
> directory but have  2 wrapper classes constructing the base class with
> a parameter and register both in the factory Init. (Not sure if there
> are examples - ask the other Michael if this is ok).
> 3) They have a lot of commonality.  You can inherit off a base class -
> or inherit one vehicle impl off the other... But put them in separate
> directories.  (This happens for Ioniq 5 and a bunch of other Kia +
> Hyundai cars).
> //.ichael Geddes
> On Sat, 27 May 2023 at 21:19, Solterra <solterra at kezarnet.com> wrote:
> Hello again,
> I've finished my initial vehicle investigation and am not ready to add
> support to OVMS.
> When creating the vehicle stub, is there guidance for situations like
> on this vehicle? There are two makes and models that are essentially
> the same. Can I create a common 'components/vehicle_toyota_bz4x' and
> point two vehicle selections to it somewhere else?
> Thank you
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230610/10dd81b9/attachment.htm>
