[Ovmsdev] CI ?
Thu Jun 8 15:55:14 HKT 2023
Ludovic,
there actually is a Travis CI workflow defined (see
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/.travis.yml),
but that apparently stopped working due to unknown reasons. My
impresssion was, these CI tools add some comfort but need continuous
maintenance.
Your workflows catch/handle a lot more cases than the old Travis
workflow. This would be quite nice to have, especially with heading
towards IDF v4/v5 & different hardware platforms to support.
My 2 cents: I don't see a lock-in issue here, it's just a GitHub addon,
building is always possible without. Github itself is completely
optional, as are all other Git hosters.
Am 07.06.23 um 11:15 schrieb Ludovic LANGE:
> Dear list,
> I've been playing a little with GitHub's automatic builds / CI for a
> few months, and I'm thinking about having it in master.
> The advantages I can think of would be:
>   * Ability to "catch" early on any incompatibility we could introduce
>     in a PR. Still in a transition period between ESP-IDFv3.3 - the
>     official builds, and ESP-IDFv5.x (the future, I hope, once all the
>     issues are ironed out) ; it can add some value in trying to build
>     the firmware for different combinations, and thus with different
>     compiler versions / libraries versions.
>   * It could also be a backup build system for the nightly / releases
>     firmwares. Hosting, compiling there is free of charge for public
>     GitHub projects
> Possible concerns:
>   * Very tied to GitHub's hosting and API - vendor lock-in
>     However a) it's completely isolated in its own directory, and b)
>     some of GitHub's competitors have a similar mechanism (GitLab, ...)
> In my tests, I'm using it to:
>   * Ensure that the documentation always compile without any warning.
>     Sometime, we have very small issues that can impact the visual
>     rendering of the HTML, and this step can trigger when the compiler
>     emits a warning (or error)
>   * Ensure that the changes I'm doing are building without error for a
>     "matrix" of different environments:
>       o target: ESP32 (but could also be other processor of the
>         Espressif portfolio, as supported by the build chains: -S2,
>         -S3, -C2, -C3, -C6, -H2 ...)
>       o ESP-IDF version : v3.3.4 (our current), v4.4 branch, v5.0,
>         v5.0, v5.0.1, v5.0.2, v5.0 branch (could also use v5.1 branch
>         and latest, but compile errors from time to time)
>       o Mongoose version: 7.9, 7.10, 6.11 (our current)
> If you want to have a look, please check:
>   * Some of the automated builds here
>     https://github.com/llange/Open-Vehicle-Monitoring-System-3/actions
>   * A set of corresponding build recipes here
>     https://github.com/llange/Open-Vehicle-Monitoring-System-3/tree/build-master/.github/workflows
>   * The output of a random build:
>       o The log of commands:
>         https://github.com/llange/Open-Vehicle-Monitoring-System-3/actions/runs/5193543334/jobs/9364221425
>       o The build artefacts:
>         https://github.com/llange/Open-Vehicle-Monitoring-System-3/suites/13419490939/artifacts/735285471
>         (NB: Do not flash ! Just an example :-))
> I'd be happy to have some feedback about the interest (or not) to have
> this in master.
> For that the next plans would be:
>   * Step1 : a PR (to be written) including all these config files in
>     <root>/.github/workflows
>   * Step2 : a configuration of our GitHub repo to :
>       o activate the CI actions
>       o After some time, mark some of these actions as "required" in
>         PRs (Can be overriden of course, but will show the creator of
>         the PR how to improve the PR and have it work across all the
>         combinations of environments we aim to support)
> Thanks for your time.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230608/29d0594d/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230608/29d0594d/attachment.sig>
